LMK05318BEVM: Crystal oscillators and phase noise relationship
Part Number: LMK05318BEVM
Other Parts Discussed in Thread: PLLATINUMSIM-SW
Hi E2E,
Good day.
Our customer is using the LMK05318BEVM and they have change the 48.0048-MHz onboard crystal oscillator to 32.768 MHz and observed degradation of about 10dB in phase noise. How the crystal frequency affects phase noise? What are the requirements on the crystal oscillators so that phase noise is not degraded? Their application requires low phase noise 100MHz and 140MHz signals and they need to vary the crystal oscillators between 12 to 48 MHz without phase noise degradation.
Carlo
  • Hello Carlo,
    At what offset is the degradation?
    The XO will impact noise below the analog PLL loop bandwidth.  Low phase detector frequency will increase the PLL in-band noise, however I would not expect a 10 dB loss.
    Can you share a before/after phase noise plot?  Can you share a plot of the 32.768 MHz XO?
    I expect the 100 MHz is coming from APLL1 and 140 MHz from APLL2.
    Have you tried using the PLLatinum Sim tool (www.ti.com/.../PLLATINUMSIM-SW) It is possible to load the XO phase noise and simulate the expected results.
    73,
    Timothy
  • Hello Timothy,
    According to our customer, the degradation in phase noise was at an offset of 10kHz. Unfortunately, their setup has been taken apart and there are no plots available. If there will be any additional details from the customer, I will share them with you.
    Carlo
  • Hi Timothy,
    Good day.
    Please refer to the attached file for the testing conducted by our customer. The two configuration files are also provided in .txt file and you can change the extension back to.tcs. Based on the result, the customer is not getting a BAW lock.
    LMK05318BEVM Phase Noise Problem with 32.768MHz oscillator.doc
    210506 LMK0518EVM 32.768MHz Osc 10MHz Ref.txt
    [SETUP]
    ADDRESS=888
    CLOCK=8
    DATA=4
    LE=2
    PART=LMK05318B
    IFACE=I2C
    ADDRESS_I2C=0x65
    INTERFACE_SPEED=400
    [PINS]
    PINNAME00=REFSEL
    LOCATION00=9
    PINVALUE00=False
    PINNAME01=HW_CTRL
    LOCATION01=7
    PINVALUE01=False
    PINNAME02=PDN
    LOCATION02=3
    PINVALUE02=True
    PINNAME03=GPIO0
    LOCATION03=8
    PINVALUE03=False
    PINNAME04=GPIO1
    LOCATION04=6
    PINVALUE04=False
    PINNAME05=GPIO2
    LOCATION05=5
    PINVALUE05=False
    PINNAME06=Status0
    LOCATION06=10
    PINVALUE06=False
    PINNAME07=Status1
    LOCATION07=11
    PINVALUE07=False
    [MODES]
    NAME00=R0
    VALUE00=16
    NAME01=R1
    VALUE01=267
    NAME02=R2
    VALUE02=565
    NAME03=R3
    VALUE03=818
    NAME04=R4
    VALUE04=1028
    NAME05=R5
    VALUE05=1296
    NAME06=R6
    VALUE06=1566
    NAME07=R7
    VALUE07=1934
    NAME08=R8
    VALUE08=2050
    NAME09=R10
    VALUE09=2762
    NAME10=R11
    VALUE10=2816
    NAME11=R12
    VALUE11=3099
    NAME12=R13
    VALUE12=3328
    NAME13=R14
    VALUE13=3584
    NAME14=R15
    VALUE14=3840
    NAME15=R16
    VALUE15=4096
    NAME16=R17
    VALUE16=4381
    NAME17=R18
    VALUE17=4863
    NAME18=R19
    VALUE18=4864
    NAME19=R20
    VALUE19=5120
    NAME20=R21
    VALUE20=5376
    NAME21=R22
    VALUE21=5635
    NAME22=R23
    VALUE22=5973
    NAME23=R24
    VALUE23=6229
    NAME24=R25
    VALUE24=6400
    NAME25=R26
    VALUE25=6656
    NAME26=R27
    VALUE26=6912
    NAME27=R28
    VALUE27=7169
    NAME28=R29
    VALUE28=7427
    NAME29=R30
    VALUE29=7744
    NAME30=R32
    VALUE30=8260
    NAME31=R35
    VALUE31=8960
    NAME32=R36
    VALUE32=9219
    NAME33=R37
    VALUE33=9472
    NAME34=R38
    VALUE34=9728
    NAME35=R39
    VALUE35=9986
    NAME36=R40
    VALUE36=10243
    NAME37=R41
    VALUE37=10496
    NAME38=R42
    VALUE38=10769
    NAME39=R43
    VALUE39=11202
    NAME40=R44
    VALUE40=11264
    NAME41=R45
    VALUE41=11527
    NAME42=R46
    VALUE42=11800
    NAME43=R47
    VALUE43=12039
    NAME44=R48
    VALUE44=12300
    NAME45=R49
    VALUE45=12550
    NAME46=R50
    VALUE46=12800
    NAME47=R51
    VALUE47=13200
    NAME48=R52
    VALUE48=13312
    NAME49=R53
    VALUE49=13578
    NAME50=R54
    VALUE50=13952
    NAME51=R55
    VALUE51=14080
    NAME52=R56
    VALUE52=14346
    NAME53=R57
    VALUE53=14592
    NAME54=R58
    VALUE54=14872
    NAME55=R59
    VALUE55=15104
    NAME56=R60
    VALUE56=15384
    NAME57=R61
    VALUE57=15616
    NAME58=R62
    VALUE58=15896
    NAME59=R63
    VALUE59=16188
    NAME60=R64
    VALUE60=16384
    NAME61=R65
    VALUE61=16640
    NAME62=R66
    VALUE62=16896
    NAME63=R67
    VALUE63=17176
    NAME64=R68
    VALUE64=17416
    NAME65=R69
    VALUE65=17664
    NAME66=R70
    VALUE66=17920
    NAME67=R71
    VALUE67=18176
    NAME68=R72
    VALUE68=18464
    NAME69=R73
    VALUE69=18688
    NAME70=R74
    VALUE70=18944
    NAME71=R75
    VALUE71=19200
    NAME72=R76
    VALUE72=19456
    NAME73=R77
    VALUE73=19727
    NAME74=R78
    VALUE74=19968
    NAME75=R79
    VALUE75=20241
    NAME76=R80
    VALUE76=20480
    NAME77=R81
    VALUE77=20746
    NAME78=R82
    VALUE78=20992
    NAME79=R83
    VALUE79=21267
    NAME80=R84
    VALUE80=21555
    NAME81=R85
    VALUE81=21812
    NAME82=R86
    VALUE82=22016
    NAME83=R87
    VALUE83=22302
    NAME84=R88
    VALUE84=22660
    NAME85=R89
    VALUE85=22913
    NAME86=R90
    VALUE86=23040
    NAME87=R91
    VALUE87=23316
    NAME88=R92
    VALUE88=23552
    NAME89=R93
    VALUE89=23827
    NAME90=R94
    VALUE90=24115
    NAME91=R95
    VALUE91=24372
    NAME92=R96
    VALUE92=24576
    NAME93=R97
    VALUE93=24862
    NAME94=R98
    VALUE94=25220
    NAME95=R99
    VALUE95=25473
    NAME96=R100
    VALUE96=25640
    NAME97=R101
    VALUE97=25857
    NAME98=R102
    VALUE98=26163
    NAME99=R103
    VALUE99=26383
    NAME100=R104
    VALUE100=26655
    NAME101=R105
    VALUE101=26885
    NAME102=R106
    VALUE102=27136
    NAME103=R107
    VALUE103=27492
    NAME104=R108
    VALUE104=27648
    NAME105=R109
    VALUE105=27942
    NAME106=R110
    VALUE106=28197
    NAME107=R111
    VALUE107=28576
    NAME108=R112
    VALUE108=28672
    NAME109=R113
    VALUE109=28928
    NAME110=R114
    VALUE110=29184
    NAME111=R115
    VALUE111=29443
    NAME112=R116
    VALUE112=29697
    NAME113=R117
    VALUE113=29952
    NAME114=R118
    VALUE114=30208
    NAME115=R119
    VALUE115=30464
    NAME116=R120
    VALUE116=30720
    NAME117=R121
    VALUE117=30976
    NAME118=R122
    VALUE118=31232
    NAME119=R123
    VALUE119=31540
    NAME120=R124
    VALUE120=31744
    NAME121=R125
    VALUE121=32008
    NAME122=R126
    VALUE122=32444
    NAME123=R127
    VALUE123=32700
    NAME124=R128
    VALUE124=32768
    NAME125=R129
    VALUE125=33025
    NAME126=R130
    VALUE126=33280
    NAME127=R131
    VALUE127=33537
    NAME128=R132
    VALUE128=33793
    NAME129=R133
    VALUE129=34167
    NAME130=R134
    VALUE130=34304
    NAME131=R135
    VALUE131=34604
    NAME132=R136
    VALUE132=34816
    NAME133=R137
    VALUE133=35089
    NAME134=R138
    VALUE134=35376
    NAME135=R139
    VALUE135=35587
    NAME136=R140
    VALUE136=35842
    NAME137=R141
    VALUE137=36096
    NAME138=R142
    VALUE138=36353
    NAME139=R143
    VALUE139=36609
    NAME140=R144
    VALUE140=36983
    NAME141=R145
    VALUE141=37121
    NAME142=R146
    VALUE142=37513
    NAME143=R147
    VALUE143=37664
    NAME144=R149
    VALUE144=38157
    NAME145=R150
    VALUE145=38400
    NAME146=R151
    VALUE146=38657
    NAME147=R152
    VALUE147=38925
    NAME148=R153
    VALUE148=39209
    NAME149=R154
    VALUE149=39460
    NAME150=R155
    VALUE150=39910
    NAME151=R156
    VALUE151=39937
    NAME152=R157
    VALUE152=40192
    NAME153=R158
    VALUE153=40448
    NAME154=R159
    VALUE154=40704
    NAME155=R160
    VALUE155=41212
    NAME156=R161
    VALUE156=41216
    NAME157=R162
    VALUE157=41727
    NAME158=R164
    VALUE158=41984
    NAME159=R165
    VALUE159=42240
    NAME160=R167
    VALUE160=42753
    NAME161=R178
    VALUE161=45568
    NAME162=R180
    VALUE162=46080
    NAME163=R181
    VALUE163=46336
    NAME164=R182
    VALUE164=46592
    NAME165=R183
    VALUE165=46848
    NAME166=R184
    VALUE166=47104
    NAME167=R185
    VALUE167=47365
    NAME168=R186
    VALUE168=47622
    NAME169=R187
    VALUE169=47872
    NAME170=R188
    VALUE170=48128
    NAME171=R189
    VALUE171=48384
    NAME172=R190
    VALUE172=48699
    NAME173=R191
    VALUE173=48896
    NAME174=R192
    VALUE174=49264
    NAME175=R193
    VALUE175=49455
    NAME176=R194
    VALUE176=49664
    NAME177=R195
    VALUE177=49920
    NAME178=R196
    VALUE178=50176
    NAME179=R197
    VALUE179=50498
    NAME180=R198
    VALUE180=50688
    NAME181=R199
    VALUE181=50944
    NAME182=R200
    VALUE182=51229
    NAME183=R201
    VALUE183=51456
    NAME184=R202
    VALUE184=51712
    NAME185=R203
    VALUE185=51968
    NAME186=R204
    VALUE186=52282
    NAME187=R205
    VALUE187=52480
    NAME188=R206
    VALUE188=52736
    NAME189=R207
    VALUE189=53013
    NAME190=R208
    VALUE190=53248
    NAME191=R209
    VALUE191=53524
    NAME192=R210
    VALUE192=53760
    NAME193=R211
    VALUE193=54038
    NAME194=R212
    VALUE194=54272
    NAME195=R213
    VALUE195=54548
    NAME196=R214
    VALUE196=54784
    NAME197=R215
    VALUE197=55062
    NAME198=R216
    VALUE198=55311
    NAME199=R217
    VALUE199=55552
    NAME200=R218
    VALUE200=55808
    NAME201=R219
    VALUE201=56071
    NAME202=R220
    VALUE202=56436
    NAME203=R221
    VALUE203=56576
    NAME204=R222
    VALUE204=56835
    NAME205=R223
    VALUE205=57101
    NAME206=R224
    VALUE206=57476
    NAME207=R225
    VALUE207=57600
    NAME208=R226
    VALUE208=57856
    NAME209=R227
    VALUE209=58137
    NAME210=R228
    VALUE210=58478
    NAME211=R229
    VALUE211=58624
    NAME212=R230
    VALUE212=58883
    NAME213=R231
    VALUE213=59149
    NAME214=R232
    VALUE214=59463
    NAME215=R233
    VALUE215=59658
    NAME216=R234
    VALUE216=59914
    NAME217=R235
    VALUE217=60160
    NAME218=R236
    VALUE218=60611
    NAME219=R237
    VALUE219=60752
    NAME220=R238
    VALUE220=60928
    NAME221=R239
    VALUE221=61184
    NAME222=R240
    VALUE222=61635
    NAME223=R241
    VALUE223=61776
    NAME224=R242
    VALUE224=61952
    NAME225=R243
    VALUE225=62208
    NAME226=R244
    VALUE226=62464
    NAME227=R249
    VALUE227=63777
    NAME228=R250
    VALUE228=64000
    NAME229=R251
    VALUE229=64259
    NAME230=R252
    VALUE230=64557
    NAME231=R253
    VALUE231=64768
    NAME232=R254
    VALUE232=65024
    NAME233=R255
    VALUE233=65280
    NAME234=R256
    VALUE234=65536
    NAME235=R257
    VALUE235=65793
    NAME236=R258
    VALUE236=66048
    NAME237=R259
    VALUE237=66304
    NAME238=R260
    VALUE238=66562
    NAME239=R261
    VALUE239=66944
    NAME240=R262
    VALUE240=67072
    NAME241=R263
    VALUE241=67328
    NAME242=R264
    VALUE242=67584
    NAME243=R265
    VALUE243=67841
    NAME244=R266
    VALUE244=68340
    NAME245=R267
    VALUE245=68512
    NAME246=R268
    VALUE246=68620
    NAME247=R269
    VALUE247=68867
    NAME248=R270
    VALUE248=69122
    NAME249=R271
    VALUE249=69406
    NAME250=R272
    VALUE250=69632
    NAME251=R273
    VALUE251=69888
    NAME252=R274
    VALUE252=70144
    NAME253=R275
    VALUE253=70414
    NAME254=R276
    VALUE254=70668
    NAME255=R277
    VALUE255=70926
    NAME256=R278
    VALUE256=71177
    NAME257=R279
    VALUE257=71432
    NAME258=R280
    VALUE258=71689
    NAME259=R281
    VALUE259=71943
    NAME260=R282
    VALUE260=72205
    NAME261=R283
    VALUE261=72455
    NAME262=R284
    VALUE262=72734
    NAME263=R285
    VALUE263=72990
    NAME264=R286
    VALUE264=73218
    NAME265=R287
    VALUE265=73584
    NAME266=R288
    VALUE266=73731
    NAME267=R289
    VALUE267=74220
    NAME268=R290
    VALUE268=74243
    NAME269=R291
    VALUE269=74506
    NAME270=R292
    VALUE270=74761
    NAME271=R293
    VALUE271=75009
    NAME272=R294
    VALUE272=75264
    NAME273=R295
    VALUE273=75564
    NAME274=R296
    VALUE274=75783
    NAME275=R297
    VALUE275=76043
    NAME276=R298
    VALUE276=76295
    NAME277=R299
    VALUE277=76545
    NAME278=R300
    VALUE278=76800
    NAME279=R301
    VALUE279=77084
    NAME280=R302
    VALUE280=77344
    NAME281=R303
    VALUE281=77569
    NAME282=R304
    VALUE282=77824
    NAME283=R305
    VALUE283=78080
    NAME284=R306
    VALUE284=78336
    NAME285=R307
    VALUE285=78592
    NAME286=R308
    VALUE286=78910
    NAME287=R309
    VALUE287=79232
    NAME288=R310
    VALUE288=79360
    NAME289=R311
    VALUE289=79616
    NAME290=R312
    VALUE290=79872
    NAME291=R313
    VALUE291=80128
    NAME292=R314
    VALUE292=80384
    NAME293=R315
    VALUE293=80640
    NAME294=R316
    VALUE294=80896
    NAME295=R317
    VALUE295=81152
    NAME296=R318
    VALUE296=81408
    NAME297=R319
    VALUE297=81667
    NAME298=R320
    VALUE298=81920
    NAME299=R321
    VALUE299=82186
    NAME300=R322
    VALUE300=82432
    NAME301=R323
    VALUE301=82702
    NAME302=R324
    VALUE302=83110
    NAME303=R325
    VALUE303=83200
    NAME304=R326
    VALUE304=83456
    NAME305=R327
    VALUE305=83864
    NAME306=R328
    VALUE306=84118
    NAME307=R329
    VALUE307=84352
    NAME308=R330
    VALUE308=84480
    NAME309=R331
    VALUE309=84836
    NAME310=R332
    VALUE310=84992
    NAME311=R333
    VALUE311=85248
    NAME312=R334
    VALUE312=85552
    NAME313=R335
    VALUE313=85972
    NAME314=R336
    VALUE314=86016
    NAME315=R337
    VALUE315=86424
    NAME316=R338
    VALUE316=86678
    NAME317=R339
    VALUE317=86784
    NAME318=R340
    VALUE318=87040
    NAME319=R341
    VALUE319=87296
    NAME320=R342
    VALUE320=87552
    NAME321=R343
    VALUE321=87808
    NAME322=R344
    VALUE322=88064
    NAME323=R345
    VALUE323=88320
    NAME324=R346
    VALUE324=88578
    NAME325=R347
    VALUE325=88832
    NAME326=R348
    VALUE326=89088
    NAME327=R349
    VALUE327=89344
    NAME328=R350
    VALUE328=89600
    NAME329=R351
    VALUE329=89856
    NAME330=R352
    VALUE330=90112
    NAME331=R357
    VALUE331=91432
    NAME332=R367
    VALUE332=93992
    NAME333=R411
    VALUE333=105220
    [FLEX]
    CH0_PREDRIVER=0
    CH1_PREDRIVER=0
    CH2_PREDRIVER=0
    CH3_PREDRIVER=0
    CH4_PREDRIVER=0
    CH5_PREDRIVER=0
    CH6_PREDRIVER=0
    CH7_PREDRIVER=0
    DPLL_REF_LOOPCTL_CHG_QUANT_INTG=0
    DPLL_REF_MASHSEED=0
    DPLL_REF_UNLOCKDET_CNTSTRT=0
    DPLL_REF_UNLOCKDET_VCO_CNTSTRT=0
    MUTE_DPLL_FRLOCK=1
    OUT0_freq=140.0 MHz
    OUT1_freq=140.0 MHz
    OUT2_freq=140.0 MHz
    OUT3_freq=140.0 MHz
    OUT4_freq=100.0 MHz
    OUT5_freq=100.0 MHz
    OUT6_freq=100.0 MHz
    OUT7_freq=100.0 MHz
    PLL1_BAW_CAPDAC=0
    PLL1_CP_TRIM=0
    PLL1_VCBO_VAR2CON=0
    PRIREFBUFGAIN=0
    SECREFBUFGAIN=0
    VCO1_freq=2500
    VCO2_freq=6160
    XO_freq=32.768
    bFindAddressBtn=Find I2C Addr
    i2cAddr=0
    sTDC_freq=10.0 MHz
    btn_page0_next=NEXT>
    combo_backward_compatible=0
    combo_dpll_mode=0
    combo_ref_freq=1
    matlab_runtime_url=https://www.mathworks.com/products/compiler/matlab-runtime.html
    btn_page1_back=<BACK
    btn_page1_next=NEXT>
    btn_xo_show_instructions=Show Instructions
    sXO_freq=32768000
    s_wizard_XO_message_box=INSTRUCTIONS:\n\n1. Set XO frequency in Hz. Example frequency formats:\n\n48e6\n100e6 / 3\n48e6 * (1 + 100e-6)\n\nIf DPLL is disabled, then XO frequency can be 25 MHz or 50 MHz for APLL1 to work in integer mode.\n\nIf DPLL is enabled then recommended XO frequencies are 12.8 MHz, 19.2 MHz, 24 MHz, 30.72 MHz, 38.88 MHz, 48 MHz and 48.0048 MHz. For 1-pps reference input, low frequency and high stability XO is recommended. For example, 12.8 MHz TCXO or OCXO.\n\n2. The XO doubler and R divider are automatically set. To manually set the R divider and XO doubler, go to tab 'Advanced' -> 'APLL1'. If the DPLL is disabled, then there's no restriction on PFD frequency, as long as it's within the PFD frequency range (10.0 MHz to 100.0 MHz). If the DPLL is enabled, however, two conditions must be met:\n\n(1) The fractional part of BAW VCO frequency (2.5 GHz) divided by PFD frequency must be within 0.0625 and 0.9375.\n\n(2) The minimum difference between BAW VCO frequency (2.5 GHz) and any multiple of PFD frequency must be beyond 2.5 GHz * 1000 ppm.\n\nThe wizard selects the highest PFD frequency that meets both requirements.\n\n3. Select the XO interface type according to the selection tips.
    OUT0_freq=140.0 MHz
    OUT1_freq=140.0 MHz
    OUT2_freq=140.0 MHz
    OUT3_freq=140.0 MHz
    OUT4_freq=100.0 MHz
    OUT5_freq=100.0 MHz
    OUT6_freq=100.0 MHz
    OUT7_freq=100.0 MHz
    PLL1_RDIV_StaticText=PLL2 R divider (two stages)
    bCALC_FREQPLAN=Calculate Frequency Plan
    btn_freq_plan_show_instructions=Show Instructions
    btn_frequency_plan_apply_solution=Apply selected solution
    btn_page2_back=<BACK
    btn_page2_next=NEXT>
    cb_allow_PLL2_prescaler_of_2=0
    cb_manual_override_pll2_rdiv=0
    sCH0_1_IN_freq=140000000
    sCH0_1_MUX=APLL2
    sCH2_3_IN_freq=140000000
    sCH2_3_MUX=APLL2
    sCH4_IN_freq=100000000
    sCH4_MUX=APLL1
    sCH5_IN_freq=100000000
    sCH5_MUX=APLL1
    sCH6_IN_freq=100000000
    sCH6_MUX=APLL1
    sCH7_IN_freq=100000000
    sCH7_MUX=APLL1
    s_wizard_freqplan_message_box=Frequency plan completed!\n\nSelected frequency plan:\n\nVCO1 frequency = 2500.0 MHz\nVCO2 frequency = 6160.0 MHz\n\nAPLL1 settings:\n\nPFD freq = 65536000 Hz\nN divider = 38\nNumerator = 161598144512\nDenominator = 1099511627776\nPost divider = 1\n\nAPLL2 settings:\n\nAPLL2 reference source is VCO1\nPFD freq = 1250000000/9 Hz\nN divider = 44\nNumerator = 4400\nDenominator = 12500\nPost divider 1 = 4\nPost divider 2 = 4\n\n
    table_frequency_plan_pll1=0
    table_frequency_plan_pll2=0
    btn_page3_back=<BACK
    btn_page3_next=NEXT>
    btn_refclk_show_instructions=Show Instructions
    cb_enable_PRIREF=1
    cb_enable_SECREF=0
    combo_PRIREF_BUF_TYPE=1
    combo_SECREF_BUF_TYPE=1
    combo_ref_priority=0
    refclk_pin_select=
    sPRIREF_freq=10000000
    sSECREF_freq=
    s_wizard_refclk_message_box=INSTRUCTIONS:\n\n1. Enable or disable PRIREF and SECREF as needed. If DPLL is not used, then disable both references and skip this page.\n\n2. Type the frequencies of PRIREF and / or SECREF in Hz. Example frequency formats:\n\n1\n25e6\n100e6 / 3\n\n3. Select interface type. AC or DC buffer is auto-seletected based on reference frequency. If reference frequency is below 5 MHz, then use DC buffer. Otherwise, use AC buffer. To select interface types for AC buffer, refer to the 'Interface Type Selection Tips' in the XO wizard page. The same can be applied to PRIREF and SECREF.\n\n4. Select the input switching mode. The input switching mode is auto-seletected based on the states of PRIREF and SECREF enable. When both references are enabled, then Auto non-revertive is selected. If only one reference is enabled, then manual holdover is selected. However, it is highly recommended to read through the 'Input Switching Mode Selection Guide' in this wizard page and make the decision.\n\n5. If manual fallback or manual holdover is selected, then choose between manually select by register and manually select by REFSEL pin.
    btn_page4_back=<BACK
    btn_page4_next=NEXT>
    btn_ref_validation_show_instructions=Show Instructions
    sPRIREF_ACCURACY_PPM=10
    sPRIREF_AVG_COUNT=2
    sPRIREF_EARLY_MARGIN=1
    sPRIREF_EARLY_calc=7.20 ns
    sPRIREF_LATE=0
    sPRIREF_LATE_MARGIN=1
    sPRIREF_LATE_calc=5.60 ns
    sPRIREF_PH_VALID_calc=n/a
    sPRIREF_PPM_INVALID=110
    sPRIREF_PPM_TIMER=3.05 ms
    sPRIREF_PPM_VALID=100
    sSECREF_ACCURACY_PPM=10
    sSECREF_AVG_COUNT=2
    sSECREF_EARLY_MARGIN=1
    sSECREF_EARLY_calc=n/a
    sSECREF_LATE=0
    sSECREF_LATE_MARGIN=1
    sSECREF_LATE_calc=n/a
    sSECREF_PH_VALID_calc=n/a
    sSECREF_PPM_INVALID=110
    sSECREF_PPM_TIMER=n/a
    sSECREF_PPM_VALID=100
    s_wizard_reference_validation_message_box=INSTRUCTIONS:\n\nIf DPLL is disabled, then skip this page. All reference validation methods have been enabled or disabled automatically based on reference frequency and interface type. However, it is highly recommended to read through the instructions and loose or tighten the thresholds according to application needs.\n\nFrequency detection and early / late window detection are only valid for reference frequencies >= 2 kHz. 1-pps phase detector is only valid for reference frequencies < 2 kHz. For 1-pps input, only enable the 1-pps phase detector and disable all other detectors.\n\n1. Validation timer. The reference must stay valid for 'validation timer' amount of time before it's considered valid. It is recommended to set the validation timer to more than twice of the total reference validation measurement time. The frequency detection measurement time is displayed on the wizard. Measurement time of amplitude detection, early / late clock detection as well as 1-pps phase detection is roughly one cycle of reference clock. Therefore, if the reference frequency is >= 2 kHz, total measurement time is approximately the frequency detection measurement time. If the reference frequency is < 2 kHz, total measuremnet time is approximately 1 cycle of reference clock.\n\n2. Amplitude detector. There are two modes: amplitude detector mode and CMOS slew rate detector mode. In amplitude detector mode, the reference is considered valid if the signal swing is higher than the selected threshold. In CMOS slew rate detector mode, the detection method can be either slew rate detection or VIH / VIL detection. For slew rate detection, the input slew rate must be faster than 0.2 V/ns. For VIH / VIL detection, the input high level must be above 1.8 V and the low level must be below 0.6 V. The amplitude detection mode cannot be used for reference frequencies less than 5 MHz. If the reference frequency is above 5 MHz, then amplitude detection mode is recommended for differential input and the CMOS slew rate detection mode is recommended for single-ended input. If the input swing is too low (for example, the LVDS voltage swing is 400 mV, very marginal compared to the mininum threshold of amplitude detection mode), then amplitude detector can be disabled.\n\n3. Frequency detector. This detector is only valid for PRIREF / SECREF frequencies >= 2 kHz. Frequency detection needs 4 parameters: valid threshold in ppm, invalid threshold in ppm, accuracy in ppm and average count. The PRIREF or SECREF is considered valid if the frequency error between PRIREF / SECREF and XO is within the valid threshold. While it's frequency valid, it's considered as frequency invalid if the frequency error exceeds the invalid threshold. The accuracy in ppm indicates how accurate the valid and invalid threshold can be. In other words, this is the resolution of valid and invalid threshold counters. The minimum average count is 2. Keep it as 2 unless the reference clock has too much wander and the DPLL loop bandwidth is too narrow. In that case, raise the average count to no more than 10. As mentioned, the '0-error' reference for frequency detection is the XO. In reality, of course, the XO frequency is not '0-error'. Therefore, the valid and invalid thresholds must take the XO ppm error into account. The minimum valid threshold should be max XO frequency error + max PRIREF / SECREF frequency error + accuracy in ppm. The minimum invalid threshold should be valid threshold + accuracy in ppm.\n\n4. Early and late clock window detector. This detector is only valid for PRIREF / SECREF frequencies >= 2 kHz. 3 parameters are needed: early counter, late counter and number of missing clocks. After setting early and late counters, the T_early and T_late are calculated accordingly. As shown in the timing diagram, the PRIREF / SECREF is considered valid if its next clock edge falls within ideal next edge - T_early and ideal next edge + T_late. Setting the number of missing clocks to x is equivalent to adding x * reference_clock_period to T_late. So the number of missing clocks is typically set to 0 unless gapped clock needs to be supported. The early and late clock detector uses divided down BAW VCO frequency as its '0-error' reference. However, since this is a very coarse detection method (resolution of T_early and T_late counter is roughly 1.6 ns), the ppm error of the BAW VCO itself is not of concern.\n\n5. 1-pps phase detector. This detector is only valid for PRIREF / SECREF frequencies < 2 kHz. T_jitter is auto-calculated according to the phase detector counter. As shown in the timing diagram, the PRIREF / SECREF is considered valid if the next clock edge falls within ideal next edge - T_jitter and ideal next edge + T_jitter. Note that the '0-error' clock reference for 1-pps phase detector is the XO, so T_jitter must be greater than the sum of: (1) XO phase error accumulated through one PRIREF / SECREF clock period (for example, 1 second for 1-pps input). This includes the phase error caused by frequency inaccuracy, accumulated jitter as well as wander. (2) The max period jitter of PRIREF / SECREF. Therefore, low frequency and high stability XO is recommended for 1-pps input. This is because for XOs with the same frequency stability, the one with the lower frequency accumulates less phase error over fixed period of time. 12.8 MHz TCXO / OCXO is recommended for 1-pps input.
    DPLL_VCO_freq=2500
    bRUN_SCRIPT=Run Script
    btn_dpll_show_instructions=Show Instructions
    btn_page5_back=<BACK
    btn_page5_next=NEXT>
    btn_restore_dpll_reg=Restore Calculated DPLL Settings
    cb_show_dpll_registers=0
    combo_disable_fastlock=0
    combo_set_max_tdc_freq=0
    combo_switching_method=0
    sDPLL_LBW=100
    sDPLL_LBW_ACT=101.4
    sDPLL_PEAK=0.1
    sDPLL_PEAK_ERROR=1
    sMAX_TDC_freq=26000000
    sPRIREF_freq_display=10.0 MHz
    sSECREF_freq_display=Disabled
    sTDC_freq=10.0 MHz
    s_wizard_dpll_message_box=DPLL calculation completed!\n\nTDC frequency = 10000000\n\nPlanned VCO1 frequency = 2500000000\nActual VCO1 frequency = 2500000000\nPLL1 frequency error = 0 ppb\n\nPlanned VCO2 frequency = 6160000000\nActual VCO2 frequency = 6160000000\nPLL2 frequency error = 0 ppb\n\nDPLL fastlock time = 124.52 ms + 12.70 ms = 137.22 ms\n\nTotal DPLL frequency lock time ~= DPLL fastlock time + 2 * DPLL frequency lock measurement time\n\nTotal DPLL phase lock time ~= DPLL fastlock time + 2 * DPLL phase lock measurement time
    BAW_LOCK_PPM_THRESH=5
    BAW_UNLK_PPM_THRESH=10
    DPLL_PL_LOCK_calc=377.86 ps
    DPLL_PL_UNLK_calc=6.05 ns
    btn_baw_lock_detect_default=Set Default
    btn_dpll2_show_instructions=Show Instructions
    btn_dpll_freq_lock_detect_default=Set Default
    btn_history_recommend=Min Values Required
    btn_page6_back=<BACK
    btn_page6_next=NEXT>
    btn_ph_threshold_recommend=Recommended
    sBAW_LOCK_ACCURACY_PPM=1
    sBAW_LOCK_AVG=2
    sBAW_TMEAS_LOCK_calc=19.2000 ms
    sDPLL_HISTCNT_calc=26.21 ms
    sDPLL_HISTDLY_calc=24.58 ms
    sDPLL_LOCK_ACCURACY_PPM=1
    sDPLL_LOCK_AVG=10
    sDPLL_LOCK_PPM=1
    sDPLL_PL_MEAS_TIME=9.86 ms
    sDPLL_TMEAS_LOCK_calc=96.0000 ms
    sDPLL_UNLK_PPM=10
    s_wizard_dpll2_message_box=INSTRUCTIONS:\n\nAll lock detect settings are set to either default or recommended values after the DPLL script is run. Still, it is highly recommended to go through the instructions and make the adjustments.\n\n1. BAW frequency lock detect. Disable this if DPLL is enabled. This detector is only useful if the DPLL is disabled and the device works in free-running mode. Enter lock threshold in ppm, unlock threshold in ppm, average count (min value = 2) and accuracy in ppm. The BAW (VCO1) is considered to be locked if the frequency error between the BAW and the XO is within lock threshold. Once the BAW is locked, it's considered to be unlocked if the frequency error exceeds the unlock threshold. The step size of lock and unlock threshold in ppm = accuracy / average. If there's no specific requirement for BAW lock detect, click 'Set Default'.\n\n2. DPLL frequency lock detect. Enter lock and unlock thresholds in ppm, average count (min value = 2) as well as accuracy in ppm. The DPLL is considered to be frequency locked if the frequency error between the VCO1 and the references is within the lock threshold. While the DPLL is frequency locked, it's considered to be frequency unlocked if the frequency error exceeds the unlock threshold. The step size of lock and unlock threshold =  accuracy / average. If there's no specific requirement for DPLL frequency lock detect, click 'Set Default'.\n\n3. DPLL phase lock detect. Set lock and unlock threshold counters. The actual lock and unlock thresholds in second are then calculated accordingly. The DPLL is considered as phase locked if the phase difference between the two inputs of TDC (divided reference and divided VCO1) is within the lock threshold. While the DPLL is phase locked, it's considered as phase unlocked if the phase difference exceeds the unlock threshold. Use recommended values for this. The lock and unlock counters should not be manually set, and they are only used for engineering debugging purposes.\n\n4. Tuning word history. This block sets the tuning word history for holdover. Set history counter and delay counter. The averaging time and delay time are then auto-calculated. Refer to datasheet section '9.3.7.4 Tuning Word History' for details. If there's no specific requirement for holdover tuning word, click 'Min Values Required'. This makes sure that the delay time is more than 8 times of the reference frequency validation measurement time, and that the averaging time is longer than the delay time.
    btn_page7_back=<BACK
    PLL1_24b_DEN=0
    PLL1_24b_NUM=9632
    PLL1_DEN=1099511627776
    PLL1_PFD_freq=65.536
    VCO1_freq=2500
    XO_freq=32.768
    PLL2_DEN_fixed=16777216
    PLL2_PFD_freq=138.8888888889
    VCO1_freq=2500
    VCO2_freq=6160
    XO_freq=32.768
    MUTE_DPLL_FRLOCK=1
    OUT0_freq=140.0 MHz
    OUT1_freq=140.0 MHz
    OUT2_freq=140.0 MHz
    OUT3_freq=140.0 MHz
    OUT4_freq=100.0 MHz
    OUT5_freq=100.0 MHz
    OUT6_freq=100.0 MHz
    OUT7_freq=100.0 MHz
    PLL2PDIV1_freq=1540
    PLL2PDIV2_freq=1540
    VCO1_freq=2500
    VCO2_freq=6160
    sOUT7_DIV=25
    AbsDCO_ppb_error=0.01
    DPLL_DCO_FREQ_PPB_ACT=0
    DPLL_DCO_STEP_ACT=0
    DPLL_REF_NUM_calculated=549755813888
    bDPLL_FDECR=Decrement
    bDPLL_FINCR=Increment
    bResetNumerator0ppb=Reload Original DPLL Numerator
    cbDCO_MODE=1
    sDPLL_DCO_STEP=0.01
    sSYNC_PHASE_OFFSET=
    bClearAllFlagStickyStatus=Clear All Flags
    bReadStatus=Read Status
    ADDR_10=200
    ADDR_11=0
    ADDR_249=0
    ADDR_250=0
    ADDR_251=0
    ADDR_252=0
    REGCOMMIT_PG=0
    bEXPORTEEPROMFILE=Export GUI Map --> EEPROM File
    bIMPORTEEPROMFILE=(1b) Import EEPROM File --> GUI Map
    bLoadDefaultEEPROMImageToGUIMap=(1c) Load Default EEPROM Image --> GUI Map
    bLoadPage_from_GUIMap_to_GUI_Registers=Load GUI Map PAGE --> Register
    bPROGRAMEEPROM=(3) Program EEPROM <-- SRAM
    bREADBACKEEPROM=Read All EEPROM --> GUI Map
    bREADBACKROM=Read All ROM --> GUI Map
    bREADBACKSRAM=Read All SRAM --> GUI Map
    bREG2EE=(1a) Commit Registers --> SRAM PAGE/GUI Map
    bUpdate_ExtraEEPROM_Bytes=Read Extra\nEEPROM Bytes
    cbEESLAVEADR=0
    cbWrite_ADR10=0
    cbWrite_ADR11=0
    mtc_EEPROMdump=
    mtc_USERNOTES=Enter User Notes
    tc_DESIGNNAME=Enter Design Name
    bButton1=Builtins
    bButton2=Globals
    bButton3=Button 3
    bButton4=ReLoad Scripts
    bButton5=Button 5
    bClear=Clear
    bEnter=Enter
    bLoadButton=Load Script
    bSetButton=Set Script
    bSystemUpdate=SystemUpdate
    bSystemUpdateRunOnce=SystemUpdateRunOnce
    cbButtonSelect=0
    mtcOutput=UpdateStatusBar("Hello World")
    mtcScript=0
    tcInput=UpdateStatusBar("Goodbye World")
    tcLHS=0
    210506 LMK0518EVM 48.0048MHz Osc 10MHz Ref.txt
    [SETUP]
    ADDRESS=888
    CLOCK=8
    DATA=4
    LE=2
    PART=LMK05318B
    IFACE=I2C
    ADDRESS_I2C=0x65
    INTERFACE_SPEED=400
    [PINS]
    PINNAME00=REFSEL
    LOCATION00=9
    PINVALUE00=False
    PINNAME01=HW_CTRL
    LOCATION01=7
    PINVALUE01=False
    PINNAME02=PDN
    LOCATION02=3
    PINVALUE02=True
    PINNAME03=GPIO0
    LOCATION03=8
    PINVALUE03=False
    PINNAME04=GPIO1
    LOCATION04=6
    PINVALUE04=False
    PINNAME05=GPIO2
    LOCATION05=5
    PINVALUE05=False
    PINNAME06=Status0
    LOCATION06=10
    PINVALUE06=False
    PINNAME07=Status1
    LOCATION07=11
    PINVALUE07=False
    [MODES]
    NAME00=R0
    VALUE00=16
    NAME01=R1
    VALUE01=267
    NAME02=R2
    VALUE02=565
    NAME03=R3
    VALUE03=818
    NAME04=R4
    VALUE04=1028
    NAME05=R5
    VALUE05=1296
    NAME06=R6
    VALUE06=1566
    NAME07=R7
    VALUE07=1934
    NAME08=R8
    VALUE08=2050
    NAME09=R10
    VALUE09=2762
    NAME10=R11
    VALUE10=2816
    NAME11=R12
    VALUE11=3099
    NAME12=R13
    VALUE12=3328
    NAME13=R14
    VALUE13=3584
    NAME14=R15
    VALUE14=3840
    NAME15=R16
    VALUE15=4096
    NAME16=R17
    VALUE16=4381
    NAME17=R18
    VALUE17=4863
    NAME18=R19
    VALUE18=4864
    NAME19=R20
    VALUE19=5120
    NAME20=R21
    VALUE20=5376
    NAME21=R22
    VALUE21=5635
    NAME22=R23
    VALUE22=5973
    NAME23=R24
    VALUE23=6229
    NAME24=R25
    VALUE24=6400
    NAME25=R26
    VALUE25=6656
    NAME26=R27
    VALUE26=6912
    NAME27=R28
    VALUE27=7169
    NAME28=R29
    VALUE28=7427
    NAME29=R30
    VALUE29=7744
    NAME30=R32
    VALUE30=8260
    NAME31=R35
    VALUE31=8960
    NAME32=R36
    VALUE32=9219
    NAME33=R37
    VALUE33=9472
    NAME34=R38
    VALUE34=9728
    NAME35=R39
    VALUE35=9986
    NAME36=R40
    VALUE36=10243
    NAME37=R41
    VALUE37=10496
    NAME38=R42
    VALUE38=10753
    NAME39=R43
    VALUE39=11202
    NAME40=R44
    VALUE40=11264
    NAME41=R45
    VALUE41=11527
    NAME42=R46
    VALUE42=11800
    NAME43=R47
    VALUE43=12039
    NAME44=R48
    VALUE44=12300
    NAME45=R49
    VALUE45=12550
    NAME46=R50
    VALUE46=12800
    NAME47=R51
    VALUE47=13200
    NAME48=R52
    VALUE48=13312
    NAME49=R53
    VALUE49=13578
    NAME50=R54
    VALUE50=13952
    NAME51=R55
    VALUE51=14080
    NAME52=R56
    VALUE52=14346
    NAME53=R57
    VALUE53=14592
    NAME54=R58
    VALUE54=14872
    NAME55=R59
    VALUE55=15104
    NAME56=R60
    VALUE56=15384
    NAME57=R61
    VALUE57=15616
    NAME58=R62
    VALUE58=15896
    NAME59=R63
    VALUE59=16188
    NAME60=R64
    VALUE60=16384
    NAME61=R65
    VALUE61=16640
    NAME62=R66
    VALUE62=16896
    NAME63=R67
    VALUE63=17176
    NAME64=R68
    VALUE64=17416
    NAME65=R69
    VALUE65=17664
    NAME66=R70
    VALUE66=17920
    NAME67=R71
    VALUE67=18176
    NAME68=R72
    VALUE68=18464
    NAME69=R73
    VALUE69=18688
    NAME70=R74
    VALUE70=18944
    NAME71=R75
    VALUE71=19200
    NAME72=R76
    VALUE72=19456
    NAME73=R77
    VALUE73=19727
    NAME74=R78
    VALUE74=19968
    NAME75=R79
    VALUE75=20241
    NAME76=R80
    VALUE76=20608
    NAME77=R81
    VALUE77=20746
    NAME78=R82
    VALUE78=20992
    NAME79=R83
    VALUE79=21262
    NAME80=R84
    VALUE80=21520
    NAME81=R85
    VALUE81=21853
    NAME82=R86
    VALUE82=22016
    NAME83=R87
    VALUE83=22302
    NAME84=R88
    VALUE84=22660
    NAME85=R89
    VALUE85=22914
    NAME86=R90
    VALUE86=23040
    NAME87=R91
    VALUE87=23316
    NAME88=R92
    VALUE88=23552
    NAME89=R93
    VALUE89=23822
    NAME90=R94
    VALUE90=24080
    NAME91=R95
    VALUE91=24413
    NAME92=R96
    VALUE92=24576
    NAME93=R97
    VALUE93=24862
    NAME94=R98
    VALUE94=25220
    NAME95=R99
    VALUE95=25474
    NAME96=R100
    VALUE96=25640
    NAME97=R101
    VALUE97=25857
    NAME98=R102
    VALUE98=26163
    NAME99=R103
    VALUE99=26383
    NAME100=R104
    VALUE100=26655
    NAME101=R105
    VALUE101=26885
    NAME102=R106
    VALUE102=27136
    NAME103=R107
    VALUE103=27492
    NAME104=R108
    VALUE104=27648
    NAME105=R109
    VALUE105=27956
    NAME106=R110
    VALUE106=28180
    NAME107=R111
    VALUE107=28416
    NAME108=R112
    VALUE108=28680
    NAME109=R113
    VALUE109=29116
    NAME110=R114
    VALUE110=29373
    NAME111=R115
    VALUE111=29443
    NAME112=R116
    VALUE112=29697
    NAME113=R117
    VALUE113=29952
    NAME114=R118
    VALUE114=30208
    NAME115=R119
    VALUE115=30464
    NAME116=R120
    VALUE116=30720
    NAME117=R121
    VALUE117=30976
    NAME118=R122
    VALUE118=31232
    NAME119=R123
    VALUE119=31540
    NAME120=R124
    VALUE120=31744
    NAME121=R125
    VALUE121=32008
    NAME122=R126
    VALUE122=32444
    NAME123=R127
    VALUE123=32700
    NAME124=R128
    VALUE124=32768
    NAME125=R129
    VALUE125=33025
    NAME126=R130
    VALUE126=33280
    NAME127=R131
    VALUE127=33537
    NAME128=R132
    VALUE128=33793
    NAME129=R133
    VALUE129=34167
    NAME130=R134
    VALUE130=34304
    NAME131=R135
    VALUE131=34604
    NAME132=R136
    VALUE132=34816
    NAME133=R137
    VALUE133=35089
    NAME134=R138
    VALUE134=35376
    NAME135=R139
    VALUE135=35587
    NAME136=R140
    VALUE136=35842
    NAME137=R141
    VALUE137=36096
    NAME138=R142
    VALUE138=36353
    NAME139=R143
    VALUE139=36609
    NAME140=R144
    VALUE140=36983
    NAME141=R145
    VALUE141=37121
    NAME142=R146
    VALUE142=37513
    NAME143=R147
    VALUE143=37664
    NAME144=R149
    VALUE144=38157
    NAME145=R150
    VALUE145=38400
    NAME146=R151
    VALUE146=38657
    NAME147=R152
    VALUE147=38925
    NAME148=R153
    VALUE148=39209
    NAME149=R154
    VALUE149=39460
    NAME150=R155
    VALUE150=39910
    NAME151=R156
    VALUE151=39937
    NAME152=R157
    VALUE152=40192
    NAME153=R158
    VALUE153=40448
    NAME154=R159
    VALUE154=40704
    NAME155=R160
    VALUE155=41212
    NAME156=R161
    VALUE156=41216
    NAME157=R162
    VALUE157=41727
    NAME158=R164
    VALUE158=41984
    NAME159=R165
    VALUE159=42240
    NAME160=R167
    VALUE160=42753
    NAME161=R178
    VALUE161=45568
    NAME162=R180
    VALUE162=46080
    NAME163=R181
    VALUE163=46336
    NAME164=R182
    VALUE164=46592
    NAME165=R183
    VALUE165=46848
    NAME166=R184
    VALUE166=47104
    NAME167=R185
    VALUE167=47365
    NAME168=R186
    VALUE168=47623
    NAME169=R187
    VALUE169=47872
    NAME170=R188
    VALUE170=48128
    NAME171=R189
    VALUE171=48384
    NAME172=R190
    VALUE172=48721
    NAME173=R191
    VALUE173=48896
    NAME174=R192
    VALUE174=49264
    NAME175=R193
    VALUE175=49455
    NAME176=R194
    VALUE176=49664
    NAME177=R195
    VALUE177=49920
    NAME178=R196
    VALUE178=50176
    NAME179=R197
    VALUE179=50498
    NAME180=R198
    VALUE180=50688
    NAME181=R199
    VALUE181=50944
    NAME182=R200
    VALUE182=51229
    NAME183=R201
    VALUE183=51456
    NAME184=R202
    VALUE184=51712
    NAME185=R203
    VALUE185=51968
    NAME186=R204
    VALUE186=52282
    NAME187=R205
    VALUE187=52480
    NAME188=R206
    VALUE188=52736
    NAME189=R207
    VALUE189=53013
    NAME190=R208
    VALUE190=53248
    NAME191=R209
    VALUE191=53524
    NAME192=R210
    VALUE192=53760
    NAME193=R211
    VALUE193=54038
    NAME194=R212
    VALUE194=54272
    NAME195=R213
    VALUE195=54548
    NAME196=R214
    VALUE196=54784
    NAME197=R215
    VALUE197=55062
    NAME198=R216
    VALUE198=55311
    NAME199=R217
    VALUE199=55552
    NAME200=R218
    VALUE200=55808
    NAME201=R219
    VALUE201=56074
    NAME202=R220
    VALUE202=56364
    NAME203=R221
    VALUE203=56576
    NAME204=R222
    VALUE204=56835
    NAME205=R223
    VALUE205=57101
    NAME206=R224
    VALUE206=57415
    NAME207=R225
    VALUE207=57600
    NAME208=R226
    VALUE208=57856
    NAME209=R227
    VALUE209=58137
    NAME210=R228
    VALUE210=58478
    NAME211=R229
    VALUE211=58624
    NAME212=R230
    VALUE212=58883
    NAME213=R231
    VALUE213=59149
    NAME214=R232
    VALUE214=59463
    NAME215=R233
    VALUE215=59658
    NAME216=R234
    VALUE216=59914
    NAME217=R235
    VALUE217=60160
    NAME218=R236
    VALUE218=60611
    NAME219=R237
    VALUE219=60752
    NAME220=R238
    VALUE220=60928
    NAME221=R239
    VALUE221=61184
    NAME222=R240
    VALUE222=61635
    NAME223=R241
    VALUE223=61776
    NAME224=R242
    VALUE224=61952
    NAME225=R243
    VALUE225=62208
    NAME226=R244
    VALUE226=62464
    NAME227=R249
    VALUE227=63777
    NAME228=R250
    VALUE228=64000
    NAME229=R251
    VALUE229=64259
    NAME230=R252
    VALUE230=64557
    NAME231=R253
    VALUE231=64768
    NAME232=R254
    VALUE232=65024
    NAME233=R255
    VALUE233=65280
    NAME234=R256
    VALUE234=65536
    NAME235=R257
    VALUE235=65793
    NAME236=R258
    VALUE236=66048
    NAME237=R259
    VALUE237=66304
    NAME238=R260
    VALUE238=66562
    NAME239=R261
    VALUE239=66944
    NAME240=R262
    VALUE240=67072
    NAME241=R263
    VALUE241=67328
    NAME242=R264
    VALUE242=67584
    NAME243=R265
    VALUE243=67841
    NAME244=R266
    VALUE244=68340
    NAME245=R267
    VALUE245=68512
    NAME246=R268
    VALUE246=68620
    NAME247=R269
    VALUE247=68867
    NAME248=R270
    VALUE248=69122
    NAME249=R271
    VALUE249=69604
    NAME250=R272
    VALUE250=69632
    NAME251=R273
    VALUE251=69888
    NAME252=R274
    VALUE252=70144
    NAME253=R275
    VALUE253=70414
    NAME254=R276
    VALUE254=70668
    NAME255=R277
    VALUE255=70926
    NAME256=R278
    VALUE256=71177
    NAME257=R279
    VALUE257=71432
    NAME258=R280
    VALUE258=71689
    NAME259=R281
    VALUE259=71943
    NAME260=R282
    VALUE260=72205
    NAME261=R283
    VALUE261=72455
    NAME262=R284
    VALUE262=72734
    NAME263=R285
    VALUE263=72990
    NAME264=R286
    VALUE264=73218
    NAME265=R287
    VALUE265=73584
    NAME266=R288
    VALUE266=73731
    NAME267=R289
    VALUE267=74220
    NAME268=R290
    VALUE268=74243
    NAME269=R291
    VALUE269=74506
    NAME270=R292
    VALUE270=74761
    NAME271=R293
    VALUE271=75009
    NAME272=R294
    VALUE272=75264
    NAME273=R295
    VALUE273=75564
    NAME274=R296
    VALUE274=75783
    NAME275=R297
    VALUE275=76043
    NAME276=R298
    VALUE276=76295
    NAME277=R299
    VALUE277=76545
    NAME278=R300
    VALUE278=76800
    NAME279=R301
    VALUE279=77084
    NAME280=R302
    VALUE280=77344
    NAME281=R303
    VALUE281=77569
    NAME282=R304
    VALUE282=77824
    NAME283=R305
    VALUE283=78080
    NAME284=R306
    VALUE284=78336
    NAME285=R307
    VALUE285=78592
    NAME286=R308
    VALUE286=78910
    NAME287=R309
    VALUE287=79232
    NAME288=R310
    VALUE288=79360
    NAME289=R311
    VALUE289=79616
    NAME290=R312
    VALUE290=79872
    NAME291=R313
    VALUE291=80128
    NAME292=R314
    VALUE292=80384
    NAME293=R315
    VALUE293=80640
    NAME294=R316
    VALUE294=80896
    NAME295=R317
    VALUE295=81152
    NAME296=R318
    VALUE296=81408
    NAME297=R319
    VALUE297=81667
    NAME298=R320
    VALUE298=81920
    NAME299=R321
    VALUE299=82186
    NAME300=R322
    VALUE300=82432
    NAME301=R323
    VALUE301=82702
    NAME302=R324
    VALUE302=83110
    NAME303=R325
    VALUE303=83200
    NAME304=R326
    VALUE304=83456
    NAME305=R327
    VALUE305=83864
    NAME306=R328
    VALUE306=84118
    NAME307=R329
    VALUE307=84352
    NAME308=R330
    VALUE308=84480
    NAME309=R331
    VALUE309=84836
    NAME310=R332
    VALUE310=84992
    NAME311=R333
    VALUE311=85248
    NAME312=R334
    VALUE312=85552
    NAME313=R335
    VALUE313=85972
    NAME314=R336
    VALUE314=86016
    NAME315=R337
    VALUE315=86424
    NAME316=R338
    VALUE316=86678
    NAME317=R339
    VALUE317=86784
    NAME318=R340
    VALUE318=87040
    NAME319=R341
    VALUE319=87296
    NAME320=R342
    VALUE320=87552
    NAME321=R343
    VALUE321=87808
    NAME322=R344
    VALUE322=88064
    NAME323=R345
    VALUE323=88320
    NAME324=R346
    VALUE324=88578
    NAME325=R347
    VALUE325=88832
    NAME326=R348
    VALUE326=89088
    NAME327=R349
    VALUE327=89344
    NAME328=R350
    VALUE328=89600
    NAME329=R351
    VALUE329=89856
    NAME330=R352
    VALUE330=90112
    NAME331=R357
    VALUE331=91432
    NAME332=R367
    VALUE332=93992
    NAME333=R411
    VALUE333=105220
    [FLEX]
    CH0_PREDRIVER=0
    CH1_PREDRIVER=0
    CH2_PREDRIVER=0
    CH3_PREDRIVER=0
    CH4_PREDRIVER=0
    CH5_PREDRIVER=0
    CH6_PREDRIVER=0
    CH7_PREDRIVER=0
    DPLL_REF_MASHSEED=0
    MUTE_DPLL_FRLOCK=1
    OUT0_freq=140.0 MHz
    OUT1_freq=140.0 MHz
    OUT2_freq=140.0 MHz
    OUT3_freq=140.0 MHz
    OUT4_freq=100.0 MHz
    OUT5_freq=100.0 MHz
    OUT6_freq=100.0 MHz
    OUT7_freq=100.0 MHz
    PLL1_BAW_CAPDAC=0
    PLL1_CP_TRIM=0
    PLL1_VCBO_VAR2CON=0
    PRIREFBUFGAIN=0
    SECREFBUFGAIN=0
    VCO1_freq=2500
    VCO2_freq=6160
    XO_freq=48.0048
    i2cAddr=0
    sTDC_freq=10.0 MHz
    combo_dpll_mode=0
    combo_ref_freq=1
    sXO_freq=48004800
    s_wizard_XO_message_box=XO frequency set successfully!\n\nInteger boundary spur = 3.75 MHz\n\nXO R divider = 1\nXO doubler is disabled\nPFD frequency = 48.0048 MHz
    OUT0_freq=140.0 MHz
    OUT1_freq=140.0 MHz
    OUT2_freq=140.0 MHz
    OUT3_freq=140.0 MHz
    OUT4_freq=100.0 MHz
    OUT5_freq=100.0 MHz
    OUT6_freq=100.0 MHz
    OUT7_freq=100.0 MHz
    sCH0_1_MUX=APLL2
    sCH2_3_MUX=APLL2
    sCH4_MUX=APLL1
    sCH5_MUX=APLL1
    sCH6_MUX=APLL1
    sCH7_MUX=APLL1
    s_wizard_freqplan_message_box=Frequency plan completed!\n\nSelected frequency plan:\n\nVCO1 frequency = 2500.0 MHz\nVCO2 frequency = 6160.0 MHz\n\nAPLL1 settings:\n\nPFD freq = 48004800 Hz\nN divider = 52\nNumerator = 85899918525\nDenominator = 1099511627776\nPost divider = 1\n\nAPLL2 settings:\n\nAPLL2 reference source is VCO1\nPFD freq = 1250000000/9 Hz\nN divider = 44\nNumerator = 4400\nDenominator = 12500\nPost divider 1 = 4\nPost divider 2 = 4\n\n
    cb_enable_PRIREF=1
    cb_enable_SECREF=0
    refclk_pin_select=
    sSECREF_freq=
    sPRIREF_AVG_COUNT=2
    sPRIREF_LATE=0
    sPRIREF_PPM_TIMER=4.17 ms
    sSECREF_AVG_COUNT=2
    sSECREF_LATE=0
    DPLL_VCO_freq=2500
    sDPLL_LBW=100
    sDPLL_LBW_ACT=101.4
    sDPLL_PEAK=0.1
    sDPLL_PEAK_ERROR=1
    sTDC_freq=10.0 MHz
    DPLL_PL_LOCK_calc=276.76 ps
    DPLL_PL_UNLK_calc=4.43 ns
    sBAW_LOCK_AVG=2
    sDPLL_HISTCNT_calc=52.43 ms
    sDPLL_HISTDLY_calc=33.59 ms
    sDPLL_LOCK_AVG=10
    sDPLL_LOCK_PPM=1
    sDPLL_UNLK_PPM=10
    PLL1_24b_DEN=572605
    PLL1_24b_NUM=5120
    PLL1_PFD_freq=48.0048
    VCO1_freq=2500
    XO_freq=48.0048
    VCO1_freq=2500
    VCO2_freq=6160
    XO_freq=48.0048
    MUTE_DPLL_FRLOCK=1
    OUT0_freq=140.0 MHz
    OUT1_freq=140.0 MHz
    OUT2_freq=140.0 MHz
    OUT3_freq=140.0 MHz
    OUT4_freq=100.0 MHz
    OUT5_freq=100.0 MHz
    OUT6_freq=100.0 MHz
    OUT7_freq=100.0 MHz
    PLL2PDIV1_freq=1540
    PLL2PDIV2_freq=1540
    VCO1_freq=2500
    VCO2_freq=6160
    sOUT7_DIV=25
    DPLL_DCO_STEP_ACT=0
    cbDCO_MODE=1
    sDPLL_DCO_STEP=0.01
    sSYNC_PHASE_OFFSET=
    ADDR_10=200
    ADDR_11=0
    ADDR_249=0
    ADDR_250=0
    ADDR_251=0
    ADDR_252=0
    REGCOMMIT_PG=0
    cbEESLAVEADR=0
    cbWrite_ADR10=0
    cbWrite_ADR11=0
    mtc_EEPROMdump=
    bButton1=Builtins
    bButton2=Globals
    bButton3=Button 3
    bButton5=Button 5
    bClear=Clear
    bEnter=Enter
    cbButtonSelect=0
    mtcScript=0
    tcLHS=0
    Your assistance is appreciated.
    Carlo
  • Ok, thanks for the info.  We'll review it and update you.
    73,
    Timothy
  • Hello Timothy,
    Do we have an update? Your help is appreciated.
    Carlo
  • Hi Carlo,
    Please find my comments below:
    1. The attached report compares 140MHz spectrum with 100MHz spectrum. This is not making much sense because 140MHz is LVDS but 100MHz is LVCMOS. LVCMOS amplitude is much higher than LVDS, so when you look at the two in a spectrum analyzer, the noise floor as well as carrier power level will for sure be different. So for a sanity check, use 100MHz for both or 140MHz for both. Make apple-to-apple comparison. Of course when using a phase noise analyzer, the output amplitude does not affect phase noise, but since this is spectrum analyzer which can't measure the true phase noise, this is very likely related to output amplitude.
    2. When DPLL is locked, BAW lock status is unimportant. The BAW unlock status (doesn't mean it's really unlocked) is likely due to the frequency accuracy of the XO. For sanity check, measure the XO frequency with a frequency counter, then change the XO frequency in the wizard to its true frequency. Alternatively, change the BAW lock/unlock threshold. For example, lock/unlock = 50/70ppm.
    Hao
