<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://e2e.ti.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/" xmlns:atom="http://www.w3.org/2005/Atom"><channel><title>Clock &amp;amp; timing forum - Recent Threads</title><link>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum</link><description /><dc:language>en-US</dc:language><generator>Telligent Community 13</generator><lastBuildDate>Fri, 27 Nov 2026 12:53:31 GMT</lastBuildDate><atom:link rel="self" type="application/rss+xml" href="https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum" /><item><title>CDC6C: Frequency correction loop behavior at elevated temperature; SATA controller PLL stability concern</title><link>https://e2e.ti.com/thread/1700960?ContentTypeID=0</link><pubDate>Fri, 27 Nov 2026 12:53:31 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:39a949c5-6f26-4daf-a39b-0311082fe6ad</guid><dc:creator>Clemens Koller</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1700960?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700960/cdc6c-frequency-correction-loop-behavior-at-elevated-temperature-sata-controller-pll-stability-concern/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/CDC6C" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;CDC6C&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;We are using the CDC6CA025000ADLFR as the 25 MHz reference clock input for a Marvell 88SE9182 SATA/PCIe controller (XTAL_IN pin, analog crystal input, 1.8V, capable to be fed by an Oscillator according to the datasheet and reference designs). The oscillator is operating at 1.8V supply in normal/fast output mode. The 88SE9182 PLL uses this reference to generate its internal core and SATA clocks.&lt;br&gt;&lt;br&gt;At elevated temperature (above 50&amp;deg;C), the SATA ports of the 88SE9182 produce link resets and does not appear to boot. At negative temperatures and room temperature the system operates correctly. Replacing the CDC6CA025000ADLFR with a passive 25 MHz quartz crystal (TXC-7M-25MHZ-AAJ) eliminates the failure - the system operates correctly at 50&amp;deg;C with the passive crystal installed.&lt;/p&gt;
&lt;p&gt;In an earlier design, the same SATA controller position was driven by a Fox FOX924B (now: Abracon FT5HN) digitally-compensated TCXO. That part caused the same SATA link reset symptom at elevated temperature. The FOX924B was removed from use after we identified two probable causes:&lt;/p&gt;
&lt;p&gt;1. Duty cycle deviation - measured at 44&amp;ndash;45% / 55&amp;ndash;56%, marginal for the SATA controller&amp;#39;s PLL&lt;br&gt;2. DCTCXO discrete frequency correction steps - assumption: the DAC-driven varactor correction produces periodic discrete phase steps, which we believe disturb the 88SE9182 PLL&lt;/p&gt;
&lt;p&gt;The CDC6CA025000ADLFR replaced the FOX924B precisely because TI describes its BAW correction as continuous rather than step-based, which we expected to resolve the DCTCXO issue. However, the failure pattern at 50&amp;deg;C is the same(!).&lt;/p&gt;
&lt;p&gt;Questions:&lt;/p&gt;
&lt;p&gt;1. Correction loop behavior at temperature: The CDC6CA datasheet describes temperature correction as continuous. What is the correction loop bandwidth and correction rate at steady-state elevated temperature (e.g. 50&amp;deg;C)? Does the correction produce any detectable frequency transients - even small ones - during the correction process, or is it truly analog and smooth?&lt;br&gt;2. Phase noise at temperature: Is characterization data available for the CDC6CA025000ADLFR phase noise profile at 50&amp;deg;C, particularly in the range of 1 kHz to 1 MHz offset? We want to understand whether the correction loop contributes phase noise at frequencies that could overlap with a SATA controller PLL&amp;#39;s loop bandwidth (~1..10 kHz range typical).&lt;br&gt;3. Frequency deviation during correction: What is the peak instantaneous frequency deviation during a thermal correction event at 50&amp;deg;C (e.g. transitioning from 25&amp;deg;C to 50&amp;deg;C, or at steady-state 50&amp;deg;C)? Is this bounded in the datasheet, or is characterization data available?&lt;br&gt;4. Comparison to plain XO: The 88SE9182 PLL works correctly with a passive quartz crystal whose frequency changes on a purely thermal timescale (seconds). What is the fastest rate of frequency change the CDC6CA correction loop can produce, and how does it compare to the natural thermal drift rate of a passive crystal?&lt;br&gt;5. LVCMOS drive level on analog crystal input: The 88SE9182 XTAL_IN is designed as an analog crystal oscillator input (internal amplifier, analog biasing). The CDC6CA drives it with a full-swing 1.8V LVCMOS signal. Is there any known concern with driving an analog crystal input with a full-swing LVCMOS output, particularly at elevated temperature where the input&amp;#39;s analog characteristics may shift?&lt;/p&gt;
&lt;p&gt;What we are trying to determine:&lt;br&gt;The passive crystal works correctly at 50&amp;deg;C. The CDC6CA fails at 50&amp;deg;C with the same symptom previously caused by a DCTCXO. We want to understand whether the CDC6CA&amp;#39;s internal correction loop can produce phase or frequency perturbations at 50&amp;deg;C that - even if far smaller than a DCTCXO&amp;#39;s discrete steps - are sufficient to cause a PLL with a narrow loop bandwidth to lose lock.&lt;/p&gt;
&lt;p&gt;Any characterization data, application notes, or guidance on using CDC6CA-family oscillators as reference clocks into analog crystal inputs of SATA or PCIe controllers would be appreciated.&lt;/p&gt;
&lt;p&gt;Thank you very much for your effort to shed some light on this.&lt;br&gt;Feel free to contact me any time if you need further information, also by phone.&lt;br&gt;&lt;br&gt;Regards,&lt;br&gt;Clemens Koller&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMX2571: How to reduce close-in fractional spurs around 100 kHz offset after applying Spur-b-Gone algorithm</title><link>https://e2e.ti.com/thread/1700946?ContentTypeID=0</link><pubDate>Fri, 27 Nov 2026 10:40:04 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:b821e0b7-a3cf-43c5-89b4-1c64277b8a9c</guid><dc:creator>Kyohei</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1700946?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700946/lmx2571-how-to-reduce-close-in-fractional-spurs-around-100-khz-offset-after-applying-spur-b-gone-algorithm/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMX2571" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMX2571&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;div&gt;
&lt;div&gt;Hi team,&lt;/div&gt;
&lt;div&gt;I have a question regarding the LMX2571.&lt;/div&gt;
&lt;div&gt;Our customer is using the LMX2571 in a production design and has implemented an algorithm similar to the Spur-b-Gone method to reduce Integer Boundary Spurs (IBS).&lt;/div&gt;
&lt;div&gt;The reference frequency is 27 MHz.&lt;br&gt;Depending on the output frequency, the customer selects one of the following PFD frequencies by changing MULT / PreDiv / R:&lt;/div&gt;
&lt;ul&gt;
&lt;li&gt;121.5 MHz&lt;/li&gt;
&lt;li&gt;108 MHz&lt;/li&gt;
&lt;li&gt;94.5 MHz&lt;/li&gt;
&lt;li&gt;81 MHz&lt;/li&gt;
&lt;li&gt;67.5 MHz&lt;/li&gt;
&lt;/ul&gt;
&lt;div&gt;The algorithm calculates the distance from the VCO frequency to the integer boundary and selects the PFD condition with the best IBS index.&lt;/div&gt;
&lt;div&gt;With this method, the customer normally tries to maintain approximately 6 MHz or more separation from the integer boundary.&lt;/div&gt;
&lt;div&gt;However, at some specific channels, close-in spurs on the order of approximately 100 kHz from the carrier are still observed even though the calculated IBS separation is sufficiently large.&lt;/div&gt;
&lt;div&gt;The current fractional denominator used by the customer&amp;#39;s algorithm is:&lt;/div&gt;
&lt;ul&gt;
&lt;li&gt;PLL_DEN = 16,329,600 (fixed)&lt;/li&gt;
&lt;/ul&gt;
&lt;div&gt;We are currently confirming the customer&amp;#39;s Dithering and FRAC_ORDER settings.&lt;/div&gt;
&lt;div&gt;We found the following related E2E discussions:&lt;/div&gt;
&lt;ul&gt;
&lt;li&gt;&amp;quot;LMX2571: Fast changing modulated spurs&amp;quot;&lt;/li&gt;
&lt;li&gt;&amp;quot;LMX2571 spurs behavior&amp;quot;&lt;/li&gt;
&lt;li&gt;&amp;quot;LMX2571: LMX2571 SPUR-B-GONE ALGORITHM&amp;quot;&lt;/li&gt;
&lt;/ul&gt;
&lt;div&gt;Based on these discussions, we understand that fractional spurs may also depend on the NUM/DEN ratio and proximity to simple fractions, and that the IBS metric used by Spur-b-Gone is a guideline rather than a guarantee of the lowest spur level. &lt;a href="https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/710895/lmx2571-lmx2571-spur-b-gone-algorithm"&gt;[e2e.ti.com]&lt;/a&gt;, &lt;a href="https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/697361/lmx2571-fast-changing-modulated-spurs"&gt;[e2e.ti.com]&lt;/a&gt;&lt;/div&gt;
&lt;div&gt;We also found a previous LMX2571 case where the following settings were suggested:&lt;/div&gt;
&lt;ul&gt;
&lt;li&gt;PLL_DEN = 2^24 - 1 (16,777,215)&lt;/li&gt;
&lt;li&gt;Dithering = Disabled&lt;/li&gt;
&lt;li&gt;FRAC_ORDER = 3rd order &lt;a href="https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/527964/lmx2571-spurs-behavior"&gt;[e2e.ti.com]&lt;/a&gt;&lt;/li&gt;
&lt;/ul&gt;
&lt;div&gt;Could you please advise on the following?&lt;/div&gt;
&lt;ol&gt;
&lt;li&gt;
&lt;div&gt;Is it possible that the approximately 100 kHz close-in spurs are fractional spurs rather than Integer Boundary Spurs, even when the IBS separation is approximately 6 MHz or greater?&lt;/div&gt;
&lt;/li&gt;
&lt;li&gt;
&lt;div&gt;For this type of close-in fractional spur, would you recommend changing PLL_DEN from 16,329,600 to 2^24 - 1 (16,777,215)?&lt;/div&gt;
&lt;/li&gt;
&lt;li&gt;
&lt;div&gt;Are Dithering = Disabled and FRAC_ORDER = 3rd order still recommended settings for reducing this type of spur on LMX2571?&lt;/div&gt;
&lt;/li&gt;
&lt;li&gt;
&lt;div&gt;Are there any other register settings that should be adjusted to reduce close-in fractional spurs?&lt;/div&gt;
&lt;/li&gt;
&lt;li&gt;
&lt;div&gt;In addition to the IBS metric, should the customer&amp;#39;s frequency-selection algorithm also evaluate the fractional NUM/DEN ratio or proximity to simple fractions such as 1/2, 1/3, etc.?&lt;/div&gt;
&lt;/li&gt;
&lt;/ol&gt;
&lt;div&gt;If necessary, we can provide the exact output frequency, VCO frequency, PFD frequency, N, NUM, DEN, Dithering, FRAC_ORDER, and measured spur spectrum for a problematic channel.&lt;/div&gt;
&lt;div&gt;Best regards,&lt;br&gt;Kyohei&lt;/div&gt;
&lt;/div&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK3H0102-Q1: LMK3H0102-Q1 variants &amp; OTP configuration</title><link>https://e2e.ti.com/thread/1700791?ContentTypeID=0</link><pubDate>Fri, 27 Nov 2026 04:46:58 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:345fc034-249e-478f-90ba-c0f40b809051</guid><dc:creator>Aziz D.</dc:creator><slash:comments>1</slash:comments><comments>https://e2e.ti.com/thread/1700791?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700791/lmk3h0102-q1-lmk3h0102-q1-variants-otp-configuration/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK3H0102-Q1" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK3H0102-Q1&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt;  &lt;a href="https://www.ti.com/product/LMK3H0102" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK3H0102&lt;/a&gt;&lt;/p&gt;&lt;p dir="ltr"&gt;Hi team,&lt;/p&gt;
&lt;p dir="ltr"&gt;I&amp;#39;m evaluating the LMK3H0102-Q1 for a design. The Ordering &amp;amp; quality section of the product page LMK3H0102-Q1 | TI.com lists several orderable active variants besides the default configurations:&lt;/p&gt;
&lt;ul dir="ltr"&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T07&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T0F&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T17&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T19&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T1A&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T1B&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T1F&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T20&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T26&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;li&gt;LMK3H0102&lt;strong&gt;T29&lt;/strong&gt;RGTRQ1&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;Interestingly, LMK3H0102&lt;strong&gt;TV1&lt;/strong&gt;RGTRQ1 and&amp;nbsp;LMK3H0102&lt;strong&gt;TV3&lt;/strong&gt;RGTRQ1 are not listed there&lt;/p&gt;
&lt;p dir="ltr"&gt;The LMK3H0102-Q1 datasheet (SNAS862B) only documents the start-up settings of the LMK3H0102TV3 and LMK3H0102TV1 (Table 7-11). It says that additional configurations are named LMK3H0102Txx and refers to the LMK3H0102 Configuration Guide for their OTP defaults. However, the public Configuration Guide (SNAU290, Nov 2024) only covers the non-automotive LMK3H0102Axxx parts (A001, A006, A014, A015, A016) and doesn&amp;#39;t mention any Txx variant.&lt;/p&gt;
&lt;p dir="ltr"&gt;Could you please provide us the following for each orderable Txx variant?&lt;/p&gt;
&lt;ol dir="ltr"&gt;
&lt;li&gt;Supported VDD/VDDO supply voltage(s). For example, is the part limited to 3.3 V or 1.8 V, as you mentioned for T07 in an earlier thread?&lt;/li&gt;
&lt;li&gt;Settings for each OTP page (Page 0&amp;ndash;3): OUT0/OUT1 frequency, output format, output enable state, and SSC enable / modulation type / depth.&lt;/li&gt;
&lt;li&gt;Pin functions in OTP mode: REF_CTRL behavior, the pin 2 (OE) function, and whether FMT_ADDR is active (R9[8]).&lt;/li&gt;
&lt;li&gt;The full default register map (R0&amp;ndash;R12&amp;hellip;), or a TICS Pro configuration file / EFUSE export.&lt;/li&gt;
&lt;li&gt;Whether an updated Configuration Guide covering the Txx (-Q1) variants is planned, or where this information is documented.&lt;/li&gt;
&lt;/ol&gt;
&lt;p dir="ltr"&gt;Also, are these Txx variants generally available, or are they customer-specific configurations reserved for particular customers?&lt;br&gt;How can we order a new custom variant, if we don&amp;#39;t find a matching one?&amp;nbsp;&lt;/p&gt;
&lt;p dir="ltr"&gt;Thank you!&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK6D: Clock Oscillator Not working</title><link>https://e2e.ti.com/thread/1700764?ContentTypeID=0</link><pubDate>Thu, 26 Nov 2026 16:39:11 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:3a82b2cc-00f2-433b-bc68-38fcb7c82677</guid><dc:creator>Nishant  Gupta</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1700764?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700764/lmk6d-clock-oscillator-not-working/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK6D" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK6D&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Hello TI Team,&lt;/p&gt;
&lt;p&gt;I am facing a problem while testing the LMK6DE050000ADLER oscillator. I have supplied 3.3 V to the device, but I cannot see any clock signal on my oscilloscope.&lt;/p&gt;
&lt;p&gt;I have connected Pins 1, 2 and 3 to ground. Pins 4 and 5 are used as differential clock outputs, and Pin 6 is connected to a 3.3 V supply. I have also connected 1 uF and 0.1 uF capacitors for supply decoupling.&lt;/p&gt;
&lt;p&gt;For the output connections, I have used a separate 0.1 uF series capacitor on each output, followed by a 100 ohm differential termination resistor.&lt;/p&gt;
&lt;p&gt;I tried different connections for Pins 1 and 2. First, I connected both pins to ground. Then I left them unconnected. Finally, I connected them to the 3.3 V supply through individual 4.75 kohm resistors. However, none of these attempts produced a clock output.&lt;/p&gt;
&lt;p&gt;Another concern is that my bench power supply indicates approximately 165 mA current consumption at 3.3 V.&lt;/p&gt;
&lt;p&gt;I would appreciate your help in understanding why the oscillator is not working.&lt;/p&gt;
&lt;p&gt;Could you please confirm the correct connections for Pins 1 and 2? Is my output termination arrangement correct? What is the expected supply current at 3.3 V? Is there any possibility that the oscillator has been damaged?&lt;/p&gt;
&lt;p&gt;Please guide me on the correct connections and the recommended procedure for testing this device.&lt;/p&gt;
&lt;p&gt;Thank you for your support.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK04828BEVM: Observing spur in RF DAC output</title><link>https://e2e.ti.com/thread/1700740?ContentTypeID=0</link><pubDate>Thu, 26 Nov 2026 14:34:53 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:f1fb19b5-e9c3-4e58-9c21-9ea358e924d1</guid><dc:creator>Harikrishnan P</dc:creator><slash:comments>1</slash:comments><comments>https://e2e.ti.com/thread/1700740?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700740/lmk04828bevm-observing-spur-in-rf-dac-output/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/tool/LMK04828BEVM" class="internal-link folder tool" title="Link to Tool Folder" target="_blank"&gt;LMK04828BEVM&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK04828" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK04828&lt;/a&gt;&lt;/p&gt;&lt;p&gt;We are using the LMK04828BISQE/NOPB as the clock source for the RF DAC and ADC in our SOMs.&lt;/p&gt;
&lt;p&gt;We are observing spurs in the phase noise measurement of the DAC output when an external 10 MHz reference signal is connected to CLKin1 (PLL1 reference input). When the 10 MHz reference is disconnected, the spurs disappear.&lt;/p&gt;
&lt;p&gt;We have also measured the phase noise of the 10 MHz reference source and confirmed that no spurs are present in the source signal.&lt;/p&gt;
&lt;p&gt;Could you please review the attached clock configuration file and phase noise measurements and help us identify the possible cause of these spurs? We would also appreciate your recommendations on any configuration changes or hardware checks required to resolve the issue.&lt;a href="https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/48DR_5F00_R1.0_2D00_REL0.3_5F00_E_2D00_LMK_2D00_CKIN1_5F00_10MHz.tcs" target="_blank" rel="noopener" data-temp-id="48DR_R1.0-REL0.3_E-LMK-CKIN1_10MHz.tcs-7471"&gt;48DR_R1.0-REL0.3_E-LMK-CKIN1_10MHz.tcs&lt;/a&gt; &lt;a href="https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/Phasenoise_5F00_Measurement.pptx" target="_blank" rel="noopener" data-temp-id="Phasenoise_Measurement.pptx-530376"&gt;Phasenoise_Measurement.pptx&lt;/a&gt;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK04828: Please help check the schematic</title><link>https://e2e.ti.com/thread/1700416?ContentTypeID=0</link><pubDate>Wed, 25 Nov 2026 14:40:13 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:43928816-0650-4a92-b9a2-e99ebc2509da</guid><dc:creator>Reed</dc:creator><slash:comments>1</slash:comments><comments>https://e2e.ti.com/thread/1700416?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700416/lmk04828-please-help-check-the-schematic/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK04828" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK04828&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Hi Team,&lt;/p&gt;
&lt;p&gt;Please help check the schematic.&lt;/p&gt;
&lt;p&gt;The PLL of LMK04828 has high power consumption and severe heating.&lt;/p&gt;
&lt;p&gt;&lt;img src="https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/5736.image.png" alt="image.png" data-temp-id="image.png-198636"&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK00334-Q1: Output rise/fall time at HCSL OUTPUTS for 100MHz case</title><link>https://e2e.ti.com/thread/1700288?ContentTypeID=0</link><pubDate>Wed, 25 Nov 2026 05:26:16 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:4755b5d0-ec97-46cb-9ccb-e826f264a91f</guid><dc:creator>Shotaro Sakai</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1700288?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700288/lmk00334-q1-output-rise-fall-time-at-hcsl-outputs-for-100mhz-case/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK00334-Q1" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK00334-Q1&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Hello team,&lt;/p&gt;
&lt;p&gt;Do we have a reference data for 100MHz case instead of 250MHz?&lt;/p&gt;
&lt;p&gt;&lt;img src="https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/8156.image.png" alt="image.png" data-temp-id="image.png-35535"&gt;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Shotaro Sakai&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK5B12212: configuration problem solving</title><link>https://e2e.ti.com/thread/1700083?ContentTypeID=0</link><pubDate>Tue, 24 Nov 2026 09:51:20 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:c5bd3858-0fa1-45fb-9395-8899ac0a4cd7</guid><dc:creator>Owen Yang</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1700083?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1700083/lmk5b12212-configuration-problem-solving/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK5B12212" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK5B12212&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Detailed Application Scenario for Our LMK5B12212:&lt;br&gt;Inputs:&lt;br&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;XO &amp;nbsp;: &amp;nbsp;19.44M OC crystal oscillator&lt;br&gt;&amp;nbsp;IN0_P/N &amp;nbsp; : &amp;nbsp;LVDS 10M &amp;nbsp;reference input (primary)&lt;br&gt;&amp;nbsp;IN1_P &amp;nbsp; &amp;nbsp; &amp;nbsp; : &amp;nbsp;CMOS 1PPS reference input (backup)&lt;/p&gt;
&lt;p&gt;Outputs:&lt;br&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; OUT0_P/N &amp;nbsp; &amp;nbsp; &amp;nbsp;: CMOS &amp;nbsp; 1PPS &amp;nbsp; output&lt;br&gt;&amp;nbsp; &amp;nbsp; &amp;nbsp; OUT1_P/N &amp;nbsp; &amp;nbsp; : CMOS &amp;nbsp; &amp;nbsp;10M &amp;nbsp; output&lt;br&gt;&amp;nbsp; OUT2~3_P/N &amp;nbsp; &amp;nbsp; : LVDS &amp;nbsp; &amp;nbsp; 10M &amp;nbsp; output&lt;br&gt;OUT4~11_P/N &amp;nbsp; &amp;nbsp; : LVDS &amp;nbsp; &amp;nbsp;100M &amp;nbsp; output&lt;/p&gt;
&lt;p&gt;Requests:&lt;br&gt;1. Please provide us with the latest version of the TICS software and a complete, detailed register manual. (I am currently using TICS V1.7.10, dated October 17, 2025.)&lt;br&gt;2. Please configure the TICS software according to our input/output scenario and provide us with the configured .tcs file.&lt;br&gt;Current debugging status: The oscilloscope shows a waveform on the &amp;ldquo;out&amp;rdquo; pin, but the APLL1 and DPLL1 registers are not locked; we suspect there is an issue with the configuration.&lt;/p&gt;
&lt;p&gt;&lt;br&gt;Translated with DeepL.com (free version)&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>DAC39RF20EVM: DAC39RF20 Setup Questions – FPGA Evaluation Board Reference Clock Options</title><link>https://e2e.ti.com/thread/1699913?ContentTypeID=0</link><pubDate>Mon, 23 Nov 2026 17:52:26 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:7529f842-1ddf-4ac0-9cf2-92a0ba181046</guid><dc:creator>Mohammad Chavoshi</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1699913?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699913/dac39rf20evm-dac39rf20-setup-questions-fpga-evaluation-board-reference-clock-options/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/tool/DAC39RF20EVM" class="internal-link folder tool" title="Link to Tool Folder" target="_blank"&gt;DAC39RF20EVM&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt; &lt;a href="https://www.ti.com/tool/TSW14J59EVM" class="internal-link folder tool" title="Link to Tool Folder" target="_blank"&gt;TSW14J59EVM&lt;/a&gt;, &lt;a href="https://www.ti.com/product/DAC39RF20" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;DAC39RF20&lt;/a&gt;&lt;/p&gt;&lt;p&gt;I am working with the DAC39RF20 Evaluation module on an FPGA TSW14J59EVM evaluation board and have a few questions regarding the FPGA reference clock configuration.&lt;br&gt;In my setup I have a signal generator that can produce signals in the 10 GHz to 20 GHz range for DAC CLK connecting to J7 connector . Is there any way to use this signal as the FPGA reference clock without needing to connect any other clock to the J8 connector?&lt;br&gt;Is it possible to use a non-coherent signal for the FPGA reference clock?&lt;br&gt;After pressing &amp;ldquo;Setup Ref Clocks&amp;rdquo; in the DAC39RF20 GUI, it determines the REF_CLK Input frequency. Is it possible to set this frequency manually and instead adjust the LMK parameters in the case where I will provide a coherent clock with the main DAC clock but at a fixed frequency?&lt;br&gt;I would appreciate any guidance or recommendations you can provide on these points.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK1C1103A: TCXO clock as input doubts. SNAA411 AN doubts.</title><link>https://e2e.ti.com/thread/1699899?ContentTypeID=0</link><pubDate>Mon, 23 Nov 2026 16:49:55 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:645f59d8-e396-488f-818b-b17da32ed8c6</guid><dc:creator>Mart&amp;#237; Bassas</dc:creator><slash:comments>1</slash:comments><comments>https://e2e.ti.com/thread/1699899?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699899/lmk1c1103a-tcxo-clock-as-input-doubts-snaa411-an-doubts/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1103A" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1103A&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1102" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1102&lt;/a&gt;, &lt;a href="https://www.ti.com/product/LMK1C1104" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1104&lt;/a&gt;&lt;/p&gt;&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;Dear TI comunity,&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;&amp;nbsp;&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;(Other parts applicable: LMK1C1101, LMK1C1102, LMK1C1104&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;Sincronous or asincronous component, it should be the same.)&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;&lt;br&gt;I&amp;#39;ve a question similar to the user who asked in :&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;&lt;strong&gt;LMK1C1104: LMK1C1104 minimum vpp when working with sine wave at the input clock&lt;/strong&gt;&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;&lt;br&gt;I&amp;#39;ve been reading AN SNAA411.&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;According to the AN, I understand the LMK1C110x clock buffers have been tested with TCXO and OCXO clocks, with very good results. In my case I would like to use the LMK1C110x buffer with a TCXO clock as input. My baseline circuit would be the following (taken from the AN):&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;&lt;img src="data:image/png;base64,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" width="356" height="180" alt=" "&gt;&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;with a TCXO instead of OCXO and a 100nF capacitor.&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;However, when I go into the details (output VS input impedances, voltage swings) some doubts rise.&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;&lt;br&gt;According to the TCXO manufacturer the max load should be 10kOhm // 10pF. I understand this is more or less standard amongst TCXO-type outputs. This would limit the resistance I use for the biasing circuit, that should now be at least R1 = 20k and R2 = &amp;nbsp;20k to have 20k//20k = 10k output dc load as seen by the TCXO. But this, coupled with the 50uA I(in-leak) of the clock buffer input, would give quite an unreliable biasing.&lt;br&gt;&lt;br&gt;Another issue. The TCXO voltage swing is 0.8Vpp. Again, I understand it is quite standard amongst TCXO-type outputs. The LMK1C110x inputs, powered at 1.8V, want a minimum of 0.72Vpp swing. It&amp;rsquo;s tight, specially with the biasing resistance reducing the output impedance as seen by the TCXO clock.&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;Maybe it works very well and I&amp;rsquo;m being overcautious, but I would really like to skip a trial/error step for things that I would guess have already been tested by someone else. Would it be possible to help me with the doubts above?&lt;br&gt;My questions would be: is the &amp;ldquo;Figure 4-5&amp;rdquo; circuit a good approach for a TCXO clock like mine on the LMK1C110x buffer input?&lt;br&gt;Is so, what biasing resistances would be advised?&lt;br&gt;&lt;br&gt;If the LMK1C110x buffers have actually been tested with TCXO clocks, do you have the exact input stage circuit used?&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;In the LMK1C110X datasheet, what exactly is the I(in-leak) 50uA current? Do you have test conditions? According to the datasheet the Clk input is pulled down with &amp;ldquo;typically 300kohm resistor&amp;rdquo;, which would account for much less I(in-leak). So, what about the remaining leak current?&lt;br&gt;&lt;br&gt;&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;Kind regards&lt;/p&gt;
&lt;p style="margin:0cm 0cm 8pt;line-height:107%;font-size:11pt;font-family:Aptos, sans-serif;"&gt;Thank you very much for your help,&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK1C1102A: a strong signal at the input</title><link>https://e2e.ti.com/thread/1699887?ContentTypeID=0</link><pubDate>Mon, 23 Nov 2026 16:02:07 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:40255301-8637-43da-add9-bdf9d9be0738</guid><dc:creator>new2day</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1699887?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699887/lmk1c1102a-a-strong-signal-at-the-input/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1102A" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1102A&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1102" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1102&lt;/a&gt;&lt;/p&gt;&lt;p&gt;We use LMK1C1102 for clock shaping and buffering. The input is AC coupled with a 100ohm pull-up and pull-down.&lt;/p&gt;
&lt;p&gt;We observed a strong signal at the input when no signal is applied. This strong signal is disappeared when followings were happening.&amp;nbsp;&lt;/p&gt;
&lt;ol&gt;
&lt;li&gt;disable the output by setting pin 1G to LOW&lt;/li&gt;
&lt;li&gt;terminate the output with 50ohm&lt;/li&gt;
&lt;li&gt;remove the 100ohm pull-up and pull-down stays&amp;nbsp;&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;It seems an oscillation caused by parasitic output-to-input feedback to me.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Any ideas?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;We&amp;#39;ve also observed that the current draw is higher when no signal applied to the input and it went down when a clock is supplied.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Was this normal?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Hopw to hear from you ASAP. Thank you very much.&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>SN74AVC4T774: Component Weight</title><link>https://e2e.ti.com/thread/1699865?ContentTypeID=0</link><pubDate>Mon, 23 Nov 2026 14:42:01 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:615d14c2-2496-4d1c-b458-0596b8bc3413</guid><dc:creator>Prasanth  M</dc:creator><slash:comments>1</slash:comments><comments>https://e2e.ti.com/thread/1699865?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699865/sn74avc4t774-component-weight/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/SN74AVC4T774" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;SN74AVC4T774&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;table class="MsoNormalTable" style="width:905.0pt;border-collapse:collapse;" border="0" cellspacing="0" cellpadding="0"&gt;
&lt;tbody&gt;
&lt;tr style="height:16.0pt;"&gt;
&lt;td style="width:905.0pt;padding:.75pt .75pt 0in .75pt;" nowrap="nowrap"&gt;
&lt;p style="margin:0in;font-size:12pt;font-family:Aptos, sans-serif;"&gt;&lt;span style="color:black;"&gt;Hi Team&lt;/span&gt;&lt;/p&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="padding:.75pt .75pt 0in .75pt;" nowrap="nowrap"&gt;
&lt;p style="margin:0in;font-size:12pt;font-family:Aptos, sans-serif;"&gt;&lt;span style="color:black;"&gt;My name is Prasanth M P from Flex. We are currently supporting our manufacturing plant in Migdal HaEmek, Israel, in collecting parametric data for all active components.&lt;/span&gt;&lt;/p&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;p style="margin:0in;font-size:12pt;font-family:Aptos, sans-serif;"&gt;&lt;span style="color:black;"&gt;we were unable to identify certain details such as reflow profile, Component Weight (g) , Failure In Time (FIT) Rate&lt;/span&gt;&lt;/p&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;p style="margin:0in;font-size:12pt;font-family:Aptos, sans-serif;"&gt;&lt;span style="color:black;"&gt;for some components from the available datasheets and website resources.&lt;/span&gt;&lt;/p&gt;
&lt;/td&gt;
&lt;/tr&gt;
&lt;/tbody&gt;
&lt;/table&gt;
&lt;table style="border-collapse:collapse;width:377pt;" border="0" cellspacing="0" cellpadding="0"&gt;&lt;colgroup&gt;&lt;col style="width:110pt;"&gt; &lt;col style="width:112pt;"&gt; &lt;col style="width:155pt;"&gt;&lt;/colgroup&gt;
&lt;tbody&gt;
&lt;tr style="height:14.5pt;"&gt;
&lt;td style="width:110pt;padding-top:1px;padding-right:1px;padding-left:1px;color:white;font-size:10pt;font-weight:bold;font-style:normal;font-family:Arial;vertical-align:bottom;border-width:0.5pt medium medium;border-style:solid none none;border-color:rgb(149, 179, 215) currentcolor currentcolor;white-space:nowrap;background:#4f81bd;"&gt;MFR&lt;/td&gt;
&lt;td style="width:112pt;padding-top:1px;padding-right:1px;padding-left:1px;color:white;font-size:10pt;font-weight:bold;font-style:normal;font-family:Arial;vertical-align:bottom;border-width:0.5pt medium medium;border-style:solid none none;border-color:rgb(149, 179, 215) currentcolor currentcolor;white-space:nowrap;background:#4f81bd;"&gt;MPN&lt;/td&gt;
&lt;td style="width:155pt;padding-top:1px;padding-right:1px;padding-left:1px;color:white;font-size:11pt;font-weight:bold;font-style:normal;font-family:Calibri, sans-serif;vertical-align:middle;border-width:0.5pt 0.5pt medium;border-style:solid solid none;border-color:windowtext windowtext currentcolor;white-space:nowrap;text-align:center;background:#00b0f0;"&gt;Component Weight(g)&lt;/td&gt;
&lt;/tr&gt;
&lt;tr style="height:12.5pt;"&gt;
&lt;td style="padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;border:1px solid windowtext;white-space:nowrap;"&gt;TEXAS INSTRUMENTS&lt;/td&gt;
&lt;td style="border-width:1px 1px 1px medium;border-style:solid solid solid none;border-color:windowtext windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;SN74AVC4T774RSVR&lt;/td&gt;
&lt;td style="border-width:1px 1px 1px medium;border-style:solid solid solid none;border-color:windowtext windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;&amp;nbsp;&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px;border-style:none solid solid;border-color:currentcolor windowtext windowtext;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TEXAS INSTRUMENTS&lt;/td&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TPS22916BYFPR&lt;/td&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;&amp;nbsp;&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;INA191A3IYFDR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TPS715A01DRVRM3&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TS5A23166YZPR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;PCA9548ARGER&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;SN65HVD75DR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;CSD68822F4&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TLV7011DPWR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;LSF0102DCUR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;LSF0101DRYR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TMUX1208RSVR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TCA9534APWR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TPS259824ONRGER&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;SN74LVC3G17DCUR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;LMK3H2104A02LRGER&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;SN74LVC3G07YZPR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;SN74LVC1G125DCKR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;INA293B2IDBVR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;TPS62865RQYR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;LP5912-1.2DRVR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;SN74LV1T34DCKR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;CD4072BM96G4&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;REF3025AIDBZR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;LMP7701MF/NOPB&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;LMP7701MFX/NOPB&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:black;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;SN74LVC2G17DCKR&lt;/td&gt;
&lt;/tr&gt;
&lt;td style="border-width:medium 1px 1px;border-style:none solid solid;border-color:currentcolor windowtext windowtext;padding-top:1px;padding-right:1px;padding-left:1px;color:windowtext;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;&amp;nbsp;&lt;/td&gt;
&lt;td style="border-width:medium 1px 1px medium;border-style:none solid solid none;border-color:currentcolor windowtext windowtext currentcolor;padding-top:1px;padding-right:1px;padding-left:1px;color:windowtext;font-size:10pt;font-weight:400;font-style:normal;font-family:Arial;vertical-align:bottom;white-space:nowrap;"&gt;&amp;nbsp;&lt;/td&gt;
&lt;/tr&gt;
&lt;/tbody&gt;
&lt;/table&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>MSP432E401Y: MSP432E401Y: ADC SSTSH3 Register Value Getting Reset to 0</title><link>https://e2e.ti.com/thread/1699811?ContentTypeID=0</link><pubDate>Mon, 23 Nov 2026 11:59:40 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:7bc4c356-8a11-472b-93b2-85c5ae8ebb06</guid><dc:creator>Harsha SK</dc:creator><slash:comments>1</slash:comments><comments>https://e2e.ti.com/thread/1699811?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699811/msp432e401y-msp432e401y-adc-sstsh3-register-value-getting-reset-to-0/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/MSP432E401Y" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;MSP432E401Y&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;&lt;!--ScriptorStartFragment--&gt;&lt;/p&gt;
&lt;div&gt;Hello Team,&lt;/div&gt;
&lt;div&gt;We are using the MSP432E401Y with TI-RTOS and configuring the ADC using the TI ADC/ADCBuf driver.&lt;/div&gt;
&lt;div&gt;Currently, the ADC uses the default sample-and-hold timing. For our application, but we want to configure the sample-and-hold duration to approximately 1 &amp;micro;s or higher.&lt;/div&gt;
&lt;div&gt;We are modifying the SSTSH3 register as follows:&lt;/div&gt;
&lt;div&gt;ADC0-&amp;gt;SSTSH3 &amp;amp;= (0x0000000F);&lt;/div&gt;
&lt;div&gt;ADC0-&amp;gt;SSTSH3 |= 0x6;&lt;/div&gt;
&lt;div&gt;After executing this code, we can confirm through the CCS Register Watch window that SSTSH3 is updated to the expected value.&lt;/div&gt;
&lt;div&gt;However, after some time, the register value is automatically getting reconfigured back to 0.&lt;/div&gt;
&lt;div&gt;Could you please clarify:&lt;/div&gt;
&lt;ul&gt;
&lt;li&gt;Why is SSTSH3 getting reset to 0 after we successfully configure it?&lt;/li&gt;
&lt;li&gt;Does the TI ADC/ADCBuf driver overwrite SSTSH3 during initialization or conversion?&lt;/li&gt;
&lt;li&gt;What is the recommended method to configure and retain a custom sample-and-hold time of approximately 1 &amp;micro;s when using the ADC/ADCBuf driver?&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;&amp;quot;Thank you&amp;quot;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>CDCE6214: CDCE6214 application</title><link>https://e2e.ti.com/thread/1699726?ContentTypeID=0</link><pubDate>Mon, 23 Nov 2026 08:58:45 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:f029a97f-cf36-4e09-a716-b244f7ea65a6</guid><dc:creator>Sean Liao (Yu-Sheng)</dc:creator><slash:comments>0</slash:comments><comments>https://e2e.ti.com/thread/1699726?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699726/cdce6214-cdce6214-application/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/CDCE6214" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;CDCE6214&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Hi sir,&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Customer is evaluating CDCE6214, when using TICS Pro simulation and checking datasheet. Here are few questions:&lt;/p&gt;
&lt;p&gt;(1) Frequency Plan check output freq display&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;Input: PRI = 25 MHz (+25 ppm)&lt;/li&gt;
&lt;/ul&gt;
&lt;ul&gt;
&lt;li&gt;Expected output: 156.25 MHz (+25 ppm) &amp;amp; 125 MHz (+25 ppm)&lt;/li&gt;
&lt;li&gt;Question is : In TICS Pro executes Calculate Frequency Plan, the Vco = 2500.0625 MHz, as attached pic. It&amp;#39;s not rounded, so after calculation, 156.25 MHz display ~156.253907 MHz&amp;nbsp;&lt;/li&gt;
&lt;li&gt;Is it just becuase TICS Pro Interface and Rounded result, or it&amp;#39;s chip limitation? In this setting, the real output is exact 156.25390625 MHz&amp;nbsp; and able to work normally?&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;(2) Output Swing &amp;amp; SoC LVPECL receving side impedence suggestion&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;Receiving side: Back side SoC pulse input is LVPECL differential input, requres differential Vpp in&amp;nbsp; 600 mV ~ 1600 mV, so customer add AC coupling cap&lt;/li&gt;
&lt;li&gt;Question A: in LVDS mode: Datasheet says the&amp;nbsp; LVDS Vod Typical is 0.3V (Max 0.45V), turns differencial peak-peak is ~ 600 mVpp, which is under SoC spec low boundry. Is there any way we can adjust&amp;nbsp; LVDS swing to increase? If increase LVDS swing, is there any caution on waveform distortion, jitter, or any?&lt;/li&gt;
&lt;li&gt;Question B (change to LP-HCSL mode) If change to LP-HCSL + AC coupling to connect SoC, would LP-HCSL swing over SoC 1600 mVpp spec? Can adjust lower in TICS Pro to let LP-HCSL&amp;nbsp; swing smaller? Besides, if changed to LP-HCSL mode, is there any caution?&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;Thanks!&lt;/p&gt;
&lt;ul&gt;
&lt;li&gt;&lt;img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAA8IAAAFYCAYAAACYiUWhAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAP+lSURBVHhe7L13nBzHdeD/7clhc867SIsciECQIAEGkBQzFShLsuQzz9m+sy37bF/y74LvfD5btmzLp2gF05IoijlngiRyzmkDNue8k2P374+Znu2p7dldEgAJivX9fGanq+rVq/emeqf6TXVXKZqmaUgkEolEIpFIJBKJRPIJwSJmSCQSiUQikUgkEolE8ouMDIQlEolEIpFIJBKJRPKJQolEIvLuaIlEIpFIJBKJ5BcEi8WCzWbDYpFzXhJJLpSuri4ZBUskEolEIpFIJL8AaJqGw+GguLgYt9stFkskkjRKZ2enVlhYiM1mE8skEolEIpFIJBLJxwRN04hGo8TjcQoLC/F6vaKIRCJJo3R1dWmlpaUyEJZIJBKJRCKRSD7GaJpGJBIhEolQUFAgA2GJZA7kgwMSiUQikUgkEolEIvlEIQNhiUQikUgkEolEIpF8opCBsEQikUgkEolEIpFIPlHIQFgikUgkEolEIpFIJJ8oZCAskUgkEolEIpFIJJJPFDIQlkgkEolEIpFIJBLJJwq5fZJEIpEsAE3TUJMJksk4aGKp5FrBYrVhs9sBRSyahaapJBNxVDUp+/TDRAGLxYbVZkNRcv8en9RUVDUpu+Z9oqBgtViw5PhsNU1F01TkSf9xR0FRLLP+h+T2SRLJwpGBsEQikSyAZDKOf2IE/8RQKsSaP86SfJhooGoa3sJSiivqsVjnH9Ni0TC+iSHC/knZnR8imqbhyiuiqKwGu9MtFkM6RPNF/EyEpkmoCfn/tkA0DexWG6XuIvJdXhSTDy4WCxKJTJFMRtFkLPyxxWKx4fGU4HB4swYkGQhLJAtHBsISiUSyABLxGOODnUwNd+FyWrFaZ19gSj46kkmNSDSBt6ia6qaVWO0OUWQWkZCfsYEOov5R3C6rDLY+BDQVwpE4Dm8ZFfXLcHnyRRFIX8z3TA/SPtFFTIljsYoSEjPUJDg0B8tKmqgrrMKiZJ/Umqbh9w8wPt5OIhHAYj5pLLnGUVUNi8VJWdlKCgpqUQz9LANhiWThyEBYIpFIFkAiHmVsoIPQRA8VZXm4XPI781oiGk0wOhbE6imnZtHqhQXCQR+jA5ewJaYoL/PIOPhDIKlqjI4HSVgKqKxfjstbIIpA+mK+c7KP9kAX1hINZ578f1sIUX8CddLC0vwmGotqTQJhFZ+vj7GxFtzuGHl58/+fSK41NAKBGKGQQlnZagoLG2UgLJF8QGQgLJFIJAtAD4TDk73UVObjdttFEclHSDiSYHjEj+Iqe9+BsEOdproyTyyWXAWSSY3h0QBR8uYPhKf6uBTswl6u4C6U/2/zokF4Ok5iDJZ45w6Ex8dbKChIUlzsyiqXXPtoGkxPR5ieVikpWSUDYYnkMpA3xUgkEolEIpF8olBQFPn6eL7EvpRIJB8UGQhLJBKJRCKRSCQSieQThQyEJRKJ5GNCJBpjbHyK0fRrfGIanz9IPJ4QRSUfMaqmEQxFGB6doH9wlMHhcaZ9ARKJJJFojIGhMbp6B5n2BdCu0aV7p30BLnX1Mzg8TiwWF4slEolEIvlYY/3qV7/6PzweDxa5dKBEIpHkRFWThPyTJCI+8vOc2O0f7jK2mqZx5vwlnnxhF8dOXOD4qYucPtdOd+8wSVUlz+vB6bCjfELvm0skVILBGIrNQ35xBRbr/P2TiEcJ+SexalHyr+CiQfF4gv7BUfYcOMlLr+/h7d1HOXaqheHRCbweFxNT0/z0ydd46fV9eL1uFjXUYLVeW2NwMqny5ntH+IdvP87QyASLG2vJz/Nc9vmlaRAMxUjiIK+wDJvDKYpkmIr4mIxPYfUq2F3z96eOpmlEQ1Gmx6aZHpsmOB0kGo5isViwWC1MDE8w3D0MgNPtvGyfrgaRYITR/lGmx6ax2W3YnQt7RjoRVVFDUOIooshVYOKbRjTqIxwex+XScLvnXh8mGo0TDEYIh6Mkk2rqM/wYXS8mkyrRaJxYLEY8niSRSAJgsaRuM54LTYNQKMLEhI9wOIrNZsVmW/h5eDWJRBJEoxpudzkuV9EsXxKJBIlEAqfTicNx5b7bJJJfNGQgLJFIJAvgWgiE337vCF/7p59w5mIHfYMjXGjtYvf+k5w404LX42ZxUx12u41YPI4vECIYDBOLJ7BYFKxWK/FEgnAoQjyewGKxoCgK8XiCUDiKpmpYrRaSSZVQOEI8kZKxWCzEYnH8gRCBYJhYPI7FYsFqtaKqKpFojEgkhqZpqKpKNBZHUZQPfUy5VgJhVdW41NXPj376Ij987EXOXexkbGKa3v5hDh45SzKZpLKshDffO8yF1i5WLGtiUWMNoUgETdOw22woikIikSQYiuAPBAkGI8RiMRQl1Y+Kkgq2Q+EIyUSSRDJJIBgmGo2hWCzYLFZUTSUSiRGJxtBUlWgsQSAQIpFMYrNZM4soqWqqv/3+UOo80MBmtaBpGvsOneaZl96hIN/D1k2rKSk2C6zeH1c7ENZUjYnhCU68c4JdP9/F7md3c3zXcTrPdgKQV5THmz99kx/+fz/EZrexdMPS1GKhl+fWFUVTNbrOd/HE159gzzN7KK0ppXZJrShmypUKhBOJJENDk5w82cbevWc4fryVnp4RYrEEbrcDp9Nhons2kUiMgYFxhocnsFqtuFxX5v8MYHh4kp6eEVRVxe12zPrO0TSNyckAJ060cvx4G62tvXR3DzM6OkUoFMVqteB02mbV01FVlZMn23j66d1cuNBNRUURpaWFothHggyEJZIrgwyEJRKJZAF81IGwqmkcOXmB517ZzYqlDfz6lx9g/eplDA6NcfjEeRwOO9u2rCGRTHLydCtvv3eYA0fPcqmrH03TKMj3Mj4xzYEjZ+jqGcTtcmK327jQ1sW+g6eIxmJUlpfQNzDCO3uOMTI2SUlxAZFIjBNnWtm9/wSHj5+j7VIvAEWF+YTCUU6eaeXYqYtMTPnpHxyhq3uQvDwP+Xke0YWryrUSCAdDYZ575T2+++hzWC1WHrx7O7/+lQfYfsMGlPTnVltTzpHj5+kfHKOirIjxyWkOHD7LxKSP4qJ8PG43vf3D7NpzlHf3neDIifO0tPcQCUcpLMjH5XRwqaufd/ceo7tvmJ7+YfYeOMXZCx0AlBQXEApHOHryAkeOX2B4dIILbakfTQaGRikuyqcg30s0FqezZ4D9h86w58BJTp5tY3ximoJ8Lx6PixNn2ti9/wQNtVXcfMN6Sq/1QFiDqdEp3vzpmzz9jafpPt9NLBoj7A/Tf6mfsD9MeX05bSfaOPjSQRatXcSy65YRDoSJRWNYrVasNivJRJKwP0xgMkBgOkAkEEFNqlhtViwWC4lYgpA/RDQSJRlPEvKHCE4HQQOr3YqiKERCEYK+IGpSJRaJEZgKpGalrakfkVBSgVYkEME/6Sc4HSQei6d+6LAqDHcPc+ClAwz3DLP6xtU0rWoSvTXlSgTCyaTKpUsDPProa3z/+69w/HgLFy/2snfvGQ4ePIfFYqGxsRK320kyqWXNsqqqRjKpoqoaqqrR3t7PP/3TM/zsZ29TUVHE4sXVKIoul6qnqiqxWCK9N64FJf3ZJBJJNE3L+JBMqiQSKoqSmqn+l395jf/7fx8jmVRZurQWpzM7GNY0jdbWXr73vZf48Y/f5MSJNo4da+WNN46wb99ZwuEoVVWl5Oenvqt0u0FB01J+tLf3cfDgBaLRGCtWNFJeXkgymbJBtyuRSJJIqJnPIJWXIBKJEY8nUBRLJj+ZVEkmZ/xKtZfSpaoasViCWCyenn3PPWstA2GJ5MogA2GJRCJZAB91IKxpGifOtPLGrkMsX9rIQ/fsoKmhhv7BUU6cbqGhvoqtm1Zz8Og5/vG7P+fg0bMMDI5y+Ph5Tp5tJT/Pi6pqPPXiO7z53mEKC/Jwu508/syb/POPnycUjrJuzTIOHT3H3/6/nxKJRlm9Ygn7Dp3mWz98hnMXO5mY9HHo2DlOnW2npDgfq9XKUy+8w0+efI1jp1rYe/AUvQPDNC9poLa6XHThqnKtBMK9AyM8+9K7HD5+nnvv3MYf/NYvsXrFYhobqlm7agmrli8iEo1x4MhZWtt7GB2f4nxLB/sPn+HQ0bO43S5WL1/E6XPtPPH8Li60dNLZPcCho+fYd/g0bpeDFcsa2XPgJF//1mPsPXiScxc7OHj0LO/uO87QyDhLF9WRVFX+9fFXePTxlzl1ro1TZ9vYc+AU+w+fpiDfy+oVS7jQ2sV3/uVZXn3rAFPTfi60drFrz1FUVWPZ4noutnWz79ApmuqrPxaBsKqpnNl7hpe//zIjPSPc+MCNfOE/fIEdn9tB3dI63HluyuvK6bnYw/mD56lqrCIaiXLo1UN0nOnA6XZSVF7E9MQ0J945wb4X9nHyvZOcP3iekb4RXB4X3iIvY4NjnHj7BC1HWxjoGODU7lMcf/s4/kk/haWFuLwuWo+1sv/F/Qx1DdF5rpNDrx6i/WQ7VpuVwvJCLBYLIz0jHH/7OEdeP8KZ/Wfoa+kDBfKL85kaneLU7lMEfUE23LrhQw2E/f4QTzzxDj/96VvY7Vbuv/8Gdu7chKZpnD7dQXt7P9XVpTQ1VdHbO8KFC91oGuTluZmeDtDS0svIyCSgcOFCNy+8sI+OjgHKy4vweFzY7TZGR6c4d66LyckA/f1jnDvXyejoFE6nDafTwdjYNK2tvUxO+vF4nFgsCu3t/bS09GKzWZmaCvDss3vYv/8shYVevF43TqeDggJ35npWVTV6e0d4/fUjXLo0wPbt67j11g3YbFYuXuzh2LFWnE47S5bUEo3GaGnpZXBwnFAowsDABJFIFI/HRWGhlyVLamloqGB4eJKWlj4UJeVvPJ6gvb2f1tZe7HYbbreT0dEpzp/v5uTJdi5dGiASieFyObDbbQwNTdDS0svEhJ9AIExPzwiapmGxKPT0DHP6dAfnznXR2ztKPJ7E63Vit9tnrRQtA2GJ5MogA2GJRCJZANdKIPz6rkN43S48HjcXW7vYc/AUsUSCHTduoLK8hCeef4vW9h7uueNGfuPfPISiKLy+6xDxRJJN65czNDzOu3uPU1ZaiMfl5KU39nKpawCrxUJtTTkXWjo5cvICmzasoKK0mJ8/9xbdvUPcctNGbt++iXA4ylu7D+N2OWleUs/Bo2c5euIiRYX5rF2ZCvTWrFhMacmHewvhtRIId/cO8frbh+jpG+ZTt2/l/k/djN1uw2azkp+eKR8eneDAkTMMDo+z7fq13HfHTQTDEQ4dP09FaTE3bV2H0+mgtKSQLdetZPnSRian/Bw6fo6S4gJu2LyGi23dvPT6PooK83no3h0sWVRHS3s3o2NTrF65mPLSQt567whnzrdz45Z1PHTvDnz+IEdPXKCqspRVyxfx5ruH+PETr7JiWSOf//RO8vLcnG9N3crd1FDD2MQU+w+f+dgEwslEksOvHWbPs3uoX1HPvb9+L+u3r6ekqoTqxdU0rmyksLyQcwfPcXrPaWLhGCM9I7Qea+XcgXMk4gnqm+sJBUIc33WcrrNd+Cf9XDp1iZPvnSQajlK/rJ7xgXFee/Q19r2wj+7z3fRc7KHlSAstR1soLCukcWUjh149xHPffI6Woy30t/fTfrKdcwfOEZgKUN9cj5pQeeWHr/D2Y28Tj8VJxpKcePcEHWc6qGqqwmqzfiSBsKqqXLzYw1NPvceFCz089NBN/Nqv3ct11y2joaGSrq4hjh5tobKyiObmep59djd/93dP4nY7WbWqkdOnO/jmN5/lyJGLFBV5OXGinV27TuDzBRkdnaK/f4yKimL27j3N1772OMeOtXL48EVeeukA77xzgkQiSVNTFceOtfJP//QMFy/2sHhxDTabje997yW++90XqKoqZnLSx3PP7WVgYByfL0h7ez+FhR6WLavD4UgFjpqmMTAwxt69Z5iY8PGlL+3kS1+6g02bmgmHYxw/3kogEGbFigYGByf4f//vGV5++SDHjrXyyisHCYej+HxBnn56N11dQzQ0VPDee6f4f//vWRKJJMuW1TI4OMG3vvU8zz67h/r6Cmw2K48++jqPPfY2x461ceDAOfbuPYPVaqG2tpz33jvJN77xDHv3nmH//rO8+OJ+vF43Y2PTfPvbz/PSSwc4deoShw9fpLNziNraMqqrS2b1owyEJZIrg4x+JRKJ5GOEpml09gzwxHNv89Ibe4nH4zx093Y+c98tBENhLnX1U1ZSyPUbV7Fx3XLWr16G02FncGgURVFYvrQRRVFo7+zn2OmL+ANh1qxczLQvyJ79J2nr6KWmqpx1q5cx5fPT3tnH6PgUh4+f5/lX99De2YfX484sQgMK+fkebrnpOr76O1/klx/+FA31VaLZnxhSz2Nb0DSVeDxBMn3bKEAy63ZPKCzwsnHtch64eztbNqzEoigEwxECwTC+QJCTZ1p5/Jk3eerFdzjf2kkkEiMYiqQ/9xR1NRXcetNGbr3pOpoaqgmHowSD4Uy5x+Nm3eql3HfnTWxctxy3y0koFGF0bJLevhHGx6dpvdTDc6+8x+Hj51FQUIBAKJTR8XEhEUsQmAoQCUYoriimrKYsdauyRcGd56awrBCnOxV4WywWlmxYwsN/+DDbP7sdi9VCz8UeRvtGKSot4vq7r+dTj3yKWz53C8s2LiMRS9BxpoPBrkFi0RghXwhN1dh0xya++KdfpHlTM4Odg/S39xMNR4mEIvgmfJTXlfPg7zzIXV+5C1eeK9PGpdOXOPHOCRSLwuptq9l05yYKywo5u/8sHWc6UJMqGh/+auKqqjE8PMno6BR5eS4WL66hujp1+/Dy5XU0NFSQTCYZHp5kctLP+Lifnp5hpqdTq58HgxEGB8cZHp7EarWyYkUDtbXl5OV5uOmmtTz00M00NlYyMeGnt3cEi0Vh+/Y1bNmynIkJP2+9dYzW1l4CgTD9/WOMjEwRi8VJJFRGR6fp6RkmFIqybFk9ixfX4HDYWb16EZ/73A7Wr1+G0zl79hRAUSx4PC6Ki/Ooqytn3brFlJcX0dMzwvDwJMFghIGBcc6f72JoaJzCQi/FxXlEIjEGB8fTM9xQWVlMLJbIBKpnz3Zy6tQl8vM9FBXlsWvXCV54YT95eW4efngHN920hqGhCV599RDt7f34fEF6e0fSs+F+yssLsdutvPPOCd599yRlZYU88MCN3H//DSxfXp9+ptrEIYlEckWQgbBEIpF8jFAUhfqaSu6/6yZ+41ce5L/96a/zh7/zBdasXILDYcdqsaQCrmQq6Eokk2gaWCxWHHY7jfVVLGqo4WJrF7v3n6CwII+dO7ZQUOBl/5EztLb30FBXydpVS7DbbVgUC3leNyuXNXHrTRv5pU/v5Hcf+Sy33rwRdzqosFmtFOR7qawooaS4AKdjYSvc/iJSXFRAVWUpSVWjpb2Hk+faGJ+cZmximrMXLtFyqSfzbKTVYsXldJCf58HrdacXINMYnZjijXcO8cTzbxONxbn/Uzez/YYNuN1ONE1DM2y3ZLfZ8HhceD1u3M7Z5RaLgsvpIM/rxutxYbPbUuVa6lyyWCzUVldw89b1PHTPdn7tyw/w2ftvo6m++mN3p5jFasHmsGGxWogEI8TCsUyZqqrEojESiUTG96rGKlZtW0XzxmZKq0uJR+NEQhGmx6c5vec0r/7wVd748Ru0n2gnHAwTCUWIhqMphUpq4a2mVU1cd9t1NKxoQNM0ouEoifR2ZoqiUF5XzorNK2je3ExpVSmxSIxoKMrk8CTjA+MMdQ2x+5ndvP6vrzM1MkVxZXHq+diPcEs0TUsFxIqS+lFHf75VXyRPUVLP0OrPt5qhKOB2O1m0qIaqqmK8XhebNjVzxx0bqasrg/S5uWJFI/fffyMPPXQzTU1V9PWNMjIyJarLwmJRaGqqor6+ArvdSnNzHXfdtYWVKxuw22ff6i2in/epH6xm/LBYFJYsqeE3f/MB/uqvfpMHH7yJoqK8zGyr3W5l/folLFlSTWtrL+fOdXH2bCfj49Ns2LCMmppy2tv76e0dYWLCz9mznfT1jWK1WvD5gvh8QQCsVgvXXbeUP/qjz/NXf/Vb3HrrBvLy3FitFs6f7+Kdd07S1zdGTU0plZXFs2Z7JRLJlePjNcpJJBLJJxwFqK0p5547tvG5+2/n1ps30lBbhdNhp7qylJXLFzEx6eO9fSfYtfso+w+dJpFIsKSphsqKEmqry1mxrJG+gRHaOvporK9ix7YNLFtcT2f3AEMj4yxqqKGhtpK66gpWLW8ikUwyNjGVCdqm/AEGh8blBZoJFaXFbLluJUsX1XHkxHn+/luP89MnX+dffvYSf/n1R3n+ld1ZM7o6qXlYAI1wOMro+DTBUJjionzKS4tQLKngIxeKMv/EkaLMtJKX52ZRY+qc8PkCBENh8vO8KIrCxJQPfyA0Z3vXIla7lfLacoorixm4NMDFoxcZ7RtlYmiCnos9tB1rY3xgPOWXkpK3O+w4XU7sDnsqKEqonN59mjcefYOQL8TWe7ey/bPbqWqsygSAOharBZvdlqrvTG9dpqUW7crYZLNic9hwOB3YHKkfITQ07E47dped4spiNt+xmXt/7V6+8Cdf4At//AVWbl2J9SPapkdRFMrLCygtLSAYjGSCulgsTnf3MP39qTtLysoKKSxMnS+kV4cOh6OZhZ5IB5YOR+qxAACHw47b7UotFpZqDbfbQV6eB5crtdCVrk9RUgtFxWJxIpE4Uf1HjDSpxw1SK6xbrVbcbgcORyptjkYsFicUijAyMsnFi92Mj/uoqyunvHzmMQ6Px0V1dQn19RUUFeVlbWtmsVhoaqpmxYpGwuEo7757kqNHWygpKWDt2kXk56eeGVZVFYfDTmlpAatXL+KBB7Zx++0bKStLtaMoCvn5Xmpry6ivr6C0tJBbblnPgw/eRE1NGd3dQzz//F4effR1zp3rQlVTn6dEIrnyyEBYIpFIPgYoQEGeh6aGamqqyilJr/zrdqUWklEUhSVNdXzmvltY2dzE4ROpRbOOnLjAzTes56F7b6GstIiK8mI2rG2msaGa5UsbuW5dM8uXNnL9xlXU1VSwfGkja1YuweVysmxxPQ8/eDvr1yzjUlcfP/jpC3zrh8/w7t7jjE9OY7fZKC8toramnIL8mYviTzJOp52dOzbzu//2MyxbXE9Lezc/e+YNnn3pXUbHJsnP8+B2OakoL6Gmuhyv142iKBTke2isr6K8tIiqihLWr1lKY10V5y508OMnXuVSZx/VVWWUlRSlnjfO91BfW0lZWRE2mw2Hw0FFeQl1NRXkeT047HYqyoqpr6kgL88DChTke2moq6SstAivx83OHZv58sN3o1gsPPvye3zzB0/x+LNv0tbRi6qq5Od5U22Upm7fvNaxWCwsu24Z67avIzAV4JUfvMKP//LHPP2Np3n0Lx7l7cffZnp0enaAbzhtNU0jFo2lVnxWVVAhHAinZoJz/S6gGH/IyIFBRlEUahbX0LC8gcBUgIFLA/gmfEyOTNJ2so3RvlEsVsv8Oq8CFovCokU1bNy4DJfLwbvvnuC55/awb99Zfv7zdzh2rJX6+grWrVtCZWURHo8TqzW1+NR7753i7NlOJicDGX1Opx2Hw0YoFKGra4hLl/rx+VK33WuaxsjIJBcudHHw4HkGBsZobKykqqoEj8eFw2Gjr2+Uw4cvcODAOQYHxw2Wgtttx263MTAwxvnzXYyOTmVWsDaiaRrRaJxz57p49dXD/OAHr/DSSwdRFIXt29exdGldlvxcX2Nut4NNm5qprS1nz57TnDnTwbp1i1mxooH8fHc6gM7HalVoaKji+utXsmHDUqqrS01mq1M/rAQCYUKhKNu2reH3f/8zPPjgTXi9Lrq7hxkf92X/siKRSK4ocrEsiUQiWQAf9WJZAF6vm1XLF7FtyzoWNdXgEvbytNttVFeWsWbVYpYtrmfFskbuuGULn77vFtasXIzL6cBus1FaUsi6VUvYuX0z129cRWV5CeWlRaxavojbbt7ExvXLKcj3YrfbqKksY8PaZtatWkLzknrWr1rGPXfeyM7tm6mqKKGqopT1q5exfu0yykuKMrdRfthcK4tlKYqC1+NmyeI6Nq5rZvWKxaxavpibtq7n4Qdv45ZtGykrLaK2qpwNa5tZu2IJxcX55HndrFjWyA2b17BkUR2N9akfKlY2N3H79s3s3LGFGzav4cbNa2isq6KwII/lyxrZumk1TQ3VeD0uqivL2LR+OetWL6WstIiqilKuW7ec9auXUlJcgNfjYWVzE9dvXEVjQzUVZcWsWrGY69Yuo3lJAyubm7hp63ruum0rq5YvoqykkBXLmtiycSWNddU4HelZz8vgai6WpSgK3kIvReVFJJNJpkamGO0dZaRnhHg0zuK1i2ne1MzYwBhjfWOsvXktzZua8Y37GLg0gLfAy6qtqyivKycwFWB8YJyxgTGi4ShWu5Wy2jJWbV2Fy+NisGMQh9vB6htWU9VURU9LD0PdQ6zYsoIVW1Yw0jPCUNcQyzYsY+X1K4mFY/S29WJ32lm3fR3Nm5pxup34J/0Mdw/TfaGbngs9REIRll23jOKKYnpbe7HZbay7ed2Hto+woig4nXby8z0EAmE6OoY4deoSu3ef5uLFbvLzPTz88K3ce+9WiovzGRmZorNzkJ6eYS5c6KGvb4RYLEZ9fSXbtq2hrq6c9vYBOjoG6OsbpaNjgLKyQrq6hjh8+AITEwFOnWrn5Ml2nE4HDz54E7fcsh6bzcqlSwPp1yCXLvUzMeHD5XJw223XsWbNIoaHJ+nuHqa7e4hz57pSdzksqs4slgUao6NTnDp1iaGhSYaGJjh16hJtbf24XA7uv/9GPvOZ7dTWltHfnwqmCwq8bNu2htracjRNo7t7mPPnuykuzmfbttXU1JTjdjsz7RYV5fGZz6SeBXY6HTgcdiYmfHR2DtLS0suRIxc4fPgCfn+IFSsaCQTCtLX10dRUyfXXr6S0tIDJST+vvHKQ1147REtLH52dg0QiMTZvXsEdd2yiqqp0Vj/KxbIkkiuD0tXVpZWWlqY2lJdIJBKJKYl4lLGBDsKTvdRU5uN2f/jPwSYSSWLxBFarBbvNljPoTCSTRKNxkskkdpsNhzP17LCxPLW/pYLdZsNqtWTyLIqSejbYIJ9UVeKxOPH0bIvDbsPusIOWuuBSVRWbbeYWyI+CcCTB8IgfxVVGzaLVWO3zX/xFgj5GBy7hUKeprswTiy+bRCJJNJbqB4vFgtNpx26zoaoq8UQSTdWw2a3YrFYSidTnb7VaMjNH0ViceDyBI90fiUQyU55MqsQTCayWVFrTIJ5IoKkqtvSz3fF039jttpk2DHWU9K2+iUSSWCyOqqlYLVYcDjs2m7n85ZJMagyPBoiSR2X9clzeAlEE9EXhpvq4FOzCXq7gLlz4/1ssEmN6fJrRvlGmRqawWC0UVxRTUV+Bt9DL+NA4Y/1jlNeVU15XTmg6xEjfCGhQXleOw+1gtHeUoe4h7HY7BWUFJOIJrFYr5XXlWKwWRvtGSSQSVNRXUFBSwEjvCKO9o5RUl1BRV8Hk8CQjfSMUVRRRUV+RWqG6d4RELEFFY6pOOBBmcniSieEJAlMBrDYrJVUlqduwLUoqgI/FqWyspLB0AauwaxCejpMYgyXeJhqLarEIfaZpKj5fH+PjrRQWJikudmWV60Sjcfr7Rzl5sp3z57sJBMKUlRWybt0S1q9fQllZIRaLwvDwJHv3nuHChW5KSvKpqirF7w/h9bq44YZVVFeX0NbWx6FDFxkYGKOsrJAbb1zDk0++w3e+8wK33LKBTZuasdksLF/eyJYtyykvLyIajXH8eBuHDl0gHk+wdGkt8XiCiQk/N9+8lnXrFjM6OsWRIxc5e7YLTdPYvn0tmzevwOlMnSuapjE4OM6BA+fp6RmG9Ax1cXE+ixZVs2RJDcXF+VgsFjo6Bjhy5CJ2u5UbblhNXV05qqrS3j7A0aMXcbkc3HDDKmpqyojF4hw6dJEzZy7h8TjZtm0Ny5bVoSgK4XCUrq7UjwddXamANi/Pw+rVTWzc2MzQ0DjHj7dRXV3Cli0rKCkpJByOcuJEG8ePtzIx4cdqtVBXV87mzctZurQ2vWDWDJqmMTUVYXpapaRkFYWFqQUQjeWRSIRIJEJBQQFerzervkQimUEGwhKJRLIAroVAWJKbazEQlszmwwiEIRUUJpNJkvH0wmR2a+a5W1VVUZMqFosFi75gUua5VguKRcksWKWkn0HVb6e2WCygkJFXLKmFl7J0WiyoWiqtl8NMHb0N0n4mE8lMmc2eWuzLzKZ5uYKBMOnPKRKJEQpF0z92WfF4XOmVmVN6VVUjHI4QDsew2azY7akfeoDM3rmJRJJwOEo0GsdqtWCz2fj613/O97//Co88cje/9mv3UFjoxeVy4Eo/6gEQjcYIBiNoWkqXpmnE40ncbgculwNV1TLPJmuahsfjxO12ZgWFiUSSSCRG3LCAmc1mTf0oZbhVOR5PEImkFldzux2Za+LsfGfmx75IJEYkEkstRudy4nDM6Eom1bS/MVRVw2q14HI5cDodGXtsNgsulzOzYFc0GiccjhKPJ1GUVMDu8bhMf1yUgbBEcuWQgbBEIpEsABkIX9vIQPjjwYcWCH8SucKB8NUiHk/ys5+9zUsvHeC++27gs5/dTn6+RxST5EAGwhLJlUM+GCyRSCQSiUQi+VCw2aw8+OA2vva13+HBB7fh9X74wbhEIpEgA2GJRCKRSK4+yaSKPxBibHyKaX+QuGErmHA4ytjENOMT0+nbPLOqSiS/UCgKFBXl0dhYmXlGVyKRSD4K5LePRCKRSCRXGZ8/yLt7j/O9f32e515+j87uAZJJlVg8wfHTLfzwpy/y4yde5fiZFpLJ2VvASOZH0zSCviBj/WOM9o0y2j/K+NA4gakAifQzoqQX0xrpHaHrXBeTI5No6ty/PERCEYa6hui52MP02OztlzRNY2pkis5znYz1j2W1JZFIJJJrF7l9kkQikSyAa2H7JElurpXtk3IxPDLB48+8yb/87GXOt3RRWJDHmhWLGRmb5F9//io/+PELXGzrprqylA1rm0kmVULhCFr6VtJEIkkoHCWeSKCgEI8nCIUjJFU1teAOEInGCIUiaJqGNe1/NBrD5w8RCIVR07L6eJ9MJgmFI/gCIULh1IJIFkP51eBqbp8Uj8Y5sesEb/zkDU69d4pz+8/Rdjy1L6+qqrjz3Niddkb7Rnnj0Td46fsvYXfaWbRmERaruc+aqtHX2scrP3iFd598F3eem/rm+ix5VVV5+7G3+cGf/4BIKMLitYtxfUS3+17u9kmSjwdy+ySJ5MogA2GJRCJZADIQvra51gPh8Ylpdu05ysGj55ia9uP1ulm7ailtl3p5/Ok36OjuB0Vh4/rlbFy3nNb2Ht7Ze4x4PEF1ZSnDo5PsP3yazu4BXC4nI2OT7Dl4kv7BUfLzPCTiCQ4dO8exUxdRgOKiAkbHJzl07Dzv7T/OsZMX6R8cxWqxUpDnJZFM0t7Zx+4DJ9m9/wQnz7QyNDKOx+2iqDB/1iJLV4qrGQhHw1H2Pr+XV3/wKsM9wwSnggx1DXF672nOHzyPw+WgqrEKTdMYHxwnHouzZP0SyuvLCflDJBNJrFYrFouFWCRGcDpIPBYnGo4yOTyJoigsWb+EmkU1AEQCEXwTPkL+EMd3HefQK4eob65n3fZ1uPPcxKNxgtNB/JN+Qv4QGhq29DZU0VCU4HQQNammVmcOpn/AsFmJBCP4J/wEpgNEQ6kVka0264JWjpaB8CcDGQhLJFcGGQhLJBLJApCB8LXNtR4IT0752HvoFK3tPbhdThLJJF6Pm47uAQ4cPZPZduf6jatYt3opr7y1n7//zuM4HXZu3LKWC61dfPtHz3DyTCvLlzWiqio/fuJVXnlrPzarhYGhMb776LO0Xepl5fJF5Hs9/PTJN/jRz15icHiMoeEJ3nz3MB1d/SxeVMvY+BT/9P0neeK5txkcGqd/cJSzFzrwuF2sWbkE2wI+vw/C1QyE49E4p947xcn3TnLdbdfxxT/7Iuu2ryPkC3Hx8EXGBlJ7B5dVlzHaP0ooEKJ+WT0hf4hDrx5ifHCcgpICnG4n7afaOfjyQfyTftx5bnwTPhKJBA3LGyitLmV8cJxjbx1j73N7aT3WSvvJdgY7Blm2cRnrtq9DVVXajrdx5PUjHN91nPMHz+Ob8FFQXIDL66LteBv7X9rPWP8YY/1jtB5vRVFS2zadfPckB185yOndp2k73kY8GqeooginsDWQGTIQ/mQgA2GJ5Mogo1+JRCKRSD4kPG4nK5ubcNjtPPX8LnbvO0FDbSWrli/Cmr7dVtM0AoEwQyPj+AMhNCAaizM+Mc34pI9EIsnypY3cdP06gsEwjz7+Ct/8wVMMj0xw09Z1bFi9jHMXO3j5zX0k1SQ7d2zh3ju3UVJcwJ4DJzlxuoXWjl4OHD6Dw27n7p038OtfeZBP33sLi5tqM3Z8bFEgryiPhuUNbLhlAzu/tJPF6xZz6dQl2o634Z/003qslQMvHqCnpQffuI/jbx/n1R++SuvxVgJTAY68cYQXvvsCnWc7CfqCnD94nsOvHWawYxD/hJ93n3qXn/3Nzzj06iEuHrnIUOdQZt/fZCLJuf3nePxvH2fPs3uYHpum63wXT/3DU7z12FtMjU7RdrKNl773Ek98/Qme+PsneOuxt2g72cbuZ3bzk//zEw69doihriE6z3Zy7uA5RvtHZz2bLJFIJJLL42M+2kkkEolE8vHBarWybvVSNq1fTltHL5PTftatXkpFWbHp7cgaWmqDWIHCAi9377yB227eSE/fEBdbu9i4bjkP3buDstIihkcn6ekbYmh4nLd3H+W1XQfx+UN4PC7CkSjFRQVUV5UxOj7JY0+/wQ9+8iKdPQN43C6z5j5+KKAoCg63g+pF1ZTXlRMJRpgemyYSihAOhPGN+4hFYtQsqaG8vpyuc120n2yn82wnHac6cLgdVDZW4nA5CPlC+Cf8REIRus53ceKdE4QDYXZ8bge//de/zdZ7tmJz2ECDoC/ImX1naDnWQmVDJVvv2UrzpmZikRhn959lqHOIaDiKb8KHoigs37ycbfdvI78on+5z3Qx3D1NWU8aND9zIpx75FJtu30RBidnsrkQikUguBxkISyQSiUTyIWGxKDTWV3HT1nWsaG5iy3Ur2bhuedYsrKIomedBg6EIY+PT+P1BYobViDUtNUscCkdRULBarQRDYaZ9AZKqisWiYLFYKCzIZ8PaZu7ZeSP/9pfv4ze+8iDrVi9lxdIGvvjZO/nU7TdQVlJE26Uefvrka7y+6xDBUDjTzsceDSLBVOBrtVlxuB1YbTO3WSuKQmlNKUvWLcHhdtB5tpMjbxyht7WXxWsWs2zDsix5/fniicEJKuorWHn9ShpWNJBfko+iKGiahn/Sz/jAOIHJABeOXODl77/M6fdOY3fYcXvdmVWlFUWhaXUTd/7yndz1K3ex+obVVC+ppqSyhI7THTz590/y4ndfpLe1N914xgyJRCKRXAFkICyRSCQSyYeIw27nlps28pd//jv8u19/mKWL67PKnQ47hfl5OB0Ozp6/xE+feo139x9ndGwS0kHwyNgEL7y6mz0HT7J21VK2blzFyTOtPP7sWwwMjlJXXcGSRXUEQ2F8/iD5Xjdulwt/IMS0L0hH1wBjY5Nsv3EDX/n8p7hu3XKi0TihcBh1nu2ErnnSwe/E8AT9Hf2cfO8knWc7qWyspL65Hocr+5lJm93G4nWLqVtWR8eZDg6/dhj/pJ/F6xZTu7R21hoqVltqQa14NE7IF8I34cssagVgd9ixOWyZFalv/+LtfPrffZov/OkX2PnLO6lsrEwpUsDpdpJfkk9+ST6eQg8bbtnAA7/9ANfdfh12p53WY63seXYPHWc6UNXUrdcSiUQiuTLIQFgikUgkkquMzWajrLSIhroqCgvyKC8tYst1q1ixrJH8PA8VZcU01FZRXJiPw2Fn+bIGtm5cTSAY5q13j9DR2U9leQk1VeU4nXYutHZx4kwbSxfV85u/+hC/+aufZtXyRbS0dnP2Qgcrlzfx8AO30VhfxeFj5/jWD5/hh4+9yJGTFwiHI0xM+dhz8BSP/uxlfvLka/QPjnLLTdexY9t1eD+irX+uFJqm0XGmgxe/8yI/+m8/4pUfvUI8Fmfb/dtYv2M9Nnv2AlGKolC3tI5FaxYxMThBb0svlY2VLFm7ZFbQrCgKFfUVVC2qYrhnmPeefo83f/wmrcdbSSaSKIpCQWkBjSsbKSgtYLRvlKGuIXwTPvra+ug824lvwpelk/QWTCO9I5w/dJ5QIMSy65axcstKCssKUaxKatVoeWu0RCKRXFHkqtESiUSyAOSq0dc21/qq0TablcryEjauW8GGdcsoLS7M7OnrcDioqSpj47rlbFy/nPLSIsrLilixrJHVKxZz+/ZN3L3zRrZtWcsNm1ezpKkWt8tJQ20ld96yhRs2r6apoZoVzU2sam6iqamGqooSli9t5PrrVrFyeRPLljawecMK7r79BrZsXE19bSXLFtexqLGWlSsWccctm/ns/bexfvUyXK7cKzlfLldz1ehEPEFvay/DPcNYFAv+CT9BX5CymjJ2fHYHt37+VqoXVROLxOhr6yPoC7LqxlUsXb8Uh9NBJBhhcmQSq83Kxp0bueG+G/AWeAlMB+hv7yeZSLL6xtWs3LISFBjtG2VicIJoKIqaVLHarKzYsoLV21ZTVluGgsJ4/3gmAB7pGaGgtIBlG5YRnE5t7bR47WJWXb8KT56H4FSQi0cucnr3aTrPdqZWsS4t4KYHb2LTzk2489zzBsNy1ehPBnLVaInkyqB0dXVppaWl2Gzyy1AikUhykYhHGRvoIDzZS01lPm63XRSRfISEIwmGR/worjJqFq3Gap//4i8S9DE6cAmHOk11ZZ5YfEXRNI14PEFSVbHZrNgNY66qaST0MqsVe3rGMh5PEI3FsVot2KxWkulbY21Wa6pOIoHVasWRlk8kksTTeXabDYtFIZlMEo3FSSZVFCV1W7ZRfywWR9U07DYrDofjqq8YnUxqDI8GiJJHZf1yXN4CUQTSn1fnVB+Xgl3YyxXchfP/v6lJlZG+EUZ7Uyss2xw23Hlu3F433kIvnnwPVpuVWCTGaN8o0+PTlNeWU1ZbBoB/0s9IzwjhYJjSqlIqGiqw2WyEQ2FGe1PbLVXUVVBcUUzQF6S/vR//pJ/CskKsNishX4jiymIqGytRUPBP+RkbGGNyeJJ4NE5+cT7l9eUUVxTjn/Az0psKjCsbKrE77cRjcSaHJhnuGcY/6cdmt1FaXUp5fTl5RXnzT1hoEJ6OkxiDJd4mGotqZy3ApmkqPl8f4+OtFBYmKS7+eM/+fxLRNI2pqQjT0yolJasoLGzMCoQ1TSMSiRCJRCgoKMDr9WbVl0gkM8hAWCKRSBaADISvba71QFiS4moGwqSDYf1ZWkVRsFgts2bLNE1DUzU0TcNisWQWJtM0DTWppvLTs/WZfFUFjSz5ZCKJmlSx2CwopPYAtlgsWAw/JqhJlWQimdGp3+KsqipaUkOxpGzU0TQtoxcldUu9sXxOZCD8iUAGwhLJlWOB364SiUQikUgk1zYWqwWb3YbNbsv5XK0eIFtt1kxQq+dbbVZsdlvW7KuipFblFuWtNit2px2r1ZppVwxaLVYLdqcdh8uBzW7L2GOxWLDaU/WMKIqCzW7D4XLgcDpmlUskEonkyiG/YSUSiUQikUgkEolE8olCBsISiUQikUgkEolEIvlEIQNhiUQikUgkEolEIpF8opCLZUkkEgkQj8cJBoOZhXZEEvEYE0NdRKb7qSrPx+WS35nXEpFogpGxABZnCZWNK7Ha5l9cKRoKMD7UiV31UVHuZfbTpJIrTVLVGB0PENXyqahbitNtvkiZhkbP1CCdoR7speBa4GJZn2g0iPgSJMZhkaee+qJqlFlntYbPN8DkZDv5+UmKiuRiWR83NE3D54vg86kUFa2gsLAOhH6ORCJEo1Hy8vLweDymz8pLfnGw2Wx4PB4Zy30AZCAskUgkwMDAABcunEdRFNOLhmQijn9yhFhwjOJCNw7Hwr8zNUBBS7/rulOp+RHlxPTCya4p2rNQ3n/75v4vFLE9MZ0iHk8yNR1GceRTXFGPxTq7fzQN9K7VNI14NIx/cgSrFqS40C2KXzE+DP/fPx/UnveP0X9Ng2lfhLjmorCsBofT8LkbXNM0jZHgBMPRUWwF4PCk+lND+0A2a+l3vWbKmqvvv96u7tz7bU30V0yLxEJJkj6odJZT7i3O/i7TUvVDoXECgQE8HpW8PAda2kiTr70sFipnRK+joyi59Yj586XfD2JdY1osy8VC5YxcDf8BQqE4waBKXl4dXk/ZLGXxWJxYPI7b7cLpnNmrW8n8J86FrkuXUwzHc5E6M/VzdP52Fspse/R2ssmVP8PC7JrdXnZ6hmx9C/E/+7PMLWdEbD/bT1VV8Xi8rFy5ktLS0kwtycKQgbBEIpEA3d3dDAz00dy8FJvVCiho6b8aoCYTBKbGiIcmKCxw4XDY0sOQPuiJw9VMvjE3Oy+Vn32hO6MnlZ4Z/GYkjHrEdkTJ7PTMsVg6Q7a8lroAM1yN6RfXYvtZujVQlLn8T5ek5YxSC/d/pp1YPInPH0Gx51FYVoPFMjOmpS4aRC0a8WiE4PQoVi1MQb4rU5gtb/R/pj1dh5IuE/035uu5ukYj2TVn/J95F+tp6aOZ81P/my01O21sebbeGYztz0hm+5/KE21JkboQnMnXcwE0FXz+CAnNRX5JJQ6nK8uGjN+axlhoktHoONZ8BbvHmpGY0T27nY/KfyNmds22KJUn1s/4n3kX683lv0Y8rKIGNModZZS4izLbJxk/13B4kmBwCLdbxeOdvc3YR+n/TMkH8d8oNTud3bIoMUPa03TJlfVfHBPM6qdKcvuPBqFwnHBIw+utwe0pyZTrdRLxBPF4HJfLhcPpSLesa0jpSFWY3bbuf0ZIS8ulI3HRfy1rBJvxX/dupjEEX7P9n/nM9eMZ741WpVIz/T/TTnZ9MT3Lf8UoMcNMS4Ld78v/2X2f4sr6r6kaE5OTTExMsXjxEioqKjIykoUhA2GJRCJJB8IjI0OsX7cGmy21zYlxYEom4wSmx0gEJygocONw6BfmszHWM0vreeTINw55ucrNjllA2pgn5pthVt8YDJsxl106ufJ1zMrFPGM78XgSny8CeiCcnhGey454NIJ/agSbFqag0PwWUbE+WmpaOZfdfET+m5XNldbJ+GVAMZE3+j9X3zOPXaqqZQLhgtIq7A7zz13VNMZDU4zGxrHlg91tnaVrrnbmS+t82P7r5MrXMeow5jGX/xrEI0lUP5Q5Sin1ZAfCqYNUIBwKDeNyq3g89ix/uQr+m0nnytcxKzezSbRvoWkdXcfHyX8ygbCaIxBOPeqTyATCxhnhbD4K/0XdZsxXT9TxftNi3lz+G8uuNf81VWV0bIyBgWEaG5tkIPwBkItlSSQSiU5mpEkNQcaBSEn/6psZgAxlIrqcOHCJg22ufLNycfA01hFt0UzkdH1im8Z8/WXM18mSyZrpnI2xDbM2dRmz/FzlRl2Y+K+lKxnt18v0tDFP03/dT1dStGwZ47ExraSDYDObdYx2i34YZczyc5XP578RXdZYJtad8X/2S5TPkhMDKxOMduv1jH4qmT9z+6+jGSZw9PyPs/+6jFm+sRxD+YL81xWayIn+kJ6N0vP0YzGtkyn/AP5j4meufB3R/oX4bywT5cS6xv43lotpnUz5NeK/GaK9Rox1P2r/Z9mSPjZiLNffRZt0jHr1tFh/Vpvaws9/Y9m16D/aTH9K3j8yEJZIJJIsDA9xGci6nUwYkMwGIbNBSx8gmWMAFDHTI5IZpA1p46CrI+bpdhttWigf1H+dq+E/Jr6IbWbnpa1IFyzEHp1r0X9Rv14mkuuzEt/nwqwtI6I9eh66vFklgUx9UZHAx81/3mf/z4fov1F3rvqalqtkYZ+D6IuIaI+ep2NWxwxlAbJmn7WWI58ceTrGz26udufz5Ur7P8tm4TtHLDeWimVi2sjV9N+IWZ4ZOf03YGxLR68j5pPDduO7mGeGmQ4jov+iHWZ1zFiI/2B6h7tkgchAWCKRSPSBJPNKjSrZg1UqTy8xDphz3SpllMMwoIk1NFIBlS6vp/Uy46AqDqJiPQyuiHlZdYWZXbFcbEdnVlvvw38dsYZm4sf78T9TSEp4Xv+NHW54M+qe6zhLr4n/epmZvbxP/1mA/8Z6Bs9myWeOTc7xD+y/oUxHLxPbzyBU0pjth/G/7BfNf2OdjJ2i/8KsNbna1eulC+byP0O6slhuKmsiY2qHAb0slz7jZ208FnXr5XP6L9TLJa+ngcx3n1ieC1FHLjt09LJcut+v/zpG+41OivUydYTveGN9sc5ciDpM2zKgl+Xy43L8N2vXWO/99L+eZ+aDEVFHLjt0jLr196vpf1YFyftCBsISiURC+iJSSx8It42Jx6Rvk55rADQeGwdlI3p+Rlf64lxPz3ULsrF9PRATbRLbF4/nS4tlRn1iW2aYtW8kY79+fJn+iw2ZtT/bFsNVpIAoezX9Tx2Y+29imqn/ok1m7eeyxYxcshn7xAIBs/b1tKlNRj/ESgJGHR83/3Vm5Yt+zNP/M4l0SjBqvvZ1xHI9LebrXC3/xf8v3fd5/TfkGfPN2s9Vzywt5utc6/5nlc0zcwyQTCTw+XyMjIwwPDzM9PQ0iUQiI5tMJvH7/UxOThKNRjM6I+EIU1NT+AMBorEYPr+fiYmJzGs8/T45MUkwECCRSKIB4XCYsbFxRoZHmJqaIh6Pw2X4r+Xw3ZivY+a/mKenxXwds7bMMGt/LkQ/Fup/KmNWjmSByMWyJBKJJL1Y1vDwEBvWr8Fut88afNRkguDUKLH0qtF2k+2T9KFIH9DMMA72ZmmdXPlGxHZEm7PK0ot85NKrAcaFQObSpZNLRrTLiNi+mNYR8810GvNmLZZlsWbN1Ir+o2kkYhECU2NYCaVWjcbcf7FdTHxngbaa+WVM64g6xLRZXpZNwqIuov9munL1vyiL2FaahfifVDX8hsWybOnFsmbLa4wFU4tlWdOLZc2WWZj/Rt8+av/F9sW0jqhDTJvlaRrEwwmSAYWK9GJZGZ91/zOrRg/j8aQWyzLVZTgW22Ue/3WMOufyX6xnli+mzfKybBL70tD/oh7m0ZVLXkSUu1r+axqEQjHC4ZlVo7NWKdY04onEzGJZjtTK4KL/mqYRDAZpb7/EiRMn6e7uRlVV6urrWL9uHcuXN1NQUMDk1BT79u6jp7ePm2/axurVq7BYLJw8eYqTJ09RUlpKc/NS2lrb6Ojs0q3IGG21WliyZAlbNm8CReHYseOcPXuWQCBIZWUl12/ZzKpVK7P2O57L/1x5WX3yC9z/xjy5WNblY/3qV7/6PzweDxaLnByWSCSfXKanpwkGA1RVVWCxplaEzhqINJV4JEQyHsbltGO1znxnKoKsPuCZDVx6uY5+nKuOccA0psVjY3km3zj4C78Ym9YVLhRytSWS1abuixCIkcMHHWUe/83SxuOkqhGLJVAsDlyefBTFkn1RJfqvKKjJJLFIEIuWwOlMrRSeJZPjWMTM/7kwK79c/836f07/DcfG/jeSqy0RY5t6OicaxGIJVGw4PXlZq3sb/dc0CMcjhJJhrE6w2FP/b7namct/8ZhcdeeQmcun9+V/jnLRf2P+QtJaOqElNLQ4eK0ePHZXxqeMbwok4hESiSB2u4bdbr4atzEtHouI/hvzzRDzje3O1aaYNuZdkf7PkRaPRYxtivlmiPnKAts0phMJlXhcw+HIx25zZ2YEFQBFQVNVVFXFZrNhTe+CYERJz8y+995uvvGN/8eLL75Md08PnZ1d7N27j6PHjlNQUEhDQz2jo2P84Ac/4qmnnmbx4kWsXr0KDXjl1df44Y8eZWR4mPKyMvbtP8Crr77GkSPH2L17D4ePHKa1tY329ktYLBZqqqvZtesdvvXt73Ds2HE6O7vYt28fLS0t1NbVUVtbgzU99uo2GhHTxrxc/b+Q/23xvNPTc/WFji5nVp4rT8xXPkD/Z9A0QqEQPl+AoqJivF6vKCGZBxn9SiQSCanrCGGsTOULCT0tDoCaYTBLZWipZ/6E5zyz5NPP9mXaMJHVdWTSYjsGeYTyzEVwRsqgN4cehHyjXpFZ/gjlC/Ffz09lzpadz/+Mr4a0Blmdaep/pi3DA8Um+o16jehVZrWrp4X+N5X/KP038QmTfKNeI6b+GMpz+a/LGt/n8l/PzmW3qOOj8F+vk2VXDv+z5C+z//W0fkxGbzohlBkR/dER8y/Lf8HHueTTlTKHmXaFz8hYL6f/sKD+N0PM/7D8V1KVstNCfTL1sq1Rsh8XznoX0W1IqiodnV088cRTHDhwkOUrmvmDP/j3/Omf/AfWrVvHxYstPP6zxzlz+gyxWIyp6WlGR8cIhyMp3ZpGOBRiYmIcn89HXl4e99xzN7/zO7/Fbbfdgt1ux2q1cucdt/Nbv/Ub3HXnHQQCAd56exddXd3ceecd/MEf/D6LFy/i8OEj7N+3n4mJySw7U82Y+T8jYzzOKjeMfXqZMS1+PuLnZqbXiFGv3qZRJlf/55JXUpWy00J9hHozfimzAn3JwpGBsEQikWSPQZlE9oAjDoWzB80sckXWaXmFmUA1046JvFmeiGn7JvliOoPgbyY7/Z7Lgjn9J/0ZmCD6n0FMm8mYkGk/pyEpsoozenOvGj2f/zpivQw5bM/lv5heKDnbF8gpJ0ZOAvNZlbP2XP4YLt4zWUZ5sfAKkNPOy/Q/J3P4b9b/c8kvCC31yqVlbi8/XBSzzzWH/wu127z2DGZ6zPKuJLP6OM3l+C/uYm72PWV2bNSTTCY5feo0Z86epaCwgAceuJ8H7r+PO+/cyS99/mEaGuo5duw4Fy5czDzDqyNaqVgU8gsKuGHr9Tz04INs3Xo9JcXFFBYWcsMNW3nwwQfYtGkT0z4fQ0NDlJeXcdO2G7nrrju4bsN12Gw2LnV0MD4xLmhOIfqfC9EuETM9eqA5H/PpnoWS2n1irv6fRQ7Z+S1M/VAm+WDIQFgikUjSZMbE9F6x2SiQiZlSf3UZ/aJGvPhQmLkQMg5mZnLpa9is14yQ+aJR4q/FRhtEvSLGct1f8SXKi7aJbRnrKLrOBfiPoVxsA1L2mflgnCmD1IHRJsx06QgXQEYfjPYZMbUtR70P4r/4Qq+/AP+1HD6Y2YtBRoOs812sa0S0TUdsk7Tdim6/SR09Q7TTqD9TJ/WvNwvdfz5m/mfJpd+NPhvbmKv/Ef1PG2GUNa1n8D3TjuFdtMmY/kj8N2lTR6wv2jJfPTFtVteYfr/+61xp/7MCOMPOfqJfmNSF1LOlQ0NDTE9PU11dRX19Pd68PDxeL0uWLqG8rIxAMMDY2BiRSDi7rvjDqQZWiwW3201enheXy4XFasFiseByu8nzenE6HQT8fsLhMAUF+RQWFuD1eCguLsLpcOLz+YhEUrPNC/FfR/z8xL6Yr54efOpps7qKwSajbTpim5k8Q2BrrDNXW2Ib8/mvI94lIFk4MhCWSCSSNPq4ZRzQdBRAywRa5gOcnjYOarnKzBDbzRoQhXeEgRajbpMgTzPJ1zFqMZfItkO004ixvqhLTIuIes38z0LwPxem/mcuMEz2TZqDa8l/sf91xFmO+dwz12LOFfPfRIkxK+VCukaOWc6Ptf8miHpz9b9+rJn5r5FZNmkuW4yYaMnJR+G/2GbGf0OeET1/LluMiO3OhWiLiLFtsU0xLSLqzeU/COe+4VAD0+/52TmgWCyAgqqmS/UAV1V1CRSLBYtxvQVVnfFR09C0lJ75AjYNZr5zDYG7qv+Yq1hMZ7rN/J+r//VbkjHU1fWYIeqej/nkjW2LbYppEVHvwv3P8UuhZEHIQFgikUgEjGOKPhhp6duPzMYbY54+aIlyer5Yph/r+UY5sY4oa9aGBugzSLo+vUwMHIzlYr7x2GiXiGiHLmNmm1mZ6JPot/4S7RD16+j5C/UfUldlueoZ7cuunUKX1xHrGfPNyoz6jf6JL6NdxrROlu5c/T8jnkG0SaxntM+s/px2CPm56mPwSZdLvVI1lPR13sfNf6O8sb5R3qjf6J/4ymWXjpltGPIz7QuNi/qM9ohpszaupP/6u/jS5Rbify4/ctk/X70P6r/ZsajTeCzaaXzpcrP8NyTMbNMRdUHqu7C2ppqSkmIGBwe5dOkSk5NT+KZ9nL9wgcGhIQry86mqrKSkpBiXK7W6+/jEOJOTk/h8qa2SotEIXo8bpzO9MrWhDSMWRaGoqAiPx8PU1BTj4xNM+3yMjY0RjoQpKirE7XHP8n1O/w1k2jUJyEVdZnws+z/DPCeAZE5kICyRSCRGlNSzPVlo6SFIHH3T5BqDxEHMOOiJA6gx3wzjoGjM0zHqNg6quRDbEQfaLMTPQ8CsjtkgbiwT8/T8uRDLxbTInOXG26rTgqI9OuIMo0iudj4q//X8XOXkaF9M61xp//VMMU/Uo5fr72K5mNa5VvzXydWWmDefHrFcTEMqU79hOlc56bbNJpQx+bxFO0VyqMlg5qtZ3nyI7YhpkbnK52r7SvhvzDPz1SxvPmZ0pmuLhurkupXegNVmY8OGDWzatJFgMMgzzzzLE088wXPPP8/Pf/4k/f0D3HDjVlatWkF5eTmLFjXh8XjYs2cfzz77HC+88CKHDh0mHo+zaNEiSkpKMz80ZpmTnqG1WCw0NTZSX1fH2NgYb7+9i+eff4Hjx0+gaRpLly6ltKTUWHNeRLeNeUqOcp25Ph/xY51LlhztXOn+F9uY7Z8oIVkocvskiUQiydo+qRKLNbVnaWZoURTQVKLREGp6+ySL1TJ76DEsjmEs03UpwiAryoiI8mKZGXp+rnIdY/vGAdmYn9GRft5Nm09vjsVBzNoy5ulpY7met1D/VVUjGk2g2Bw4Pfnzj2mKgppMZG2fhGEB6SxfTfw3/Szm6X+uov+inFguYmaTMf+q+a9BNJZAVWy43NnbJ2GwRWNm+ySLE2zp7ZN0xLY/Nv6b5OlpY7meJ/plLDOipf9oCQ0tNnv7JKNgIhEhEZ/ZPklHt0n0VS/L5X/Gzo/af4NesVzErNxY93L9N2K0R7TTKGMs1/PM/VeIJ1QS+vZJdndGQiFlx6ztk7Lqp2aE8/PyKCgoYNrno7Ozi9Onz3L8+HEmJiZYt3YN/+bffIUtWzbj9nhwOBxMTU3T09PD2TPnOHHiJIFgkM2bN/Lw5z/HihXLsVqtqKpKb28/ra1teL1etu+4mUVNTVisVrweD9FYjKGhIVpb2zhz5ix+f4Ct12/hc5/9DEuWLM5sXYiJ/2afl04uuVyYyeh19XbF9j7q/p+tOfUjXSgUwu8PUlRUJLdP+gAoXV1dWmlpKTZbajCSSCSSTyI9Pd0MDw+xfv1a7DZb1gCkaRqqmiQwNUo8OEFhoRu7Y/aAbTpQmQxouWTJUWY2OJrJiHlzYbRHTxvri/4bnwEz1snIzNO+WC+XrFnZQvyPx5P4/BGw51FUWpMJsHKhaRqJWITA1BhWQhTku7JmyIxtml3gLMQmI3r5Qj53MW0kV1tmeXNhtEO0yViuI+r+oP6rqobPHyGBi/ySKuwO16x2U/o0xoNTjMTGseaB3ZP6ccooY8Qsby6M8h+m/2JbYj2ztM58+gES4STJAJTbSyn1FJmctxrh0CTB4DBuj4rXY59lU0rO3F5juYgoYySXPjN/xbTOQvQvFKO8aJOx3KxMLxcRZYzk0ifabZbWydTRIByOEwqpeL01uD0lIDxhG4/HicfjuNxunI7UbctGNFKKwuEwfX39nDt/ge6uLpLJJHV1daxeszo1C+x2Q3rP4b6+Ps6fv0BPTy8aGnW1daxatZKmpkZc7tRtzaqq0tvXx/lz51FVjfUb1lFbU5O502pycpKzZ89x/vwFAoEAFZWVbLxuA0uXLsXlci7IfzPEevNxpfpflxHLRebTl4v5/FdVldGxMQYGhmlsbKKiokIUkcyDDIQlEonEGAivW5P6PhRmNpLJBIHpdCBc4MZhCISNiAOdMYg0Ig6exgHPiJmM2YA6V1rULeoU6xjJVTbboxSz7Fio/5pmeq+maKueJ7YTiyfx+yIo9jwKymYC4bn8j0cj+KdGsGlhCgtds+T4GPk/V3ou2412iHLMUTbb0hSz7BD8zwTCmouC0lQgrKUEs/zXNI3x0BSjsXFs+WB3W019Eu0T/RXTep7Oh+2/zqx2r0T/a5CIJEn4odxRQqmnGIt4m6ymEQ5PEgoN43KreDz2WT7m1C/kmTGr3mX4L9ZaiH3GMrO0nqczy4559BvzzJhV7yr4jwahcJxwWMXrmQmEMdgej8dJxOO4XC4cTqdRzSz/NVUlEo0SjUbRNA2Hw4HL5cKavjNKl1NVlWgkQjQaA4WUnNOJ1TCLqwGJRIJ4LIampWTs9pn4QgNi0SjhSAQ1qWK323C5XFljrk4u/+fqH2OZWVrP05nVD/PoN+aZMaveVeh/o32aqjE6OsbA4JAMhD8g89w7JpFIJJ8MNM040qSGIONApJgMoOIAq6MPVBozuphjMM3k688iatnb4ojtLCRtrI9gf5ar6XejjJ5nVqYfi20aWYjdpv5nMub2XyRTblBq9FVPZ/mf/qwVZlaNNsrodYzH17z/hvR8/uvk8nGussv136jXFE3Lnp0XFQmYFYu+Xkv+M99nIPT/fGRk0ssbpOpm386dsT/d8Mz5P4PYplhmZC67Pqj/el7G1gXUYR57Z/k/h86r4b8xCDJr1yxvIbaaMZe9c+m0WCx43G6Ki4ooKS7G6/VmBcFGOXd6y6OioiK8Hk9WEKxjt9lwezx4vJ5ZQbACOJ1OigoLKSkpJi8/H5vdDib+i+eQ6JPOXP31QfvfKG+UM7PLiLGNy+1/sR2jPTOkpPT/Z8n7RwbCEolEopMZnWZvUK9l/qTIGqwMg5A4mBn1iIOkcaBT0oOm/m6sM5fOXPlZeg1tGeVEO4wvsQ0doy0sxH/BF0zaIi2Xq46oU8SYr+sz+qoIfs3oSOem153JsicjY06WL+/Df9H3K+m/sWw+/0UbZtlj0GWGXq7x/vzH0Ibx2Mz/TM30gV4ukqlnyLsS/hvtFNHbWoj/ok7xRVrOWEfH6JNeLpKVn1lhO6XZaKeI0Ufx3cx/0RYEH4z5Rl+M5aLfRv8x8W++tJ4n5mtCvtGvufy+0v7rMjqi/zrv239tZrGsXP6bpT9O/pv5Jab1PDFfy2GDnif6K76LxxjqiXrN5EQZnavhPyBOJkveBzIQlkgkEiOKkhlVzH5lNRsAjReuZpgNfDrGmnp7mcHSpH0zxHqIeg15uWwx8yBX+xn70umF+L8QRD/M2p+dYyKX2e85heh/KqFfZgjCBmbpTfNR+m9Odj3m6f+Fkqv9K+K/SRVdLuU7mWBuoVxp/3NNRb9f/xdKlv9CmRmzWk1XTJ3VM6VZumaMnpW1UGb5L5TnQpfT38X6l+u/Xi/lf3b+XMcLacvINeG/MvO9pZ+mC7HpWvXfqG9B/pu0q9cz63+xDT3f+L5QjP6Lbc3FfP7riHbmIqvdhVSQmCIDYYlEItHRSF+Bp0aVrJkZYaDRB0BxwBUHNHQZw0W1WDejw/CrsJJu30ynOAAbf03WX8Z6YluZ9nKUiXohFRSJ+kRdZrai25PD/ywdoh8m/jOH/zqKYYYXUdYglyIlbGaPmf+inFGfaKuZ/2Z1MzoW4L+ezm5bqCfYYtqWUCa+SLevc6X819PGerlsSpF9d4a5/ymMNl2r/pvVNeowypBDp26HiPG3HXL4L2Jmi5lduezPkjGxlbSMsb7+Pp9N5NCZ0/8c9Yz5Yj3RD/FY51ryX5fJKphDpzFfLBf9EI91rrb/4rGeNtOpCfI6uerlatOYZyZjlM3lvxEzW0nLLcR/o7xeZqZzlv+iMsn7Qi6WJZFIJEB3d2qxrA3r12BPP7NkHJiSyTjBqTFiodRiWXZH6hkq4yCVekAvNSKJ45Jx8BKPMZHX0WXFOmKeUV7HWJYZiNPBlVl9TVjYYz7beD/+G3SLvmAirzPLxvS7aH9m1WhbHoXpxbJy+aalMrJWjS7Md6Ex2/+egSmGx4Imlpgxl8xcZR8Gl9v+QuqbyxTmO2luSu0zKi6WZXO4wKSWhsZYMLVYljUfHO7Us4i5+l/HeD7O2f9pxPpGjPrF/w0doy79/J8tNbv9jN70u1kdTHwU62b7CPH0qtEVjuxVo/X2tfRiWcHgMB5ParGsXMznf5bvc/QJ8/hvJq8jls9XN1ffivab1RV5P20xn/85dOWS1xHLtfSfUChGOKzh9dbgMSyWlSrXiCcSqcWy3G4c+jO4Jv63tHYyPjmdyTdFb9Tk/M+gfxhmIgupfzW53PYXUl+DivISlixpMO3bhRwvBLGuJleNvmxkICyRSCTpQHhkeIj169dgs89eSVVLJghMjRILTVCUDoTnGsTMynLlGck1QM51nYFJuV7fLN+Y1vNypUV5sSynPTkunEX5K+V/LJ7En94+qbCsBoslFQiL9YztJaIRAlMjWNOrRhvLdflzbSN09U9lfkiQvD8URaGs2MPW9XVopFY59fsjxHFRUDITCGfk0++qsGq0LR0I5+p/sd/088cs35jW83KVG9NmZTnteR/n/0J0i+V6nmhnPJxENawaLf4wpQfCodAw7vSq0WZ6zNJmZaI/OlfD/1x19WNM6pvlG9N6Xq7ya9F/Tdw+yV0yq59jsRiJRCKzarSZPwCHjpxmcGgENDWdI/lAKBYa6mvZuGElXOX+N+bpgXB//zBNTTIQ/iDIQFgikUj0QHgktY+wzSbMJpIKhP3ToySCExTMsX1Sy6VB2rqGxexZWCwKN29pJj8vtf8iQHSyjx9+61vsao1gTWcqAIWVPPzrv8Fn15VmBs35Bkz9PRmf4ulv/4Tghgf5yo4GbJlyjcnuk3z72XN85Vc/T0Nx9sWS8Zgcg/VcaFr6fuO0tFhH14VRt8nFAzlkRalcM8KizZnPR9NIxKIEpkYzM8KkFxoyyp9rG6Gzb1IGwh8QRVEoL/GydX0dCNsn5ae3TzLrfy0dCI/ExrHlgc0zEwib9b+I8f8As/7PocNMXk+LZXOROv9TkmbyZud0rvMfEzvMpLSsQDg1I2y0IaUjvY9wOhD2CjPCoo9iu8YyEaNdZv6rqkoikQTAarNisaSezpvLJ50s3YCaVEkkEgDY7baMLqM8mkYikUTVNGxWS0omPWOfqz3RxyvpvxFRVy57dPRyLa07Eo4TCqVmhN2eklnPhIvbJ4n26/oOHTnN4OAQmhrL1Je8fxSLk4aGWjZuWAVXuf8xyKb2ER5nYEBun/RBkc8ISyQSSQ5mXTjMLNSZuiAxyOh5E9NBRieCePJKc74sNi99gxOoaur5x4zOeJhzp1vJX7aB++++lfvvvpX77rmV+27bwopyQ8AgYLQjSx+gqlEunTpJ52goa7BVgFhwguMXukgk03YIzzHp8sY6xjIz/zN2KKkNXIx1jOj5mc82XceoV/TL6JtOlg1CoZlsxhc94DJIadrsbYtEHZIrx6xzy6T/AbT0ukBz9b8xP1PPkKenje2R7vNMudD/ulxWnbR8rnYz9QyrQJuhl83nv/4S7dLR05r+JyOQ/Uy/SMqXbP8z+UY/gEQ8QV/fMKMjE2hqqkTTNMYnpunpGSQQCGXqa0AikWRgYJTRkQnUpEo8kWBkZIIzZ1rZv/8kBw6c4szpVgb6R4hGokxO+Whr66avf5hoLJ5yQwN/IMSljj66uvoJhcJomkYymWRsdJIzZ9vYt+8Ee/Yc59SpVoaHx4nHU4GxpmkE/EHa23s4fOQM+/ed4PDhs7S0dOGbDmT6WZc1Yua/sY+M/W9818nUW2D/G9MYulB8zZbN1izakYssX0z8l1weWjo49fl8+H1+kolEpg/D4TDj4xOEwxHQNELBIKFQGFVVUdJ9EUjnJZNqzv6fjezDy8H61a9+9X94PJ5Zv6bpaOkFIuTr6r1If2lKJJKPDp9vmmAwQFVVJVb9+zBrhkolHg2hxsM4nXasVsusiwoF6B+cIJ608qlPfYqmpibTV35BAa2traxursPpSN2NoygKieAEb79xhI1f/E3+7T2bWbdmOWvXLGfdikVU5NuZ7D7F3333WQZ7WvnB937GU7vO4KhbxuJyD8nQGO+99Bzf+PbjPPbMG+xtmWLRyqWUOCLsf/FNuhMOzu16kUef2Uckv4rl9cWEx7p45WAfd+y8kWJ7nHOHdvPNf/ohP35uLxenFJqX1OJ1zB4b9F+7zfzXUdLfb/N9s4m6SNfRX8Y8s2M9raoa0VgCLA5cnnwUi3n/6GiahppMEo8EsWgJXE7b7O9hTWNsIsSUL5KdnyYa8hEIholEIplXLKFhs9mxKKCpCfw+H2FDeSQSIRKLY7c7ULSkaXk8oeFwzNyenws1GU9dTIXDRKNxFJsdmyVVKxHxE4oqmWfZjUQCPlSrHWtaFk0lHPQRi4MjfT5eKRRFwet2UFdVAKmPlFgsgarYcLjzsFispv2PAqF4hFAyjNUBVvvMeSj6Y9a/ZvlieQaTbcsg+/8/CyFP1G9SIyfG8z9zPWB46YjlZigKJOMaagy8Vg8eu8v0/zQRjxCLB7HbNex2yywfjfKapjE+Ps2j//o8A4MjrFm9BIvVSiKp8u47h3juuV0UFOTR0FCdkR8cHOWxx15meHicJUvq6eoa4IUX3+GFF97l5MmLnDnTxqFDZxgcHKW0tJCzZ9r55jd/RmtrN4uaaigpLkBVVfbvP8k3v/kzTp1qoaG+mrKyYvr6hnjhxXd49tm3OHW6JRVcHzjJyPAElZVlFBfnEwxFeO+9ozz55Ovs33+SU6db2L//JMeOXaCktJCGxuqsa965/DfFIC/2kZg3H5rw7DQm/a+/6+WgEE+oJOIaDkc+drs7a0YYUrfMqqqKzWbL3PFpZlf/wAiBQAC01Ey95IOhKDYKCwuprirH7/fz1ltv09raRnl5GXl5eSSSSY4eO87bu94hPy+P4pISDh48xNTkJMXFxTgcDmLxOEePHGVycpKiokIcDkdKd7oNfTw19qOmaYRCIfz+YGpvZ6/XUCpZCHMGwklVIxiJ4QtFCEbihOTryr+icZKqhsNunfVlLJFIIJFIEA6HAbBYZl+0XSmmp2cC4cwte4YLFDEQtlktmYuYmQuUVCDsDyVYsWKFITebYDBIa2srq5rrcLscGR2J4ARvvvoGXQErU32dnDpzkdNnLtLaPUxxbSPq6AW+9X+/x1DeKh647wbUzv08tmeM27evpufNx/irF/u4+7P3s3Wxl8MvPMlJSzN3r8ln/xOP81p7gtvvu5O1RX6e+tmb2JZvodY6xKuH+rhz5w1MHXmB//LDY1x3+53sWFnMmdef4Yi/kps21GEVL/j0C3cT/40Xb4ph8BYx/gioy2Eia9RjLBfTqqoRjSbAmgqEM2Oa4RY1/VgBUBTUZIJYJIRFieNy2WbZqigKIxNB00BYS8Y48tK3+OYT79HWcoFTJ09w7Ogh9u07xrSaT0NDJUx38a/f+RpPv3WIY4cPcuDAgdTrXCcFtc2Ua0P867fF8kO09oVZtGo5eXPEpGpkgqPvvs5Lr77F0eMnOHr4EOf6/ZRU1VDsddB78El++voAK65vxm2sFw+z6yff4GSwmuVNpVjRmB44z+M/+indPjtrljcYpC8fs0A4GkugYsPlzsNqSwX8Yn+iQSgeJpQMoTgVLOlAOFf/58rP1f+ZczZdpueJ/S+in68KKX25zn8dUaeep3Mlzv+MjAZqQgNjIMyMj/psZiIRIR4P4rBr2NOPeJj6n373+4O8/fYhHA4HWzavwWazgqYRCIQ4dOgMDqedVauWYLVZ0VSVw0fOcPzEBVasWERpaRGP//xVLl7s4r57t/Pw5+5k+45NNDTUEI3FKC4qYHR0guMnLtDXN0xVVRlLltQTCkV4+ZXd7Nt3gsKCPNatX05hgZfnn9/F0WPn2LF9M7/0S3ezfccmPB4XBw6eJB5L0NRUS0dnHy88/w41tRX8ylceYOfOG9iwYQV2h53q6jLq6qoyn/uc/W84zuQJM71i34h1RJ16no5xjMFEVk+L5fF4kkSCVCBsc8/SoxoCYav+6KNw/itA/8CwDISvAKlAuIDqyjImJib4l0f/ld179tLU1ERtXS1Tk1P8/OdP8OSTT7Ny1QoWNTXy3HMvEPAHWLx4MR6vh0gkwksvvczU1DRNTU0kk6kfSoPBIMFgiHg8js1qxWpNrU8CqT6VgfDlMWcgHI0n6BqZpGN4mmFfmBF/iBGffF2x13SIkakgkVic0nwPNuvsPpBIPulMTk5y6tQpenp6MoGXzTb7mTCdcDjM6OgoU1NTJJNJHA5HTlkjU1PpQLiyAotVeP5X09A0jXgkRDIexqXPCAsXwbzPQHhNcx1O58zMXzI4wWsvvcSF0QShyTF6+gbp6RtkNBBn+fpNeENdvPrOAF/58z/gvs3NLKpUeO2Fk2y8cxv1FVVs3nErO9Y1UFtfhXX0EvsnS3loWxWH3jhA/ad/mz/+/A2sXrOCyLm3eWewiOsbNd463MedN6/k3Z8/zlnbcu5aV4Fid+GODPHK3kG23X0TZfYcsxYm/iukPi9jECFe3On9KOaLaRGzcv2iTpwRzupzw4xfRoempQNh44zwTBWd0RyBMFqS3rMH8ZXdyL/5wv1cv3kjG69bT12+n9ffOkLJ8vVU2YMcO3KWVXd/hc/ceTNbtmxJvdavoaGiCEtsmmNHzrI6q3wza1ctpSTflXlOXESLBzj62tO8dSbCrZ/5NHfsuJHVzQ1Mte/n7XN+1qxcTKT/BMe77Gy+aSUeY101QfuRXfiL17K6qZiJrpM88/QbJGq38sB9N+Ox5Wj0AzJXIOx052G1zkT7WS0bZoQtTgWrfWaGXxCbFWzMkjPrfwHFrJ4BvczYVq7z3zjLp+dlMc/5L/qjI+bNkldSgXDWjLDBb92mRCJCPKbPCM8EwqJ+0roDgRAHDpyioMDL5i2rsdpSd094vW5a27oZGZ5gyZIGigrziERivP7aPsKRKDt2bKane5A9u4+xcdNKHnzwNmpqyikpLqCmpoKlS+uprCils7OfyUlf6v9P02hoqKG3d4iWlk7i8QQlpUWsWrWEcDjKq6/tZcnieh5++C4aGqopLS2ivq6SoeFxWlu7qK4uZ2o6wIkTF2hubuL6LaspKy+murqcZcsaqautwOFIr6Js8DOX/zqzPuv0u7H/jWmjjJGs70+hzKwNI8a8eEIlkdBw2POxO4QZYU2bFQgrzD7/FRkIXzH0QLiqshSf38+777xLLBanID+fiooKWlpa6O3t5VJHB1s2b6K5eRnv7d5NUlVpamrEarXg9wfYt/8AdoedxYsX0XKxhaPHjtPa2sbRo8eYmpqivLwMj8cz84OGDIQvmzkD4Vg8yZg/QhQreYVFuL15uDxe+bpCL4fTTVLTsGgqlcV5MhCWSExIJpPs2bOHb3zjG5w6dYrp6WlUVUXTNCwWC3a7Peui8+LFizz66KO89dZb9PT0YLFYGB8fZ3h4eM5XV1cXo6OjeD1uAsEgfp9v5uX34/f7iEVC2CwqLqcNS/rWaPHV9z4C4VXLanG5HJmLk0Rwgl1vHuPW3/2P/Od/ey/33rWDu+/awe3bNlCZbyU01skr7/Vw22duo6HAQWi8l1ffbOH6+26jKS/Oyb27ef7Vd3nphbd46+AZfO6VfOauRo6/u5+irZ/ipkUFWLAQ6DnJ2wMebl3h4Z1jfdy5dTlvv/YiF8Y0opNDtF/qYThooWFxLZs3rqfUPXPBr/upI/qvQWaQ1svFi0Mx4hT1zZI3oJdntWeYEQ5FEwRCUaZ9/tRzWn4/fp+PaZ8Pn8+Hb3o69e73EwwEiMfCOOzgctohvViW0Z9cM8JoSfrOH2bEvoQbNywhz+3E5fZQmKdyfP8ZSlZupNEb4cSxs9RffwfrGsvJz89PvfK82K0WkuFJThw7N6s8z5s7CAYIDF/g+ZcPsfFzv8K25mrcLhd5hSXUV5ehROJUL6on2n+aM/0utpgEwpeO7yFYspZKrZ3HnnyHgjU7+fw9Wyl2mS8AJ5JIJLKuGbT0D0XG/0MdPRCurSpI9Vc6EA6G4wTDsUw/+fzp90z/+AhEgsStCaxOS+bW6Fz9r7esv2fyTWZcxXPZaLXY/7naEeX0sitx/psdG/P0thF1a6DGVZJhlXggRsgfwq9/roZXOOJH06I4nQoO4dZ5M7+CgRAH9p+ioCCP67eswWpN3c5us1qZnJjmwsUOiosLaGqqpa9/mF27DlNfV8lNN2/k6NGzDA6NsmP7JpYvb8osWGWzWXG7XVgtFlpauxkZmWDZskb8/iCJZJLOzn6cTgclJYXEojFWLG9ibGySs2fb2LRpNZs3rcrostvtTIxPce78Jaqqy2mor6K1pYvOrn6mfQH8/hDhSBS7w47H48Jqyw7+5/Jff4l9KMoZy8Rj8XwTMas/d1ojnkgSiyYJBpP4feFM3+rj1fT0dPoupyDBYHDm+8/4XejzMTI2SSQSlYHwZZIJhKvKCfj9HDhwkObmZfh8PpJqkgsXW6isrGRiYpyVK1fQ3LyMPXv2MjAwQDwRZ6B/gPZLlzh27Bjl5WWsXrU6c50TCAQ4dPAwXo+XFStXkp+Xl/munQmEAxQVFctA+AMwZyAcTySZCESJY8Ht9qR+WUpPy8vX5b8sFgvJRBwrSaqKZCAskZhhs9kYHR1l165dHDlyhEOHDnHgwAEuXbpEJBLBYkndoqx/P506dYrvfOc7HDx4kLa2NlpaWjh48CD79u2b83XgwAF6e3sIh0N0dnTQ3t6e9ert7UFNxCgvKcDlcmA1/L8aL5Te14zw8jpc6RlhBUgEJnjr9b1UbbuLrYuKsNls2NMvRYHgaBcvv9XGjfffSkOBYyZ913WcePyf+dGRJHfduZWtW9ZSFh3iUqSGz9zZyPEX3yLcdAM3Ly9BSUY5tmsXfc7l7GhWePtIH3feupG+E4ewbv0K//Qfv8Ddd9zM7ds2sPm6ddQU2lEMixXpmF0YGtNZ5JghE9/1YzFtRCzX85KqRiyWoKdviCPHTtLa0solQ/9d0l+XLqVe7e0MDQ1iVTRKivJwuxxZivXDuQPhg3SGimluKCERjRAKTHBu73tcGLdx0y3bKFZ8HD34LqfOt3PyyMyt0Wfa+6lYtJo8dZITR0/grltJuVtLPyMcx+Z0zhEIq4x3neS983DvPVspdOrBq4Ijr5TFSxvx2CxMdp+cIxB+l44RH6cOv0d7pJIvfuEeqvNy7ydrJJlM0tHRgdfrxWazkUwmGR0dJRKJmF6E5ZoR7usf4eSZc5y/cDHTH8b+6bjUgT8axF3sxZVnzwqExY9GyXH+iXJ6np6vvxsDSx2ztJin58/LBzz/zXSb2aHo/iupQDgwFaTjwiXOnjhNe1v291hHRweB4BQer438PBdO5+xHAnSdOoFAiAMHUzPCW7akb40m/SODonDkyDkSiQSrVy/l5MkL9HQPsmXLGpYtbeTY8fOMj0+xedNqamorsQizkqqm0trSxdDgGJs3ryESjXL48BnC4Qjr163AYlEYH59i+YpFTE8FaG/vYe2aZSxf3pTRoaka/QMjnDvXTkNDNVu3rqOktJCJiSlOnLjIvn0nOHDgFAP9I5SWFlFaUpj5IZMr2P9m5ZjUzXWsp/U8sWwmTyEeT+L3hzl//hInTpydNV7pfd3Z2Ul7ezttbW20tbXRnn7px7GYit3ukIHwZWKcEfYHAuw/cJA1q1djtVk5fvwENquVdevW0tbWxpLFS2huXsbevfsYGR3F6XQQDoeZnJik/dIl6uvq2bBhPbV1dRTk59Pa0gqKws7bb2Pp0iVYDXes6YGwzycD4Q/KnNsnBSMx2oem8CUgL7/ANFi+HDQNkok4kUhqNUDSzwDa7Q7sjtRzc8lkkkg4BCi43K6s26jUZJJoJIKmqTicrsztOmaoakpWX24fwGq14nA6sVlts36hNSOZSOD3TRMKBrBYrBQWFeHyeHO2OR+qqhIM+LGrMdY3VeKyz+6DuYhGo4yOjhKLxTKfn0Tyi4amaZw7d47vfe977N27l1gshs1mw+PxUFRURFNTEzfeeCNbtmxhyZIlnDhxgv/+3/87/f393HXXXfzZn/0ZJSUl8/6fDgwM4PdPc92GdTPfh4qS+qJSFNCSJKNBHEqUwgJXZlEh/SJK/w88dLydgdEwDz300IxygeGREV566UV+6f6tFBXMhCmRkTb+7Kv/g/y7f5PPrCmDjF4rpbW1OMeP8Pv/6VX++Nv/nZtr8xg+/w6/+59e4T987bc58O2vcarkHv7Lr24l0nmCf/yHH9FR+wWe/vp2vv/I7/K29zb+v9+/F9fwSb7x3d3c8Sf/ibsKLvAH3zjA3/zlHzD1zr/yH386yG/88ZfZVAXvPP4oh6w38dd/9iClqclS0wtG0X+xXMf4DZVLBkGPWEczPO+p69Db17dPiibtKI48FGWO8UpJadeSCdRYkDynRkFBavsko170fYRNtk/SkjEOPPU1/vVgkCV1pajBcXpGgjSuvp6dd93JhsUVJCc7+OdvfgfL8ltZVTlzgeLwFLJizQa84Q6+849/S2uokGJX6nyyOyu5/5FH2FiXZ2jNgJak+9gL/NNrPv7TV3+ZshwBbMfuH/HYoSJ+908/Q6khX42Hef2f/wNPtpRyx53bCV98F5Z/li/dsxnPAoagRCLB0aNHcblcNDc3MzExQVdXF0uXLqWqqkoUR0lvn3R9evskLb19UjBqweLwolhyjb8agWSYkD2Ko8iKw22ds/+NGGenc81Ui/XE81ccUWdrSHGtnP86sVCS+HQST8KFR3HOWkQJQNVCQID8PAteb+r8Ee3X05qmMTQ0xte//ii1tRX83u9+EYfDkekyfyDEt7/9c4aGRvniF+5h774ThIJhvvzl+6mtreDnP3+VvXtP8PDDd3HbbddjtWXPQMfjCV588V2OHjvPvfduJ5lM8uijL9DUVMMXv3gPBw6c4vy5dh566Db8/hBPPvUGd925jc997k6sVgtaelXrl1/ezSuv7Oa++3Zw3307SCRUfL4APl+A4eFxTp9p4+23DnDDjet55FcforSseMH9P/sTnOFq9L9og5jW0tsnBQJJNApQ0j91KYqS+Z5KJBIkEgkcTifO9KJLZrZebO1mcnJKbp90maS2T6rjuvUrGBgY4G++9rfceuut1NTU8NhPf8Z1Gzew7cYb+Zuv/S137NzJfffdw9/+3dfxerzcf/99lJWVEQwG+f4PfkhVZSUPP/xZ8vLz2bN7L4cPH+Hmm7dx44034vGm+zrdrqqqjI6OMTA4LLdP+oB8pIFwMplgsLeHU0cPEg2HQVFwOByUVlTSuGQZFVW1+KYnObZ/N1abnfVbbqC4tDxjx/TkBKePHiIWjbB87Qaq6xqyfikxosuOjw6jJpMoFgWPN4+ahiYaFi+loLDYdLDUUZNJBnq7ee/1l+lqb6G0opIdd97LslVrsae/ZN4vlxsIt7e389Of/hS/34/VKhfbkvxiomka4+PjHD9+nNbWVpLJmV+ulfRtcUVFRVRVVXHDDTdQUFDAT37yE0ZGRvjsZz/L1772NSoqKub9/+jp6WF4eJAN6X2EgawLdDURJzA9RiKUvY+weOFyOYFwdKyTv/zz/8rLbQr5hlVyoYC7/81v8MtbQvzlX77BI3/5J9xYm8do237+/C/f4JH/9YeU9Bzm777zPIMJJ1W1jayqinJiqJb/+T/v5uX//X85bm3EOd5J52iSnZ/7Cr/7+c2EOvbz3/75EH/6H/8d9Y4pnn3sCZ599yzRpBVPwyp++9//KtsXpW9pTVuS61NcSHlGT47gBEGP2cWj8fPW06QDYb8vgmLPo6CsBqs1NdOFHsCKAYSmEY9FCEyNYiNMYUF6YSG9PC17ds5A+B85EN/Er9y3GUt4lH1vPMupcCOPfOlBGoqcxCY6+MF3fsyKX/pDbltalFUfIDbRwfe//UOqbvsyNzQVAumZhfLyOZ7VVRm/tI9v/8sRfumrv0tz6cxSWJGJHt7ZfZTFN34Ke8sTcwTC/4NLVQ/zG5/ZyPTZd/nWzw6w5fO/zj3XVWM+gs6g/z+2tLRgtVqJx+OUl5ezdOlS0+sIYyCspG9hz+wjXFKF3Zn+3PWFp9KfswaMhyYZjU1gzQOHZ2aBGLP+F/N1soJi4TwiRx0MssZ3TOTnK9fJkvuA579ZG0YZNEhEkiTT+wiXeIpQ0n2QkdM0wuH0PsKuJF6v+fWLLq9pGsNDY/zd3z1KbV06EHbOPM4Rjyd4860DvPTSezQ2VDM+Mc3qVUv40pfuxWq1sGfPcR791xdYv66ZX/mVByguKUQBotEYgUAYm93K228f5PixC9x//y2sWLGIw4fPUFCYx7q1zTz19JucP9fOZz6zk/x8L9/93pNUV5XzyCOfpqKiBItFYXRskn/5l+fo7x/hy1++n2VLG0gmk3i9HhxOO8lEksHBUf7+H36Mx+3id373C9TXp360Me+FhX32RhZSvtD+N+t7vUw/CIfjhMIqXk8NLndJSsbw3GgikSCW3kfY6XDM/v4jZcehI6cZGhqWgfBlYgyE+wcG+Nrf/C0779jJzp23c/FiC+Vlpbhcbv7Lf/3zTCD8d3/395SVlfH5zz9MZWUFgUCAb/zTNyksyOfBBx+kv7+fp59+lubmZdx1152UlpbgcruxGeIcGQhfPh9pIByNhDn43tv889f/D6FgkNKKStREkngsyvotN/LwI79FwD/NN/7Xn+P2evntP/lzlq2auUjtbLvI97/+f5meGucLv/57bN1+Gw59UBXoaLnA9//xr2k9ewpvfgFOp5NQMEhBYRH3Pvwldt7/GdweL6qqEgmHiEUjKIoFt8eDze5genKCXS8/x9M//j4ut4fN23Zw2z0PsnTVmtRtJR+Ayw2Ejx07xve//322bNlCTU1Nzh8BJJKPM5qm0dXVxdNPP83BgweJxVIDtsViwev1UlRURG1tLStXruT2228nEonwF3/xF/T39/PZz36Wv/3bv6W8fOYHtFx0d3czPDzEhvVrsNlnb12jJhMEpkaJhSYoNATCGC5eAA4eb6ejb4oNGzZkykWmp6c5c+b0rEAYIBIOEo2rkN6zWL9estldeNxWwsEIDo8bq6Kktr0JpdI2NMKhMLGkhsVqw+WwEI6oePOcJMNB4lYHWixGEgWX243TZgFUQqEoLrcbi5LejicUJamB1e7A65qZ+ZkLo//iBaGYno/MhWA6IDIGMYh6DReU+oww9jwKS1OBsC6nCPX143g0QmBqBBthCvL1FXaz3uYJhL/BMcvN/MZnb8Bt1QiPtvD4Dx8ltOR+Hvn0Tdh98wfCP/jOT1jxS39gWp6LuK+Hx7/3PVj/JT6/czUuC6DFadv/HD/ZNcGv/v4jcPqxOQLhv2Ss+St88Y4VWONBDjz/XV5pyePXf+dXWGwIrOdifHyc1tZWSktLWbRoEXa7+cy0HghvTc8Iq6qG3x8hQToQdpj/AKFpGmN6IJwPdvfMc5263FwBhU6u/hdrGXtXLJsLUZfYjn68UIz+k/789HwE/xXDDLGeFw+nAuEKRymlnqKZ4CgjlAqEQ6FhXC511owwoj/pGeG//bt/wWaz8fDn7kwtNqWA1+OmvLyEiYlpvvmt1DZHq1ct5eHP38XNN12XCqKHx/nhj56lpaWLO++8kbVrlmGxWhgcGKWvf5jVq5fS0zPIiRMXeeCBW9m6dS2RSBRFUbBaLPzs8Vc5f66dz37uTlatXMzTT7/Jnr3HuX7LGrakn1c+fvwCu/ccY9u2DXz607dz/vwlWi52UldXRU1tBTarlY6OXl59dS8bNqzgi1+8h8LCvKy+y+X/fFzV/jfcRp6lV4NQKEY4rOH11uDxlGS1YgyE3S4XTqdzll36+6HDp2QgfAXQA+EN61cwPDTEN7/1HXbs2M6dd+wkHo9jsViY9vn4y7/8K3Zsv5mdd+zkO9/+LqWlpTz44P2GGeEfkZ+Xx003bePZ556nva2d9RvWU1tbQ1lZKatXraKkpCRzbqiqyujYGAMDMhD+oHykgXAkHGbPm6/wj//rv1BaUckXf/33mBgd4eUnfopisfCl3/z3VFTX8Hf/7U/xePP44//5N6xcdx229IDbfuEc//i//guTY6P82z/4M26+426cLvNAuPX8Gb7xv/+c4f5e7njgc9Q3LeLw3nc5+O7bbLzxZv7DX/wN+QVFDPR20X7hLGMjw1gtFhqXLmfRshX0dXXw8x99hzPHDrFk+SpuvedB7rj/M+QXFs07EOficgPhI0eO8Nhjj/HlL3+Z5cuXm/ahRPJxJ7Wf5H7++q//mqNHj2K1WikqKqKyspJVq1Zx4403snHjRqqrq8nPz+fdd9/lj//4j+nr63vfgfDI8BDrN6R+bBP/q5PJBEFDIGzcf9N4MXTiXDenL/SaXAZlp21WC/ft3DArEM6+4EnPkhnzTN5FeRGxjhka6SssYeZgIRj1irbqLFRfli4T/0U5vSwRT+LzRVAceRTMEwjrpALhUayE0oHwbP/PtY3QuaBAGNCS9J96i2///BA3/NJvsrMxzA+/9S3iDTewLCvAdNK4ZgOL8308+gECYbQkvafe46fPHaRgyUo2NNcSHLzI0fM9LL39l/nc1sV07fkB335pmM23rEe/ydpVUM66dWs5+tOZQNiORmyyk5//848I1d/Jb39ph9CYOVr62TSn0znn2GMWCPsMgbDjfQTCufrfeO6J59lc/W9Egw90/ot6jWnjGfN+9On+k/78xDay5IxtaxqJiEoiABX2HIEwGuFQKhB2u1U8nplA2Oxz0jSNsfEpfvjDZ9m9+xherxtFSf0Q2byskYc+fTvLlzfxzNNv8cyzb7Ft2wa+/Mv3UVNTgQYkEkk6LvXyxhv7OH7iAqqqYbOl7mBbtWoJn/rUTQz0j3DhYgc7dmxm/frlGf+TySSvvraXtrZu7th5I6tWLWF4eIzXXtvHgYOnsu4O2rhxFffdt4P6+irOnGnj1Vf2cLGlE0VRcDrsKBYLa1Yv5d57t7N4cd2s8SCX//Nh/PyNabO+F2XNMPZ/zh9BNAiF44RDKl5vDW5PCQqp80RvOx6Pk9BnhIVA2MihI6cZHBySgfBlYpwR9vsD7D9wgEWLFtHcvCzzmQdDIXa9vYumpiaam5dx4MBBPB4Pq1evwuv1EovFOHz4CA6Hg5qaGg4ePERvby8utwu7zUZ5RQVbtmymuiq1/ZdGar9oGQhfHtdGIPy//wsNTUv5w//v/zA5McaPv/0PjA0P8oV/+zvUNi3m6//9z65YIDwxMsxnvvJrLG5ewb533uSN555g043b+f3/+r+ZnhznqUe/T09nO+WVVUxNTpBMJLjt3gexWm08+S/fY6Cnk4rqOnbcdS+/8nt/RH5B6na2D8KVCIQff/xxHnnkEVauXGnahxLJx51wOMyzzz7LP/zDP6BpGkuXLuWmm25i8+bN1NXVUVBQgMeTWswP4JVXXuGP/uiP3ncg3NOTmhFev35t6tYjQ0CppGeE/VOjxEMTFBW4sRn238RwsaKqKsmEmk6nLk3ECyMdh918y565WMjF1FyIdpjpyiVjbFu8sDLWmblgy30xp+eZtT8XuerE04Ew9jwK07dGYyKfsTNza/QYNkJZt0Ybfcn9jHCc9qNv0WtdzvaNi9HvZFdjfo6/8yL93rXsXFvJwXdf5dJILDWDn8HL2ptuY0ODlQO7D1G9eSfLyxc2E5tBTTDW28KRo6cZ8kVx5JWwauMWVjVV4rRaGGnZzcu7L5BQZgJIb1ktt9x6G2PHXiZYvY3rV+m3QmsMXdzHme4gd37qU1nNXC56ICw+I5zQXBSUzswIz+onTWMsNMVobBybYUZYlJsPUT7XuW0kl8yVPP/N7DKzRWROOQ1i4STJwOwZ4YyIfmt0cBi3R8WbDoSNiP4n4glGRiYYn5hKRWEAioLH7aKiopS8fA8TE9OMjk5QWJBPRUUJNlvqVnYlHQxPT/sZHplgasqPokBRYT6lpUUUFOYRjUQJhSIUFOTh9c78H2iaxuSUn3A4QlFRPh6PGzWp4vcHGBoaZ3x8ElWF0rJCqirLKCjwYrVaiUZjTE35GR+fwu8PYbFYKCzMo7S0kMLCfGyGay2zz1L036zPxH4w7X+T88OszCydCy39JxyOExICYaOMMRB2OJ2z2tXtOXTkNEMyEL5sMoHwhpVoqko4HMZmt2c9n62pKqFQGJvdhtPhIByOoCjgcDpT1ydaasFESK2qHg5HMnfAKUpq4VC3x4PDcPeNnBG+fK6JQPgf/uI/k19QyO33fYaJ0WGO7HuX6rpGHvn9P8FisfDX//mrVywQ7mq9yNIVq7E7HfR0tOP25vFLj/wWm2+6lf3vvMGTP/oudU2LueGWnfT3dPHWi8+w4fptPPilf8Mbzz3JiUP7uP3eh7j34V+mtnHRZX0mMhCWSOZnZGSEN998k+7ubjZv3syKFSsoLCzMrFor8kED4e7ubkZGhli/bk1KrzAzJN4abTcEwsaLnFkXPHPM0pLjQsl4UQWQeX4ynTSrMxdmcsYLIjF/rpkx8UJqrmPI1mVElDPTkWEO//Vj/dZoxTbzjLAuY6yjowGJaAT/1Cg2LR0Ip7dPMtp8PseM8FVFS+Lz+0kmzdq0kldYkAm8r3WMgbBiuDU6bhIIY+h/TdPmfUbY2P+5EOsY88U8Pf9yz3+xDib5ol2iDiNmMnpabCseTpIQbo0mq87MjLDLPTsQNvOPdL9ppJ7XUIzbjClKOiO1hRaKgiXH/7umqiSTKkBqH3ZLauVmTdPSH7mS0Z2pp+ltzqxkpwBJVSWRSKIANltqFw4jKZ2aoT0rFktKgeibkVz+z1UuHot1MMkX9RvLjf5jli/MCJvdGh1PJEwD4XR1SNc4KAPhK0IqEK7lug2rTPtf5HL635iemREeorFxkQyEPwDXxFCqaRpjI8Mc2r2LrvZWlq5Yw30P/zLNq9blfO7ogxJPxJmaHGewr4eAb5olzStZfd1mNDXJUH8vk+OjdLRe4N3XX+LimZPkFxbhcDrxeLx48vJTC/OUlFJSXgGaRigYIBQMkDSsRi2RSK4cRUVF3H333fzWb/0WO3bsoL6+nsLCQtMg+HIwDl6K8GxW6qWZX+Gk6+pF+nFmMDMuVGPQJ6az2hdeug6jbnHgFPUaydQzBHPG9oz1FMz9N5aLZOwUbATQrrL/Wb6nn6s2YrQtK5jVbz3Va6SFFGb7/6ET9XFq/5s89dRTs17PvfAWXRNhscY1z6y+SpOz/xVmZrmE/Z1z9b9ZX+Xqf2P/GuuZ9b9YLh4b2zDW09/NbNUxluvo+vSXUUZMZ7WTDiiNGG0TirJ0GfOM73q5xZJ6ZtdqtWCxzLz0z0pRlFReOgjOsku3w2LBZrdht9tQ0oGrlqmbHejqL4uioKTLjP5bLBacDjt2hx2LJbV6dJYfaXvs6fYsFvO90GfVE95zlRuPjfqM9fR33X9Rl1FOL9ePjS+jDmP7ekIvz+gWfogQbTKzV3JlED9rY79cqf43pjNKNNmTH5RrIhC2WCzUNi7iS7/5e/z+n/9v/vC//RW33H0/+YWFmS0wYrEYI0MD9Pd00t/dyejwUOb5kHg8zvjoMP09nfR1dzIyNEA8Hstc6BgpLavgU5/+Je7//FfILyzmUst5Ws6eJh6P4/Z4cXm8LGpewZ0Pfo6Hf/W3+JXf/Sq33vMAnrx8URW+6UmO7HuPg++9nVqNWpX7sEkkVxqHw0FpaSllZWW4XC7T2dUrgab/EQI3c1IS4qBnxMxK42CGiYyYFjEOlMZ0Js/kO8+I8bPLJZkrX0djJqAws0PHzJcr7b+RLJ1mAoL/MxeL6SvstHLRlxyqri6uIrbd8RkeeeSRWa+vfPlBlixwQatrkcznKcz8pbNmMBSKfSCmM8xz/osBghnzaMg6/415IrlaUsRzVShbCKKcsf15XTSc52Z2m+UZuRL+6/K6jJgWEfPF9Hz13w+6LjOfMPhvbMtMVrTFaKNor5gWyZUvslA5ydVH7Aux/83OH7GOjpgvpiFXpmQhfOSBsGJRsDsclJSWs3rDZlasWU91XT0eb176NhkFm93O1MQYL/zsUf7563/Fd//2f/PSEz8hFAxgs9kI+qfZ9dKz/ODv/5rvfu1/8eyPf8Do0CCq8ddfRcFms+HyeKiqq2frjtu55e77Cfp9vPXi0wz09bBo2Qoqa2oZHRzgwqnjtJw5yclD+zh/8hjRSASrzYrN7sCSXp15fHSEN559gleeeoz+nm7U9C04Eonk44eiZA8mxsEp9TIGyNnP3ZmNQZphwMuUm8xICc1mYaojjWmeMBujH+svEaNucTAW/c+yRXjuULQDUT6TeeX8N0U0fi7/tdStnlpaKJf/s+p9KChYbTbsdvvsl81G+g7Pjx9ZM/Iz/Wp0x/h5G4/nc1lJn5cixv4X2zGeW7n631iekRcWoJrd6mz9qcwZj/S8rHIT/2fpyIFul0gu//WGjP7paUNxVvn79Z8cthvzxHIz/zHRIZKrPJf/Wf7M0Y6x3Og/c9TBxH+jjDEtli3Mf6NUiqxyk0A9l/+zNUmuBPP1f66yhfW/GbInPygfaSBstVooKatg3aatNK9eh8ebh9Vmy/oy9+bnZwJkp9NFPBYlFo0Sj8VwezwsW72Oles2kl9YRCIRIxZNlYuzsx6Pl+ZVa1m57jqKS8upqqvnjgc+y/Y778XjzWOot4dlK1fzxV//PdZs3ML4yDCt504TDoUor6rB7fVS37iEVes3Ul6V2qrI6XJTVVdPVW09brd7AT/FSiSSa5XMNaqmZRKzBihhrJnrQsLs28DsQtUMcfDLtGG4kNbbFjWK9uQabMV6YrmYZ5YW2zIiynKF/dfzRY2iTbn813/5UNJCRtPE9iVXBr3/Ff3jnwtjf6Q7ZCEzkfr/hU7O/hcwKxdNFNPvl4We/zq6tG7PfP7rX13GVsz81wtEOZ0r5b9o3/utL8qL+sxYSP8by8yOr0X/s/3KrUmD7H8uw/9cplwvytJk/KTk6/2/ZnP1+l9yJflIF8vSNI1oJIxvahKbLfXsrT7bqhOPxZiaGCeRiGflO5xO8goKCfp8xGLRrAHCbndQWFyCPb1aG0AiHsc3PYmaTJJXUIjT5SaZSOCbniQei+F0uckvKCQejxH0+4lGI2iqis1ux+PNw+XxEgkFiUbCuD1ePN48kskk01OTaGoy/Szx+7tt82ovlhVPJgjFw1kz4590LIqC0+bAaXMIc3qSXxQ+6GJZxlWj7en/Jc0wGKmJBIHp1KrRBQUu7PbUFiCkv8sUk8WcPgjihUqu/169TG8rl1wGLXvRqqx6hjJx8M3IzbUC7tXwX9ApIvofiyfx6/sIl9VgsQjfpyb+6/sIW7UwBYWpRZtE/8+1jdDdPzUrCJEsDEVRKCv2zN4+SXORn14sy/QcNqwabdxHWEfs/3n/b+Y4x3OVGZl1/hvTl3H+5/LBeP6L/hjlxbrxcBI1AOX2Eko8xSj67K3uo3Ef4fT2SYo284hhLtvn9F+wMZcOM8x8SCU+mP96ubFelv+CfaL+XLZfS/4j7CPsdqf2lTWSiMeJx+O43G4cDkfOc/zgkdMMDY2KLUjeNwoN9TVct2HlVe9/o7y+WFZ//xBNTXKxrA/CRxoIf9K5moGwpmmMBCc4P9qOJvzy+0lFQ8OKldr8CpqKa7GJF8qSXwg+aCCcWTV6fWofYR39fyeZjBOcGksHwql9hGFmlsfsMmKu/ztxAFTS/7fZU5Op9Cw5k7qZKsLAKR4bEWVEPXqZGRop+3L5n6veXGT5rweeJrdhmvmvrxqNLY+ishqU9KrRGQy2ppKG7ZO00P/P3nnHSVKUjf/bk/Nsjrfxcs7ckdORBRQVfyr6mhVfFdTXgOkVE0b0NWNAUARRQCVIOMIdB3ccl3O+vd3bnGdnJ890//6Y6dmemp4Nl7g75vv59O501VNVz9PV3dVPV3UVHo8t89Cn/h840kdLu28kIs+EKfLaWTS7EgRH2FNcgUnrCGvqX9HMGm1yg0nHERYRz5EMhPpHR2a081/rCOnup38l0dNPj4xzWTz/NY7LePJXVEfYD6WWYoocBSM6qg/WwvJJ6jrCnA72p/5LwrFQ7dceB738R61/nTSizGj2i5xo+7XptfZrj01aLsfySVqdY1pH2GzOyEtFAXw+f3qJHu2RTtqnDcuMT56fI2HJ0NTs4emJ7sSjopKdz0h1p7RUUnlmXA9C2vR/ssIUlHRnR/J3drnZemrSH4P9dpsNt9uZlhwPWq1VJMaof03+I8sn5WeNPlbyjvAbyMl2hDv8PewfPEJhUVFyXdQ3ObF4nFAwSIHBxZTiOsx5R/iMQJZlEokEJuGziVwcjyPcerSFKVMaMarrCGsaOzkRY3iwl2igH6/HhiW1fFJW86RVMd26pX6kG3WdMNQPVcVmUWSs+NHQS6vRWauXaJcmndooZ8edevtVXdLLJ5ndeEsqs3uESZWlOtiQcoR7MCkhPOl1hDNtlhUFWdaUJ6p9rKTMHTUfrSp64ar9ox0yIW3G85seucpMcaz2m4wGkKT08klxxYa7qByz1a45GCT/KAqQ7BHujmjWEc6IT5JONh6E+s8+ENqPxdWDmvqfCs8oL51+DC2yDppOOVn26zBWfMoRTgwnHeFiR0HmyCdJQlFkwqojbJdxOEdGzo3oodFzVPtFuRzksj/Xfi77xoxPqZKLrPoXddbR6zS0X1EUQsEYoZCCw1mJw55aPkljfywWIxaPYbPZsVotGv3G0PU447WljE4yn9Hl1VCxPFFaNVzvv0iucJXjix/dHi0nxn5ZVhgc9DE46GPy5Cl5R/gYyDvCbyCnwhE+ONRCWVl53hFONQx+vx839rwjfAbh9/tpa2vDYDBQVFSEx+NJDvXKwbE6wh0dHezevRtJYqSXU9NBk4jHGOrvIhropdBrx2I1ZTVPacQHrozmU22k1d+AlFpHc0Rct2E80fGZ+ot6ZesvcjrZH4smGPSFkKweCktrMIg9wim1SNUrKMQiYYYGOjHJQQoLUg5ZUjKrBLE8TjP7OYb4TP1FvbL1FzkW+2VFYdAXJq7Y8ZZWYbEmZ8DWXmuKAgoKPcN9dEZ6MHrB6siuT+EoHh+jmw9C0Khl5kgPOuUwiuwYiNkARAMJ4kMKFbYySp3JnkKVZLUoBIO9DA+343DIuFyW1LHXHPxUz3EyTTJc3c+F+JIyl7xYjkou+VOFqNdpbb8CgUCUQFDB5arB6SwBkmswk7p2YrEY0WgMu92OzWYd64zVu2RHDRfRymlPcRExv9FkTyWqXln6TdD+kTrQRyxnvPnnJvmi1uVyMX36dIqLi0WBPGOQd4TfQPKO8Kkl7wifmfT19fHoo4/y4osvsnDhQpYsWUJdXR3FxcW43e6se9exOsLxeJxQKJTzgSQei9LXeYTwYCuVZW5stvz5czoRDsfp7h1GshVTUTcTo2nsNejDQT99HU1YlCHKS5ND2vKcXBKyQnfvMFHFTdmkqVgdLlEESD7MNw+20xRswVwCNs/Y9Xk8JIeWppwfze+Joh2OqYeat9ZBzSU7YRQID8WJ90GDo5bagkqduTAUhoba6O8/gMcjU1CgjoTIc6agKAo+X5ihIZnCwpl4vZOyHN1wOEwkEsHlcuFwOLIc9TxnF0ajEavVmvU8lGds8o7wG0jeET615B3hM5NYLMZTTz3Fd7/7Xbq7uyksLGTu3Lmcd955LFy4kEmTJlFYWIjdbsdgMByzIzwW8ViE3vbDhAaOUlXuxm4/uQ/meSZGKBynq9uPZCuhqmE2RnPuUQMq4cAQPe2HsMg+Ksv1HbI8J5ZEQqGrZ5gILsprpmNzekQRSLVhTYOtHAocwVwqYffmr7cxUSDkixHvhcnOeuoKqjEIDpCiyAwNtdLXtx+vN0FhYd4RPtNQFIXBwTA+n0xR0Sy83rqs77fD4TDhcBiPx4PTmX/JlydPLvKO8BtI3hE+teRyhBOJBIFAgHA4nLM3MM8bh6IobNmyhZ///OesXbuWeDyO3W7H7XZTXV3NokWLOPfcc5kxYwbFxcVs2LCBO+64g7a2trwj/CYi7wifGeQd4ZNI3hF+U5B3hPPkOXHkHeE3kLwjfGrJ5Qj39vaybt06mpubda+DPG88HR0dvPTSS2zdupVYbGQpNZPJhMPhwOPxUF5ezmWXXYbH4+E3v/kNnZ2deUf4TUTeET4zyDvCJ5G8I/ymIO8I58lz4ji+J8PTBEVRiEWjBAPDDPuHGB7yEQwME41EUBRZFM+TJ4PBwUG2bNnC4cOHM5ysPKc/kiRhMpmw2Ww4nU7M5vzDcp48efLkyZMnT56xOSN7hBVFIR6LEfAPMTzsJzjsTzq/w35i0QiKomC2WnE4XLi8XlxuL063B6fLnXxQPk0mDcj3CJ9acvUI79u3j3/+859UVVVx+eWXY7cnZzHNc3qgKAqbNm3iZz/7Ga+++iqJRAKn00lhYSE1NTUsWrSI8847j5kzZ1JQUMCrr77Kl7/85fw3wm8y8j3CZwb5HuGTSL5H+E1Bvkc4T54TxxnlCCuKQjQSpr+3h46jzbQ2HaC7tQX/YB92uw2vx4vdZgMJgsEQPt8QkUgEd2ERZZPqqK6fQsWkWoqKS7Ha7W/4LHp5R/jUMpoj/PjjjzN58mSuueaavCN8mhGNRnnyySe566678Pl8lJWVpSfLmj9/PhUVFbjdbqxWKwaDgZdffpkf/ehHdHV1sWLFCj7/+c9TVFQ05vWuKAqJRAJZllF0vhWPx6L0dTQRGjxKZVneET7dCIfjdPX4kazFVDbMHtes0ZGgn972w5gVHxVleUf4VJBIJGeNjiguymumYXW4RREgOZPykcF2DgeOYCmRsOUd4XER9sWI90o0OmupLajSnTXa52tlYOAAHk8iP2v0GYiimTW6oGAWBQU1o84anXeEz24kScJgMGA0Gsd8zsmTzRnjCMfjMfp7umnav4cDO7bg6+2isb6W+XPn0NjQiLfAi8VsTuuYkGXisRhDQ0M0HTnCth07OXDoMK7CUqbNXcjkmXMoKi3DNI6HpZNF3hE+teQd4TOT/v5+/v3vf7Nq1SoWL17MOeecQ21tLR6PB7vdjlE4twcHB2lpaSEWi1FUVMSkSZPGNWQ6FArR399POBwWowBIxKIM9LQSHuqgrNiJzTqx6zXPySUSjdPbHwBLIWWTpo7DEVaIhAIMdB/FpPgpLXJkuQx5TjwJWaFvIEhUcVJcWY/Vrv8CQlEU2vxdtATbMBeB1Z2/3sZEgchwgvgA1NqrqHKXZz0YK4rM8HAXPl8TLpeMx2PNiM9z+qMoCn5/BL9fweudjNtdldUjHI1GiUYjOBxO7KdBx0+ek4vFYqG0tDT//HoMnP6OcGqIR/OhfWxZ9zL+7g4WzZ/LsnPOobq6Crfbjc1my3oYVkkkEoTDYYaHh2lra2Pta6+xZftOCsonMX/5BdQ2TsVmf2PWWDvljrACsXiMcDA5O7IESAYDZosZi8WCZDhxxyAeizM06CMcDuNyuXB53Rnnj6IohAJB+nv7sVgtFJeV5KzDiRIOhRno7cdsMVNYUpTON+8In5kMDw/T09ODwWDA6/WO+S2woijIcnJuAPVN6Xhob2/n0KGDOByOVBq1V1gCFBLxOMMD3UQCvRQW2LFYktdUWkRF7EzWi1PDxP1cZKqSyWj56zEeGXKUOdpvlYnoJ+7nQq9MlVTaWDTB4FAIzB6KyiZhMI59P41FwvgHOjEqQQo8ydFEafTKHO23Sg79QEde3M+FXpkqo+Wvx3hkyFHmaL9VxtBPVhSGhsLEFDuekkosVu39diRTBYWeQD9dkV6MbjA7Tkz7cLYTCyaQ/VBuLaXEWZjVI6woCsFgP4FABw57Aqdr7E8IMlBGO3dSla+kBCS9E0SP8cqJ5edKJ56EIqL8BDgN7FdQCARihIIyLncNDkeJKEUsGiMai2G327BZrelrK/nkl2S00rRmipe8Xrgakpn/iPRIjYysoZ2dXh+xfBVt/qRKJ+uM1yLql5tcduYKV0PeCPtlWWbQN8SsWbOorq7WSOQZD6e1I6woCoFhP/u2b2HrulWUeJxcc9WVzJo5E6/Xq6vzaMTjcXw+H/sPHOC551+gub2b+edexJxF5+B0e065M3yqHeFEIkFrUwub124gEolikCQsViuFJUVU19VQXl2Oy+M+Icehp7ObF59cyeG9B1l60XIuuOJibPaRIVixaIwdG7by6P1/p6axlvfe+gHcXv0hchMhEU+we+tOnnnkSeqnNnLtzTfgdCeHBeUd4TMTWZaRZfmkD/tpaWmhvb2NWbOmp0ZQqM1MsumRE3GGB3uJBvrxem1YLEahGR6diciKjLfBnAjj0WcsmbHitUxEVmQ89sdiCYb8YTC7KSipwjDGOuEKCvFomOHBHoxKCK9Oz9hYOo8Vr2UisiLjsX+iHI8+KhPJQ5WVZYUhf4Q4NjxF5ZgtNt1cFBT6ggN0R/qSjrA90xFWU6j5iv9VxH1tODr5iPEqopw2frRy9eTJoRM58hHRS6vKxUIy8jCUWoopdhTouAUKwdAAgUAnDruMw5H7peJYiLqOxkRkRcS6OhEcjz4qE8ljIrIiov2KAqFQjGBQwemswu4oSsWlJYjF4sTiMWw2G1bLxO9t2WfuSN7q7xG3T8xJTKPKji2XjViKVvOxrciFvj5azhz7Y7EY27bvpKGhkfr6ek3aPOPh9HWEFYXhYT/b1r/Krg2vsHDOLK656komTZqU7L08jgfiaDRKS8tRVj6/kk079jBryXnMW3oeLs+pdYZPtSMcjUR4+ZlV/PzOnxCNRCgsKUKSDMRjMcoqy7n8xiu56OrLKCpJfk8pyzKRcIR4NIbBaMRqs2JK6ZhIJIhFYxhSPcoA8VgMWVYwmoy0Nbfy11/dx9b1m7nuXTdww3tvwmyxYDabsFitRCNRXnrqeX7y1buYtWAO3/zl9ygsKUJRlOSbzEhy0jOrzYo5Vd9yIkE0VabJbEr2+ilgMhnTE6D1dvXw7wce5ZXnX+bG976dq266Frsj6djmHeE8o9HS0kxXVxfz581OXkupc0q9IyQScYZ9PcQC/Xg9qR5hHcSmTVEU3fuK2ISr6UT0ZCS9ckbZF/MW8xTTaMkVl21Rkiw9xmu/ouhOZCjqqoaJ5URjCfxDYSSzC09JVbpHeDT7Y5Ew/sFuTEoIr9eWJccZZP9o+6PprtVDlGOUuGxNk2TpIdifdITDxBUbnuIKzJbUcRfsVxSFvuAgPdE+TClHWM8mUT/RXnFfDVM51farZJV7IupfgXg4QdwPpZYiih2FGCT1VZ4qqBAKDRAMdmFLOcKijTnzF8L0yEp3HPaLqcajnzZOb18NU8nSY4z8tWF6ZKU7CfajQDAUIxSScTqSjrAqreoei8WIx5KOsMWa6Qif6faPpp82Tm9fDVPJ0mOM/LVhemSlOwX2R6NRNm7cQm1dfd4RPgZOoWc7McLhEHu3b2b3xrUsWziPt914Iw0NDVit1hEnLRIhHE4O850IFouFhoZ6brzhBi5ctoQdr73Mzk3rCYeCouhZhaJAJByhv6cXu8POte+8gevf/VamzJ7Ggd37eeTev7Hh5deIRqKEQyEO7zvEK8+u4j//eIKXnlzJ7i078Q34SMQT9HR089pLr7Jr8w5i0RjD/mH2bN3N5rUb6WztIBGPE4vFCAaCdLZ2sGHNep7/9zNsWLOevu5eFFlGjieIhMJEI9G0A9zR0sbGV9az8l/P8Myj/2Hjqxvo7e4lkUjQ29XD+pdeZfPaDRzee5CdG7fTcriZRCI5DFaWZdqOtLJp7QYKigqYs3geFusEh33leVOTfmRMNUjahkjSaUBz3XnUhkphJC9GaUzT4eq9TP10IUc549nXpkfQX5unno1qmF6c+lssU8t49Na1Px0wuv0i6XhNplpb1f0M+1PHWkJKF6SVUdNof5/29mv2x7JfJZeNo8Udr/3afHVRlIxnwrGaeL1o0dbTyX7GOgZC/Y9FWkZKPU8DUqr/SdHoLqVkQHv+jyCWKcZpGU0vrf3aXrCx7FfD0rqOIw1j6Jtl/yh5qjKj5acybvvHuP/rhY1HVz1G03esPBVFIRFPICcSyJrzT5RTyWW/mu5U2j9afSma/MbKU6u7Vl4rp8aPZj8nyH6xHK0+WkS5PBPDePvtt39z5Ju4TGLxBP3DYSIyWFIO6KkgHo9xaN9uNq56jgWzp3Pj9ddTWVmR1jEej9PV1cWWLVtobm7GbDbjcrl0bciFwWDA6XRSXlZGcNjP1i2b8ZaUUlBUguEEfas6FknnL4pRSVBR4MJkHL/+pL5p3LlzJwsWLNBdHmY4GqQ/4sPpTB6bRDyRdG6fW0VlTRU3f/jdLD7/HCY11NLd0cWeLTuxWC3MX7aQg7v38+df/JEXn1zJkYNH2Lp+M5vXbsBmt1E5qYptG7bwy2/dTU9nF0svWk5fdy//+NNDrH7mRbxFBXiLCti1aQcHd+/H7xviwK79vP7ya2xeuxGA2sZ62ppbeXXlasoqy7n0uhX0dffwj3sf4om//YvWphb27djDhtXriITD1E2uZ+/Ovfz8zp+wYc169u/axysrV2E0mZg+byYms4ngcIDXVq3l9dXrWHbxuZx/+YVYbSPDsWVZJhqNYsVMkaMAo5Q8Xn19fezbt4+ioiKmTp066venec5efD4fw4FhKsrLMBgMWfc7WZGJhYMkYiFsVjMmoyHdWCUf3JPyYmOmzUWv8VORUo2m+j8jXPgt5qkXLsZpHxZEOT1yyWh1YTz2C7aQy37Vdp00Yp5a1DBZVohE42CwYHO4kQzJ+lE3PfvlRJxoOIBBiWO1mjIyF8vRos1jovbr2U5KLlcaMU8t6TRjxIn259JDRZUR81Tj1PDx2K/mIyVFiUTjyJiwOlwjPfc69odiYQKJEAYrGM0j9aklnWaMuNPGfjUTAT37EcrXliuGqeFyXEGOgsNox2EemSRJa0s8FiYWG8ZiBpPZmNZLq582TEX9rS1PKy/+l1I/xHxUMsoTjp/KePa1+ujFobFF3bT2iv/VtKLe6m8xXzFOT0abj0pG3hO0PxZLEI+BxeLGYrZnDbtNpD4pMplMGFOjBVWdJI3eciJBX18fTU1NHDx0mNajbfh8QyiKjNliwWQ0EolEaG1to72tDaPRiM1mQ0o9OzW3tDDsH0aSoLOzi5aWo3R1ddOd2rq6uunu7iEcDmOxWjCZzciJBF3d3bS1thKLRrFarekRjbnsHW1f3US04Seq/rX5qPmqcVo5UUYbr5KRRqf+tXlow8R9OZGgo70Tb0EBBQUFgkSesZiY53UKUBSF3q5Otq9/lbICN1dfdSUVFSNOsKIodHV18c9//pMHHniAv//97zz44IO0tbWlJ8gZLwaDgfLyclZcfhmTayrZsPp5+nq6J9zDfCZiMBiw2my4PC5qGmqZNmc6sVicztZ22ptbefnZl9i+YSv1Uxv5wG0f5cIrL6H5YBMvPrGSztYOgsMBuju66O/tR04kSMTiDPYP0tfVSygQRJGTx9BoMlLbWMd1N9/AkvPPSTq/z6+hu70zo75CgSDbN2xl9dMvYrPbuead13PhlRcz2D/Iq8+v4cjBJkKBIN0dXXS1d5KIJ6ib3EBxeQmG1CRfXe1dbF2/GU+Bl4XLF2PVfJOcJ8+4kaTklrrfiGgbt3QjqHlwDUdiBIKRjG04tam/A8EwgWAkIz8AOR6lp7ubto6RrbO7H384ni5LD1XPDJ208ZqwXPmIDSyafBOxMF2DwXRatRw9+/XIVaaIaIfe8c8O0ZFLdfKq6NovqY8ZSWE9C7LyTXHK7BcFxiBDJyFcDZtQnifIfl10kqj5Kamik5PfjJ8zyn4dMuwX4vTIKjWVMHlWj8Rm5DWidFbQeMmyX4jPhSqn/hfTH6/9arqk/Znho/0eT1laTgv7pZGblnqajqaTWAZAIh7nwMGD/OlP9/O5z3+Rz3/uC3z2c5/n9s9+jl/+8jfs2b2HSCRCe0cHv/jlr/jErZ/iuZXPE4lEicViPPPsc3zpi3fw05/9H6++upbf3vM7Pv3p27n11v/mQx/+KB/+8Ef55Cc/ze2f/Tz3/uk+jrYcpb+vjx07d3LPPb/jM7d9joceepi+3t4M3cdlv46Najq9+tezX1veRFDL0StrNEarf1Gv8eiUzmc8wnlycto5wpFwiMP7djPc28F111zFpOrqjJ7OUCjEli1b2L9/P+9617t4+9vfTl9fH2vWrCEYnPjQZqPRSF1dHRdfeAHxwBB7tm0kEg6JYmc1iqIgJ5KXnmQw4B8apmn/YcxmM/POWcii85aw8NzFeIsK6e7sov1oG4l4IpU4nYsmxxHsDjuNM6Zw4VWXcP4VF+Ep8OIbGEw60BpH2D/kp/ngEXwDPgb7+tm45nX2btuN2WLGYJDw+4ZQUvK1DXV88PaP8LEv/TcXrLgIs8VCNBrlyIHDNO07ROOMyTTOmHLCZqHO8yZDUdItS0bPTOoU1zZeYiOoANv3tPC3x1/L2B5ObSO/1/PIU6/jG0res9Q8htr28OUPvoNr33077/vIF3jfR77Au2/5LLf98CH29CUdZ70GWPs2Wd20jWmGbOq/ihiXna9Cz/61fP6bv6GpL7m0lFZOm5/YgGvL1zqVYvp0HqIdqd408e6Sy34VSRm//ZAS1tFHm6+iqHOSZm9pmXHYr5c2nYdof448RftVcqXTLUuIEzc4Ofar+9p0ujqlA7XzsJ759uul1eahlSFHnqoeItp3O+SwX0RPFz29cumfIaOjKykZbXr1/1g6kSPPnPbnSKcNF9OJdoi/VU4n+1WZjIhR8tSGpX8rCj09vTz414f4031/pq+vj7nz5rJkyRKCgSAP/e1hHvjrgxxpbiYcCtHS0sLePXsZ6B8AFBRFoa+3jwMHD3L0aCuxeJyqykqmTp2C0+Wivb2D1rZ2PF4PU6dMoaqqEqPJyNq16/jJT37KAw88yObNm+nq6iIWi2fpOJr9x1L/Whktaho1XPytkqv+tejpSkpurPqXBHk1Ti9P0f70dZ/nmDitHGEl1Rt8ePd2Fs6fy4wZM7BqPvJXFIW2tjY2btzInDlzWLp0KcuWLWPRokVs2rSJrq6uCfcKA5hMJmbMmMGyJQs5sGMLg319GY322UgikSAYCDLYP0jT/sPs27EHq81GTUNdcnKpVKNvMBgwmozJGXsNBlCS9aA+IMRiMYYGhwgGQ8Si0aw3+JJkwGw2J4e9KAAKRqMRo8mUed0qSZ1AwuFyMamhhnnnLOTad17PxVdfRml5WbJ8wGK1UFpRRkl5aXqW697OHrat34LFamHJBeecsNmv87w5Uc8dbSOkpJfCSO1r/qflFAVZVnC63FxxxZW627nnXsKUqfOIxuIZ6Um1ZYm4nbd/8nbu+fm3uOfnd3L3tz+IfetK7vv3ToIyKPEIA709tHd00zMYIKGAHI/Q3ecnnvLpQv4BeobU9ZBlhgb6CcUSKIpMwDdAR0c3nT2DRGLJ+2UiFqZ7cBj/QC8dXYNEZUjEQnR39dDePUA4niAUCqf1jIYCdHV209HVx1AohoJC2D9Any8po8hxent6GAonX5glYmF6BoPEosme5dCwj46Obrp6fUQTI3eNXFdsrvDMGhlBLz/tPV2tq+Qvbc9KZo5i/np6qLmM5KlfvhYx37Hkc4WL+ahhevll2T8ORDk9PfTsV9GTR5XXiOrpOxIiTPakQS/8TLFfbz+XvBiu7mflk1JEVSOX/cmAzF09xrJGa7uiI5Gxr32poA3XIKZXEcNz2a+G6R3PLPt18hXJSKHzPPFG2Y9gj1Y1JRk5UoYkoShJx1VLIpFg69ZtvPLKqwQCAd75jrfzlTu+xFe/8iVuueU9OBx2nn32ObZt2048nkCWFRKynJGXnF6qUKG0pIT3vOfdfON/v87/e9fNVFVVUVFRznve8//4+te/wrtufifVVVV4PB7q6+spKChAUZKfHKno2SnphB9P/WvTiPmKZMgeQ/1ncIz1P277c2WaZ0xOK0c4HovR1nKE4f5uzl2+HLc7czmdaDTKwYMH6e7uZvny5Xg8HjweD3PmzMFqtbJ161ZCoWPrzS0oKGDevHlYTRKH9+8iGlEfIs9OBvsGWPfCGv7910d56J6/sHPTNibPmMr5Ky6kpLyUuimNxGMxdm/dyY4NW9m+cSuDff2UVpQxqb4Gl8eF1W6jp6OLFx5/jtdXr6PjaPtIT3GKaCRCR2s7m9ZuYO2LrxAYDlBZU0VZZVnGt9hOt5PaxjqcbgexaBRPoZe6KQ2UVZVjMJmyHGwtiUSCo4eb2b5hK5U11cxdsiA/SVae40JsSJON3EhzpDZOauOX3lKNncVsprq6OmurrKxi7Vo/v/j5nnReKukGXDJTUVPDlMl1TJ1cz/zFyzl/npP29m4i4QBrn/gbn77tm3z+S9/jY5+9iz+/sJuuIzv45he+x0uHByER4Zl7vsGVt/+OpoEI8UAbv7jz+/xj2wBd+zfw7W/cxW1fvIvbP/9tvvfHZ2gfjtO9fy23ffx2PvvF7/HFb/2ZDYfbWPnw7/jwx7/OF/73bn7z2CZ8iaSC0YFm/vizn/LJz36bz3z2m/z3137La039HFr9d27/7mN0xyHUdYA7b/8on39gMwkU2re/wJe/80c2vP4St3/mS9z5zZ/wxa98jw989A5+9uQ2grHkFa69yvXqQHu8tXFqfDpQE5FOp3m5kZTT1GIqY7EHWq1j3fSCPmr9p3MVnSLN7L1avVW05ar7aGTTemjCtPnoxWeEC/pr5cRytTLa9Ho66tkP47BfOAhZeWt2MvTQJNW1M1f46Wa/Nk4oF0EHdV8tTw+FEUW0lmr115LlPGl+a8seSZ+toyqjbuo+evbr2KRFzFuUFfdF0noKMiP6jxwVVU4ro/2tLUsrL+qoyrwR9mvrU9GMgJFScZJavpKcjVi0PyHLHD58mI6OTmpqapi/YD61tTVUVFaybPk51NbW0tHRSUvLUYLCc7V4LgGYzWaKigqprCinoLAAs9mEyWSiqKiIiooKCgoKsNlsLF26hI9+5EMsW3ZOsqNLAVJPeHr2i/vZJSfJsF8vXHBERRntb21Z2n1RR1VGW2a6vlITjmnlRrNBzFssZ6y0eY6d08oRHhocoLP5MA31tVRXVWUt6dTb28u+fftoaGigsrISk8mEwWCgqqqKadOmsWXLFvx+f9YNaDwYDAYmVVczc+oUDu3eQfgYHerTGUmSsDvslFVVkEgkeOHJlTz/72dpb2ll7pIFvPND/48FyxdRMamCC668iBnzZnFg515++/1f8Py/n6WmsY6Lr7mMSfU1VNVNYsGyxciywsp/P826F1/BaDRSXFaCw+nAbDbjLfTicDnYuXE79//fH9i4Zj3T5szg8huuoqSiDKfLQXl1JYUlRbi9HhYsX8xFV1+GnJB54qF/8vsf/5q//+FBdm7aRiQcwWazUV5VQWFpUYYT7fcNsWfbbob9fuYsnkdRaXHWxGF58oyPke+DNSFplJEJhrPixkNzs4+HHtrF7t29kGos0TakioJEgoGeHjo6umlv72T3hlU8uTVAXUMVg/vX8vM/beKi993K3T/4Iv99VS2P/eovHIx6mOzys/VgP4lIN3s2ttK/9yhNgyGGmnays6+AWVVR/v6HhxlouJxvf/sLfOO2txPZ/B/uf/EwMWQCTf1MvfZ9/OB/b6FiaAe/f/gQb/3U7fzgKx9iuiPA4UFADrD6H3/jqYMevvjtr/B/3/tvLnS28Ov7XsE1dRqJozs52BOnr6OZzsN+9q4/QG88zsEdu5GKGil2mfDvb8Yx9wq+990v8dm3TeW5h1fS6Y8mD5C2lyP9K7uhF/fRyotPFDqoxzq9p63UURBFxqp/VRW980U3PIf9IqIeaM+hcaCam1X+BBkrnVgVqryS+pNVvmB/Rp1qOFH2a/ePhbHS5bJfLy4ZOLH618pky2eHKJpgbfnZkuNDTCfaI9qoZ38uG8S8VXLpLY2SRkWbLpdeE0FMd+rsF3JO3cLUNAqg6DirGfYrCqFQiGg0itPpwJmaNFeSJFwuN3a7nUQiQTgcJh6PafIY6RGWtJkK+Y8EjghIkoTD4aC4uBin05l0TqWRFOO3P4konyuNinq8pUy1x0yXCzGdNk91P1c5apxog95vLXr2aw5hnmPgtPIWhnwD9HW1sWDePJxOZ0acoih0d3fT3NzMwoULcblc6Tiv10tjYyO9vb20tbWlhthOnKKiIqY0NtDb0c7wkO+YhlmfzhhNRqbMmsZ/ferDfOAzH+XmD72H9/33B7ntzi9w253/w4VXXYLb68FitTJv6UI+cceneddHb+Giqy7lbe97B5/8ym1cdv2VOFxOGqZN5gO3fYRbPvlfvP0D7+IDt32Uj37hk7zrI+9lxvzZFJeXcuGVl/DB2z7G+z/zYW54z028++Pv4xNf+hTnr7gIl9vF5JnTuOW/P8jV73gLTpeT2sZabvnkB7j1q5/huptv5MIrL+Et/++tvO2WdzB11nQmz5jC+/77g1z7zhtxp4Y+K4pCZ2sH217fTElZKQuWLcr3Buc5DjKbMm2DozDy7akaJzZ04r6WRELhiScOsnlzF9WTkqNd1B6kdDmSRCzazZ9+dBe3fOQL3PKxO7jjV89Td+k7+Ni10+nZt4PQlEXceOEsKiuruOSKFUzztLGxy8iSuRXs2HwAX2czLea53DDfyP7mPg5s3Ylx2jzqw4d5dsMRuvZt5t4//pX7H1vNgaYjbNm8m0AUTBWNnLd0ClUlHgYO7kWZvoS3nDeNSTX1XH3VucwuAAKDrNvexNIbr2XplEoq62fwtuuX07n3NVptM5jpHmTjrqO0Hm6j7LwV1AYOcbhrgB07jzJrySycJjCXTuPSyxdQU1XO3EWzcQZ66YvEkg8oml438fjqPcAgHnMhUk82/fCQ7iEZkVLf4qvlqPIZDxypBztRP20YmrrVptcixo1mv1YPbXmMoof2vzY8ozwye65E+7Vy6u9jsT8XYt569sPIC6hjtV8tQxFt4Y2zX40by351E/VSUfcV9U9aYPRPDpK2ZNqfDtfaMYr92v8q6XTjtF+7j47d6pYrHz09RJ30ykmXdwban/ydmbOox2jlktKvoKAAh8PB4OAg/f0DxGIxFFmmp6cbn28Ii8WM1+vB5XJhMiU7H8LhCLF4HFmWCUcixBNxzGYzxlS8qm8aHYc8iVZqpPdUtFvPfi1qLpm5ZaKXNl3eGVj/WtT4PMfOaeMIK4pCYGiIgG+AKZMnZ3wbTGqSrNbWVhKJBFOnTs2IN5lMVFdXU1VVxY4dO455eLTJZKK0tBS3y0FPZ3It3LMJo9FIVW01K956NdfefD1Xvf06Lr72chadu4RJ9TU4XKk3dIDNbmPKzGlc+bZreccH/x/XvutG5p+zkIKiAiRJwma3MWP+LK57141cd/MNLLvkPM5fcREXXXUJdZPr8BZ6mbNkPpddfyWXXreCa975Fq56+3XMXjwPt9eNyWxK6nLjVZxz0XIsNisms5nKmiqWX3I+17/7rbzzQ/+P6951A/OXLcJT4KG8upLLb7yKZZeci93pACARTzA04EORFeads5BJ9TX5SbLyHDfpRkdoJBFmFxYbJ7Fxi0QSdHYGkGWFnp4g//73fgwGiWuvnZyWURTNR32A0VzCez792fQ3wr+5++vc+anrqfOakKMJTHYXFpMBBTCazNjtEoGwiRkLZzO8bwcvb95HcO4i3raskG3btrNxZy9zFs3AGQ0xbHdx3iUXc+XlF3DVFZfw31/9Gl9533I8ZkCSMEpJm+ORKNicmI1JiywODx5PKi5uwOuxp2212ewgB4kpRSyeW8y2DTvYdvgI1RdfxvyyPl5f9xq7u1wsnjUJI4DRmM4XJAySgvaV40hM9vFVEcPT+0KEuiv+Rz3ualjq8Kv3vzRi/afQDx3JP1e8Hor2e74Ux2y/gGh3Ljm1fNF+8SFRRT80d/4iUuqPMpr9msyEz/OzyhH3VcRwcV/lVNuvRWt/Wg/NpkUbr4eqflJOXFAnlS6ViZIOyLZHTCei1VcrO1Y6PTJeRKT+i/ar/3PZL+qvcqz6jSX3RtuPznfzo5Ut5gNgNBiYMWMGDQ31tLW1s/rll9myZSs7d+5i5XPP09R0mCmTJzO5cTIV5RWUlJRgMBjYs2cvW7duY/fuPRw4cIBAIEBZWRkejweDeP8UkBWF/oEBjh49ypBvCDmRYKB/kJaWo/iGhpBlOcN2UW/1eIvHXKyHXOGiTC7GkjuZ9X8s9uc5Pk4bRzgWjTLs92G32SgoKMhyZvr7+zl06BBTpkzB6/VmNVilpaVMnTqV3bt3H/PwaEmScLvdlJaUMNjXTSJxdjnCACazCafbidPtwul2YnfYMVvMWceTVA+y0+3EU+jF5XZhtmSur2s2m3F53DjdLqw2Kza7DbvTgclsTi3PZMXhcmB32JPluZwZa/SazCacLic2uy1dvprO5XHjKfDidLuwWC1IkqQrD1BdX8N7bv0vrn3n9bg8IyMF8uSZOMnzSlEbnXSv4QjahxW1B0mV18rF4zK//e1m3v3uf/Haa2089dRBdu7sYcmSSi65uDadl5T6fmukzOQ3wlMn1zG1sZZJZV4sxmS8s9jLcHMTPcMRQGFooIf2Lhv1FQ4KpsxmcmI3jzy+m1kzZjJ75mSaXnmVp/vsnDevHKmwnDqLEaO3iosuPpfLLl7KJEec4TAjjqgkgUHCU1ZMtKWJ3uEooNDT2sSRLsBipdJr5MDeo0QVUJQYzYeaMZprqCgxMX3eLIb3PM+27SEWzZzJzMkFPPuPp+moWsjc6pFPXTKPVeYxF1Eb/vTxSYWL++nAFOnwlKOhIDhd6XvISHejWL7efTHjTb9O/afjUoh5qqTlNaMCsuyZgP3acO1+LvvVsNEmcTlW+7WIeWrDpNHsV9Q/Corm+9Szxf60vDgqRJBVyxLjxfKkpDoZMknBTPu1SIxuvx4Z9qdQ80csO0eeov1qGDrptfaK+6r9Wn20csljkrv+k4IjTqWeriKni/0ZL+n0f2aEKYL9RqOR2XNmcfU1V1NXV8uzzzzHN7/5Le74ytf49+NP4HF7eNvb3sr8+fPweD0sXbqUGTOms3btWr773bv46te+wbp1r1FVVc2SJYspLyuH1LExGpJrDdtsNowGQ1rreCzGunWv8evf3MPGjZtJJBJs3rKVe373e157bT2RaOoTGQ2i/Sq5jrlW7kysf5Hx2A+Zp0OeiXEaOcIRQoEABQXeDGcJQJZlurq6aGpqYu7cudjt9ox4ALfbTWNjI8FgkKNHjxI/xt5cm81GYYGX4aFB5GMcYp3n1GE0GSmvrmDBskVMaqhJLxyfJ8+xkdk7m25s1DChsVEdWD0SCYXWVj+bN3fyv/+7hgce2InRKPHOd86grCz56YckZCk2sGjjDUYmL7mYCwrb+MFP7uPRfz7J9+/+C0M1izhvaiEmZzXzG+DFTUNMm1JCQd1kPEd343dUMrXQgaV4Mu9a0cjjP7+b/7v/Cf5yz2/5xv/9jf1DsqYhUEAyUr/wApZ6j/KDu//M3x5+hJ/c8wSHg4CtiKuuX0H7S//gW798jAfvf4C77n+dRVddQqPLSFnjTJyDe9gVrGF6nYPJkyfR8voeJi+ZRVFqve/kMc62Ex3bRXLFp49RLgH12KYeYkCt09SW+icmT0vonROj1L/ocIioL1DE8sR9kVzxYml6cln26yDGaY5QRpjKsdqfi4zyRWX0g+BMtH+M+s+Vekz5VKZierWsDMdeFNLJf0z79bPJkskivdZxJln2COjJi/qp4eK+ar8Yp0WMOxb7RXm9PNVwMW5C9kua4UliRjrnX5b9koTX4+HtN72Vz97+GS659GKsNitGg4Fzli7l9ts/w83veiflFeVYLRauvvpKPvOZT3H5ZZfhcDiwWq2cd9553Hbbp1mx4nJcLle6jIqKcs4/7zzOP+88SktL0u9aJEnCaDBgNpmZMWM6l112KbNmzcThcGTdY/UQzVSPv3i89eSy7NdBjDsp9Z+yM5ee6OSpoievPZ/yHBvG22+//ZuO1EfyIrF4gv7hMBEZLFZr5k30BBMOBTl6+ACGWJjly5bhcCSHvgLE43Gam5tpbW3liiuuoLCwMEsXSZKIxWI0NzcTCoWYNm1a1vBqlWg0Sn9/P/F4HIsl2duoEgwGOXDwIIOBMJNnzMGSI48TgaIoxKJRjEqCigIXJmN2HYxGe3s7O3fuZMGCBZSWlmbV4XA0SH/Eh9Ppyoo7W5AkKb3E01g2yrJMNBrFipkiRwFGKSnf19fHvn37KCoqYurUqVkvYvK8OfD5fAQCASoqypOThggNqKLIRCNB5FgIm9WEwSjIpLbWjn78wTizZ8+kvt7L0aN+BgaSs9Cff/4kPvGJRSDF2L9/P7OmVmOzWdKNmByPEgzLTFu8hNpCq9BYSpidxSyYP5lgxyG27++mfP5F3PaRa6krsGGUjDjtFmLlU7jpktl43A5sMZk5517MkhllmIwWGufOpcEbYffuw/TF3Vx3y3u5YckkjIkIoYSN+YtnUmgzYXYWM39eA77mA+ztCDP/ggtYOq2ac+ZNp6phMgvq7BzZs5vmQSOX3PwePnD1HJwmA1arDTBRvvRCVswpx24zYzaUcM2N51PltpCIRQgnrCxYMpMCq5FENEw4YWP+4hkUWJMvscZq3NV49diosrKsEInEwWjB7nBD6n6gPvxo81SSEciJBNFwEAMxbFYTpJwIsU61Do+2XK2MmHdGmJKauTUVljHuV5Ne/X0s9mvLQxuey35NHtpyRLtylSPKqXG69mt/KxCJxpEVE1aHC4Mxcyk9VV4BwrEIgUQIowUM5lR9nuH2J39oS8wsP9dvbZhaNmLeCsgxBaLgNDqwm23p4araNPF4mFg8gNmsYDEbM8oR7VI30QZRTo0T5VTZjDBtpJBeL1zc19oixmllIFn/6n5WnKC/Vk7cRBtEOW2c+FssT0Qv/ej7CrG4TDymYLG4MZvt6YHwEkmbZVlGlmVMpuTszXr2G1KTVzU01HPu8mVcccUKrr3uGlasuJz58+dTXFSMyWhESsnVN9SzPCV39TVXs+Lyy1gwfx5FhYUj7aEkUVxczMJFC1i+fBmTJlUnn6lSz2qVlRUsWbqYyy+7jCuvvIIrVlzOJZdczNQpk7E7HBnP47nsH63+VU7b+tfxo/TSj7Yv2p9IJOjo6MTrLaCgoEATk2c8SEeOHFGKi4uzZmgGCISjHOwcZCgOLrdnTEfjeBgaHOC1Vc8R6+/ktk99kuLi4nScoigMDAzQ3d1NY2MjFov+ZEg+n4///Oc/bN68mc9+9rNUVlbqnnTNzc2sXLmSqVOncs4552T0MHd0dPDYvx6npW+IK296Ny63JyPtiUSWZQLDfsxylPn15djM2XUwGhs2bOBvf/sbH/jAB5g5c2ZGHSqKQoe/h4NDLZSVlWOawHezckImEokQj8VIPr9JmEwmzBYzJo2OkXCEgd5+FEXBU+jF4cy8iYmEQ2H6e/owGAwUFBVgFYY4x2Nxhnw+wsEwLrcLd4Fn1PwmSiwWw+/348bOlOI6zIakLfv27ePxxx9n8uTJXHPNNbojDvKc/bS0NNPV1cX8+XPS15L27JMTcYZ9PUQD/Xg9dsyWkWtK0jR26zcfZNeBDkpLS1FkhZ7eIMFAHCRwucyUlCSXCOvr7+PmtyzD63HoNnB6Da92X0VNI8aLjeVo8eJvrVwuRDntvvo7jWbt8XSQRjaX/qPtq6jpo7EEfn8YTC68JVVZDpaYXlEU4tEww4O9GAniddtA05smliMiymXZrOUU2C/Gq+FauVzx4m+tXC5EufHaL8sKQ/4wcWy4iyowW2z6+isKvcEBeqL9mNxgsievN1GvM83+dJBG72PRXxuuTR8LJZD9UGopptiRnNNDlUv+UAiFBggEunA4ZBwO80m3Xy8vrfyJsl/UZbT0ovxoafUQ5bR6iOjlpZde3M+lv6JAKBQjGJRxOquw24syXr4oqeedeCyGzWbL6NDRy1/8rZXLhSg3UfsZo9zR7NdDzEuUE9PnkhflciHKTcR+rWyuckUbxHgtkWiUTRu3UFtXT319vRidZwxOnmc7QQwGIyaTmXA4kjVbs5Sa3W7KlCmj9ta53W5qa2vx+/20tbXpDo+WZZnOzk527NiBw+HIegGQSCSIRKOYLSe3B/x0JjA8zLb1m3nm0Sf5z9//zTOPPMGqp59ny2ubaGtuJRqJggJdbR088qe/8eBv72fv9t1jTi7W1tzKX39zH3/7/QM0HTiMnMis56FBHy89+Tx/+MlvWffSq8R0vhfJk+dUoG2MtNtIK6c/tBGgrMTDlLoSvA6FAhdMrXcwf7aHebM8NNba8TgUir1mZk6pwmrJ3Rsm6iAB2u/9tGnU/+k0mjUMczWgo5Wr3deWJ5aryomocelNmA1XlRH/i3og7uvYr6KXH6R6YzX7aSRNieI6nILtucpT5fTCM7ZTZH86jbb+RxmKpyKWq90fqzwxTg3P2DT268low9JyUvLP2Wa/Kq/qov0v6qFNI8H47FfImgk9I15FsyOWK5ath1ZOL1y7oZOfGC/mp9VB3WcUndR4IPniIf0zh/0atGVp9chVFjr6IqTXbmqcaI9WHzE/rQ7qPumwVKgaKEziqLUfHV1EtGVp9TiZ9iPoI+an1UErK+YhxicDRyROx/pXw7T6iPlpddDKijqpvxVGbM0zMU4bR9hsMWOzO/D5BnUdWIPBgMlkGtU5NRgMlJeXU1lZye7duwmHk8MRtQQCAVpaWjAajVRXV2c5wuFwGN/QEE6XB6Nh/L2oZxOD/YO89OTz3Hv373jwt3/hXw88yp9+9nt+dMd3ue9nv2fPtl1Eo1FkWSEUDBHwB4hFosSiMcKhMLFoDEVJrjUXj8dTYVHkRILgcJCAf5h4LJ5ejy4aiTI8NMxg3wCH9h5g06uv03K4mUQ86SjLCZlQMMTQ4BCB4YDu+ZEnz4kh8xvhzAYrOWlP8nf2fUgNaawt4+LlM3W3S9K/Z3DhOdOx27JHt2TnPIJ6/xNltI0sGrkRgewGUmxQ1YZYi9b+7BySiGlyoc3/WBvssexXlRTjc5FOl1o+Wkwn2n9sWo9wsu3PWf8pxFInWv9i+omStp/kKTlqftq6HDFsJEyDqNtpb/8x1v9Y9idHcKEzX3QSsVStHnr2aznV9o8mIeop6qZX/6KMGqZyrPaPlkbkRNif1DO7VD15bZie/qfSfm3+x29/JqJuJ6L+1d9pnXXSo6NLLk6m/Sp6ducZm9PIEbbidHsIBkMMDw9n9QqPl+LiYiZPnszevXsJBAJZJ1xvby+HDh1ixowZuN3JtWi1DAcCdPf0UlBckl4X7c1GIp7AP+QnFAwxeeZUbvrAu7j0uitwOBysevoFHr3vYTpb23G6XcxbuoAFyxdRVFpMR2sH61etZfeWHUQjUaKRKM0Hm1i/ai0Hdu/H6XGx6LwlzD9nEcVlJSiKQl93L5vXbmDlv57m1efX0HaklXAwlHJ2k472wb0HWPPsKp5+5ElefOI5dm/Zid83lFW3efKcKBSdhlBCylhHWEXSNFrqb62Muq/NT7zvaFFlFSXplKsNn5iPomlQR2scARAm9VHzEdOoZYj6qv9FeRVtfrnsVxnLfiZovxovpRKqMwyPZJZMIeokkiouq5zx2M8Y9qvxabmTZL9urjnsF+XV/PX0Vf/r5p9C1JMc+aVldV48qIyEp1LrDFnXs1+X08x+iWOvfzUOdV+0XzO7dhod+0nnM6KHnv3pfIXfemj1PF77IWkbmnRiPrn0zEKnLEVH/ljtF+VPtv0qyfMj+TuXbrl4I+xXOWH2p/6LemahU9Z47EeQyVWGqMdpZ3+eMTltHGGDwYDLW4Dd5eZIczPRYxwW6/F4aGhowOfz0dbWRkIz83Pyg/IOjh49ypw5c7DZbBlp4/E4fb199A/6KC6vwGjKPQz7zYDZYqa2sZaLr76Umz/yHt7xoXdjsVrZtWUHe7btoru9kxcef5anHn6cI/sPs3/nXu75/i954Nf30dnaQW9XD0889C/+8JPfsunVDbQ3t/Gfvz/O0488QWdbB/3dfTzzjyf5+Td/zIP3/IVnHn2S3Vt3pnt8I+EIW9dv5vc//BUP/vbPrHrqeR7+/V/51Xd+xuur1xGPxUSV8+Q5fnI0UlkNUY4XMdrU+hJjowiNpbbRy2iohSGnej2/ai5ioy6ioJ/+eDie3HLZryXb/uw1Z1VE+0e246+xXKnU8Fzx42W89muHxI6GmE+aVP2PL5cRxpIX41WdxfCxEPVW7VcZb35iPmlOkf0TRU2fpbc4a7U6JDZLUB/xVqfuHq++uYqfaL6iPnr5Hk/9i/mJ5R0rUo489MJGQ6uPJOqrc39M5586L0T7VM4G+/V0HW/+Z4v9imbLc+ycNo4wgNtbQGF5Jdt37CQYDIrR48JoNFJZWUl1dTVbtmzJyMfv93Po0CGcTif19fVZw6J9Ph+HjxzBW1SMp6DwpE4OdiYgpdbutTscFJUUUT+tgfLqCgL+AB1H2wmHwgz09tPX04cClJSVYHXYOHKwiX07dtNxtI2t6zcTj8Wpm1yPIiv0dfcx0NNPNByh5dARnnnsKXyDPi666hLe/oF3MX3uzPQSSD2d3az+zwvs3bGHKbOmcv173sbM+bPZu303r6x8mVAwJKqcJ89xkmpqUkP7Fe03eanWJt0gCTMJaxskCZ0eHTG/FOK+tsFTnUGxEVQbRjVODUMtRydflbScsJEqL52foK/o+Gek0+xr7T1W+9O/dezXlqPGaVHzEuWy4hUl+XmGGiEdm/1p+8T9UewX89GStktKri+tho1lv5L6Ix5jXTlNPhmyqv2i7ao9GrR6TMT+jAw0ZauoeqIZ4juW/WkbdM6x083+zFxGylZJ6zuB+tfaoGh3dOxXUTSjH7Q6TMT+tLyOXqp8xv4E7deG5Sonw/7jrP+03AmwP1kRJ85+FW252hcZCiN663E22S/qmw57k9S/tmxtXJ5j47SZNRogEgqxae1qdq17ic/f/hmmT59+TGX6/X6effZZ1qxZw2c+8xkaGhqQJIm9e/fy4IMPMmPGDG688UZcLlc6jaIo7Nq1iz/95a+UNsxg+aVXYnck1/o8WZyus0YfOdDE7374Kza+sp7r3/1WPvTZT+BwOdi5aTt3f+0HdLZ18P8+dgtzF83jN3f9nIH+QT72hU8ya8FsHvnTwzzz2FNccs2l1E+bzF9+cS+zF83l9m9/ka7WTu76nzsxmUzc+tXb8A/6+NEd36NuSgNfvfubmMxm/vqb+3ll5WpuvOXtLLtoOff88Ffs276H6XNnUlVbTW93Lwd37WPhuUu4/c7/obSiDGmc50h+1ug8o5GcNbqT+fNGZo1G0yAlEjECg73Egv14PHYsFmO64dP+b+0cor1rSJNznhONx2Vl5uTS9L4CxGMJhobCYB6ZNRolc7ZeRbOvALFImMBgN0YlhMebHCEkCQ89Le0+OnuH0/t5Jo7XbWN6Q3IlCEWBIX+YRGrWaJNl5LhrUVDoCwzSHe3D5AKzI9mGiQ+gAHJCIREdGf2VgVr/ap2K3aBiuOhISOq47NQHuONBlYekpsmTKrWbzCMWjaIocoY96n0kC02EVt5kNmF1WNNhKAqxkIw8nJw1ushRkF4+aSStQig4QCDYhd0u09UVorc3/1L5TENOKDidVqZMmYLdUQSp10aKkjxP47EYsdSs0epSotrzS/29d38Tff2DIxkLp3/6xFR/jwdtHtoCtfsnGrFMsTxxPxfHYX9ZaTFTJ9eCThK17ckKz/E7F2J68rNGHzenlSOsKApHDu7jpX//nXMXzeOmt70Vj2fiyxcpisL27dt54IEHWLp0Kddeey2SJPHss8+yevVqbr31VqZOnYpR4xz6/X6efvoZnn7pZa579weprm3AMAHn8Vg43R3hDWte4+p3vIVbPvkBFEXh1ZUv84ef/BZvgYePfelTFJeW8Mtv3512hM9bcSHrXnyFn33jR9iddibV13D0UDM3feBdvPWWd3Bg1z6+9/lvYjKZ+Pgdn8bXN8BPvnoXU2ZN42s//RZIEn/51Z9Y+8Iabrzl7ZxzwTJ++4NfcnjvQZZcuIw5i+ZiNBrxD/kpKS9lxY1X4SnwZjzojkbeEc4zGhmOsNmcbv/UsyuRiBMY7CEa7MfrsWGx6F+vew/30tLhp6ysTIzKcwLw+XxYjAnOXViT4djGYgmG/GEkkwtPSRVGY7J+tA8OGQ8dikI8GmE45Qh7U46wippu14FumtsGs3oE8owPSZIoKXRwzvxJSNrlkxQbnuLk8knoPH+CQm9gkJ5oH0Y3mO3J9W4z6jNV/8M9YVo39gnpT28OHdhDb29X1vmp/lZRUn/SfrpGpmZGDZe956J0uAREgwkSw1CWWj4JYVkdUo5wMNiFzS5z8KCP9vbs+VTynN5IkkRRkYN5c2foLp+kdYQt1uSa9Nr7n8prG7bT2dkNSo4XSXnGh2SktqaaRQtmijGQ49hr0bv6Mq/b3PeIaDTKho1bqMs7wsfEaeUIAwz7h3h99Qu07N7MrR/9CLNnz8pwWMfLwMAATz75JNu2bePmm28mFovx9NNP09jYyDve8Y4MBzsej7Njxw7+8tDDFFQ3cuGVb8Gh6S0+WZzujvCrz7/M3CXzOfeyC+ju6GLjmvUM9PZz4VWX8oHbPsJAbx8//foP047wxddexpH9h7nn+7/ktdVrMRgMzJo/m9u+9UWmz53Bzo3b047wp77xORKJOD/5yl0kEjI3/dc7KSgu5LnHnubQ3oO87b/eyYq3XMnf//ggq595kXlLF3DFW6/B6XLS3tKGZJC47uYbcLjG32ufd4TzjIbWEVaXadM2XnIijt/XQzww0iMsygDsPdRD75DMkiVLNKF5ThT79+8nMNSbdIQ1x340Rzj9ACH0CMcjYfyDPZg06wirqA8cuw9009Q6kHcUjhFJkigtcnLO/EkAKJp1hD2pdYQR6ynVhvWl1hE2usAySo/wcE+Yltd6UORojkfK0wkJyWDmwL49GAwKy5cvFwXSaF/0iGzevBmcMld9cAVojl80mEAeVii1lFCUWkdYe1xJrSOsdYTb2obz5/cZhiRJFBc7k46w2COceq7VOsLpdJo8UB3hjs7UtZPnWJEMVmprq1m4YJauwyrui4j3Py3aNKqc9nc0GmVjvkf4mDn5nu0EcTpdTJ09F7PTy3PPv0BnZ+cxzSDt9Xo555xz8Hq9/OMf/+Dxxx/HYDBw0UUX4XSOOE+KotDd3c3Lr7zKUDjGnMXLsDkcGXm92TCZTBQUFeAt9NJ65ChP/+MJNq5Zj8Vq4Zp3vIW3f+BmSipKMVusFJWWUFpeit1hxyAZKK+q4JxLzqOiupLSijLmLJlPTUMNRqMRs9VMSUUpJRWl2J12ahvruOjqSzGbzTzzyFM89fC/8Q8NUVJegtvjoayqnIuvvYxZC2bTeuQoD/72fv549z089ffHaW9uzTfceU4CI06SipLekt/76Z11GWE5HlzznFj06gFNuFpvam1IqYdHLUnZ5MeSudLlKifPxJByPASqx1e9tlQ5SbsMkGY2ZDVe3R9BAUU+M7YUNpuNmpoa3a26upqWlhYMBkNWXE1NTdYLW71ji3j+C3E6BzHPmYiiqVud9id9TYkRkD8BTiiZUy+Kv9V97RHX3v/U/+Kmyo3aLulXbp5xYLz99tu/6XA4dHt7Y/EE/cNhIjLJoRU6F9iJRpIk7A4nksHItg3rkRSZSTWTsNtsEypfkiQ8Hg+VlZVEo1HKysq46qqraGhoGOntURQGBgZYtXo1azdsZtEFl9E4bSamVPzJRlEUYtEoRiVBRYELkzG7Dkajvb2dnTt3smDBAkpLS7PqcDgapD/iw+l0ZcWNhmQw4HK7aZwxhXlLFjDvnAWce9kFXPm2aznv8guprKnCZDZjMEh4Cr1MmzODqXOm4y30YrVZKSwupGJSJYvOW8rSi5ZRXl2J0WjEaDRSWFzIjPmzmTJzGqUVZdQ21lFVN4nGGZNZdtF5LL1wOTPnz2LmgtlUTqqivKqCmfNnUzu5nspJldROrmPReUtYfun5lFVWTMguWZaJRqNYMVPkKMAoJdP29fWxb98+ioqKmDp1avr8yPPmwufzEQgEqKgox6CZqAZAnTwjFg6SiIWwWc0YNder9s7UOxAkGFGorKzUhCZRlATDg3309Q/iD0YxWqyYDNn3tUQsRG93N4NDfvx+P/5gGIvVhlFHVokO0zssY7dmjihR4hEG+nroH/QTw4jVbNJtK5V4hP6+HgYG/cQxYtGRk+MRenv6MdjsmDIiZQL9vQwlTNhTPeQnm/7+fmKRIJMqvRl6yrJCJBoHgwWbw41kMGTZkYGioCQSxMJBDFIMq9UEmiV91P+9/QEGh7LXpAcI+fsZGg4SCoUIhUKEwxESGDGbk8N4QSEWCeL3DxMIhojF5eS9U2jLYqFhfP4oZpsFnSo+o5EkCafdQnWFByl52IlE48iKCYvDhdE4cr5lmK5AMBYmmAhhsILRnF2f6n40GMfXGjilwzvl6BC7N77Mk088zcvrNtEZMFJVVYbVJDHQvIWH7/8zK9esY+3atazbdQR3ZSPlbgsgIRlM9Pf1YjabmD59upg1iUSCF198kTvvvJPe3l4WLlyYtcrFoUOHiEsxpixszAhPxBXkqITT6MBh1n9uisfDRGMBLGaF/oEIfr9+b2BQOL8j0TgGoyn9rJKIhvANx7Hakp+STAyZ4SE/ktmCUdAxEQ3hC8vYc3x+oo/MsH8Yk8Wia/PZhiRJOBwWystLMFvsGRPLIUkkZBlZljGZTLojPlWnqq29m+Hh4VN67ZyNSJIJr9dNZUUpsViMjo4OhoeHsVgsGE2mtL/R0dGJyWTCbDbT29tHNBbFYjZjMBiQZZne3l5isRjmVFg6f53/6u9EIkF7eyfeggIKCgpSoXnGy2nnCAMYTSacbi/haIytmzdgNRkpKy3FNkFn2Gg0UlhYyOTJk5kxYwaVlZUZTrDP52PV6tU8++JqGucsYv455yed8AmUcTycro6wxWKmtKKUxumTmTJrGpNnTKF2cj1llWU4XS4MKT2tViuVkyqpaazDW1iA0WREMhhwelzUNtbRMK2RkvIyzCYzSGC1WamunURNQy1urwezxYzL66Z2ch1TZ0+nYWoDNY211E2up6S8DJPZhNliwVtUQE1DLdPmTGfm/NlMmZV0ok0THEqed4TzjEbSER5OOsLGpCOTvhNIEigykUgQOeUIG4zZD+YoCn0DQQJhmaqqqqy4zt3P871v/YDHnnqeZ596kl3dcabPnonHor0+Zbp2/Yfbbvk4f336eZ584nEef3kL7ilLmVkpfrIh0/7ag/zkhX4uXDIF9cxV4iG2PPMXvvODX/HMiy/w7KpduGunUVfmyXC0lHiILU//mW//4Jc8m5abTl2ZWyOnEOzYwfe/8DkOFy1hSUNx2m451MWf7/oST/ZUcen8mlPixPX19RGLhqip9GaEy7JCJBJHMlmwOtxj3/MkCTkRJxoOYFDiGY6wpHlQ7MnhCMuxMKsf/Ba/+vvLbNuymdfXr2fdq2vZuOMw9qp6qgochHqP8NwjD/LIf15g/evrWLtuK11ROzWTyrCbUvrJUbY8+3t+eu9LFM2cR03h2fVphuoIT6pIfo6UdoQlEza7KzmpmeZaU3s6FCCkcYRN5sz61J5qp94RjtO07gkeXt3K3PMuYFa1jb1rVtJmqmV6XQFde19j3UGZJcsWUl87iZrqKmqrK3BZTYzHEd61axc//vGPOXDgAC0tLZSUlDB9+vQMh0Z0hJXUHyWuoEQZ0xGOxwKYzQr9/fqOcCIyzHN/+ga//9c6tm7exPr163n55Vc52DZE8aQaipwmeve/wr1/e436+TPxTPBFWCzYwaP33Etf4VTqS12a+pTp3beGPz23m7kzp2BVr5MxiAXbeeSBB4mVzaK6YGQo8NmKJEk47ClH2GxPXxESyYtMGcMRVo93W3tX3hE+ASQdYQ8V5SX09w9w3/1/5rV1r1FdXU1xURHRSIQnn/oP9//5AUpKiqmsrODfjz9BV1cXFZUV2G02wuEwTz31Hzo6OykvK0u+/Epdv2q7pEfeET4+xneHeQNwedwsWHY+NdPn8uQzK3lu5Uq6uromPEzaZDLh9Xrxer3pm0EikaCzs5PnX3iBp59/icqGaSw890Jcbo9uo/FmQzIYsNptON0unG4XDpcTm92WXNZIc3gMRgM2hx2H05HhlBqNRhwuJw6XE7Ml6QSr4XanA7vTgdGUbDSNRiMOpwO3x43NYcdqs+FwObFYR97qGo1G7A47bq8HT4EXp8s5YSc4T56JoDpC6aFI6rIHwlDCrGFNkpRuuBR1CYbUFo908M8//Jng1Jv4zk9+zLe/9lFCax/hwRf2E9HKyjL9bU0Yp1/Dd378C37xi1/wi+98mcunF2XlqSSG2f76AepqarClw2UGj27mT/c9w+J3f54f3vUtrpvs4w/3PUZPIKZJLzN4dBN/uv85lr7nC/zwrm9xbaOPP9wvyoG9rJ5l8ypY++IGhhIj6QdadrPhcJzzl0zFgKDbSdpGJTWEdlx3cUVTw6kEYroxSkOOydTPv5wPf/xWbr31Vj7xifezuHiIF/6znoFojF2vPsG24WLe/l8f4xOf+DjvvW4JXa//i7X7e9J5xIZb2XWgn7pqI5s27icyVqFnKHpmidePioQ6NDqFZuh6aveNJR6io3OIxuUruHTZfOYvv5SLFk3i8K4jBBIJBnoGKJk+h3lzZzNn7gKWLVlIuWd8zpnP5+Nf//oXR44cwel0kkgkeOyxx9i5c+e4zv+M/6OgCMdUj0RMYeo51/DRT9zKJz/xCT7+gbdREdzLo/9aRW9YwlM1gxVXnE+p0wJKgsDQIP39fQz6AyTSuiqEg376+/vp7x/AH4qlylWIR0JEwkEGB/oZGPQTS6hpZCLREec8Hgky0N9P/4CPcGzEYVPkOMO+AfoHBgnHZOKREHF5LKtOX8T6FfezEOo5ox1KB+qfDGPknOeYSB7raDTCoUOHWPPKq+zYsRP/8DBtbW1s376D9evX093dTTyRoLm5hfa2dmLRGKR8k6OtbbS1thMKhWlra2Pfvn3s27efffsP0NbWTiQSEcrMc7ycto6wJBkoKCpmyQWX0jh3Mc+vfpVH//kvdu3ahd/vH/sGoYOiKAQCAfbs2cOjj/2T/6x8ibqZ8znv8qspKCrJO8F58pwFJBIJhoaG6Orqoqenh4GBAQYHB8fcfL4hgsEgwWCQQDBIKLUFgyNDA+PxWIbTpG7qvhbRgZMjUUrnXMz7b76cuvJS6mYsYlaFRGdbL3GtrJygq7kDS0UlHQc2s37zXmIWDy5bcniVdosNdrGx08zsGeWacBnZYGXJ9f/FOy9bQGlxAV6HGaMiYZC0esnIBhtLbng/77h0PqVFBRQ4TZgUBDkFjF6WX3oRob2r2Xw0mAxPxNm/cTWBynNYXOvJ0m0iWygUythPJBLEYlpnfGRLH1/hYU5J/UnEEwTDYQKputPWqTZMHcocT8QhNSuvmmdWvjmRcLiLqKisTK5fXzONeXPqiAx24g8nGB4YwlM5hamNNVRV1TBj6flcddlFOIzq2SLTs38rLbEaVqxYSv++1znQc/o/6MTj8Yx9RVHGfEktXh+JeIJIOJy+xtL1kv4dIhJLLjGEugJRatP+fkMwuVl+4/t554VTMQBy1M/Rjj4sbhcmOUJPRyutBzbzyAP38Ztf/orHXtjAUHT046MiSRIXXHAB3/nOd/j+97/PXXfdxUc+8hG83swRELqkDogsK0RjUYKhUPb5HwoSTS3dNPYBNOD0FlNZWUllVRUN0xdx5Q2XE2zezp7Wfnzte3l+5av0BEJ07ljFn3//W/5033387re/41/rDxKJy/jbtvLIX37Pvffez+9+/X/83z33sbvTn8w+PsyW5//Jn/54L7//zW/410ub8EczlYr7jvLcP//KH/94L3/8w++596//4khfEBSZ1l2r+O0vf83v7r2Pv/37ZbqDmeflmYQsy3R3d2dcR36/n2AwmCGnRVEUotEooWAo6zpS73HautfeA1X5RCLfE3wiUc9ek9FIQ0MDTUeOcGD/ATZs3ITX66W8vBxFTq4pHIvF6O3rpbmlmcOHmzhypJm+3j6i0SiBYIBVq17mz39+gD/+4V7u+t73+fs/HqGrqyvZFr6R97+zjNNyaLSKJEnYbHZKK6uxOd1s37aV7du3EYtGMRmN6XH2erpricfjDA0N0XL0KK+tX8/jTz1NS2cvC8+/jPnLzsNbWDxmHicD5TQdGn22kh8a/eago6ODlStX8sILL7B79246Ojpoamri0KFDo2579+6lq6sTk8lIX18fPT096a23p4f+vj5ikTB2qxGbLTk0Gp0H/N7+AMGIQkVFRUa4weJl5oKFVHuTvSedu1fx56e3s/D6d7Gkxp2WkxPDrPnHr3jxQAC3zUjrjtU88fxWqhaeyyS39txU6GvaxNr9Pay47BLN8GoJm6eSefOmMtz0Cnf/z508uqGL62/9b5Y3FGn01cqt4SdfuJNHN3Rz/a2fYnlDYZZdVreHI688TpNpJstnlUOojcf+/A+KLrqFy+eWH/Nb1Xg8zosvvkhxcTE2m414PM6+ffvo6enRXYKqv7+feDTEpNTQaNUpkmWFaDTOgC9Ae2ey3ro19aduanhvTzc+3yBKIorDZsJmNWf2Qqby7s4xNFqR4xze8gJt8iSmTCokFg7h723m5VVrGHTM5JLlUymwJtjz+ho2bttLz1AEjDYmTZ3NtKrk981KZJBXVz5PqPoCrlreQNvra+ix1TOzroi0r3yakUgkOHToEC6XC5PJRCKRoLu7m3A4nDERpYp2aLT6siISjTMwGKCrp5+u7pHrTLzmhsMBsEqY7SaMmqHRYh1FA3F8badyaDQYjEZMBgk56mfnuhdYvU/m8htWUG0Ns2/7XtwzLubG6y5jRo2LTc+uxF8whcYqD4YxhkZbrVYaGhqYOnVqxlZUVJTxDKYdGp1+IJaSvbiR4Si+rkF6O7pT57p26yUYHMJgiONwmHJ+I6wkouzf+CLB4oUsmFKRPh8NFhMd618hWjmLatsAG3b0MX9JHdv+8yTBxit59w2XUu8KsmtvBw0zamjf/CoHmcrNb7+Gc+Y30r99LQcNjSysMbNj9UtEa5bzjne8lXkNLjasfIlYxXRK6GJLS5hl8+vZ9fxjrB8o46a3XcfSeVOIHlnP5m4n06qiPPW3p/EuuZ53veVCCuLtrNvTxcyFy6gpzPye+kwgFouxa9cuZFnG5XIxMDDAwYMHsdvtuHRWMZEkCYvFQDQWpqNDvaeN3N+6e3ro6e6mv68v2Z51d9PT3U13alN/+4aCyRdbp/DaORtRvxGuqChl2O9n3WuvMXfOHHxDQ/T399PW1kZ9fR09PT1MmzqVadOm8vLLa9izZw+dnV3s2buXbdu3s3XrViZNmsSSxYuYMXMG8+bNw+V20dbWxvRp05gzZw52+8j5LQHx1NDogvzQ6GPitHaEUS92q5WS8grKq+sYGg6y4fX17N69G9/gIOHUG69QKEQkEiEcDhMKhRgeHqZ/YICuzk4OHjzI2tde4z/PrGTzjj1UNExj+eXXMHn6LBxO1xtiF3lH+JSTd4TfHGzcuJEf/ehHvPDCC3R3d+N0OhkaGmJgYGDUrbu7i3A4jNfrSd5HgkECgUD6zXkkHMZikvC4rNhsZkypb4STD/cjy5z0DIYIhmXdybKSyHTsfpHv/ejPlJz/AT50/XzsGq9HTgQZGJBYct37eO/br+aiCxbT/sJfebW/ggsWN5L2dxWZ/a+t5HBsFpeeO3UkXEVRkIwmCifVYwweZtUrzcw7/xxKHML5rShIBhNFk+oxBg6x6pUW5p2/NEtOMtoxDe/mifW9XHzBQqIHnuO+F/p45wffRa372D9VSCQSrF69mkOHDlFdXc2BAwd44YUXqKmp0T2Geo6wpH4jnHKEu/sG8Q+P1J22V0y7H49FsZkNuFN1qvWwJJLHprs/OIoj/AyrNh9k786tvL5+PZt3NWEomc51115KldeGu6yemVPrMUWHaWs9wvbX17Ju20FcVfVUeO34O/fyzIv7WHLNVTQUe1H8e1m9y8+C+dNxCt/Eni7Isszhw4cZGBjA6/XS3d1NU1MThYWFOR/YVUdYSh7SdD319vsY8g9n9WQFg0GCoRCKESweKxanOT1ZlthaS2/IN8JJ4qEBXlv5CM9sD3Ll297KorpCTGYHjbMXMGvyJNwOO56CIsJt69kbLGXhtGpMhhFHOBwOIUlS2jmZyNba2orRbmDKwsaM4yLHZCKBKEM9Qwz1DxIMZPcSIsVx2E04nRYGJugIK3KU/RteRalZSK3dx5Y9gyw4dx5y1yE27DxKNB7DVjaV85YvpNjlorRuOrOnVGNIRBjs6+bw/r30WRtZMtXFrh2HmHHp9SyoL8btLSLY/DqHouVMdgfZdjTMsqnFrHr+JdqCEOhu4VBTM+1tRznSE2d6ucT6AwGuuv4aJhU6KShycnT3XspnLjkjHWFSy+C0trYSj8dpbW3FYrFQXV2t+0wiSRJWi4FEPEp//1BGPQeCQQLDyesqHA4T1hkho27RWOo1yim+ds42ko6wl8qKEvx+P2vXrmPmzJkUFRay5pVXKC4qYsnixWzbtoPJjY1MmzaVdWvXYbPbWb5sGdOmTaWivJyOzk4qKiqYO3cOJcXF+Hw+Xl69horyCi699GLKy8syfBYJkBMJOvLfCB8zp906wqMhJxIEAwH6ujs4uHcXR/btYqivl6LCAioqyiguLMRmsyIhEQqHGRj00dHZRW9/P56CIuqnz2byzDmUVlThcI1jMpWTzOm6jvDZSn4d4TcHTz/9NJ/73Oc4evQo1113Hd/85jcpLCwc83pva2ulv7+fBQvmYjKZkFLDj0itwynLCWJBH8SH8XrsmDWTw2gfzvcc7qV3MM6CBQs0oUmURIRDG5/k5398AvfiW/j8f11GkU3QSw7T0+PDVViG3SKBHOOl393Gb1sW8uuvf5Ti1OkpxwZ55P/+l8AFX+aDyzMdxnjYz1DURJEnKew/+jp33HYXF33919y8cEQ2S65lPXfc/n3O/cyXCa29n2c3d4PRzAXvv4PPXDeXoaZX+No37+dtd3yN+PO/5qnIxfzgc9dhE72TCaAoCk1NTfznP//BYDAQiUSYOnUqK1asyJopl1RPWGi4n+ULayB17BVFIR6XGfKHiSlWbO5iJENywrOs4WPq8GpJQo5HiQZ92EwxvG4biuAIK4rCroM9HNFZR1iOhVn5x6+y1XI5N1+5EJtRwmC2UeB1YzUbQY4x5A/hcLsxGSSURIzhwW5ef+YhtgQX8rGPXEzbS3/lFw9vo25GDVYJIr5ODrRLvO9/vsDFU4szyjtdUBSFvr4+9u/fj8FgIBaLUVpaypQpU3SfI6TUOsLLUusIy6l1hMMxExZXIUaTJSmoqZfkrsJQLMCQ5MfkMWCxZ7Zham1IwHB3mJb13SiJiF6NnxTigS5eeeZfrOuwcc0Nb2VerRcDEB1s4l9PvMbMFTcyt9KBHB3i+b/+ipbya3j/1QuwGCQko5UD+/bQ3d0hZjshamdOSq8jTOoQxkJx4n4Fr+LGY3amj6dWKB73E4sN4nTCwUP66wgnIsM88Zuv0TPtg/zX1fPTL9qiQwf4ww8foP7tH2WRbR+/f7SJ//rs+ylLDLBv9252btvG/rY+LOXzeP8t1yG1vM4za7YxGJaxWa0MdzbB9Jv45E21PPa7vzDlhk9wQWMBJCKs/9fv2WxdzlvqBrh/7SCfedtiHvjDPRhnvYXzJo884FscHoojB/nVUy18+JMfZJIT4qEe/v6X+2i44mOc2zCOYeSnIYlEgiNHjnDkyBEKCwuZMWMGjhzLeUqSRFGRg2lT6zGbPZn1rCjE43Hi8ThWqxWzdiZt4TrbsfMAPT29+XWEj5P0OsLzZ9Le3s4Pf/hjLrvsUubMmcPf//4PZs+excKFC7nzW99mxeWXc9111/Djn/yUggIvN930NspKSxkeHuY3v7mHoqIibrrpbZhMRp544in6+/u54oormD175siEv5rnjkgkyqZN+XWEj5XRnwxPMwxGIy6Ph5rGqZx7yZXceMtHuP79H2P60gtRHIU09/rY3dTGzsNHaekdImH3Mn3JBdz4vo9z4/s/xrmXX03t5Gm4PN4xH4rz5Mlz5mO1WikpKaG8vJyysrJRt+LiYjweN26XK7l5PHg8HjxuN263G7fThcWSemhPNULqpqL2DuuiyBxa+xDf+uVjTL/+09zxoUuznWAg6jvET7/4ee5bfYi4AnJ0gP37+5lU04h9pHgSg4fYd6iARdMzh2CjJGjZ9E/+57M/YF9PCIBYKMBw1IhVuxyJkqBlY0quNykXDQUZjpqw2R0UlFZTV19PfUMDpYVuQMJTNZPljQZefPEVXto9wPmXLDwuJ5jUA11jYyNvectbMBgMTJ8+ncsuu0zXCdaiPfbaN+RmszlZf243Lrcbj7il6tXtduN0ODGbTGnfSazTsUcLab8RrqC8pCDpBAPR4Vb+8Ztf8dTGZmKygmQ04y4spcTrJhyKEo/0sW3jfmZddh03vuV63vKW63n7zTdzwRQzr722h1CO0+iNRpKk9CzGiqJQXl6e0wnWonW0JMBsNuFyOnFr6sWdut6S++7ki+3Ui6h0PpqHwHT4WNV0opHD7Hjpcf6zuZf5i+ZjD3dxcP8BWtr7SVidGHr3s/LZlzl8tI0dr73IlqMW5s2s52R38ktS8o/BYMBms+me/263G5vNnpz1fqLHTY5yZNMG2swlNE4qTj9AKtFhjjS1Ujx9Oe/60Cf57IffiqV3KwdbWln1/MvQeDkf+/gn+Mh/vZ0ZFQUj7yqG/XT3+ogrkIj4aGn3U1ZUQHpwnM1JtddNQnIzffZc5s6dTW2BRDgCxsIiHKE+uvoDKEB0qJXW7uSkQ2cqRqORuro6Zs2aNaoTrCJJEna7feQaUus4dX9zpe6D3ozrauT+53a7x7xu80yM9F1OAoPBSG1dLR/96Ie59NJLsto0CTCbzNhtNux2Oza7HVNqlZVIJMLLL6/h9Q0bKSsrx2q10NPTQygcznCCSV/3moA8E+K0HxqthyRJmC0WHC43BYXFlFZVM6l+Mg3TZjF55hymzJxH48w51E+dQXVdPcVl5bg8XiwWq66dbxT5odGnlvzQ6DcHBw8e5Nlnn2VoaIiZM2dy1VVX4XA4xrx/pZdPKi/DmBpBoe11kpXkmrPqOsLq8kkZ/oqi0DcYIhBKZH0jHO3dxU++dhfbwhVMLYqxa/MmNmzYid9UyCR3mId/+z1e6i9l+YwG5K7N/OVvzxOMh9jywmO8fMDGLbe+n8kF6QWSaN/8LM/46rh5xcz0skkqNpuJg+ue4NktR4kNHeXxh/9JqPZy3vvWc7F0rOcbP7sPU+1iplc6OLj2CZ7b0krU18K///4YkdrLef/NV7D0nIu48soruWLF5cytSfXGGG14pB5+f+/DhCsW8oG3r8CbNSb72PB6vTQ0NDBt2rRRR2UMDAwQTy2fpH0g0K4jbNVZR1jRDF9XX1gkl08KYZBi2KwmFEZkVLlcyyclh0a/SJ9jFotmTspycgwmG8bhFl589gV2Hmyhrf0Im9a+yLqdg8xfsYJJwd08u6Wfy972DubVl1NUVERRaQWFhn7WrN9F1ezFVLhO34dUu91OUVERpaWloz5MS+o6wuXJVRnUodGyYsLqyFw+SbxCg7EIwUQIKbWOsBb12pPegKHRieFuVq9aRVOXn56WA+zYvp3t23fR5Xcze9E0GmqK6dq3iXUbtnCoM8aSK65n2YzK1BrcI0Oj3W4XK1asYMaMGelt6tSp1NbW0tjYmLHNmDGD2bNnp+WCwSBYlIx1hBUF5JiCrLN8kvb8j8fDxKKjL5+UHBr9DLs6ogT6Ojiwbw/rX3melze3MffyGzlvRjnhviNs2jPIgmXTaF77NM9uaCYuh2jZv5MWfyHLz53DcNMujvREsJiiHNj8Gq9t24NUNpflswvY88qL7D/aTzgyzO71L3PQX8TlV56HbbiFTS1hli1eQLEtzJrnV3PUF8TfsY+VK19iwDmFBTPqULp28dLr+4hFfGx6dTXrW0IsXn7eGTs0GsBgMOB2u8d8DpE06whbLCPLJ6n3tvQ6wmYzxtTznyRJGfdMKb980glDHRpdUVFCOBTm4KFDNDY0MnlyIw6HA4vFkvoOfDeNjQ3U19dz4MBBCgoKmDZtGg6HnUQ8zqFDh3G53JSWlbBq1Wpa29pIJOI0HTlCX28vpaUleD2pe2mqDvPLJx0fZ6QjrEUyGDCZzFisNmx2Oza7A5vDgc1ux2K1YjKZkXRsOx3IO8Knlrwj/ObgRDjCWesIk3y4iKYcYbvVjNFoyOiZklIPGr2pdYTLy8u1qQn1NrOrM0ixx0Y4MMzQ0BBDQzFK6qYztcpBW0szpoo5zKktpXbWfCbZ/ezee5iEdzrv/diHWFyXnGApSYz+jnaKpi1kZkX2MECTo4Q586Yy3LKPPU091Cy+mg+/71oqXWbiw73sahlg2uwF1JRXMmfeVPwte9lzpJfaxVfzofddS4Ur1zUgYfd6kXsjzL34GpZMG/l28ERgt9tHdapQHeFYmJpK7fGARGqyLIwWbE43kpT5oiLDCU4GICcS6XWEbTZT+uECTZ3mdISVBNFQAGf5VOorC7OOg2QwU94wnfpKN4EhH0P+AGZPFRddfT3nzirD196JoXgGS+bXYkmnlXB4PcT8UQoqJ1HmtWWeg6cRkiRhsVjGbFtUR3hSRfLFBQpEU+sIW1PrCGfUU+q/ooysI2y0giHlCKv1opU91Y6wwepmxsLlXH7ZpVx04YVceOGFXHjh+SyYVYvTbMLuKWfmvIUsWbqU5ecsZnJNieZFyYgjbLfbWLp0aXqJR6/XSzQa5e9//zsrV67k9ddf5/XXX2fHjh3U1NQwc+ZMCgoK8Hq9tLS0ZK8jLIEcVyAKTqMdh9me6i4aOf9R1xGOj+EIy3GiIR/BiEQkHCIUjmD1VnPh1Tdwwfx6LEaQE1ESBieTp0+job4GyddBS3snMXsll199JVOrSqmqLifSe5SOHj+e2rmcv6gRu72I2kmFyJKdKdPrGWxvJeau44prr6S+2IaSiKGYXEypraagvI7GShu97Ufp9ctMOedyLj9nOg6rnUmTJ+OIDdDc3k9hwxzm1pdRWz+ZImeu+9fZg9YRNpk09ZyKkxOJ9DrCRlPy3paRPvU/7wifGNR1hKsqSzGZjFRWVlJXVzsygaAkYTQaqa6qpLGxEY/XS1lpCQ2NjRQXFWIwGjFIEqWlpTTU11NSWkJlZSXz5s1h1swZNDQ2UF9XT3l5OVabNeMeGM9/I3xcnFHfCJ9t5L8RPrXkvxF+c6D9Rvimm27iJz/5CSUlYy+P1tLSTFdXF/Pnz0l+I6yJUwAlEcfv6yEe6MfjsWPRfCOsZe/hXroHYsyfP1+MynMCOHz4MOHAAOemvhFWicUSDPnDYHLhLanK7WClfiuKQjwaYXiwByNBvG4bpJZQ0srvOtBNk843wnnGh5TjG+G4YsNdXIHZknT21Z6s9AsLRaEvOEh3tA+TC0yO5PWmymqvz+GeMC2vndpvhI+dkW+EHQ4r119/fUZsOBzm4Ycf5he/+AUDAwOYTCauuOIK7rjjDqqrq9Nyzz33HCFDIPMbYSAWSiD7odRSTLGjIMNBSh4ZhVBwgECwC7td5uABH23t2d8I5zm9kSSJ4mIn8+bOwO4oQvsBgZJ63onHYthstmRHlnDdqL/Xb9hOR0dn/hvh40T9RnjRglnJtiWRwGAwYNCMTFJSSwNKBgMGSSIhy0gkh1CnGqX08lmSJJFIvcxQMRgMGI0mJEPm5yLRaJSNm7ZQW5v/RvhYyHu2efLkyZMm82FQ6xQpgKSMhCmaTSufmmILRWcN3Px2/JtIRh0I0aK09kFwpId4REpRFCRNfSuKNjbPiUY91unfqR558dpSUstaqfWiRdw/07HZbNx4441cd911WCwWpk+fzoc//GGqqqpEUdAeI/WP5mJQf2ofmlUkzsKD9yZGrEq9OteixuvdU/McO0rqPmY2mTAKn+dIkpTsoTcYkr+NRoxGY3rZPkmSkj3DRmNytKvZjMVqxWK1Jic9M5uRDJk1m3HJ5zkm8o5wnjx58gikmxrxIUFnnVktyYd1MTTPySZ9xIVDr+6K/9E8AGodAr1RA9kheY4XKfVHSdWD+CCXfCjU7Gdfhmc1BQUFfPjDH+aSSy7hfe97HwsWLNA9N0VUEfXMFlNoz3UlHZDnbGC0qtS7/6mM57zKM14mfiy1LyIU9d6n2dD818arTLzEPCJ5R/hNjhxP4GvtY/Bo71m3hX1B0dw8ecYg2ayob1lHeg1HUH9LqUZM0shnyOn0Zua3E7Op9aA+GIwc9JGf6XAl6Wgpap2kBTSPGamnC239JUVGvhnOc+LQXkNSalborPpU1D8Kiuo0Cw+FWfV/FlFTU8O3vvUtrr322lGdFc1ZPLIyjlZAOP+1SOk/ec5oNNWqd7/S1r8aryeX5/gRLye945yuj9T9Tw3TQ3u/06KmT++LAnnGTd4RfpMTC8fo2n2UwYPd+A71nDVb166jDPf4RHPz5BkDJaNFSTc2apjQ2OQdpdODdB2ITyEatE4XqHWa2lL/xOT5uj21ZBx/sTL0g85apNTEOenJdkYh4/zXe6GjOf/TiEJ5zlzEC0PHK8q6/2WRPkvy2zFtSdLPDJqjqkV9GZWZKom6n117SfTkVVkxLs/4yU+W9QZyOkyWFRkO07x2HwsXLMDtdovRZyybNm3CWuGiZEplOiw/Wdabg5MxWRZAIhFn2NdDLNCP12PDbMmWITVZVlt3MOc3fXmOj76+PoxE05NlqQ8C8ViCoaEwmF0UlFQhaZbl0cppHx7ikXBysiwliNczMlmWtl53HuimuW0wqzctz/iQJImSQgfnzJ+EJEyW5SmuwKSdLEtTPwoK/YGxJ8tSgEBPmJbXelDkM2MdWclg5sC+3SQSUebNmydGj4s9e/ZgKTRxZWqyLCnl/8RCCeTh5GRZRY4CDJoep6SMQiiUnCzLYZc5cNBHe3tAyD3PmUBRkUN3sixSzzux1GRZVqs165ohtb9+w3Y6Ons0KfMcK7U1VSxcMBOENkR0VsWWRO+epoariPHa39FolE35ybKOmWNyhEMDvQx3t4vieSZAQe1kjFb7aeMIL1m8GI/HI0afkSiKwoYNG7CUO/OO8JuQE+UIIzREcsoRjgb68XrsmDWzRqsNGUDT0QGaWgfScXlOPAUeG4tnJ180qA8F0VgCv86s0Sriw4WiKMSjYYYHe0edNfrAkT5aOvKjS46HIq+dhbOS9+K0I4wNd5Ewa7RQP73BAXqi/ZjcYLKPOMJaFCDUH6Ftc58Qc3pzpOkgPT1dYvCEqJpcwcXvujDj+ImzRmcNvVQd4UAXDodMIqEQiSZnr9XKicdZRJTT7qfL0oSNhZifGqaXvx6irCg3WnoxLTnktIhyos1axsqLUfLT21eAaCROIiFRUlKL3V4Emt5eRWfWaBXxGA36/MRimS+Q9I6fHrpySnJyu3Skkvm9f07EzMT9MRDrUEyaFZYVMMIoURmIclarFbc7ewRHrrxEnRnFBjFeSyQaZdPGLdTW5R3hY+GYHGF/Vxv+tiPUTKrK9xJPkHg8ztHWdspmLsBkd542jvDiRYvOKkd448aNp8QRjsXidHR26Y1EyjMBLBYzlRVlYvAxcTyOcEdHO7NnzcRkSl0vkpTsZpEk5LjYI2zMiFdPAkVJPuxnnxKpIbgZeuRu3iRNLKQyRk2fO91IOdqwXM2tiqitGK+SKSehHRo+Yl+W7oj6pwNT/7PLy8pDsD+57roqJRFTHWGzC29xJYZUj3AqkZBbcj8WVXuEQ3g9Iw+L2nxlRUGW1bSiVYItSrIHVJQCUf90YOr/xO0fkRKZWP0ncxM11ssXUaMJ2W9KLbQsK+BXl08qqsBssWbqpx6flCPcHenD5JYw29VnDdH+VD3FR5YZUVCyesjGIvvInHi01SLLMooyorOKWHXpYykomPwnYbaaMo5DLJQg4VcotZZQbC9IHc6R46soCuHwIIFAcvkkp9OsM9pBmBUwS4kU2nM5PeRTrX/VEu3/VJqs/DRyaVW154KerPpbRLSFDPtH9jXlnUD7UxEn1f5kr36MUEjB4azCYS/KsFFRIB6PEYvFUz3CFp3jduban/lbRLSFjGMzsn/22B+NRtm6bQf19Q00NDSk4vKMl2N2hON9nVyx4iKMORysPPr4/cM8/+LLlEyff8Y6wkoswLZX/sOjj6+ia1hh0oJLef97b6S+wCKKviGcSkd4aMjPmldfx2azTvjBK0+SSDSK2+XkgvPPEaOOiWN1hNvb22lqOkxJSTFGnRd8iUSc4cEeYsE+CoQeYYTmCbLaqkzENlMN05NFiBPl9PJSyVBIJ16PXHqL5QqMab9og4pevIiYVsf+WCyBzx9GMrspKK3CkLq+RyMWDeMf6MZEamg0OnqriOUKvNH2g076DIV04vUQ9daGi2GjIeaTSj8yNNqOJ7WOsB4KCr2BAbqjfRjdYEn1CKfJdSxFm0XEYyfapKe3Fr0y9OomVz5ieu2+qIuKWB46+aaIBpNDo8usJcke4axMFYKhAQKBzqQj7DAng0W9ciHIKQjvZk4kGhuzqipHmVly4yVHflmcBvYrikIwFCMUVHA6qzOGRqty6aHRdjtWS9IRzvDBUsJis5j251LhadNSGYvHViueqaMmIiWYLl+jRNrX08Rry9CWnQ7IEkiRpYQmLlXWybJf5VTYL/rSiUSCzq4upk6dRk1N8pOhPOPnBDnCCv7O/axa9Rqd/gSTZi3jonNm4jQbiId7efmJf3OgP57M1GRj7sXXcd6UkszC3iSczo7w+L4Rlmlb91c+e/cqLn7HzcwtCvLMX/7E8LyP8t3PXofbmO1AnGoURWHTpk2nzBF+Ze0GLr5wOV7v+F4k5Mlk15799HT3vuGOsN/vp62tjXA4pOkhGWl9EvE4Q30dRIa7KC50YLEIw6fTLaZmX0RsNcdCr0HXlqMXr6InpyKGH+N+RqN9quzXoomPRBMMDAbB4qWksgGj0ST0dGYOHQSFaDiIr7cdkxKguNCeXd4o+2LQG21/Flp9RF3E8GPYF4PGa78sK/T7QsQUO4VltVhs+vdbBej099Ae6cTklbA4TWmHQyGZv6heekft6EkFiapkHa5UmpyI8WIGQsdS+uE2QyiHvhrEItLy2nxHs1+B6HCMhE+iyl5BuatYc9arIzUUAsM9DPlbcDoV3O5jfIGd6+DmOekoikJgOMpwQMbtrsflKhMqQiIajRKNRnE47NhtmnubiuYE03Y+5twnU16L1plDFRPL0+SjFq2k0orhkJk+q7z0nyTa9Aj6iLJpTqb9euVNxH4hvfa4qmlEbDY7kyZNGneHVp4RTogjPNy8lq//709pM9Yyt9rMlnUbmX3L//LVWy5g+NCTfPSd38A4dyGFdiPYC7nivZ/i5mW1YnFvCk5XR3jRwoUZF5ASHWLVw7/mmYHpfOUTN2Ie3M+f7vk9JRe9l4rDj/O4bzHf+fRbsBtlDj79c+74c5Af3P9lGoVesjeCN8IRvuzSCyjwegCFyFAfPb7QyMOJ1U11aQEGCRKRAD19A8QVI56iEjz21Nt4gUQkQE/vAHFGlzsb2LlrH52dXTkd4Ugkgs/nQ5IkPB4PVs33TnocqyMsyzLxeJxEIiFGARCPRenrbCI00EplmRu7fWLXa56TSzgcp6tnGMlWTGX9LIymsa+ZSNBPb8dhzPIQFaXOrAeQPCeeREKhu3eYiOKmrGYqNof+C1gFhebBdg4HmjGXgM07dn3mgbAvTrwXGp211BZU6fYI+3xtDAwcwONJUFCg3yOf5/RFURR8vjBDQzKFhTPxemuyvKdwOEw4HMbtdo9r5vE8ZzZGoxGTyZT/XPUYOH5H2BDjld99hR9sqeGX3/841U7Y/o+7+NIDcX7z6Lcwrvkln/urjx/8+MvUeZIXqmQ0YzG9OSvrdHaEM3uEFXp2/Is7vvkgl9z+LQo3/ZF7mybx/W98nMleI5GEAbvVhBIP8Nxvv8Qf9s/l13d/lNKTVK+yLBOLxTKcoHg8jsFgyLrwVUf4VMwane0Ih1jzqy9z+29WYS9wI0kSplnX8Ptv385kb5DHfvFD7l25HZPVgqf+Mr781Y8yuzyzkVIivTz6ix/wp5U7MFkseBr05c4WxnKEOzs7ef7552lvb2fBggU0NDRQXFyM1+vV/TTjWB3hsYjHIvS2HyY0cJSqcjf2s/jlxJlIKBynq9uPZCuhqmE2RvPYPV3hwBA97YewyD4qy11idJ6TQCKh0NUzTAQX5TXTsTn1ezAURaFpsJVDgSOYSyXseUd4bBQI+WLEe2Gys566gur0rNFpEUVmaKiVvr79eL0JCgvzjvCZhqIoDA6G8flkiopm4fXWZbRviqKkHWGPx5N3hPPkGYUT4LWYmHHVR/j+He+nrsCByWTBaDFhMICMQtvhQwRCPh782Rf5wIc+xR+eeJ1w9vwQed5gFCU5icbIBiWzruJ9b5nDQ9/9LL9+YYgPffS9NBbZkIxmbBYjcjTA5hf+zv0vBbj+XVdSbExO4nAytv7+flavXk0gEEBRFILBIOvWraO3tzdLVhHHrZxKIgH2H2pn2fu+zh/v/RP33nsvv//ah6krtnJ03SP8+cUePnHXr/jFj77CNP9L/PqRtcTTE/EAyLSse4S/vNjHJ77/K37x46Tcbx5dJ8i9efB6vRgMBh566CG+9KUv8fWvf52HHnqIjRs3cvToUQKBALKcv6nkyZMnT548efLkGT/H7whLJkrqZzG7rhgAX/N67nlwHXPfeiV11ijN+/cxEEow54Ibeedljaz69Tf507N7ODNW+zv5KArEY3GG/cP4/f4JbYFAgFgsRiAQyIob8g8RCmm/dTwGDHYWXHY5pcN7SDQuY9nUovQJI0f9rPvXL/j+nzdy9a3/wzvOqcsagHUikWWZ7du3876RfucAAP/0SURBVOKLL+L3+1m1ahXr16+fsH2KohCLxQkFgwRTWygUIhaLEYlE0mHj2UKhEJFoNCP/RMjPoS6oKIuzYc1qNu1pw1VQiFkKsGXNesxLruHKBY3UTl/KTdcvoGntJrq0Dq48zJaXX8Oy9BqunJ+Se8sCDr+6MVPuLENJ9fAnEomszWQyUVlZSVFREU1NTTz33HP86Ec/4nOf+xx33303Tz75JDt27KC9vZ1QKCRmnSdPnjx58uTJkydPFsbbb7/9mw6HI2t4KUAsnqB/OExEBovVmh56EQ34kUPDTG6sG0mnJOjau5rvff9XDNa+la984i0U2UwU1y3kLTfdxAWLZzJr4TI8PS/z0IYwKy5bhvtNONIpGo1yuKkZR0kFBrOFcCRMb2c7Lft303T4EE1NTePe9uzZw/79+zGZTPT29nLkyJF03JGmI3QN9GBwm9M9anokonF8R/uoKC/HYhGGEiaCrHnsj2zq92AcasNQv5i51R4SkX5W/vWn/Or5Tm7+xOd4+0VTsepnf8KwWq3YbDY2btzIvn37aG9v5/zzz2fy5MlZQ14VRaGzsxOTy4KjaGS4tyzL+P1+uo520HqgmeYjzTQ3N7Nv3z527dpFOBwmHo/T2tpKc3MybrStpaWFrq5uEjI0NtRhs1kZ7jnAw3/8DU0RBwWmCGueeJjn9wRZungK2599lPi067h6UQ2SZEAe2M9jT+9h2Q3XUaUuDRId4pUn/kF8+lu4euGkpNxgUm75DddRmV5C5Oyhu6ePrs4u+vq6aWtr092am5vZs2cPLS0tRCIRAoEAPT097N27l7Vr17Jhwwba2toA6OvrY/Xq1QwNDTFz5kyuuuoqHA5H1nkyUWQ5QdA/QDw8hNtlxWzOHpad540jHpcJBKJIJgfuwjIMOsPmReKxCEH/AEYlgts19lDqPMePokAgGCWBBZe3BJMl9zf/g+EhBmKDGJ0SZtvY9ZkH4hEZOQhFlgIKbB6d+55CJDJEKNSHzabk5zo4QwmH40QiCnZ7KTbbyHrRKvF4nHg8jtVqzX62y5MnT5oT9FSd4Mi6v/G5r34fw/z38P2vvYdJHjNEhti/dz/+mJIsSLJQXOIkFBoilppE+s2OIisM+gbZuXMnW7ZsmdDW3d1NeXk57e3tbN++PSNu27ZtNDU1ERUWSh8/CTq3PMX9z3Rz0+fu4tPX1/D4Pfezq9PHnufu56cPbWTpiquZZOxl64aNbNvRRPAk9lgajUYWLlzIxRdfTDgc5qKLLmLJkiW634iORjQa4UhTE2vWrOGll17ipZdeYvv27YTDYTo6OjLCx9pWrlzJK6+s0fRKK0gWFxfd/AX+9ytf43Nf/Bo/+s5thF9+mJXbWonLiYxvnA0GI4oSJq69FhSFuCxj08hJBgOyKHeW0dXdzb333ptze/zxxzly5EjGRFbxeJyhoSE6Ozs5cOAAa9asYeXKlezfv5/42Xyw8uTJkydPnjx58hw3xz9ZltFA946n+J+vfB/n5Z/ny+++CK/ViCRZcDl8/OITH2FT9fv4wf/cgCN4hF9+6Ut0LLqNH316BY4T5IafSYiTZQ37/SihIeqL7FhO8NJD/bEhupVBKioqMBmz6xfNZFkL5s/H5RqZLCYe6ORvP/sGuwrfxtc+fg3Ggf384q4fEF/4NkoP/oM/PHuEohIPSTdUorz+Gr5x98eoPcm9ZIlEgsHBQQoKCnI6wYqisHXrVt3Jsnw+H4aATKW1GKOUTK9+VyxJUtZb1bEIBEMcONicniwrHh6ka0ihoqQQowESg018/ZO3YLz+u0ze9EteqbmVez5zGUZJouXFn/Pxn7bwk4d/yCz1Yoj28eevfIyXa/+bez59GUZJSckd5e6//5CZZ2GP8M5d+2g5epTJjbW6w+sVRWHnzp3cc889vPzyy0QiEYxGI06nk6KiIqqrq1m8eDHnnXcec+bMYcuWLXzta1+jtbV1QpNlJRIJIpHIKLNGR+jrOELY10ZFqQub3aQzI2ueN4pwOJaeNbqibiamsSbLUhTCoWH6Opowyz7KS126y1LkOZEoxBMKPX0BIrJr1FmjZUWmZbCdw8EWLCXSyKzR4vtWSSdMRa3PXPF65DoH1Dz04sX8J1ruWHlq48U8BfvDvhjxPmhw1FJTUIlBymwzkpNltTEwcDA/a/QZiqKQnjW6oGAGXm+N7mRZkUgEt9uNw+HISJ/n7MNkMmG1WnM+F+fJzXE7wob4EPd940N8+Y+bmLpoNgWp5XMKK67kzl/eClse5ct33odSXIk52Iu17iI+d8enmFs+/pl5zyZER/h4Zo0eDWWCs0bPnzcva9boWDhE3GDBnlovNR4JEcWEmRiRmDg5kRG7y55yjN9YRnOE/TqzRh8PmbNGuziy7gFuvXMVX/v13ZzXWIDv4Go+8bHvcO33fs20Xffw7deque+Xt1FqCvHszz/Hr44s5c8//TAFBrURC/PaH77Kt1+v4f5ffoYSY0queSl/vlsrd/Yw1qzRiUSClStXcuedd3Lo0CE8Hg+VlZXMnj2b888/n/nz51NRUYHL5cJms/Hss88e06zRPp+Po0ePEomExSgAEvEYQ/2dRId7KCqwY7Vqzp9cD606aNcETJMjjbh+YU7Eh2MVzQN5lopj5TkRsjLPzcmyPxJLriMsWTwUVdRjFF7+ZZSbyi8aDjLU14FRCVBUYB9fWXqcBvbroqYT63+s/CbKBOxPJGQGfWFi2Ckorcm9jrCi0DncS0ekC5NXwupMvbjUyIxRVAZ6h2gi6UnlcSxpRmO0/PTKG8v+aCBB3AeV1vLkOsKpyh6ZTkMhGOjF72/F6ZRxadcR1ivwRJM6F8c8B8eSU+3JFS+ge92p6AaeJMayS2UUOSW1jnAgqOB21+J0lAkL30I0FiUWi2G327HZbLpGZoeMjqqPel9ST5eM/2p86v9YaHUQTz+9/LWosnpyYj56nM72q0nF/LVo05rMZurr6ykoKNCE5hkPx+8IK3Ga9m3lSFcgI63VMYmFy6dhl2N0N+9nf3MP2AqYNmsm5Z7c3wSd7ZzOjrC2R/hMRlEUtm3b9gY4wh7C/fu5+4uf5/XoTN5+zRx2rHyCI/YL+MkP/pvCnle4/TM/xTDvIhaXBXjinxu55qs/5pMrpnDwxd/zrVVxvvv5j1I08GpK7mIWlw3zxD83ce1Xf8ytV0yb8I37TGAsR9jv9/PYY49x3333UVlZybJly1i6dCmNjY243W5sNlvGW9BjXT4p+W34ESoryjEYDVmNbCIRZ3iwh1iwH6/HhtlsTD97KKk/Etmts7bxEvMUWzYlJZCOS6XXTZdqGTPy1wpqss/QK4X2wTBd7qjKZuqiRc/JPC77NYqP1/5YXGZoKIxkduEtqcZoNGbYn3EsUvuxSJjhwW6MSgivx5ppm2pz6qFGTZNOrw0/DeyHE1j/GtkTbb8sw5A/TEyx4S2qwGwd6ZHUFq8oCr3BAbqjfZhcEuYcQ8gUjVKCiZn2C4jHlRxyWrRpxHDGiCNHvJbR8smFaH8sKBMfhjJLMcWO5LejkkZ3RVEIhQYIBDqx22WcTvOo5Yr1j5rPGMcvXZ4mTCuvW1bqv14+4u90vGB/Rlzqv6ivXpz6W0S0X0+XUdNrfuul1aKXj1iOlNIpGIwRCik4nFU47MWZfrCSfN6Jx+PYbDasVktWiQpKKkTKqU+SEa2SabK1y04/EjJiv155mSmz81FDEY6Cup+r/CS5wjlG+7NzzFX+qbU/Ho/TcrSVadOmU1tbm4rPM16O2xHOd8NPjNPVEZ43d67QI3zm8kY6wqDg79zDI399hF2dIepmn8eNN6ygpsiOpCRo3bmGhx95ml65gKWX38CV58/EZYLm9Y9y7zaJT93yVkodkr6cWf9B8ExnLEe4p6eHnTt3IssyjY2NFBYW4nA4ck4AcqyOcEtLM52dHcyZMyv5KUFGu6Mgy4mkIxzox+u1aybLymy+Rt4Ea56gNGJq85UO06bXa+v0yHjjPEp6LWJeWhm9dIL9yQKTvyVJSjs/IiN6CWXmtF+DqIeos4rOG/dYLMHQcBjJ5MJbUoVBvL7FvBSFWDTM8GAPJiWExyMMET0j7E9lqiKm15KKS5evldFLp2t/UmDEfqH8tP0aY1VSQYqsMOSPEFesuIsqMFs0x11TpoJCX3CQnmgfRheYHZo27Ay1X70dpIsZS//MrEfIZT8QCyWQh6HUUkyRo2DEcUnnrXWEFRwOc3a5GfKpP2eC/WJ6LZrDkFZdiMsddrrZrxAMxgmFZJzOKuz2oszyUo5wLB7DbrNhsVhPC/uz7BmP/brpzsz6z7ZjDP317E/FacuJxqJs2bKN+vpG6uvrNcJ5xkPeET7FnM6O8NnWI2yrdL8BjnCeiTKWIxyPx4lGoxiNRiwWy5gO7fE4wl1dncyfNweTyZRs7DRtUCIRY9jXSzzQj8djx5L6DEQPvbZLLF3b1onh6cZ6lHi930xgX0UNz4WYXgzXYzS9VHKFq+jFi2HacqKxBP6hMJhTjnBqaPRoesQiYfyD3UlH2Kv/raSYHiX5UJRLb94g+/XiRttXSdulQdKR19o/1rU0ml6yrDDkDxNXbHiKBUdYg6yMOMImN5jtmT38jFHOWPsqp9p+lVzhKto8tGGMZr8CsXAC2Q8lqR5hQ0pXrf6h0ADBYBc2u4zDYc6wl5Ngv550rnAVvXitTrn0G+++ilrOmWQ/CgRDMULBlCPsSDnCGt1jsRjxWAybzYZFO/lm+leSM9H+0fQb777K2WB/NBplw8Yt1NXV5x3hY+Ds7GLKM2GSb5by5Dn9MJlMOBwOrJol3E4W6dxT5WhLk1J9K+qVMtoVo8qJDZfY2OYK14vX5oWQRtRF0ZFT81PDxHDtJsrryYllatHqrZUX7dQLzxWvzYtc9mtewotyYlr1nielEklKpoz2t3Zf0gw1zYVWb9EOrYxeeK748divjRPlxLQj9mdvonyGnOhY6SDp6Ky1U0r/GcV+TeGK+r2kRqcz2X5VRi9cG48mfjz2pzPUkRPtITVUUw1Tf4v7Kun4Y7AfHTtzhauI+ov2a9HaqO6L6bVpFTLrXxsv7quk409D+1VEfbVo055t9qsy2jRiem3as9X+PMdG3hHOk0ZJzZ58Nmx58hwL6aZR5xxSyPwgU9sg6Z1zeo2W2kAySgMoopePSLqR1uyreWfoKYSpemt1Gi8TtV/cPxn2o2OLWGZmWEqLVMR49FGZqP1qmMrJsl8l29YRch0r8f9oiLaI6OmUUa5eIi2pFxOgk5GAXlmns/2k0uilE9HLR0SV0do1mv0AivphuI7d4n89RFtERH3UMJWJ2K+MYgc5jpGaRgwnR5iKVq/R9BNtERmP/eMhp/3CPUeM18aKcdp9WZYZHBzk0KHD7Ny5ix07dnLw4CEGBweJx+MoQCQapa2tjUOHDuHz+ZBlBRSFgYEBmpqaaG9vx+/309bWzv4DBzmQ2g6qvw8epLOzk3A4TP/AAIcON7Fz12527trFwYMHGRwczLlaQ077NejV83jrX6zrk1X/oi56afQ4VvvzjJ+8I5wnT548aVJdirpvfZNhaoy2wRytp1orh6bBElMopF5GadJoHVVtoyo2omI6NI2jGJaRNjX8O70rxIvlqGSVNQ77xbzEFIqOHROxPx2JphpFPbVpJVViRHg0+8XfGfnq2K/G6emLYH9azxz2a+UzylXDhHQay7LKT//WOceP2X5NnIoaJ5afRpMop/2a1Geb/do0Oe0fZ/2jpktFjGZ/mlRibZxovxZtuFZHxmG/Hnr2o5O3Gq+Sq1xtOtV2UV7dB9L3PjE+F2IeufRQUeNy5a21eaL2JwMzvwkW06XTCPd4bfqELNPW1s4///lvvnnnt7n9s5/ntts/xzf+904eeuhhmo4cIRaL0dPdw18eeJD//ea3eXXtOmKxKLH4/2fvvOPjKM7H/ez1O516l+XeewM3bGxjsCE0A6GFTto3hISSHkoghUAIyS8QEkpC6B1TbDAGN4wb7r1JsmVLVu+6XnZ/f9ztaW61J8kFMHCPP2vtzrwz8747tzvz7uzOhFj16RoefvhvPPvs82zevIUXXniRu+++l9/edTe/+c1d/Po3d/Hbu+7hd7/7Pa+9+jpHjhxh6dLl/PGPD/Dzn/+S2267g3vu/h1vvrmA6uoaZFnuZAc69neyUXPejqX+1TC9OhTR5pFIDxUxb/GvyonUv7ZcneewSY6BpCOcBAC/34/P5/tabH6/X2tekiQ9JPKkW21ZxAYovrGLvB6r1wDuLa3ivY+3xLaFwiaGL1q2jXaXF4SG211bxoM/+z6XXHMbV1x3G1dcfwfXfPdeHnt7A+2h+NZOLF91xLQ6aRtM7X53x5F9hcZDm7nvkRc43BxZWkotR5tWi175IjH91X2NHZKmEycilh9zRDUF6ZXfWRehF9mNrJifWH4i9MoX6RSewH69cxCn5wnUf1ckkj1R+xOmFe3QFejgq2y/Sqfw46z/2MnSKNVd+SraePVYG67yedmvvb5U27u1XwgTwxWdsETp9I614Sqfp/1i3sdiv5guLi7RyLGi0NzUzBtvvMk/H/8X27Ztx5niJCsziz179vLYY4/zysuvUlNdjcvtYvv2HaxYsYIjh49EHFZZpuLIEVavWcvWbdtpam7G7/fjdrk4fLiCtWvXsW7dOqqqjuJ2ufH5fAQDQcrKyjh69Ch2ux1FgXXrP+Nfj/+bNWvW4vcHTor9KqdC/Xclpw0/3vqPPdNNclwYb7/99vscDkdsIiyRYChMk8uHXwaL8H1ewN2O7HUxcEBf3XRJEhMIBDh46DCOnAIMZgvBQACjEqYgw4nJeHLPpSvgocnfSkqKM2E9hQMhWisaaGpqora29muzBQIB7FlOHFkdM2HLskwgEMCKmSxHBkZJ/5wcC35/gCMVVfTv3web7Zu7LNiJUFffiMvlpk+fXtqo46K0tJQlS5bQ1tbG8OHDmTdvHg6HQ3fUTqS1tRW320VBfl7c0jsqiiIT9HsIB73YrCYMOterBJSV11JR00pBYTE2u1N3UyQTlVU1jBjcC5vVHEvrbazg+adfIn3KxVwwfTQjhvcnz+Hh/Vffpy1vNBMHZmGMHwiIa7S1OovtoxKd5EOVEeNiaaMy2rzaqvbwvw/2MOesaWQ5OiaZ0ytPDVfzF8tQ48RjFa28Vk+9PEX7ZVnB7w+B0YLNkRqxQ7RFa7+iIIdDBHxeDFIwui60vv3actGxHR29tGnEfMVw9VjPNnXTHosyavo4nbR1qbVfJ/9OaTSyIsdrv6yAPxBCVkxYHc64Sc208p6gH0/Yi8EKBnNkSTNR5qtov1i+iFZem4f2WJRR06OAHJSRAxIpRgcOs63DZmGSn1DIRzDgxmxWsERnvxfzV49VxHCVruwX97VhevaLdmltUzftsSij5hGnk2CvaL82H21e4rGKGK7yedmvotVTq18wGCYUBIslFbPFjhRdlieSWCEsy8iyjMlkik1qK9ofDofZuHEzL7zwIgcPlXPVlZfzk5/8mHPPnYuiKGzfsYPy8nKGDBlCenoay5atoKSklJmzZjJ+3Fgkg4HPNmzks88+Izsri7nnnM3cuedw1pyzSE9P58CBEhx2B7f++BZ++MPvM2XKJPLy8nCkOJg9aybfvuwSRowcwf79B9i//wBjRo9i9JhR2O2RdcW7sl89B2L9q8cdB1/f+hd1lKJ1WVVVQ3pGRnId4ePguGeNbj9aTnZWpjZJkm4IhUM0NbWQP2L8KTFrtByW8bXGrwH9dcFst2K2dyyx83nOGj118kTSk7NGHxclpQepr29MOGv0sXJSZo02dzinasMlh0O4W+oJeJpIT7NjFmaNFnNev6WUqnovF198sRAaT21dHYsWLeSKCyaTkeaINWgth7dz+w/vYtrvnub7UyMznitBF8/d/QtWZlzMP+48G9fB7by+YAk7DrWS1n8kN1w/n0FSBY//Zznn/OAmTiuwse7tJ3lyfw5//sll5Fvbef2/r2CY9G0uHBBm+eIPWbx6P15rFudeOp/50wbRfngr/3jxEzJtMnsqrdx421UUtO/huZeXUxmwc/qYfJasr+KRB35Gv9QAG1cu5+0lG6jxmBg6bTY3XToN95aFvLQrnTt+dA62lgqe+tcTeMZdyy/OH0ZT2WaeWrSXOWf05/2PtjG4yMmGDXtpt+Xx7ZuvZ97IHEyaWbq1HQbtsZZAMEx7e8fySZLBGNcR0stHXEc4Lc0WNwqppklUrraj1B2J5MX8E+mpd6xFG68++FDjusonUdjnYb8iK7RH1xFOyy7AFJ01Wmu/dtZokz3amY/Ga9Hqearaj045alhXemqPtajxIW+YsAtyzR3rCMfnq+D1RGaNtkdnjdbmrdVJjFNJZE8iEsknOs+izuqxGK+G6ekMHfXfKVxzrBd2LPZrwxORSP5Y7O+wDbzeIB511mh7VtzbBAoQCgYJCrNGa20LBgI887/nePTRf5Ka6uTuu37DvHPnYZAkNmzYyB/+8Cc2b9nCb37za6ZPn8aDDz7MihUr+f3v7+O7N9+IZDDw738/yRNPPMmIESP4za9/yWmnTSQcDrNw0fs8/PAjhEIh7r//d8ybew4GoxEUBb8/gNFowGAwsGHDRu7//R/ZtWs3d9/9G675ztWxZTy7sl8vrNP5O8b6T3SsJ99VeCISyatlaeO70kkb5g8E2JScNfq4OS5H2NfWgre5QSue5BhILSjGYLZ86Y7wN4nPyxH+dM0GDAZDt45WEn0URSbV6Tx1HOGxoyPLJ0XD1QZKDodwtUbXEdZZPkmVW7+llOoeOsKXXzCJzLQUiKZvPbyNO354N1N/9zQ/mFoIikJ77X7++Ks/0T7ph9xzfgq//81T2Cadw6Wn5bF28SLW1BfxwK/m8sqf/0Hf797Dd0+38viPvsufSkbw3iu/YVRwJz/57SKu+eOdNL31GG9UFXLjxacRrt7Dgg+3c86tv2SmfSc/uO4h+n3nFq48cxgFzmb+/LtnyJoxn2+NsrD0nYW8XV/A+4/9FO/6N/nFs/uZf+0FDDTV89ZLC0k56wf8dGIttz2yi9/987cU1X7KLd/9LQ1TfsF7D5/P/ref5p+b0/nFpTn88paH6XXudVx+9iB2ffg6H7aO4Nk/30xhWvxyRyrqeY1Dx8kJBsO0tftAXUfYGKlDsYMR18FRFEIBf8QRxktaaocjrNcREumko9KxSGiidInSiPJaGTVcRWuPGt9VmQntF8LV40T7WrR6anXUhonhiZZP0tqvoNDgjl9HWGuPNp1emaea/SqfV/0HvWHC7ZAXXT5J6yARdYTdnlocXTjCiexAR0+tjonCRI7FflX3ntgvopXXymrTdRUnotVTz1a9MJETsl9R8HpDMUfYEV0+SSxTu3yS1n6f389jjz3OE088ycCBA7nrrl8zY/p0AA6UlHL33feybNlyfvaz25k9exZ/+9s/Yo7wzTffiDHqCP/7308yYsRwfvObXzHxtInI4TCLFr3PX1RH+L57mTdvbtxSq+FwmMqjVTzzzP944423GDp0MD//2Z1Mnjypky+ia38P60orr5XVpusqTkRbT6KMXjqtPJxg/WvKCQYCbNq8lT59ko7w8XBcr0abrDbsGVlf282WloFktaOYLaRk5eLIysGekY3FmUbYZMZgc5CWW4DZmYZituLIzCElKxd7RhaW1DSw2LClZUbDsjvlb8/IwmAyoSjKl/5q9DeJz+PVaJPJRE52Fr2KCr72W2FhPgf27eHf//4nJqPEjOnT6N+vD62tTbz5xmvs3buLiRPGkZGeytatmzBICpNOn0ifPr0wGmDHjq24XK2cccYUcrOzyMpKJyc7k5ycLPJys0lJ6f715Z5wwq9GF+THrhdJ2BQlTNDnIRzwYrOZMRoNHY2T4AhVVjfh8oQYNmyYpoQO3G43Bw4cYNSQ4rhXo/2ttSx6+3WWbSxlyfsf8cbbH/LWohWUS0P4yQ8vIrhzMW8czOQPv76OsUP6MmFYAesWvYsyagaDfQdY05TPnD4uFrxdRlqamdzR40g5uJolTcVcM83Cv//5AQWTptM/TUEx22jcvZadngIm95dYsa6RG371PWaPKOTohg9ZdDiX+379HcYPHUC/1DZWbm3mojMH88HLr2Ocfi2/vmoKg4YMYVh6G8++t5PJF8zk6MqlyENOJ71qK9vKZYJuOO2sMez44B3CI+cyrcjNR5/UccPdtzJ37AD65ip8uGgnk+ZOo9Bp0e1EiIg1qK3PTq9Ga+55qnTsryQhh0P4fW4MhDq9Gi3SKa0QF0PjCKu/G3XTQ2tDj+0XHgR0ikuAVnc9vbQyicK18eg8CFDz15ajqK9GE3k12hh9NVpNQ9R+RQFv0Bt7NdoYfTVazUS0v5M+UcRwre5avbRxXYVr44/F/hia35m4r1f/cXkksl8BOahAgNir0dpyAEJBH6GgG5NJwWKJPGCgC/u04YnixX3Vbq1sjBOxv4syRfTCexKmFyfuJypH3JeETQ/tfUbc74n9oZBMMKhgsaRiMkdejY7LQ3g1WnQuVZlwOMzuPXvYvHkLkiQxZcoUBg4YAMDBg4dYunQZNTU1zDlrNoMGDWLtmrUcPHSI6dPPYML4cRgMBtauXcemzZspKipixozpFBYWoigK+w+UsHbtOmRZZvbsWQwaODDWpgaDIcrLD/P662+wePGH5ObmcuONNzD9jGnYbB0PxbRo7dc7d4lkupPVhiWK04vXHmvltbIqJ1r/4nE4HKa6uob09OSr0cfDiXsCX0MCfj8le3ey/P13OLh/D+FQCBSF5sYGPlmyiE+XLsbr8dDcWM/Wdaupr6mKTf3e1tzMzs2fUXGoLJIuydcao9FIdnbmN2PLyiAUClBXW0NbWwuHDpWhKGFqa6qpqqrE5/Vgt1mxWs20tbbg83pISbHjTHFgNhtpb2vF63FjtZipra1m39497N61ky2bN3HgwH48Hk/EofxSiTQv2kYnQnS92Whk3BPfaKPWVcOXCNFmBZAMNsZMOYPLLzmXyy+7gB//7Be88NgdTO3jwNfqwllUTLrNBEjYnZlkpwWoarEwZsJgqnbsZPv+EmqGTubyqTZ27y1h29ZyBo4bTVZ7Awda26gu2cOqNZtY/dlO6DWK0wdnYFRAstqwmyWQZdxNrdgKe5FuMSJJBjLyiynIBkIBmrwGBg4sxCQBkpHCojyC3ira5V5MHGxl66YD7Dx4mMJ55zI2pYKdu3axozTMxDH9MAOS3Um6PfIGhcFoxiQH8etM6CKey0776iRCSvxaqOLJF/MQ0xJztCJlStEAKZKxmjxWv9q0kppelBHqHyF/NV6UVRFtQMhX3dfqrcZH1Oz8rWuifW0YGn3UfTVORcxf+1dNE5Ppof1xeUZXKUtov0Ssa6+u8azqqbVfRc9WvTBRF3VfzEcNRyetqkecPT20XySWj+b6V+MS6S1Fy9PqB+pvOL6suHhhn6i8Xj4co/1quJiH1q6Tar+OfiraNGK8mI+aPlE+iWyL6d2FDDp2ae2PhR+H/WhGf0W0doj3NDEfg9HIkMGDKS4uprLyKBs2bGTvvn2UlJbyySerKC8vp7i4F/379yM/P5/0jAwMBomDBw+yb/9+yg4epLy8HLfbTXZ2FqmpTgyah3MiSvQV3t179vDkU0/z/PMvoigK5547lwH9+9Ha2orXGz95ZCL7pS7qTZtGjBfzUdMnykdbt+K+ml4rI8pp61WvvhQdOY7Dfq3uSY6NpCOsgz/gp+zAXj567y0+XfohrvY2AgE/h0r28dE7b/DpRx/g9bhpbmxg64Y11NdUIUcd4daWZnZu3kBleRl+n5e2lmZamhppaWqgpakRt6sdRZG1RX5uyIpCKBQkmNwIhUPI8hd37r+uFBcXk5+fz9q1a9m6dSvl5eWMHDkSq7VjsjCv10tpaSnr1q1j7dq1bN68maqqqtiofF1dHQcPHmTjxo28+eabrF69+qs523cPGruuUIh0akUMRienzZzNFZeexxXzz+HsycMpzHJglMBsN+NqrMcbjCwz4fe5cXttZKdZyB82mvy2nbz70X76jhrJpNH92LfuMz6pNjBlQm8kRyr5WXnMu+67PPj7n/Pg73/GXT//Ht+ZOw5HZFA60qRKEnanHV9TA95Q5HrxtLfS3g4YTaRZgtTVt0ZMV2SaGlswm7NIT7UwavxQ6ravZOfuRsaMm8iIgVaWvbeUw85hjB8YeQWcaOe741x12K93/uI6F8L+saJ2OmJ5xM67MPtYD4mJJ6h/sQMj6qy3r63/Y0HsRMXCtAFROtmvI6s9ToSexqL9Klr7VTps78J+cdnuRCJfMfv19hPa3wO09keuyS70U/TXzFb3tfonImH+wr56fSldyNMD+7uK1dNXLwzBfj19Tpb94n7sQVc38sdtv1j3+rvRAGFJLsF+o9HImDGjOXvOWWRlZfLWW2/zpz/9mT/96UFee+11ZFnh/PPPY8zYMWRmZjB+3Fh69+7N8uUr+OvDf+OBBx7i09VryMzMZMyY0eTm5elrG9VTURQaGxp48YWXeOWV16isrMDr9bJ69Vr+8Y9/8r//Pceh8sPa1Ho5xuhka4IwdOzXxol/u0ObHk1a5Yuof62+PVU+SSeSjrAOiiJjMBix2mzU11Zz9Eg5tdVHKd23m4ysbELBIIoiEw6H8bhcuNvbcbuiW3sb7vb2yPeoba3s2PwZ6z9ZxuplS1j2/jts37iegD+gLfJzwWgwIMngcrlpb3N94zeXy004GMZo6HgVLMmxk56ezsCBA/F6vSxfvpxAIMDw4cPjvgFqa2tj27ZtLFy4kHfeeYePPvqIsrIywuEwGRkZzJgxgwsuuIDevXuTk5PDtGnTSEtL67ZR+EIQGhS1IYt1OIXOuaRp7I6XWBlqnloBNd5gpO/oieRVb+elhWspLS1hwevvcMDXh0mDM7BmD2BUbgNvLT7MiEFFFA4cjG/LWrYqOYwpTMFcMIRzB1h586mXWbWjjO1rl3HPL+7lmRXlBGLPhxQwGOg9ejxZ1dt4+f317NuznZdeeo9tTUBKFjOnjmbzu+/y/oYD7N2+gadeWEHBiCkMyDZSNGQE8pFP2VKRxYj+WQzpX8DqhStwjh1LsUWwLDqSK5KowyB25DrFd3H+1TBtfcXOseo10FGp2vxjEmpnTtgS1X8sPvpbVstTN0VRUAT7tXmqYTG6sF+v/Fg50WP1byf7BVm1s6rNP6ZbIvuFYzTlJrJfRMxPzVMNjyoGwmrC2vRfRfs/1/oXjYsi6hZ3f41GSNp9AVE38RjRHk2YuK/3V+uMiGXo2a/Ki/Eq2vLVMFGPOH11XhMXj7Vxom7iMQnsV2VUVBl1H8GeE7ZfEh7gCRESxH7PIlr7JUkiKyuLK664nO9992aGDBlMbU0dFRUV9O7dm+9+9yauueY7FBcXY7XZOP/887j5phsZOnQItXV1VFdVM2jQIL7/ve8xb+5c0tPSY88WMzIyGDFiOCNGDCc9PT3yu1MUQqEwZrOZfv36MmrUKDLSM2htaaWmtpam5mZCwSD01P4E51+sF4S/WvtVxGNtnFg34jGacuL0FfZVGXUfwZ7YsbCJYSrHan+SY+e4vhH+uuP3eak8VIbb5aKwuA+1VZWEQyEOl+6nqHdfmpsamTrrbDxuF1vXr0aWZTxuF7VHKzlUso+K8jKK+/Unv6iY5oYGfB431ZUV7Nm2mbT0DAYOG4HZYkH5PL8Rjr52hgJWyYJVMn/jN7vBSpo5hUx7Gg6z/Rvzez5ZKIrC7t27KSsr4+KLL6a9vZ1Dhw4xe/ZszGYzpaWljB8/HrPZTHl5OaNGjeKGG25g5syZDBkyBK/XS0pKCpMmTcJgMHDgwAF27tzJhAkTmDFjBg6HQ1vkcXFi3wi7KSjIizxEEhoySZJQlDABvwcl6MVqNWMwdl7ORYp+I9zew2+ERw7uhc1miVyskkTA3cyWDdvpPeVsRvdydjR80Xh7RgFDeltZ9eFiFixcRaknix/ccT3TB2RjkEzQXsmyylRuumYWRVlWqjdtJ23kWVw8YxBWk42Bw/vQVrKBtxauZPm6/fSacSHfv3gCFk8dm7ZXM/GsqfRKtWLPyGdgkYll737AO8u34LHlkJ+TwTkzJjN0+EBSXId4561FfLhqN5bhM7njB+dSnGLGZjZRsW8vjb1ncOO5Q7CE29m3sYZzb/g2owvteFtq2LSthtPOmkJRqhlvcw2bdkSPnZEZ3tXGPa62hLpT49V9FVlW8AdCYLBg13wjrMqp+SpE8pTDYQI+DwaC2KymuAw71b8mXCun7ovhImrZMdk4p0T/G9MYPbBfW56IGhdnfyJd1DBxO4n2K8LySTZ1+SQd+1HAG/TjDnsxWiLLJ6nxWv21+1rUuFPBfpUTrX9t/hKRV8jDQQUl+o2w3WyLe11VtSEU8hEMRZZPMpuNYvYxVLvUTXvOtHLaOK1cnM5dfB+pm1cP7ddDDRfTaG3RSytpNm0arZw2TivXE/v1wqDD/o4whWBIWD4p+o2wKC9rvhHWs99gMJCamsqwYcOYNetMZs2exbx5c7n44guZfsY0CgsKMJvNSIAzNZXhw4Yxe/Ys5pw1m/POO5eLL7qQqVMnk5eXi9EUGWCQDAby8/KYNm0aZ885iwED+mOxRO7tKSkOxo4dw0UXXsBll13C/PkXcdFFF3DhBRcwc+aZ9CruFfueuSv7v+n1r7U/+Y3wiXFcs0Z/3WltaWL10g+pOFTG0FFj+WTJInLyCujVN3JBr/9kGbfd8yfqa2t49rG/kpmdQ15hEUajiebGeqoqDjPn/EuYcc63UBSZupoq1ixdQktzI+dffg19BgzCaDQiy/LnNms06mvRcvI7ZREJMEhGjN+Q3/LJRJZlXnvtNZYsWcJf/vIXGhoaKC8vZ9KkSWzcuJH33nuPm2++GbvdzjvvvEOfPn24/PLLsdlsHD58mAULFmCxWLj55pspKSlh8eLF5ObmMn/+fLKysnQ7o8fDic0aXcvYsaM63Q8lYdboQHTWaO3ySWpD+dmWUsoqmhkzenQsXktbezu7d++KLZ+EkD7g9SBZ7FiMkc632PgBSIqM3+8nGFKQjKbIxF3RjrokB3H5wjjsVgwSBH1eQpIl4uRFCQcD+AMhFMBksWE1GwAFv9eP2WbDECtQxu/zEwwrmK0WlHAYm9WKJIEih/D6AoRlMFks2C2RjhZAyO/Dp5hw2kyAjM/tx2S3YTZEzpIvWo5RApDxegNYhHLFWtK1X4gXEZdPSsuJ3I9FtOkVRSEU8OFqacCIh/S0nk/UgkZOrH9xX4zvDq1+alhP7dfKauW06RPJa3VHJy9OwP7YrNHYSM0qwCLMGi3KKopCwzEun6RnjxhPAhntvhZtXpyA/YnQ6qeGafVKlJcaH/KECbk6Zo1W73sxnRQFr7cZt7sWh6Nj1mhtOSJ6ZerZnygPvfRaempfV/Fi+Vo5bfpE8lrd0cmLL9l+JcHySbHyFYVgKBSZNdpujzmianr09FUUZDnyyY12FQytTrIsR95qiMp90fbroS1fK6dNn0heqzs6eaGR+7LtTy6fdGIkvYEuMBpN9OrTj74DB+P3eRk5dgJ2R/Q7tyjpWVlMnX0OF1xxLRddfT2zzruIwt59MRiNGIwGZFnmUMl+XO2tzDz3Anr16Rf3CunniUGSsBjNyU3YzEZz0gk+AYxGIyaTCaPRyODBg5k1axaZmZkYjUbMZnOsATUajZ1+52pYU1MTK1euZN++feTk5FBVVcXhw4fxer2xVxC/PJToqxSdQiMNkSZKr+Gz2Swo4QDbt21OuB0qO0BqSsQBEJEAi92BOeIlxhrYWCOrKCAZsNjsOJ0OUuyW2IiPBGAw43TYonpJmG0O7NbIMkLqZjJbSElxkJLiwBadiVdCwmrXOKOSAas9Uo7VbMJuizjBkSgTDoeDVKcDmyXe4TRbbaTa1DIN2FPsUScYFCRsdtUJBjBgjx6r+sXOdSL7O1cDCHWhJWEHQlJL7Kj2RLJ65aEjp6LmLJQAXeSj0pX9cAz26/yGtbqIaMtJJKclkVx39uvFqeExPYRIrTXaY7R5neL2J0KrBzrHapgWtaxIXGcJrS5oJso6GfaL6U+G/eq+Np32GK0uJ1D/Xclp0cqdLPtV9GyPoInRmeYglpcwoaBWRkUCkCQMRiMmo7HLSa+IOspGHbkTsV+V7Yn9emFxmnwB9a8n92XZr9UjybGR9Ai6QoKsnDzO+tZ8zr7gUgp698FgiO/cm0wmUtMyyMzOITM7l7SMTMxmC5Ik4ff52LNtMzs2rmfwiNH06tMv9n1QkiRfNSRJIj8/n1GjRmGxWDCbzaifVWRnZzN8+HDS0tJwOp0MGDCAwsLCmGNst9vp27cvvXv3xuPx4PP5AFi+fDnPPvssS5Ysob6+/pSazEyvMVOEFkfd1TZ2Y4b15ooLp3DFhZO58sIpXHHhFM3fyVxx4WQu+9bppKd2vA6ubcx0G+ZOr8h1NJ5ioyk+zVfD9BpV8Vhrq3gslqFFqzcJ5BDz6cE9sKf2I+omTrCkQS88ki4yu5AkOOP0wH5Rrqd0Zb+Yj1henB7d2K/merLrX5XVyot/e4Jol/jgQY3T24dIAq1umuivlv09rH91X6uLtkzxnCLMtq3GiTJxCAF6ZYjH2vSJdOkK1a7Py36VE6l/7fGXYT8a+9W/HTJabRPbr6LVXw1T0ebYnf0qnUtKTFf2a+nKfm2ZWt2+iPpX0erSFZ+n/UmOn6QjrIMkSZhMZiwWK2aLheK+/Rk+bgI2uwOT2YTVZkeSIk/ELFYbBqMx9tM0GAxYrFZMZhMNtTVsWL0Sl6uNYDDAvp3bKdu/JzYhQJIkXyUkSeL000/nhhtuwOl0xoWPHDmSq6++mn79+lFUVMR5553HlClTYq9kZWdnM2fOHGbNmkXfvn25+eab+dOf/sQvf/lL7rzzTi677DIKCgo6jSKfSkhEvsHTIjZYEiAZJMxmIxazCbPZGNsssX0Tluim018BsaHrosEUG1Rto90d2ka2J3SXvxqfWOMIUvQ30xXHa3+3SkbRtT9xUdDDrFX7u8mqW/tjaOwXj8RyVN16mKu+/d3Qk/x7Yn9MV51RrDiU2H8xQa39Kl8l++Hk1b9KTLfuzqlAT+VUvhL29xDlONJ0J6/GnzT7de59cfZr4sUclQSzI6t8mfZLJ8t+Yb873bR80+1PEk/SEdbBbLZQWNyb/oOHYrFYMZpMkb8GIzn5hYwcfxoWm43UtAyGjRpHZnZO7PvpFGcqg4aNJK+wGIPRiN2RgtOZRnnpAXZt3kB5yX5CoaQjnOSricPhIDMzs9ON3GazkZGRgdlsxmw2k5aWFjdBlclkIjU1FafTidVqJTc3l169esW2nJycuO+YvlR0GqnOjVvHmx2dpSOoabTx2uNEiA2mWraaNtaQC7PGKnTuHEWEO+up13AmamTV487noGuOVV5LIvvFTp5ovyooqZGxsK7tV0fPemJ/XFgXHVGpizTa856IruyPxQvlKDo6Qff2q3xR9qPRuWvitdTajyYvrU4RgXh5df9LsV+n3ERIdF//YpxCh61x5erYryLe6r4O9mvLA3379XQ4UftFTor94je/aphYrqadiitPpw07VezvKd3Zr43TKw845eq/pxyL/ceSb5LOJB1hHWw2O0NHjeX0M2ZhE2ayNRqNDBgynHMuvJQUZyq5hYXMOOe8yHe/0cl1snLymDLzbAYNG0lx3/5cdv33uO6WO7j8xh9w2Q3fZ8Y552Gzn5zZcZMkSfL5ITaw2jC1GdI2hmKDJUUE4uOFY23jJabVIoYpxOcbKyvaeHZCCNM20KIOiToKWj1VxHzEMHpofyJ0LNANUxHtR/3uMUExov2KohD515lE9mtluzrWs78n6NmqDdOWo8br1r+AaD86+qucDPu7JYGwWHbMLiGMk2C/SgIVPj/7e/B70LNAL0wl/nxJnYvQXP8qShefEWjtV4+18t0dHw96tuqFqYi/EV05nfufivZ3pLfflf1auovvCXo29CQsof0CXyf7VdS4hPZ/TetfJaHdSXpMctboL5HPe9boJEm+iZzwrNFjRmIymWKjjWqqRLNGq42rKtfc5qO13ddt46Q2mj1tZFW08sdaTndo9dCm08arnKheifLVIgFWq4n8nOjr+YqCJEkEg2HadGaNTtTZUYCg34erpR6TEp01OupIizo1t3hpd/vj0umhtePztB+d9InoqZyKVg9tOm28Sld62Wxm8rMjE03KskJ7u48gNtKyCjDrzBqtEHlQ0RidNdroBLNDf5Z2tf4Tkaj+VcT61h5r48Qwrb569isk1k97njqlE1E6lldCKyPkrwAhb5hQe8es0Z3SRWeN9nhqsdllvJ4Qbk/i1SW050YN66RjF+dCjFfRs7+7fLs6FkmkZyK9uiKRznp5fFH2AwQCYQwGI0WF/XA4suJyV8RZo202LFYrJDhPtbUNeL2ROTvUMJFEOieS09qvLVPleO3Xnlu9/LU6kMAONby7slW6s9/pTCEnJzO+7GO4/rU6q2jLiztWFILBIJs2b6VPn+Ss0cdD0hH+Ekk6wkmSnHxOzBGuYeyYUZjN5li42kCFw0HcrQ0xR9hiMcY1Xir7yuo5dLT11HnV+2tGIBAgI9XKlPG9Ix2CqJMQCoZpa/OB2Um6xhGOdRxEp0FRCAX8uFrqMCpe0tM7z+INsKukjorqtmR9HieBQICsdBuTxxYDEI46wiHFRlp2xBHWdvIAFBQa3PGOsG6HUFHwtgSo39eqez3qdSpFIr+LDn9R2yHVkxf1UPfFNDEEIW2elRWHaW5u7JROa2NXFPTLY+Lc8aAuYaNA0BsmLCyfFItTEwmOsN0uU1LaSm2tL+6el+TUx+/3k5lpZ8zoYdgFR1it62Aw2MkRVuNFPtu4g/qGZiyWZP2fCF6vj97FBUwYNwLE+0S0fdJe/+I1rr2faEl0b1DzDwSDbN60lT7J5ZOOix44ws20+BUcTmfSET7JyLKMx+3GRoix/ZOOcJIkJ4PFixdzxx13UFlZeRyOcOd1hNXGRw6HcMdGhG1YossGaRu6vQcbaGwNM378+FgeSU4eJSUleF1NHY5wNFx1hCWLk7TszusII3RC1P1QdERYXUdYr8Oxp6SOVo/E2LFjoyFJjoX9+/cT9LUyKeoIK+o6woqN1KgjjE4HUBZGhE2pYLbHP3gSO5Tueh8VnzXQp3cv3b7MqYSiKBypOMre3Tvw+dzH3XE9cuQIaYVO5t50Ngid4pBPjqwjbO56HWF1RLi0tJVAwM6oUaM6Mk9yyrNr1y5k2RNzhLUzhXfnCKvXz/qNOzCbzEycMCYmk+TYWbtuEzabhQnjhseFi44rOve5RA6wEn1oK97z4uKF+18gEGBzckT4uOnSEfb6g5TVNlPX7sVksiCpi0wmOSkoikIoGCLdZmRUnzysSUc4SZLjRpZlmpubefvtt3nggQeora3lnHPO4f7772fo0KHYbPojfiqiI2yO3g/FRigcfTU65G4iLToirJUB2FtWT2ObzGmnnSaEJjlZHDhwAHdbg74j3M2r0YgdQUUhGPDhamnApHhIi74aLXYUERzhCRMmREOSHAt79+4l4G3RdYTVEWE9FEWhwdNMfaAp5gjHxYuOcJ2P6i0tzDtnZrfX+ZdNMBhkyccr2bl9Kw6HlQsvvFArEqO6upr09HQcwlwlKh999BFegzvOEYbIiHBPXo12u2uxOzoc4eSDnq8WO3bsIBx26zvCikIoFCKoOsIWS9zDWoT722cbd2A2m5l8+jHc3+Qg9VVNpBbkYTNFc/W3cKQm8lZGBAv5vQqwmSTkkJ+mhgbc/jBmRzq52WmxteVFQj4X9Q1NBMJgdWaTm5USWXM+7ONoVR0hWc3dSEZBEelWAyhhWhrqaPUEsKZkkJudHlunPuhto66hmTAmUrNyyUixRM+BQsDVRF2TC9lgJTs3hxSriZCvjeq6ZmLFREnLKSIzpesR80/XfIbVYmLCuBGxV9MNkoTRaIw4tIqCLMuEwzJGY2TVmVAohCRJsWUmFSAcDiNFV6BRr93OZyrpCJ9MjLfffvt96lqgeigKmAxgNxuwm6TkdhI3h9lAqtVEptNOusOGQefGkCRJku5RFIX6+noWLFjAiy++yKFDhwiHw7S1tdHe3k5RURH5+fkJ73MAra2tuN1uCvJzYw1TXMdBkQn4PISDXmxWMwZjfF6qbEOLB69fobCwMC4+ycmhqamJoN9DcWE6COddlhX8/hAYLdhSUjFIkfqRNJvax5EkCTkcJujzYJCC2GymmKOgdholoK7JjS9Asj6Pk4aGBsIhH8UFadHzC4FACEUyYbU7O43cx/qgEniDftxhL5IFDOaO+hSRgIAnhKvax6CB/XQf6n9ZKP5mPv1wES32PhSkR0blZFmm7GA5dbU1mM0mhg4dqk0G0ZH0e++9F5/Px/DhwzstLVdWVkZICjJo/ACIObkQDioQgBSjA4fZFruPiectFPIRDLkxmxWamvyEw2by8/MFiSSnOnV1dShKkPz8HMxme2SiNDVSkpBlGVmWMZlMkTkvolGqA6VuR6tqMRiNFPfq4f1NkanY8h6/vuNRUqeezaDsyO/60NK/cf71d7Hwww94Z8ECPlqxj0EzzqJ3Kmx+/wnu+uO/+GDJB7z99lJCmUMYOSg/5rACyMFGFj3+e+7710ss/WgRCxZ+iqloJEP7ZBGuXM93r7uJJ157h0XvvMOCBcsIF41h3KAcjq57kbvufoB3P17OO+9+TFPmYMb2y8PgP8qrD93DPY++yCefLGPZ2p3kDRtP7ywHvvp9/POPv+Tvz73L0oXvsbnJyMQxw/GWLuPe3/yMp19YwIIFC3j9pWd4+J9P4x08lznD8zqU1eFIxVFMRgOFBbn4/X527d5DTU0NzpQUrFYriqJQXn6Y3bt3Y7VaSElJ4eDBg7jcbhwOByaTiXAoxMFD5bhdbhwOe+xeFtduCWWqdRgOh6muriE9PYOMjAxBIklP6HJEWFEgLMvISsdSIUlOLpIkYZAkTJpOdZIkSXqOz+fj448/5s9//jO7d+8mEAhA9KlqdnY2V199NXfccQd5eXkJnWHtq9HaDrccDuFqqSfoiYwIm80dT3HFb0/3HWygoTXMxIkTNTmAu6GMDxe8ycpNpfgMaZx1+fVcOmsMVrFHgELToXU8+sDfOeCJPsHOKObyH/yM+WO1jbFCy/7lvLDdys1XTCcyHRGghKnZv5HXXnuDHRXt9Bp1Ft+98RL6ZFjj7VLlXn2DnZURuZt15Ny1e3j6708y4KpfcdG4oo7koVaWvfgUO1LO5LbLJ/NFrAJdUlKCu62BqeN7xzp1AIFgmPZ2H5icpOcWYTSY4p6ai50JoseRybKi3win2VCk+Lok+o1wq5tOI8Jy0Mfip+7kmU+asJkjlhuMdvqMPZPrb7iMoTkpBF0NbFrxHguWrKW6xU9awTDOv/pazh7fB6v64FMOsnnRv/j7GzX86A+/4ox+X6+OzL59+wh4W2LfCMuaV6MtmhHhWF1FX42uCzRiFEaE9erRVe+jevMpNiKsBNm5+El+fNvDXPLUBu6YHXE0ezIiXFVVxV/+8hcWLVpE3759ue+++5g+fXrc71IdEZ4XHRFWz0nQG0Z2Qa7wanT871/B64n/RjgQsDNmTPyrsWG/i7cfewDfaTdyxawhWADCrSz9z2NssMzgzhtnYoupo1Cz8U3+tbyBq66ZxQe/e5CNniAmg4QkgT13MOdechXnTR2KwyyhhAMc2rmO9956l22H6wibMzn97Iu48sKZ5Du13+KHqdrzKa+/sYhdFS3Y80Zy3c3Xcvqg3Ph7mRxk24fP8o/nlhMwRe7xeUMncetPb2NgBoQ8NSx6awEDzrmRvPatvP7SO+ysbCFv5Exuuu5SBuVoR91lakrW8dpL77CrsoW8UTO56VqNXLiFJU/8g22pc7j9uulYhfNRtf5Vnvi0nZt+8H36p8dpelLYuXNnx4iwPStu5B8gFAxGRoTtdiyWSDui50x9tnEHph6OCMv+Fj5d+D8ee+xZVu138vQni7l4aBoQZvn/u4lHD03m/p/MIwUwmuzkFfdCrljKz+54gpE3/pIrphVTsuxFnl4nc8/9v2RIZkdbfOSTx7jlr+u5+e77mdHXypZFj/LwShP/fPQPpJW+ys0PruL2e25jUKo1MiKcX0hW8BC/vvV2vGf8lF9dMobSJf/mT6+4+fvrD2JZ8zC3PLaX/7v3Pmb0s7B2wT94+8goHr7/Ova9dB9/XW/h7l98j0zXXv76+78z4v/+Hz+cVURDbS3+EKAEWP/qP3ilJIvfP3QPEwu1v494IiPCZsaPHUZNTQ1/fvAv1NXVceuPb2HS5El43G7+859neG/hIu64/Tbmzj2bJ596mszMTC684HxycnJwu90887/nSHU6Oe+8eaSnpxOW5VgZRqMRs9kc14eRAH8gkPxG+ATQ7xFGkSQwGQ1YTEasZlNy+xw2i8mYdIKTJDkBFEWhrq6OjRs3UlZWFnOCiY6+NDY2smXLFvbs2UMolHh2VC2KpsOtEGl1YmFCB1PtbKpxSvThobjJoVYWP/1XXtkS5FvX3Mj8GcV88PhDLNhUTShOVqbx8E52VzuZ861LuOyyy7jsvDkMz7N3ylNRfOxZs5I2rNiFcE/9fp586G8csY/l+mvmI+17nwf+9R7N3nBcek/9fp546G8cSRnLddfMR9n3Pn/+93u0aORsqRnYQlV88MkufHJHuLu2lEUff0Z6UQGGTrp9flusChJ07qQES8NIwoaiLp8USalXl3H1r9FBlkNU79+CJ2Ug35p/GZdddinnzRlH0+rneeSpJbQGg2x67zH+9PRSskbMYP7F8xhgruLR+37Nh7trY/kEvVWs/OhDqg6v4/1V+wjo2PtV3hISfQ09ds0IdaASWdwqvr7FfTH9qYVC04FlvPjmEkLOjGN6QOTz+Xj77bdZuXIliqJQUVHBf//7Xw4dOqR7PvV+/2qgVjru3GquEW29yaEAlXs3UtHgjlwrioJicFKYC6s/WszB5mCHfLCFFe8u4qg/j0xbG3s2HyR35AwuuewyLr5wHkMdjTz9x9/ywrK9BBSZptJP+cPdf6WUIuaefzFnTejFttf+wiMvrMIVjtfDV7ONR//yd2oyJnDTd69lbMohHn74vxxo9MfrHPJzYOtGgn0ncNGll3HZZZcxd/rpZFgi8e4jW/hssw97+DBPP/IPyp2jufaai3GUv8sjzyyhORhfbqB5P0898g+OqHKH3uVvz3xEiyhncFKYK7Pq4w8pbwkJ56OZZW+/T20on2xn53N7sjYVSfikA+1vQSB274uivcd1h7tiK68s3cmUi29k0pjIgy0AlBYO7m8hKz+VfauXs3rzAaS0LBwmKF3zPq1F0xmbUccH77xPXfZZPPS7WxiYEd/vDZp7cfGVP2DO6YPILejNaRNHY2yooNXtpaHiCJa8YgKlW1i6YjV1ASsZThtB2czp827kR1efTa+8XBxOB7LdisFk4GjJHrJHfYs5U4eSX9SfWeedRcumlew7VMuG9TuZcM75jB/SmyFjpvGtyXl8tmkXsjGF3v0GMWjQIPKUw3y8uYbvfP/7jCvo2gkWUYgMIHo8Hhobm9i//wD1dfUcKCmlobGR1tZWvD4vsizT1tqG2+VGlmWU6LwI7e3tuNwu/H4/+/bvZ+3ataxZs5bly1ewdetW2traIg9rhftfovpO0jOSHliSJEm+8ng8Hurr6+OcYBUl+tr0zp07KSsr4+DBg7rbkSMV1NfX0VBfH7fVR7emxkY8Hm9c3trOR3xHM77TEmqv4VC9kfk3f5e5M6Yy79s3MrN3mM2bS/GLsuEw9YePkjJ6KmdMm8zpk6cx9+zZDM5P6ZSn7GpgSwmMGtqno7OqyLQ1VdLuHMnNN1zG9OmzuOCsobQcKcMTEB1cmbbGSlzOUXxXlZs9lObDWjkFyZbH7DkzqNu4nJLmaIdPDnN453pqLMOZMTy/k27HsoVCQicyusmy3ClM0XEEEDtzSsSRaGhsjKs/sR7r1P2GBlpaWvD7fbGK68ino6PREdRZF0Ux02fYJC68eD7z51/CVdf9H7dcM5Oa7ZuobPVzYNtWis+8lp/+8Douvew73H7PXXzn9Bx27K2Kppdp3P0pG2t7ce2157J76UJKm+PP/am4hcPxOiaqK3XTIgF+n5+mpqa4OhLrqb6hAZfLhRzuGBER05/K+JsO8vLzi0mfch1nj+x1TPp6PB5MJhOXXXYZN954I9dddx3Dhg2joaEBWRgd0iXq2YTDYdrb22loaOj0+6+vr6e9vZ1wOBST19aXokQfQWjDFIk+U8+lj3cfa3YcjT3Ac1XtY3VZkJnnTSNVUlAsaYw+4xwunj+fyy6/ljvufYA7L+nNe6++zKGWIHWH91JlGMpPbr+Vqy6/jBt+9DN+9X+X0HBgK9Xt8WU2VZTRnnYa1197OVMnn8mVN3wbe90O9h9ti5MLBlxU1LcweeoMppx+GlOmn8WcMyeTaVNQlDBlOzbiGzae9LYjNNmHc901VzJ9+tnMmzqCupISWvzx5bqrD9NsH8G1qtyUEdSWauUM9DvjWxS17WHt7qrY+Wiv2M3qcpg5bwpOKT7fRFs4HKa2tuMBmRJ1inw+XydZJXpNybJMW1sb9fUd9Ry7nhoaaNTcB+Puf9HwYDDY8fsJe1j76iNcedE8Lrr8ezz6ymJ27tvHyg8/ZuvBWqzFE7nr/r9w+9XTSbd0uA9KWz07DtZQtn0jJdV1rF3wKN+77SH21DVyeF8J29e/y3Ovr+Bo5QFeffS3/P31z+hYkC7CwGmX8v1rZ5JugJCnlo8WfIy99ziKMg1UHC6nfOtG1u87QtXuFfz657/llfUVmLIHcfkNV9PXu5s//eq7/OTvSxh7/oUMcFhJz+9Fw+HtHKhoxd3ezP7te9nT3kJLWxvNPj+9inIir2abzeQXFnL04FGC6r0m3MS7/30Oz4ALOGdSv7hXuHuCBFgsZsaNG8vRo0fZuWsXmzZtpqiwkH79+sXe7AjLMlVV1ezctZtt27axY8dO6urqCEe/7z50qJwtW7bxySef8Mwz/2Pp0mU0NzV3enihPU5ybHT7jXCSJEmSnOoEAgFKSkrYunUrfn98E2swGEiJfqdz5MgRdu3axY4dOzpt27dvp6rqKIocpqqqiqNHj3L06FEqo39ra2uRgwHSnDZsNnPsTQ71iazaGDU2e/D45E7flBqsmUycMZORxemYDBL+5hLeeutDciZfyLRhubFRIznsY/27/2HZ7noO7/iUt15/i121YYaOGk6aVbxPK7RV7WLxziOcffZssh3q5y0SKdl9mTFrCim+w7z3zP9486MdjLvwO8wYXYwpNheBREpORM7hO8y7z/yPt3TlorLpdjYtfpv2wkmM75cJoRaWvPgMwZHzuXDKAN3JT3pCOBxm586dZGVlYTQaUaIPLlpaWkhLS9OKR74RDnjpXZgeO/eS+o1wIERNXRP7Sw9RUVEZq0NxU+vz6NGjNDY1YFDCpDmt2GzR77EkKe4V1LomN/4gFBQUCFqAEgqy7eMXqUo7g7lThmIxKgTdjaxesoDNTfnMv2galtYDLFm5GZcvgIwZe3o+E888h9OHFGIxGSDUxkcv/If9KbP40bWnseH1N/H1ncz4/pkc5+n83NGrr9raWtrb20lNTdWK09jYiBzy00v4RtjvD1Hb0MzB8grKDx/pVEdHjx7laFUVbr8Hk9OCJcWEKfqNsKJZN1c6xb4RVmQ3y19+nI3KeG7/ziS2LvkA2/j5TO4fWfe6u2+EbTYbY8eOZfr06bFt2rRp9OrVK+47Ye03whAZGQwHZbxtPqrLqzhcVs7Rys7XgdfbhtVqICXFTHOzn3DY1Okb4XDQy8bFbxIafDZTRxTG7k9GcwqB8mUsq0hlzqRhWI1h9q1awLKqfG6+cjYOuYrFL62i19nnMaFfJgZAMlrIcgZY8NYqhkw/myGZIXZ8uoTSRi/egILV7qD3iCnMPXMCOSnmuN9+Sv5gZs6cTH6qBYMUpmrLhyxcW89ZF59Pn4yO16j9bft54z9vUlLfyPql7/LmO8vwpfRl2MACzOF6lry0lKKz5jN51AhmnDmF/MBBXn75RV76YD/jz7uSs8YVYRbKtWX1ZcaZk6NyL0TkvnUFszVyRnMKnrKP+KQ6k7NOH4LVEGL3ijf4pKkv3718BmmCw9gVHo+Ht99+m/T0dNLT02lpaWH58uWYTCZycnK04tTV1REIeGhtbaK0rJyjlTr3uKoqqqurOVpZSWVlJRUVFVRWVFBRWRnZKirw+IKkp6dHvhH2VPDGax/TZkzFLtez5OX/8Nf/908+KQsx69y5DC7MIt3pwOCuYsF76xg570KG5VhRAl5cxnQuuP77XHX+OcydMYzNrz1BWeYEMss+Yr17IPf/5U9cecG5jO/dzpP/+Ygxs+ZSnN55Aio50MjCx+7nhb02fvzL2xmXZ6G9rZ0hZ13GD675NrNnzcB66D3+sz7I/DnjsJsNhDGTV9iLXuYm3l30Cf2mzmbckP5Ur3qDZ958n62bPmNPrYeWljbOmD2LI5uWkT/5Isb1zkBCpmrHJyw6YOW6i6ZgMxtoL/2EB5/6lPNv+xln9I3ct7oj8o2wkcKCHNra21m3bj1jxozG6/FSXl6Oy+Vi+PDhHD5ymEEDBzFkyGBWfrKKTZs3UVpSxtat29i0aTO7du1mQP/+TJw4kSFDhjB40CC8Xh8ut5szzzyT0aNGYokudabe/+RwmKrkN8LHTc+u0CRJkiQ5RZEkiZycHCZNmsSwYcOw2SITxBD9piYvL48zzjiDuXPnctpppzFhwgTdbeTIkfTr148+ffrQp29fevfpQ58+fegb/durVy9S01LjxqNU51d9Qi82mNon+AoSFrsDs0HC3VDGa08/TWX2LC47azAmQU4Ou/EpmUycPZ877/kDf7znRwTWv8mzC7fjFV5LVmSZmkOl2CwDyHNGJuPo2AxYbWaCvnY8ISOhsIcDe/fT4tOONkblvO14Q0aCoURyCuaMAZw9KZ+Nq9bS5pdxV2xm7UGYNn08VoOOvT3cQqEQa9euZeXKlbjdbo4cOcLixYs5cuRIJ1l1U9HroDhTUiguLo7Uo86m1mefPn0oLCgkJSUlOqFQfG5qKWqoVofIPy/r3n2cH950Lddeex03ff9W/vNpGxdedTG9UsxMuOgn/OL6M6lc/z4P//EufvKjH3Hfv96k1h1AURRcNaWs2l7D5LlTycsazJyJdlYsXdnpFfZTaQsGg3z66ad8+umneDweysvLWbx4MZWVlZ1kFZ3RYIic1BRHCoWFhbH6UK+32Na7N5mZWRhNRiIfb3dGP/TLRKZi7Rs8s/ggU6ePw1VfgzsQorH6KM2eYKeRm2AwSHt7e9zmcrnw+XydNo/HEyenOzocLcBkMpGdnU2f3r07/f779OlDdnYOFos58llp9CRq601R1FHh+DiD2cHps+fg2fEJ5a1eQr4mNq7ZzJDTp5DvMNJR5fF5mTIySA+FcXuDZPQ/gzt+cxt53hJe+veD/Or2W/nRnQ+woaypUzoMJhwOGwYlRNWuZTzx0gqGXngV43rFvyETbHNjyh/OvCu+yx8efJifXzOet595mjUHm/HUlLNHKmb0gDSQjNjtdtxt7bT7A9gMLqrLD+Lya95qiMq52tpo9wcjcocO4dbIGSwpTJl9Fq1bV3Kk1UfI28Rna7czfNIkcu2RB0U92QwGAyaTiYULF7Jv3z6WLVvGkSNHSEnp/CaQEj3JRqOR7Owc+vTuXMfFxcUU9+pFn9696du3b+Te17cv/fr1o2/fvpGtXz/sduGbensvrv/l/fz7yX/zryf+w8uvvcHChQt59ck/cOaQnITXm2zJYPKsC5g8KA+L2YyjcBDjemVw+GADtpxMeheMol9xOiaTmaIhI0hva6WhzaPNBndDKf+9/y5e3BTmx7+9m3NG5GAwO+g/fg4XzZ5Ais2MxZnJmLGjkauP0uxupbKyCVNqNqNPP4vrb7+DmSm1fLjhCI70Im6452Eeuus2rr7+B9x69QyKjA4cNjvWgI+mFi9hIj9wr89HYV4mRoMh8m3/uk9pKTyDs0flJbS5OyRJIi0tjYmnTaSqqprsrEz69+8X9zDLYrEwa+ZM7rjjNu655y5+9aufM336GThSHBgMEja7jdraWkrLypgyZTKTJp0eNwdCrG2KXqdJjo/kiHCSJEm+8hiNRjIzM0lJSYm8/lVXRzgcpqCggEsvvZSbb76ZKVOmMGDAAPr376+7paWl4UxJYeTIEeTl5ZGTk0NObi65OTnk5OSQlZmBxSihhP2xWaNj/UhhmYOGBCPCERTc1Tt58u9/ZXX7cH5x500MyXHEzXNiMNoZPnkWZ542nOx0J1k5RSjVK/jwkIV5Z4zHHh3wksNe1n38Bt5hFzB9SLbOCKKEPS2fUadPYtLwTBb/9xXSJ53F0LzYlFodcunxcs4xE2jcsZSPP/mMrdu20WrJp39+Ok5rgI8WrmH4GadT/+lbrPeP5aZLJ5FyrO+OaQgGg6xfv5729na2b9+OoihMmTKFlBStrpER4VB0RFhFEUaELfZUCop6k5ubG6nDLra0tFSMkozJEI6MCKsVofYqJIn6Jje+hCPCL1GZOp1vX3AWo0eNZPzUOVx/03XMHNMbs0HCaHbQa+BIZsyZy3nnzGZEsYOdi5/j0+pcZkzpT/mat3jy1Z3k5pso37ebQ4dKWbWqjInzzqFflj2uvFOJQCDA+vXrcbvdbN26FaPRyOTJk3WX+RFHhCFSWf5ACJPFTm5+EXl5+eRE6yo3J4fs7OxY/ZhsZgJSEKNNwmg2RPw8zWzunFIjwn72rlnGmp0H2bt5LctXrGT1Z5soOVSLs2gwowcVICkdI8I1NVXs3r2bnTt3HvPW1NREWnYqg8YP6HhoI0VmjZZCBnLTc+iV36vTbz4nJweHwwL4MZslmqIjwrm5uXGWyEFfx4jw8AJh1ETCme6k7JN3qMqZwkjjHp57r4zzrv0OA7OsBL3qiPA8xvfNjNWVr2IbL3y0i6nnXsDgPCcZ+b2ZMGUm5543jzMmDEWu3sTzb25i6NRpFDg1dagEObj6LR55/Hkyzvwet141m3RxWBawpPdixpzZjB5URGpKKrn5uex/72W8/aeQ2byNEl82504bjTpAa8ssZPxpU5k6OovXn3mN1NFnMCQ/pdNvq5PcmOkaOQPO9BRKlr9NbcE0hinbeX5xBRdccyX9MrUTfyXGZDLRq1cvKioqWLNmDYFAgHPPPZe+ffvGvaGiUldXh0SIAQP6kpdfHLuGcqLXT2ZmJpmZmRQUFFBQUBBpy4TrTN0am9owmUyREeHoQwejJGGyOsgp6EXfvn0pyEmLf0PIFT8i3FaylNtuvQvDuLMZme8k2HSA/z3/HoVzruPs4mbe/KSCM845iwKnkfodi3lnfT3nffuSuBHhsOswT9xzL+uCw/jV737FtEE5GCQIuup56jc38kZNMbPH98Os+Fn9zvMccEzkwv6N/PIXfyL19HMYnGUn2HaYBa8vJHXyJQxt/pBf/Wsj51/3HcYNyKFk0dN8XN+La66Yg3vfJ6xrLebcyYMwh1r54MVnYfR5zJs4AGPQxeKX/4M8/lIumTyQ6Lxr3aKOCBcU5OBqb2fN2rUMGjSIKZMnYbPZGDduHPn5eSxfsZIBAwYwZMhg1q9bT1ZWFlOmTqFXURE2m41t23dgt9min0M08v77iykoyOess2aTm5uLZIj0O0TC4TBVVTVkZCRHhI+HHlZxkiRJkpy6SJJEVlYWl1xyCTfccANZWVlIksT48eP53ve+x+jRo0lNTSUlJSXh5nDYsVgtWCzCZjbH9s0WM0aTMa4R0j6EFY+1T/AVRabx4Doe/cuf2W+fyh9++z1GF6chaUZAgi0lPP7Qw3y0rwkUBUUO4HKFSHU4MRo65MKeCsr2Bhg7si8GMQ85TMWWhfz+oWc42i5jNJlxZuaR6gzi8gnf4sphKjYv5A8PPcNRV0QuNSMi19pUx6cfvMC/Hn+cfz/5Hz7eUYmMgdwBE5iY18Kq9Zv5ZPMRxs6cSpZJz9aebwaDgUmTJjFr1ix27dqFJEmcd9555ObmdpJVunvsrYDRYIjUmdWKVbOJYRarFYvZEh0F0GYUj1YHRYmMB4OZPsNO54KL5zP/4os4d/YU+hdkYTaAv2kf/++++3l/VwNGi420rHzGzriAi2eNpXp3GS3+Zj5buoKssWPJtRsJhSF/8ERGZVfz1vJdBLXlnSKb0Whk6tSpzJgxg+3bt2M2mznvvPPIzs7uJKtuehiEerJYLFij11lH/VgiTq3UMUOdeu3p53gqYGX8RT/iif/+l389/k/++cj9XDRlDFfedjdXzRkZc8JEgtHZfY91C4fD2qw6zpMkYTKasMadT3WLnFfJYNBONBxH5Pet7sdjSO3N7BlD2bpyFauWr8BXPIXR/dTPGLTSoIR97Nr0Gcbs3vTNsbDixYd48LmVuGQTDmcGvYdMZP6V5+Nsr+BIgys+sexnz9JXeeTf79HnW7fx0yvnkGPrPP1YzbZ3eOAfL1AZTS4HmvEZLKSYoOxgDTm9h2I3S9TtWMSDf3+Jal/kHDkzM8kz+HC74z+pqdu+UCOXQZ7Bj9vti5MDMKb1Y86MwWz55FNWLVtBuN9URvbp/JlAd2RnZ3Peeecxfvx45s2bx5AhQ7oepJIkTCYT1mi7pV5D6nUk7uvd/6xWa6dluY6H9P6nc+5pWTz9x9/x+DPP8dD9D3Go4EyumjmY3qdfzNT0Xdz3q9/xzH8f575HF9Jn7mWMLLJS8dkb/PS6+9nZ3Mam1//OvxauR5bbWfLyE/zloQf5x7MLqAvYmPOtszjy1gM8+K9n+e9f7+O/Gzxcfslseg05jbNHWvj3H/7Ak88/x0N/eJgjxXO4esYgsoacRn7jUh548O88/Y8H+dvbpcy78ir65aRy5rfOxb/mMR549Cn+8aff8X5lOudOH4PVCMFAO4ePtDG4fxGm4zw1kiRhsVgxmUxkZGRw9pw5DB8+DLPZHDnn0YzNFgsmswmDeiFKEmazCZPJjNfrY9my5VRXV5OZmUlrSysVFRX4vF6dK+xUfDvmq0NyRDhJkiRfCyRJwmq1cvToUZYuXUp7eztjxoxh/vz5pKam6j5VF4msI+yiID8Po9EYkRdGnxRFIRhbR9iEKToiTLQRUjd1RFg7gih7qvnfA/eyuLE3V58/DYO7gaNHa/Eb7KRbQ2xe9SEl3nT65jnY9+ErLPisjj59Mjmy+X1eWniQs6+/ifG902Ijvy37VvLmvkwuv3giKeLtW1IIuqp455mXqbbmkmv1svLtV9nS3JsrrphDdqCShcvXY8ruTapcyzvPvEKNJY9cq4eVb7/CluY+XH3Dtzn//G9z/Q03ceMN1zFzVG/MRgMGqx27+wDPLFhJs6WQa6+8kPyUzt95HSsGg4H8/Hxyc3OjT87zE9ZXc3NzbERYiX4vKgkjwpLBgtWRGmvTYqNlmr8oCnI4TMDnxkAoto6wFP0tqV6Cuo6wtj6VUJDtS1+mKm0a50weikXTaZIJs/+Dl3h5yRYCsoy7vZG9G5fy+lvryJlxMTOyynnixS1cfOf93HjBDCaMH8/40yeQ5zrAO8sOMGHObPKjSwadaqj1lZOTw/jx48nLy0tYX42NjchhzTfCgRCyYsLqiKwjLOm4TwrgCfrwhL1I1sg6wmIJkbwi9X/qjAhLmCxWHA5HZDP5Wbf4Q1KnXs2MwRFHUfxG2Gg0MHToUPLz84958/v9WFMtDBo/oOO3HR0RloV1hNV7mHjuQkEfoaAbU3Qd4VDIqDsivOnDlzhEL7LMPqqj3522y3YynCmkZ5hZ9erTrNoRZvZNNzGtb8S+oLeKD5//kFBxb1LkNo5WlvHZRwt44o0dTLrih5w/oZBg9Q6eeuZN6j1BAt52Kst28cGbr7Mv3IcrLjmHHEfH776l5GN+d++jWCdcyJwxRbTUVXO0vhVHajpKWwUffbACY14/0k0u3njmGQ4Esih0eFnx+jOsae/H1RePY+eapQw682IGZdsIuWt44X/PUKHkkWtxseLN51jbXsyV355Lui+Snym/H065gef/9wyVMbnnWesq5qrL5pKfov2NGUhNM/LJq//h050K59x8E5OPwxEGcDgcDBgwgByd74JF6uvrgVBkHWGTvaOeo/cucR1ho7AcoPZvZVUtxmNZRxhADhPAyrBxY8lzGJFMKQwfP5FM71H2lh0lbfBZ/OSW6xiR78DizGXS1AmYmg6zt7KNkedcy4+vmkOWTcLfXkdts4HR04fSvP8IQWcWKaYwHo8bt9tN2JbOqDHjGTb2dEYU2ti7azft5j5c/cOfcO6EvlgsqQwfNxFnezm7SypJHzyHW//vGkYWpGB15nPa2IHUl+2hwmXjWzfeyuWzR2AzGsnoPZxRfdI4sGs3HvtArr3lFs4clo9Rkgj6mmlqlRgxaQp9shxx101XiN8Ih0IhWltbGdC/P0VFRVgsZgxGI+FwmIbGRgYOGEBRURHNTU3k5+fTr18/LFYrsizT3NxCTk42WZlZHDhQQl1dPbV19ezfv5/GxibyC/JJT0+Pu9/K4TBHkyPCx02X6wgnSZIkyVeNxYsXc+edd1JRUcGll17KI488Qk5OTsKOukpkHeEaxo4ZhVkzGQVE1hFub60n5I6sI2yJej6iDMC+snrqWkKMHTtWCIX2suX85PY/cdhnIc2hvjKXwZxrfsoPvlXIs3+9l6qRP+L3l0+g5chmXvzvS2wqb0I2pjP7kuu58rzTiM2HRZB9S55msed0br/k9E6NtRL2s3f9+zz70mKq2/ykFY7gmu9/l6lDcvGXLeeHf3mTK+98kPMGWdm77n2efbmznDZPFXflZ9x159+xnXkDd//oPJxfsK928OBBfO7mTusIB4Nh2tp9SCYnaTlFGI2Rk6XKKES8MPV3oAAhv4/2lnpMeEhPtcVVpOqY7Smpo9mlMHr06I5IIBxw8/bDP2Bb9o385nvn0KlvjIK77gCLXnuFhat20RYIYrSlMfmc73DD1TOpW/IEj38C9zx0B707FmSl9eByfn3fa8y45V6umtLrK//aVmlpKSF/G5Oi6wgr6jrC2EjLKsAcXUc4rp6iTm6jp5n6QBNGJ1iizpH2wQan6jrCREYzy/ftx9x7DL2iflGwm3WEm5qaWLFiRWSZlChGo5ExY8YwalRkjXMSrCMsAQFPGNmlkGvJISu6jrB4XlEUvN7IOsI2u0xpSSs+v5URI0bEygMIeVt4+Y/f4dlNkGrreNh1+mU/5Y6r52ALN/HWI3fw30MjePxvdzIoLSLjad7OH6/+BRsx47CaAAVrWh/Oufw6rjx/MmlGkANtbFz+Lq+98QEHG92gmCgYNYNrrr2WacM7Jg6EEFvffJCfPboYS2oWVvU91fxh3P6zXzHOsJMH/vwM8+56jDn9LJSsWcB/XltKrTuMLW8kV914IxPSDvPcfzZy8S9+RN8UCSXso2TNAv73xjKq2sLYC0ZwxfU3MnNkHm0HVvCnB5/jvLsf46y+Zg6seYv/vbGc6qjclTfcyJkj8nSXwwp5G3j94Tt4oXIc//rbT+nvPPEHhF2xd+9eFMUbWUfYkQXRWQ7UNzBC0ZmHbTYbFqs1lk57X1+/cQfmHq4jnCQxkXWETYwfNwI5HMblcmG12bBFz70SfQjW3taG1WrDarPicrkwGo3YbTYkgwEUBZfLhcFgwGw20+6KLKMUqTMJi8VMamoaFkt8/yQQCLApuY7wcZN0hJMkSfK14sQc4VrGjhmJyWyO7zwCcjiIu7WBgLuJdI0jjNDB2HewgbrmYCdHGDmMx+frNKmF0WTFZjURCvgISmbs5ki+4aAffyAEBiMWq1Uzi3NEn6Bi7OgcalFkAn4/wbCMwWjGarVERpOVMB6vH7PVjtkoJZZLiIzf40MxWrBZv/h2Q3WEp4zvDTqOMCYn6TlFGKKOcCJTFCDo9+FqqcOkeElLs4lv4cbqf3dJHS06jjBAOOAhqJixWRN3euVwkEAgSFhWIq++WWxYTAbkUABvABwOS7yOiozP60Wy2BPX7VcI1RGeHHWEZY0jbLLYYvarHbvIvkKju4W6QCPGVDBHR8dFWfX4lHWEdejOEW5ra+Of//wnr732WqQTLEmMGTOGe++9lxEjRsTuY1pHWEXrCMdeu4yiiI6wTaa0VN8RBgj53fg1S68bTGbs1siDPDnowxuScNitwm9Yxu/2IiaTJGPklezoTPsAihwmEAgQii5ZYzRZsKoTeAmEg358gc7rv1ts9sjs+z4vRqsDswEURSaovZcRxusJYnXYYvc1XTkpcm66zS/RDQWQg168IYPmfHw+xDnC9sinQKjXRXQSQtURtgqOsJb1G7djNluSjvAJEnGEzUwYNxw09zIt8fe5xHIi2n6GeBwIBNi0eSt9+iQd4ePhq9/KJkmSJMnJRJIi72+KKNHmShOsoteQab+TVCQDdnv0lUlhs1oiM4sazVZsJkNM3mCyYHc4sNusGKOdNHGTDKbI5F3actQNCbPVhsPhwGY1d3yLjAG73Y5Jnek5kVzCTcJit8f0/qI3Eb3zLtJlfGytYCkmqNcpiXU8dHQxmO1YLaZO4eImGUxYbfZIfdsjDx8URUEymnHYzaBNg4TV7ui6br9iG0LHLYbSOSzu3HcXr3P8dSA1NZUrr7ySCRMmEA6HycrK4qqrrmLo0KHdPswD9TYVketKWone6mK/fZ16M1o6369sFnMsXjJZcdgsmt+whEWTxm63YjTE/56RDFii953IfTAyeqzVwWCydNLB4XDEHgxabXZM0bV60buXYcDmsMbd13Tlor/TbvPTOU/qJplsOufj89tiCBUtEalY7bWjRY3vPPVckuOn46yLZ1XRuf/phXWFcKnqHh9TZkni6NIRVpTIgs/BUDi5fY5bWG8ZhCRJknwJRFoTtcMZa2jU1wuFlkdsd9RGrVMHJcnnhm73LTLoConiRWJORYfHpYZI0frsNo8kPabTuex4/qB/LQlh6KTXHn9dkCSJgQMHcsstt9C/f38uv/xyzjvvvG7f2ovcf3Q6yAnoiUySUxzhIom7ZqIP+bqiu/gkJw/xmlTrSC9M3RfrUu9emOTk0uVkWWFZpsXlpdHlodXjp82b3E721u6NvHZjt5g7vcKUJEmSY6e0tJQlS5bQ1tbG8OHDmTdvHg6Ho9vRlNhkWQX5GA3RpVrUxirq4AZ8HuSAF5vNjFF4zU/NWZIkGlu8uH0yeXl5sfgkJ4/m5mbCQV/c8klEX7n1B0JgtGB3pEa+ueoKRUEOhwj4vBikIFarqdNrmUBk+aQAnSYTStIzmpubUcKBzpNlYcJi75gsS0Q99gZ9uMNeDJb4ybIUTUf+1Jksq3vEybLMZhNDhw7VigCQl5fH8OHDmT59uu4EOGVlZYSkIIPGD+gIlEAOKSjBjsmy9O57oZCPQKBjsqxg0Njt5ExJTi0aGhpAik6WZbaDMLYriZNlmc2YdGaGVq+ho1W1GI51sqwkneiYLEu/ndDes2J1pROuDRPj9FCXT0pPTpZ1XHTZUwiEwlS3uCiraeFwg4sjje7kdhK3ww0uyupaqWxsI6S3FEKSJEm+YCKvRWtHdWOdSaGF0jZYiRqpJJ8P2iflSvQ/KTrAq/dUXQyL1Gnk5UmiI8lamVja5Cj/CdPp+hBGL9VzrFdfEKmbmJyYRsju64bZbGbSpEnk5+droxITPSGKAuoCX2qw9nzp+MdJvuJo6ztyEPkdaH8DavV/na+hLwPtdaa2HWI/Qb1/xWSiconqKe4+KaYR9pMcP11OluX2BSitaaLFr+BwdixHkeTkIMsyHrcbGyHG9s/HZu5cByeCrMgEldA36ioxSAZMUnTpmyTfSE5ksqy62hrGjBmFKTprtJhCDodwtdbHJssyRyfL0ua6r6yemqZAwpGeJCfG0aNHCfra4ibLUqKTZbVrZo0Wb32dOn6KQijgx9VSj1Eza7TYCdlVUkdja4ghQ4aoKZMcAxUVFSghN5PHFkc6b7JCe7uPoGIjLTsya7RCpD5i3ln0Hd8Gdwv1gcbYrNFivYj7rjof1VtamHHGJKy2xBMDnQoEA0E+XbOBXTu2YjYbOPvs+MmuesqaNWsImH3Mu+nsuN950BNGdkGuJZtsR0bssw4VBQWvpxm3uwa7Q6G0tJW6Oj8Oh0OQSnKq4/F4SEuzdJo1mui1EYquN63OGq29/6nHn23cQVNzK2mpx7fcU5IILa1tFBbkMGFcZNI57XlWw7T9BbE9kqLfdneVRj0W8/dHZ43um5w1+rjogSPcTFsQUlLTTsrC20k6kMMyLlc7FiXA2H4n1xFWUPCE/NT7mgkr35zRZofRRq4tA5Ph5J3LJF8tTsQRVpdPMplMneTD4RDulnoCHp1Zo4VlefYebODgkabk/fJzQlEUMlKtPZo1WtuBEOUVRSEU8EUc4eis0WICKSqzu7Sew0dbkvV5nMiyTHaGvfOs0VFH2BRdPkl7dWpnjbZo1lSOc4TrfRxZX4/J9NWoo1AoTMn+PdTVVceWajtWwuEwxUOL4maNVoCgN0y4HXItWeQ4MuNmE450oDscYYdDobklQGurX8hZQNsLT0RP5b5q9NSunsqdLBQIhmSsFjN9+w7AEXWEhWiCwSAhzfJJ2vuhBBw+UkVrW7sQI9BTu3oq91Wjp3ZF5TIz0+ndK369eSE6ds9SEcN6UoyImC65fNKJ8aU5wkp0mnqPy4WsyEhIGIzGyLpb9sg3y8FggPbWFoxGE87UNIyCjqFgEHd7GwqQ4nRitlh0f0rhcAiPy0UoFMJmt2OzR74VFMPtDgdWmx1FUfB53LhdLsLhECazGUeKE7vdgWQwIMsyfq8Hl6udUCiE2WQmJTU1luex8nk7wi2Bdg61VyFLCoau5vz/GqAokQ5XmslBf2cvLMbj61wk+epz/I7wEY4erWDIkMEYjcZoI6XEnrOHwyHcsRFhW3REWI3taJbc3gC+6Joj2sZPe9wTjicNsbth9NXfhBxb7scm3Vlee6xFL14vzGQykOZUHahIbDAodzjCuUUYhYdhitA6iPvBQGT5JKPiJT0tMjLZ8StRUBRwe4ORb48T6NIVWnntsRa9eL2wnnAq1b/JZCA9Wl/a5ZPUEeGO8x5Jo8TWEW7EmCphthtAM+pF1MJwSMHXGhBy6JBMbL82p+45dvvjz7+Y3utxEwwGY3EiHbYlRgGsdgvZhZnRkEhZQW8Y2SXFRoQjOgjWKgpeXzMedy12u4zDkaitjGiuN6twh01q7iriOe1Ipz1KlK9KJEft3NfaXNSjDl3i9eogzv5O+SZCX09VtwiJ7I9HWz46+Yp0Z78CeDwBvF6FFEdRzBEWNQkFg4RCQazWziPCiUvuGd1bfGJ0nN3E6NlxvOmOlVPN/mAwyO49+xgwYGDSET4OvjRHOOD3U7Z/DxtWLcfr9SBJEjabnfyiYgaPHE3vfgNprK9l2aK3caQ4mTnvQrJyc2Od2fqaalYvXUw4HGbSjNn06tMvzlFWaWtpZtuGtVSWH2LA0OGMnzwNq81OY10t61YuxeNuZ9ykafTuN5D62ip2bd3Mwf178LhdpKZlMGTkaMZNPoPU9HQaaqvZtWUTJXt24nG5SElLY8iI0YwYN5H8ol4Yo+tW9pTP2xFuDrRR7q7GZDZhsVi7dQS+yoTDYXx+H3YsDHD2wmqMrHOY5JvH8TrCNTU1lJWVYrVaOmSF1iYcCtHeXEvA1UBmhh2LpfvrVdI0mh30tDmOOOL6eYjo53cyyu+ZnD7HWn5n+Z7bHwjKtLR6kcypZOb3jt6PO+cYQ4FAwEt7Uw1GxUtmut76s/p69pTEpevn21m+5/b3LD8VffnO9FROH73yZVmhpS0yIpyeW4TFahekiaVQFIU6dxO1/nqMaZFXo+N10eYs0hO5+PJOPseSf1f6ivl0JRd5IBz0REaEC6x55KZkdfoWWFEUPJ5G3O4q7HYZp9NC3Eo8OqvHqeHoLGklEvdmu1Bu7FiTvit5bbzesYpeuF5+Ionivyr2u90BPB4FZ0oxjhShfYuWEQwGCQYD2O32BOsIqwUq0f04zTTH3YWriPFS9Fx2la9GHjQPjiKTA0SyiD6UFo470OYbCetcvsgpaL9GPvY2Rzf2R65pL0OHDqOoqCgWnqRnfGmOsMflYtVH7/O/xx4mGAiQX9gLv9+Hq72NkeNO49r/+ylul4uHfnsHmdk53HHfg/QfNBRDVIeSPTt57E/3Egr6ufEnv2DcpGmx1z9EWpub+OjdN3nn5WcZMXYCP/jZb8nMyWPnps/410P3keJM5ebbfonN7mDhqy+wae0qLFYrDmcqoWCQzOwc5n/nRgp69WbJO6+zZvkSLJZIvKu9jXAoyLTZc5l/zU3kFxUf03fUX4QjfNhdjdlqwfoNcIQ9Pi82xZx0hL/hHK8j7Pf7aW1txefzaaMACAcDNNUdwddaTV6OE5ut82y3Sb48fP4QDY1uJGsmeb2HYDQlGulSUfB73TTVHsYst5ObnRLXGU3y+RCWZRqaPASUFLKLBmCzO7UiEO3cVbTVcMRbiTlLwpp68trHryuKAoH2EKFmiT72XhSn5Xe67ymKjMtVTUvLIZzOMOm6D4CSnMooikJbm5/2dpmMjCGkphbF1bOiKPj9fgKBACkpKdjt9k6/gyRfL6xWK5mZmQkeeiTpii/NEXa3t7Psg7f5z9/+TN+BQ7j2/26juvIIr/3330iSgRt+fAeZ2bk88MtbyczN47cPPcbAocNjjvC+ndv4690/Jxj088Nf3MNp02bqOsKhYJDN6z7l//3+tzhSnPzkrt/TZ8Bgli58i1eefpxxk6Zx3S23s2Xdal5+6jHSM7O49LrvMWzMWJrr6zlcVkLv/gNpqKvh+X/9HXuKkytv/j8GDx/N3h1befO5JwGJ73z/VmaddxE2u/p0u3uSjvDJI+kIJ1E5XkeY6PeMcoJ1vUNBPw1Vh/C2VFCUl4rd3p2jleSLxOsLUlvvQrJmU9h/JCZz1/cARVHwe9ppqDqIWWmlINeZdIS/AEJhmboGF34llfzeQ7ClpGlFIDrZY3nLUQ66D2POlbCnJ6+37lAU8LUGCTXAwJS+9MkowiDFP5xXFJnW1kqamw+QlhYmM7PnfZYkpwaKotDS4qOtTSYzcwTp6b2RhHpWFAWfz4ff7yc1NbVHywcm+WojSRIGgyFZz8dBz4cvPzckjEYjqenpZOfmkeJMjRvyP1FMZjOFxb0ZMmI07a0t7Nm2hbqqSnZv24zNbmfUhNMJh8Mc2L2DcDjMmNMmM2XWHAYOHcn4KWdw7qVXUtSnL4fLSvB6PAwaNpLTz5jJwGHDGTdpKsPHTqC1uYkDe3YQDCSYcOJrQOT7aS+NdQ001NTRUFNPU30jbpe7w3FQIBgI0NzQRE1lNTWV1TTVN+Lz+mKve8iyjNvlpqG2npbGZkIJvpFKkuTLwGAwYDKZutiMmIzGyN/kdoptpmjdmDB3qrfOm9lsxmQyYTRF6tRs1uaX3D6PzWwyYTJGryWdeonVj6mjfpJbzzZT3LEJU/Qcajez2YTRqB53rqPk9tXYjLG2SL+eI/Ed97rk9vXdjMbkainHy5fuCMvhMFVHDvPeK8+z6PWXaGqso8+AQfQbPBSz5eQ8Ac7MzmX0hNMJBgLs3rqJgwf2Ubp3NxlZOYwYOwFJkmhrbcFsNpOdm4/D4cRgMGC2WElNz8BoMuNqb8NkMpKRlR2dzMuII8VJZnYucjhMe2srsqI/kvR1IBQMcvBAGW89+xovP/kCrzz1PG/+71VWvL+Uw6XlBAMB2tva2fbZVt5+4Q2e/+czPPfYf3nr2dfYum4TAX9kIhNXWzubV2/gjWde4YM3FlJxqIJwcg3lJEmSJEmSJEmSJEmSfIF86Y6wosi0t7VSXnYAv8/LlJlnc8m1N9NnwKBjnnwqESnOVAYNH0V6ZhYle3eyeuliPC4XA4YOJ79XMVabjRSnk1AoSEtTI35/ZAQzHArhbm8jHAziSHESDoVpb20h4PdHv8Hw0dbchMFoJMWZ1ukVpK8TwWCIQwcO8u5LC/jwrffZ9tkWVn6wlKf/8jgvP/EcR8oOs3XdJp5++F8sfmMRFWXlVBw8zJqlq1jx/lK8Hg+KolBdUcXCV9/hzWde5a1nX2PDqvUEA8lR4SRJkiRJkiRJkiRJknxxfOmem9FkYtDwkfzfz+/hF396hO/d/mvGTZqGzd6xuLvf6+XIwRJK9u6idO8uqioOEwpFlrMI+P1UHTlM6d5dlOzZScWhMgL++FeUDUYjeYVFjBg3gZamRjasXonNbmf0xMnYU5ykpmUwcOhIFGD3tk1s/WwNZfv2sGvrJtYsX0JdTRV9+g/CYrNycP8etm9cR9m+3ezcvIG9O7eRmpbO4BEjMVs6f6P8tSH62rPP42XA0IH89N6fcekNVxIOy+zZuovdW3ayfcNWyksOUdi7iG/ffBXf/8UtXPvjmxg/ZSIWq5VgIMiRssPs37EXRVForGtg1+btuNrau5jZL0mSJEmSJEmSJEmSJElOLl+aIyxJYDZbSHGmkZmdQ3G/ART17kdWbh5Wmy3y4bfJiN3ppK21mdeeeYJ/PnAvjz94HwtfexGvx4Xd4cDtcvHBmy/zr4fu59E/3s2bzz1NS1NjJ8cqIzuHsadPJSMrG6PRSHHf/gwfPR6r1UZqegYTpk5n3KRptDY389KTj/Lvv9zPf/72ACs/XEQ4FGLE2PFMnTUXn8/LK/95nCcf/iNvPvc0Qb+fCVNnMHbStG/EbG1K9HthyWjA7rBjsUZeXzcajVhtVmQ5zIGde1my4AO2rN2IyWRi+LiRWG1WWhqb2bNtFwajgdNmTKa4fx8qD1VwcH9p8lvhJEmSJEmSJEmSJEmSfGF8abNG+30+9u3YyqdLF1NQ3Jtz51+BMy09Tqay/CDvvPwsba0tsdnQjEYj/QcPY8xpU1izfAm1Rysiq4BFPxIv7tufb337O2RkZWumk5epOHSQD99+DVdbK0NHjWPWeRdGJ+eKjCwfLjvAxjWfcKSsBK/HjcOZyrBRY5ky62wys3Oorqxgw+qVlOzeic/rxp7iZNiosZx2xpkUFvfFZD62b5q/SrNGe1wePnrnA/5+78M4UhyMmjiGlsZmaqtqOH3GFK6/9WZaGpt583+vsnf7bvw+H8FAkLTMdOZech6XXn8FleWVPHr/X2lvaeXcyy6gdF8JOzZs48Kr53P1D68nNT1SF8dDctboJCrHO2t0MBjE7XYTTPBQJhT001R7GF9LFfm5Tuy2k3e9JjlxfP4QdQ0uDNZs8vsMw9jN/VhRFPxeF0015ZjlNvJyU5LLYX0BhGWF+kY3fsVJbq9B2Bz6yyfJikxFazWHPBWYsyVsacnrrSf420KEGqGfozfF6QWdPtlSFJm2tipaWspITQ2TkZFcPumrhqJAa6svunzSUNLSinWXT/L7/TidThyOjjcsk3z9UH0jp9OJxZLs+x4rX5ojrCgKAb8Pr8eNyWQmxZmKpFmDNxQM4mrTTkIlYbZYsNnseDxuwqH4TqvJZMaZmhZbZkkkFAribm9HlmWsVhv2lJS4m0coFMLncRPw+5HlMAajEavNjt3uwGA0Eg6H8Xrc+H0+ZDmM0WDEardjd0QmzzpWvpKO8D1/wWw2M3TMcNIy0hg0fAgzzp1Nr77FtLe00lTfRH1NHaV7S9iydiNb1m5k5IQx3PLbn1Jx8AiP/eFvmC1mJkw9jfqaOnZv2cnEMybx8wd+S+8BfY5bx6QjnETleB3huro69u/fTyDgjyxcr5m/Xg6HcLXUEnA1kpFhx2IRr3lt3mpKMbynYcfCiaY/VrTlaY9VEoVr6alcIjrSBwIhWtt8SOZUMvOKMRgi91MlQe4KEPR7aW+pxaR4yEiz6wvGodVXe6ySKFxLT+UScaLpjxVtedpjFb3wSJgsQ2ubjxA20rMLMVnsnaQkQEGh3t1EbaAeY6qExXHsbew3kaAnTLgd8q055DiyIHY3i6Cg4PE04nZX43DIpDgsXdRWfLgoJ8araOUSoZVLdCyGiWjltWjju/t1ao/FMDH8VLEfwOMO4PEqpKQU43Bkd7IyFAwQCAax2+3fiLcVv+lIkoFRo0ZRUFCgjUrSDV+aI5zkq+kIP3b/3xgxfhS33n0HmblZ2Ow2HM4U6qpqWbN0FeFQmL6D+mEwGNj+2VZef+ZlBo8cyuU3X83qjz9h1Ycr6NW3mLyiArweLwf3luBITeGHv7qVmeeehcV6fA5s0hFOonK8jvCRI0eorq5iyOCBmEzG+A6IArIcwtXSQNDdRHq6DbPF2KnnEuvQ6PVohKBY3tEdVbVEyfQ6Q1IX5STqWCna8hMgysTKEQJj+p5C9geDYdrafUimVNJziuIehnayh8h/wYAPV0s9JsVLWpo1zo4v2361SDFcRGt/pzid467yE/k87VdkhbZ2PyHFRmpWPmaLTd9+RaHB00J9oBGjE8waR/iLsh+ExIL9ihrOsdkfh/Z8RoNFfRPpqmu/AkFvGNkFuZZsshwZSFLEEY7lpyh4vc243bXY7TKOlM5vTnQq96tivxincyycpi7RptcqE2e/UHac/d3ZTkd6rV7d2q+AxxPE65VJSSnCHn3gIRIMBAmGgtht9li/SltOIjqVe4rZ31052nRifiTIU0SbXqvMqWZ/MBhk9+59DBgwkL59+2qkk3RH0hH+EvkqOcJej5dPFi/nmb8/yagJY/jpfT8nIysjFl91pJL3XlrA+k/WoSgKdrsdr8eL0Whg9gXn0H/IQF5+4jmMRiPf+b/r6TuoP+2tbXz09mLWLV/N2RfN46ofXocj5fhe4Uk6wklUjt8RPkxtbQ1jx4zCZDIhSVJcOxcOB3G1NhByN5GWph0RjkfbDmqP1TAShIsNYKJ4vX2O4VhFr6EV0abXhuvRlV4qicJV9OK1YWI5gWCY9jYfmJ1RRzhyP+1Kj6DfR3tLXcQRTtd/RVSbHkWBqHORiC/Dfr24ro5VYnYJSDryov3dXUtd6SXLCm3tPkKKjbTsAswW/fMuKwqNUUfYlApme8fDqa+y/SqJwlXEPMQwurJfgaAvjNwOOZZssh0ZGKK6ivp7vc14PLXY7DIOhznOXj4H+/WkE4Wr6MWLOiXSr6fHKmo5XyX7UcDjDeL1dHaEVd2DwSChYBCbzYZFGBHWy/OrZn9X+vX0WOXrYH8gEGDjpq307duPfv36CSmS9IQvbbKsJF8tTGYTA4YOYv613+aMc87EZot/1SY7L5c5F83j4u9cytTZZzD6tLGcc/G5/PBXt/Ktyy+ksHcR08+ZyYVXzWf06eMo7F3EgKEDmXPhXM67/EL6Dx2IQfNqfJIkXzSxhifa0IkNkRR9xVBtgMSGU4sqp224tI1tonC9eDEvNGm0uoiNqJhODNOGi5tWXk+uq/JFvUV5rZ164YnixbxIVL7wdF0rp02rTqgoRRNJSryMuC8eiyNsiRD11tohyuiFJ4rvif1inFZOm7bD/s6bVj5OTutY6SDp6CzaKcX+68J+oXBF+XrZr8rohYvxCPE9sT+WoY6c1h5Q4sLUfe2xSiz+OOxHx85E4Spa/bX2i4g2qsfa9GJahfj6F+O1xyqx+FPQfhWtviJi2q+b/aqMmEabXkz7dbU/yfGR9DyS9AiTyUT/If258OpLmDZnBlZ7/FN8i9VC/yEDmXvpt7j6h9dzzS03Mv+6yxg/9TSycrPpM6AvF149nxnzZpHijHybbTKbGTxyCPOvvYzJs6Zh1TjXSZJ80cSaxtg7d2JctDceRWyQtLPUk6DRUhtIumgAtejloyXWSAvHat5xemrCRF3Evz0hTqce2K89/jzsR8cWbZnxYVEtohE90UclLt8e2K+GqXxe9qt0trWDROdK+7crtLZo0dMprly9RCLRBxOgk5EGvbJOZfuJptFLp0UvHy2qjGhXV/YDKEpHjGi3mLYr/bS2aNHqo4apHIv94l899M6RkiAcnfOkt6nxidDaokVrv1YXvTR6SEL6ODT3HG28GKuN09ND/KsN00MvD5HP3X4Bbd4kKFNFT4+vm/1Jek7SEU7SIyQpMklZanoqdoe906shEcfWRIozhfTMdDKyMnCmpWKxWqJpzaSmp2FPccTSduSZhkMIT5LkyyM6pKj71Df6u43GiA1mV79dUQ6hwdKmUIg4VKq8eqzGqfLa/NBJh9A4asM6pRX2tfFaWZVOZfXAfm1eYoqYnsdofyxM7RQKEd3aL6kSHcJd2a/dj8tXx341TpQTORb7Rfm4ctUwTTrBsk7lx/Z1fuPHbb8Qp6LGacuPISRKaL+Q+utmv5gmof09rH/UdNGIruyPEU0sxunZoSLKiTqSIJ0ap1t2AvvRyVtLonLFdKrtWnn1GIh/5UCTRg9tHon0UBHtEf+qiDZ3Z7/Wzkhg/Mel2nSxNNFPfFTE9GKZejaIaPPQLUtAzFv8q3Ii9uuVK6YT61KbV2z/a2S/znPYJMdA0hFOkiRJkhhKpFXRvDal3Sf6mnRXDaC4LzbKImp4LC/1IZG6aToxImL5sYdLGp205Wv3uzvWxon5acvSQ698kU5lHaP9sX21U6spSK/8zroIvchuZL8s+/XOgZ79Wp30yk+kix6JZE/U/oRpRTt0BTr4Ktuv0in8OOsf9Zt1jVJK56BOaOPF40TpYvppIzQcq/2ivmpcj+zXSUcC+7Xp9MLUY224il5ZeuiVL6IN19qv2n6s9sfFdTNyrBemHmvDVXTL0eHLsl9Fr3xtOr0w9VgbrqJXlh565Ytow4/X/tgz3STHRdIRTpIkSRINYgc0rjFSZ4sUxqq0jVVtfSs79lWwc18Fu6KbuL8juu3cV4HfH1n+TU0baG/gowUv8/hTHdt/X3ifzw7UEYrKiG2e2EBqG05FKyuMrmrjYmmFBwBiPu6mChYu20CLV9UigrY8MRydMtQ4UVYNQ6uvRs9EMnGoAUrEFjFtZ/uFEqL1msh+NUwtV8xHK6fGqfJiGjVOlFXDSGBbT+3X6ty9/fGbbhpNuSJxZQlyapyYt0iHfvFhWvlIdEeIqEe8TEd4nD5aW04x+7VhWnmxXFUf8ViUiRExopPOkWCNdNeHnexKZIdWTkWVT5ROi/ZcieX21P44faJ1GQsX6h8hH21ecWl0wlXiytLRRSuvoidLAvtFHbV6KIrwqU40MKaL8BuICie0H0WhpaWF0tJStu/YwY7tOzhQUkJTUxPBUAgF8AcCHK08yoGSUppbWpBlGUVRaGpqorSsjIrKSlrb2qisrGTfvv3s27ef/dFt37797N9/gKqjVbhcrugyhQfYvn0H23fsYN++/TQ0NBAOhXpsf+wcCPLqsXgORLlE9mvzikujE64SV5aOLlp5FT1ZNLoQlTkm+/UyTdIjjLfffvt9DodDd6KiYChMk8uHXwaL1aor82WjKArhUAiv14PH5cLjduF1u/H7fYTDYSRJwmAw6L669mWjKAqBQAAjYQoynJiMJ/f8+sJ+WoMujCYjJmNkFtyvK4qiEAyFMGEk05KG6TjWdU7y9aC0tJQlS5bQ1tbG8OHDmTdvHg5H96/et7a24na7KMjPiy29E9cwKTJBn4dw0IvNasYoXK9i47RrfyWbdx6mqdVPbYNLd6uqbaW8so6hAwuxWyPLl0iAq6aEh+6+lw3NDgwBN41NjZTs3MyCJZtJGz6RYfnxa65qG041TA0XG0yt/bppBZmOfBQaD27kgWdWMX3GFLIcnWe3F8tUj9WGXCRRp0IN00vT1bG4H5YVAoEQksGCzZGKJMXf9zvbLyGHwwR8bgxKCKu18z0yUVla9OzvCr34E7Vft/67tL8Dvfqni7K0iGWqxwlRIBAIIWPC6nDGze4t2q8o4A368IS9GK1gMEeut0TlfGXsTxCvtV8MT3TcyQYJlJCCEoQUowOH2dYxyqzaJkEo6CMUcmM2K5jN+rNxi8fafRHVdr34RGHacNV2dV8M15IoPlH996RutWVrj7X7Imp5evGJwrThUg/LFI9DIZlgUMFiScVssnfUM4AkocgysixjMpkwRldBEJEAWZapqKjkg8WLefa5F3jzzQUs/nAJmzZuoq2tjeycbFJTU6mvq+eFF1/i9ddfJzMjk379+qIoCsuWreC5557n4MFDmE0mPvhgMS+99DJLly1n6bJlLFu2nBUrPmHVp6tpamrCbrezfPkKnn32ed55510++OBD1q1bT2tbG0VFRaSmpsb5GV3Zrw070frXO+6qLlRUOb34RGHacOk46l8MC4XDVFXVkJGRQUZGx2ouSXrGV9IRVmQZn9dDU30dNZUVHD5YQvmBvZQf2MPh0gNUHCyh6sgh6quP0tzYgNvVTjAQwGA0YjKbO10QXxankiMsh8K0VjbhbXHja/WcspvFYcWgc56SjnASlRN2hAvyIw/PNPGKIhPwe5CjjrDJGJFR5dSGrLK6CVkxM3/+fEaOGKG75ebmUlpWyoghvbBbLbGG0N9aw8cfrOecO+7n19efy9w5Mzj3nEm0ffo+69vyOev0fuBuZPXy5Xy4cguHmoMUFOQiuWv5eNk2UgoLSbUYqNi1lvd3NtO/Vx4WQ5Dtaz7lKNkUOCUO7djAex+sYVNJDfasXHJTrXibKvhwzW4aD+1myeqDpBYX4fDX8NH7y1mxpRwkPxt213HO2dPIdBhoOLyfxR8sZ/XmUlymVAqzHDTu38Qn+z307ZONwdvKqmUfURbMpH9uCt7mo3y0Zi9Wc4BVGw8Qaj3K4g8/ZdvBRtILCsi0xy91pO6LHQQ1TAHEJSzUTossK/gDITBYsDpSkQzGTh0MsYOjKEqHIyypjnBEVtsx0qLmIeYV1xHV6K2GqxtCmlgemjLFcDFM22HS67QBsbwT2i+Eq2m1eSZCTaPNS42jC/sVBfyCI2w0muJ0ExN4oo6wZAGjOXK9fdXtj8V/TvUfDinIfh1HWEgbCvoIBDscYRVt+YnoZIsmTi9MlEdjvyin3RfPi2iDNr6Tvjp5a+tfm0Yrnwg1D1EHMU4vTKvjidmvxDnCFos9+rFOB2GtI6y1X1FobGripZde5r///R/VVdVRZ9RJSUkp69atB2DAgP54vB5ef/0NPvnkU8aPH8uYMWOQgOXLV/DuewsJh0MMGjSI6poaKisqqa2rY8+evVRWHsViNmOz2SgqKiQnJ4eNGzdxpKKCjMxMUGDPnj1s3bKN/gP6MXTokNhSrl3bL9ihc24jAp3P7den/uPtkMNhqqtrSE9POsLHw1fKEZZlGbernaoj5ezbsZVdG9aya8Nqjuzfjextx2E2kGIxYjMqyF439UePULJrG6W7t1F7tBJXWxuyImM2WzCf4Lq6J4NTyREOeAJUbT1IuD1AoNVLoOXU2nxNbtprW0gtzMAUHUETSTrCSVROliOMpgFTlHBkRDjgxWaLjAirjZToCFVWN+HyhBgxYgQGg0F38/p8HDhwgFFDirEJI8L+1lo+XLScPmfN5/R+6RgNBgj72fXZCiqtw5g93MoLjz7OG5/VkpduYvWHi1lRFmTcQAcv/vNZlGFTGJED7/6/e/j1uw1ccN5kMr0l/O2hV3FOOAPXujf4wzOfYnCm4T6yi/c+3kre6PGkNG7jdz//CztbzWRmZ1OcBy8/9k/e2eEmN9XH2tVb2ON1cPncKQRK13DvQ69Q4jJjcVew4JWFtGUPpY9vBw88u5PJ50zCVLuLB+75Hcvcw7h8Rj/K1y7i8YWHGNtX5pH7/s72I16MDhPbPl7IR0cMzDp9GCnmjvoROxEicR0FTX3KsoLfHwJjdERY016JnQmi6eVwCL/PjYGIIwwRB1v7S+mUVoiLoXGE1d+NuumhtUE96tZ+nbUsE5WhotVdTy+tTKJwbTw6DwLU/LXl6DnCKqqcEpXzBr14wl4MVjBFR4QjAvH2d9Inihiu1V2rlzauq3Bt/LHYH6OLTrBe/cflkch+BeSgAoF4R1hbfijoIxR0YzIpWCyRB0YksE/UX/tXRSuv/hXTatFeZ+J+t/Z3UaaIXnhPwvTixP1E5Yj7krDpcaL2i46wyRxxhOPyEBxh1blEyCcsy2zcsJEXX3yJ8vLDXHnl5fzkJz/m3HPnAQpbt27j8OHDDBk8mPSMdJYtW0FpaSkzZ85kwvhxSJLEhg0bWf/ZZ2RnZzP3nLOZO/cczj57DukZ6ezbdwCHw86tt/6YH/7wB0yePJmcnBwKCgs4a/Yszp5zFkOGDKG0tIzKyqNMnTKZUaNGYrFYemS/3rlLJNOdrDYsUZxevPZYK6+VVTnR+hePw0lH+IQ4uZ7X50gg4Key/CDrV3zE8ndepXTrOgYU5fDd66/h/nvv4pc/v5Mf/eB73HzDddx8w/X83w++xy9/dge/u+s3fP/GGxjcO5+DOzaw4p1XWb/yYyoOleH3+yId2CRRJEaOHMnkyZNPuW306NGdOn5Jkpx8Ir8x/V9adL3ZaGTcE19hZEc/bWLEe5ACyIqbVYve5V9PvcS/nnqRv/z5EZ7bZmb2jJHU7VjJor02fnnvHdz+k+/y519cjuuzj9nWamF8Xyvb9tchuyvZv99AcdBNWYOHuv07OWwbyticBt586zNGnX8F118+l6uu/TZDw6W88eFO3DKYTEVc9sPv8dObz8V2dCurj+Rx7/23cectN3Pd2YMI+4BgCx+8vhDfkHP5y30/4te/vYNfXjqExQtWEOg3inzvIfZUuKmrKCccLsS3/yBHvUH27dxH7ohxZDqMGMMZnPu97/Krn97Eb269gIbNO6lt98XsR6cToe6rDx4k9Rtu4ZvOmGD0r5iHmA/RfNTzLkUDpEjGUYl4XbR/FWEjqo9Yjpq/Gi/Kqog2IOSr7mv1VuMjagqv/OnIafMQw9Doo+6rcSpi/tq/apqYTA/tj8szukpZQvslYl17KRqh6qm1X0XPVr0wURd1X8xHDUcnrapnnD09tF8klo/m+lfjEuktRcvT6gfqbzi+rLh4YZ+ovF4+JNBX/au1Xw0X89Dapc0vFn489mtkRbRp9OwX9UmUTyLb1LK1Noky6Nh1Mu0nOsOBHlo7xHuamE84HOZASQkVFZUUF/di8pTJDBkyhL59+zDzzDPp378fh8sPU15ejs8XuT+rqcXfdgQJs9lMbm4OxcW9yM7OxmIxYzabyVHDcrLJzctl/PhxZGRksGnzZhZ/+CHV1dUMHz6cwYMHY7VFluXszn61DsQ4FW0aMV7MR02fKB9t3Yr7anqtjCinrVe9+lJ05DgO+7W6Jzk2TnlHWFEUXG2t7Nm6kZXvv8XR/TuYOfU07vzprVxz9VVMnjyJ/v37U1hQQE5ODtnZ2WRlZUWePBUU0L9/f6ZMnsQ1V1/Fz277CbOnT6H6wE5WLnyT3Vs24WprRVFkbbHfWAwGA0aj8ZTckiQ55ehBY9cVCpFOrYgc8lF95DAHSg5x4GAV4bxx/PFPP+fbp+XRXl2Dtf9gBualYTSZKegzkAH5bvbVmpgwoT+lm3dyqPwgVcVTuHK6hX0HjrBzawl5o0ZR2F7JutLDrHzjeX5771+5649PsOpgK+7mGnwBMKRnkJ/lwGyQaKmuwTJgMP1zUzFbbAwcPoLBuYDXQ3mjj9GnjyDTZsJosjNq7BC8TfupUfozrleITVvKKDtURf455zPCcIh9B8vZsa+VMeMHYTOAISOfPoVpmExmnBkZpMhe2sOJ78HH1cjrVITa6YhFxc67sAxJD4mJJ6h/sQMjqqK3r63/Y0HsRMXCtAFROtmvI6s9ToSexqL9Klr7VTps78J+cdnuRCKnsv1R5zhReR3nQC+3nqG1X4kqoZejar9asJ4uJ8t+RbBL6UKeHtjfVayevnphCPaL+mjtTpRWi55O2vMZe9DVjfxx2y/Wvf5uNECY2FGwX1EUXO0ufD4faWlppKWlYTQZMRgMZGVHvg0OhkK43W4CgYCQoRSvc7TATuWqCHoaDQbMJhMtLS1s3ryFzZu34PF46NWriNS01E6/Z7qyP0GZemHo2K+NE/92hzY9mrTKF1H/Wn17qnySTpzSjrAiy7Q2N7F57So2Lv+Q/gXZ/N/3v8uFF1zAoEGDyMjIwGKJrFObCEmSsFgsZGRkMGDAAC48/3x++L2bGdgrn00rFrNp9UpamhpR5MQdsW8SSnR2wVNxOxUJBIOUH67gUHlyO5GtqqpGe2q/PISfmtqQxX5/mok6xcbueImVEc3TZM7m2z+4hYf/9Cse/sOd/PZH3+as0/pjM0kYJAiHQ4TlSImKohCWjZhNFgaMGYO1chdLVu0hdexYzhqXz45NW1hzwMukSYMwSQachf255d7f89xTD/Hc0w+zYMHzPHrbeWRZBW0UBYMESjhEWBHWJ40aaZBkwnI4Zn84HEbChNWawtjxfTm0fSNb9x1h+LQzGNk3wLqlK9nvL+b0oTmRRj3SC+vUwKv2q/sdER0dOW2ars6/Gqb+VfWVYvkIZz4qpM0/JhGtfyGFbv1LYny0XVLLUzf1fibaKuaphsU4Rvtj5USPRd3i7e+QVTur2vxjuiWyXzhGU24i+0XE/NQ81fCoYiDM0K5Nf0rbL/wVt8+1/kXjooj6xPWVohGSdl9A1E08RrRHExanu5BnzLaoPT21X5UX41W05athoh5x+uq8jqo9FhF1E49JYL8qoyLmf9Ltl4QHeEKEBLHfs4jWfglwOp1YbTba2tpxtbuQw2EURaGluRmXy43ZZCIlJQWH3RGbHDIUChIKR+7/gWBk32g0Rj7j0egOUT2jhEIhZFlm4MAB3Hjj9fz0p7cyYMAAPvlkFStWrKSluRl6an+C86+eczVM/au1X0U81saJdSMeoyknTl9hX5VR9xHsiR0Lmximcqz2Jzl2TllHWFEUWlua2LR6BQe2rOPMqZP4zlVXMXLECNLS0o7re2WDwYDT6WT48OFcdeXlnD1zOgd3bmLjquW0NCed4W6Rg+xa/DT3/v0lat3ayG8mPq+P3XsOcKj8COWHK5LbcWz7D5Rx8NAR7an98oi2NmojpjagoKAIfQ9tgygk7TkxBzvyV83TaDJhtpijr5cZIy/CSRJ5AwbAvu1s2F+F29XO3u1bKavNYFRfJ7aiwYxIKeeVd0sYOagfAwYPpX7tKlZ405jYPx1jfn8mpgRYsWwLrUEFv6ued/77JM9+XIYv1pJKYDBSMHgw7N/GpgPVuFqb2LRuPTtqgJR0xg3KZ/PS9ZQ3u2lvruWTVdtx5oygb56R/iNH4tv/EVv3WRg9sBfD++ey6LXF+IaOZ3C6WoZK5+a7c0g8anx3cto6UolPL9ZwZ2Ft/evVt95xImLp9R7cauo/ET21X0Urlyi9nk6fl/1iQCydnv0KsdW6xVej1b89LVOUO6XsF9GzX4fu7JeU+ExEOU1UXAY65sfbL6TVih67/Z2lRR310MYnsl9LIvu15ejl9fnZ35nu0neOj1qTIFPt71nUn+i+wWhk8OBBFBf3orKykvWffca+ffspKSll1apPOVx+mOLexfTr15f8/Dwy0jMwSBKlpWXs27uPkpJSysvL8Xjc5GRnk5rq7FSuiCLLHK2qZsvWbRw9ehRnipPexcVkpKfjcrloaGjAG/cKdgfaXI+3/sVwEb28TuX617W/U0CSniKVl5cr2dnZcR/Tq7h9AUprmmkLQkpq2hf6eqq7vY0taz/hwNbPOHvWDM6aPZusrKyYAxwOh/F4PMiyjNPpPGbdZFmmpaWFFStXsnjpCgaOOY1JM+aQkpra5cV8MpHDMi5XOxYlwNh++djMnevgeFFQaA60cdhdjdlqwdrN5GB+l4/Da/czccIEUlNTtdGAQmvZcn75019T0fsSnnr4txTriX1OuFwuNm/eTO8pg7GlObTRkd+Dz4tNMTPA2Qur0aIV+Vxoa2tn9dqNzDxzKulpadroJD1gz9791NU1MP2MSdqo42Lx4sXceeedVFRUcOmll/LII4+Qk5PT5e8f4MiRw9TW1jJ27KhO90MJkMMhXK31BNxNpKfZMVviZ1tVG7rPtpRSVe/l4osvjsVrqa2rY9GihVxxwWQyor9nBWg9vI07fng3U3/3ND+YWtipIZe9Tbz73P94aXUVOWlmqho8TL/kKn502RSchiAfPv5rbnhe4fUFv+eMjBpun/8zambcwH/uuoxMc4i9q97jD4++j5JbhMXdSLBwBHfcdhO9W9fz498u4ef//h1Ti5zI3ibefva/vPRpDdkZRmprajloG8J7j/2MHM8BHvzri5S1GXBKPprJ5Maf/pALxxUQrC/hFz++k61pV7LgqatpW/MG1978PJc//QR3zupN9a6l3HL3x/zq3/cypTAleryUX/37HiYXOkHTnmvt18aLBIJh2tt9SCYnaTlFcZMwoZNeQSHk9+FqacCIh/S0yPdpeh0WvTJFObH+xX0xvju0+qlhPbVfK6uV06ZPJK/VHZ28OAH7ZVmhrd1HCBupWQVYLPHnPaaHotDgaaE+0IgpFUz2zkuaiWht0Mp1yr+LfS3avDgB+xOh1U8N0+qVKC81PuQJE3JBniWbbEdG7L4X00lR8HqbcbtrcThkHA6zbjkiemXq2Z8oD730WnpqX1fxYvlaOW36RPJa3dHJiy/ZfkUBrzeIxyOTklKE3Z6FOCmaEp08NBQMYrPbsVg6+kOqjKwoNDU28swzz/Lyy68SCoUYNXoUZrOJ3bv24PV5ufzbl3HjTTdQkJ/Ps88+z3/++ww+n5/Ro0ZiNBrZvmMnsizz05/+mKuuvIKMjAxCoRALF73Pww8/QigU4v777mXevLkoisInqz7l2Wefo7m5hZycbBobm9i7dy9Wq5X/z95Zx8lRpH382+Mz6+7ZTbJJVuIOBKKEwB3OHdwdzh2HHhx+uLsdfrg7BA8hIUSIu9sm65t1H5/pfv+Y6dmenlmJQeCd335qp7vqqaeep6q7q55+qquu+/c1nHXWmcTFhbwxhT7WT7j2VKbTDY36WA01L37l9lfD6XKxZs16cnPzyMvLUydH0AuOyFWjXS4nu7ZsZNPyRRw7YRwzT5hJUlJSoHyXy0VZWRlLly5lz5496HQ64uLi9ssYFgQBk8lEamoqosfD2tWrMMfEkpyavl98DgbSEbRqtNfloa2yiYz09KCHpgxHUwlvvfIhrqRkPJ5Epk8/hthQsv2CKIohMoWLA3C73ezbt4+47KQjatVop9NFRWUNAwfkYbGYfasCCyIdzQ3UNzbS6fBijo7C4P/2xuNop662npa2DkStgSiz0TflSHRSX1NFU0sbbW1ttHVa0VtiMBt0wSsOC2Bvb6KuvpFOhwdTdBRGP285eGwtNDg0xFkM/jiJ9rpKaptafbzb2rBrLMRHGdBoBFzWVmrr6mltt6I1RWE26gKrFTfV19LY3IrdJWGJtqDX9cYvdIXk3kJDYzOdnVb69ctSV+8B4aBXjVbsI6xEuH2Ew3Gs3tdMa4eTrOxsnC5X2NDe1kZpWSnFqlWjdeZYCseMZVRBLtGG0O1iBJ2JQUOHMWZoHoMKijjh5BP5wzEFROs1CIKWzIFFTD/+KMYNSEZvimHY2FFMP240mQkmBEFLcr/BTDpqOAX5Axh7zCTOPHU6hakWTDGJDB89jIK8FPQaAY3ezKChwxhVmEfh8JGcdtbJnH7cCPIzEzDHpXLUhOEUDc5l+JhxnHXmLMYPTEIQQGuKoXDUeKZNG0P/BDOxqdkcPWUSx47pj1krYIxOYuSYYRTk+soxxSQxYrTv3KAJ/qZSUAww5HP8q+WGG+jI2ycJ/u2TNIqpejIvgvLJ+wjb0Ehu36rR/kQ1797ilGlyWcogI5zcSghqfVVpICH4F8oJn+5HN6tKd5dHWa4yvrtzGcr8yjh1kCH5/7lcHiR0GM2hq0YH5FBun2T0bZ+kpFHLFHR+BOvfHS9UcnRHJ9Oo0+WyvG4JySUFVo2W60Epi8fjwO2xotNLGPSh24yF4x0OcrwyXc6vDDLCya2EWg5lm8iQ49V8gs4Pov17olPHKfOr45VBRji5Zci0Sppw14LvWMLj8eJ249tHOMz2SZIo4hVF9P5Vo9WyIAiYjEZycnKIjY2lw++VbW9vJzU1lVNPOZkzzzqDAf37o9frSU1LJTo6GqvVSnNTE51WKxkZ6Zx66in84aSTSM9IR9BokCSJhoYG6urqSEpK5qijj6JfTg4AVquVysoqampqaGpsxuly0i+nH2eeeQYnzjqBlNRUBKVBL4saEDq0jpTxAfzO21/NR4zsI3xQOOI8wpIoUl1Ryk/ffE5WUgzn/+1vZGRkBAY1oihSXl7ORx99RFlZGUajkfj4eM4991wGDBiw3zKKokhNTQ2ffj6bHaVVnHDW30jP7hco73DiSPQIjxo5kliVZ1MSO5n/8uMsco3gtCG1vPRNO3c/ePNBe4RLSkqIjo4mLS0NQRBwu93s2LGD4uLikPrv7Oxk3bp1R6xHeNrUScTHxYLkZu/SL3jsv++xT9AidXgYfs6V3HDODCz2Ul567BHmrKsnyiTgMWfyj//cxolDM6jf/jX//PN11MSkY9QJkJDDP/7zCOcf5etAZLSVr+LROx9iQ7OE5IYxJ1/G9ZeeQLx/6xl35z4+efpGPtacwWe3nI5WIyB6Knn4zLN4r1JDYpQONDqKzr6NFy+fjm3fZl568DEW13SidziIHjadW264miFxLpZ89jxPvbMUQ5QJu11i6kXXcekpR2HGz69KS1KUDrQ6is++jRcvmxF2il1v2LJ1J7W1dUeIR7iWEcOH+vYbV6V7/R5ht98jbFB4hFF0WivXlbB+a3nYZ6oSkiQGeYQD8UFnfetIlXnU6XIedaeqPu8NvdEr07uTE5kuzEBFRnfyKtPUkAC320tHuwP00cQpPMLd8ZMAt9NBZ2s9OuwBj3B3UOdXo7d0GQejf3eQaQlD3x0/9Xlv6I2+t3QZXlGio8OBRzIRk9TlEZbRJa9Eo9XnEdZGg8HSfd/+W9L/sLa/BG6HF7EDUvwe4ZBFu2SPsK0Os0kkKir0xXI49CZPb+kyDqf+4Wi746c+7w290feWLuNQ6B/iEbYkgsoUdrvduNxuzCYTRqMxhJ98Lnq9WK1WWltbaW1tQxRFYuNiSYhPIDomGr2/H/N6vXR2dtLW3k57ezsA0VHRxMXHERMdjVbu7yQJu91Oe3s7oiQRHxeP2WIGvxOrra2N9rZ2rFYrWq2WmJgY4uJiiY6ORqfT9Ul/NXqi7Y6f+rw39EbfW7qMQ9H+akQ8wgeHw2/t7SfsNht7dmzFa2tn1syZpKV17emJ/43SunXrqK2t5bzzzuPss8/G7XazcOFCOjs7g3j1BRqNhoyMDI6bdAwGwcumNStw2G1qsv9XkJSLVIkudi/5jHmVsZxzzgkkm7Xg3/LiYEN1dTVz5syhurqazs5OFixYwMqVKxFFMYT2twJ7Uwmvv/IWydP/zrPPvsC9159J7U/fsLW6jg1fv8G3JQnc/t/neO65Rzkzv41Xn/+SRlGkrbIEqeBknnzpLd566y3eeuZhThmRHsRbEm0seOcFdkdN4ZHnX+TJO//Knjmv8vWmekCkee9anrr1Gu59+XuqW7tWeRSbqtjrSOHaR9/w8X7jNe44eyKC5GTxRy+ywlXEXY+/wDPP3Mtg2xbmLCth395lvPTGMmZdeTfPPf8st140ifnPPs+aqhbEpkr2OlO57jE/v9df5/Y/TzwgI7gvkCSJzs5O6uvrVds4/LIQ6NrGRQllhyUAhYOyOHXmGP4wbYQ/DFf9juCP00ZwyoxRxEb7BghqBKqyh2tf8tcNirL72gT708nK6I2/nN69xD4IhH7D1i32U/9ehfQjrP7dFwV9ZC3r3wurA9ZfeaYsR5atj1zD698L+sK/L/oHZO1tsW4p8C9AqNZfxm9Jfzh07S8jIFtvdapAX+lk9Ka/nH7I9JcOQP8+QjqAPL3R91V/oc/6h3IJ0l+VruQoScELMqmh1F+r1RIbG0tOTg7FxUUMGzaUvLw8EhLiA0YwMl1cHDnZ2RQWFlJUWEhubj8S4uODPc6CgNliIT09ncyMDCwWcyDNaDCQkpLCwIEDGDq0mMKiQvr1yyHezyMIvemvOO6tbdT4XbS/4rg32SLoGUeUISxJEg21NZRt38KEcWMYOGBA0M0hSRIVFRWsXbuWsWPHMmzYMIYPH87YsWPZsmULNTU1eL3eIJ59gVarZWB+PhPHjaVsxxZaGuoRIwtngX9K9OsvvENVeyuLP3+b9776mT271vL5p3Oote5/XSsxePBgXC4X3377LfPmzWPDhg2MHDkyxBtMmIf+kQmJhpKV7PEOYvIQI/M//5SNbRnc9uh9jM+JRZdSwPmXXcDEQdmkZQ1k7OjBWCtr6BBFassq0aWmUbrhJ75fsJI2LMRagt/Ui7YylqyuY+Lpp1LcL4PB409k+mA3K5fvxI6VVV9+QZlQzBXn/5E0hX1lrSljn5CBvmMTc7+fz446J4lxFkRrCYuXVTHtlMlU/vwNXy7czQlX38flswZj0EYz7dyLOXPKCFJT0ykeN54kbxNNdhedNWXsEzLRtfv47fTzO1zwer3s3r2b2bNn8+OPP7J9+3YaGhpwu91q0kODMJ1UaOfW9YJGTR0bYyYjLT4QMtMSyAz69cWnp8aj0ahzd0HZYcply9SBjlyxaqzU3X0SRs5wHWd3nax8HloH3aO7AUFY+bpBd/orB3lK/WVCQU4MxPWsv+xH6Yv+QXE9DER70l9d792hJ/0D6YpypDAyQe/6y/il9Eclc88IllKtPypeapl8BMH08vGvon+YcruDQO/tr0yT6NI1qNww+stQPuoOVn8lDon+iq21+qq/ujwIr384GX4p/fsKoZspwoFyVf1UUHlh+rDe9EcQAltVqg01mbfgl0ur0fjkC1MOvegf4OFfabpbHr3or04LVx7wu21/Zdr+8I0gFKEWx68Il9NBdUUpzs42xo8dR3S0b/EUGXa7nT179tDW1sbYsWOJjo4mKiqKoqIi4uLiWLt2LXa7PShPXxETHc2wocXEx1jYvX0zLuev53n6NSGpPbf6GCafeg5Th+eg12rQ6TRIggaNVoOEEEq/HyEtLY2TTjoJSZLYsWMHU6ZMYcSIEWHl+E1AkmirLGHVqkW88u5X7GtvY+G7T3H74+9T6zQxata5/HVqke8738YSvp63htSJI0gTnJRuX8/u7espqWygbPWX3Hn9Lfy4qzX44Wxto82toX9Wmq8z0ZhJT4umrqIcu8vChL9cwQMPXse4vHi67Csv1WU7qarZzup1e2iq2sKzt1zFM5+txllXxardO/nk9VdZUVJL5bpvue8/97Gi2kHKoGP4x/mnkRKlQ3R3svrH76hKKWBQcjQ1pbuolvlVbuaZW67k2c/X4DlMzaTVajEajWzbto0777yTW2+9lbfeeiuwRkBbW9sBvQDrDbI64TtIXwWrr01lhyX4CILTFefq6lLmVUMZJxHMN1CWv/MMgSJO3UErZVDmDCkvDJR8lHEywunfF4TRIGycDKX+CHL9BJEEoNRfkiR8f6HoTn81bU/nh1N/dTlyetj2V6Cn9lfiUOjfK7ohVpYd0EsRx/7qH+b6l9GNCIdP/z5cD2E0CBsnQ1lHAkJoESr9ZUiqRYfD1Tt+neRzNevezg8E4XQNFycjWP8w6GP7/9b0V8d1q78Ch1p/NXpL7wvC6RAuToac1q3+h7H91egtvS8Ip0O4OBnd6h1Bn3FEGcLtrS3UVuxlyOD8kCnRAI2NjezYsYOCgoJAuiAIZGRkUFBQwObNm2lrawsZnPYFGo2GzMxMCgcPYu/2LThsR/b0aEmS8Hg8OJ3OboPb7TmgulDCFJvJ8X+6gAsvvJALL7iQM2dOYED+SP548nRSzQd/+2VlZXHyySdz+umnM3r06P3+xlsNUfQtQKaui8MVgjeaB6/LTr2QwblX3cyN19/EA/dejX3ZlyzZWRt4SLqa9/DyEw+xsH0c/75oJmZBJO+o87nnvge45eYbue+Jp5iZVMPbH/5Iu0fBXBSRBAGDvstTrNFq8HjcSJKWhPQMEqLU30aLWLLGcvV/7uPeW6/nP/c8xN0Xj2feOx+wq8VBs2hh1IkXcdtt/+HuRx/h2NhqPpy9jE6/XSm6Oljy6TM8/nEFF19zNYUpRqKyx3L1rff6+N37MHdfNI4f3v6AXZ0Hfq2JkhRSt8o6TkpKol+/flRXV7Nw4UKefvpprr/+eh566CE+/fRTVq9eTVlZGe3t7Qd5zQv+EaLPcyd3goEQ1FsKgQi5xJAOU73PbJg37eHO5TyBIHXtJYifjzKdXjpDNZ1MG5C3GwNdUusfRmaZju7098vuO+2SUimT+lypm+SXL5Cu+OZRTlMipB7UbSDTCELXV3WKrXzUMnWrv0oXetC/6/Tw6R+it4zu9FfpEyK7//hA9Q8ch9Ff8P9TyqyUMaCbfO432iR85e6X/ipeSrpfS3+ZRl2WfB7QTQ6q9g+iUd67XY+kIKjLQiG+Ol4tk8xuf/RXHgfpHzgKlUl9rAzKuJ707w5KPurqUedWy3Ek6y9DrZP6bYiSj5o2mDJUjp70V8om0wSS5bTDqL+k4t8dlHx+t/qrFYugzziiFsvau3MbC774kLNOPonJk4/DZOpaREMURdauXcvbb7/Nn//8Z8aPH4/RaAykrVy5knfeeYdzzz2XsWPHhl35uDd4PB4WLlzEK2+/x1mXXEV23oAQY/xQ4mAWy7Lb7ZSVlbFv3z4guIP1RYA2xoApJxZLdFSfF8saMXx4iCdeierVn/DCnGauvO6fZHZPdshhs9nYsGFDr4tl2Zo6cFd3Irl/mantoijhcElMn3Ys8bHRbPvqQf78v1o+e+txhqSYcDbs4qa//5OB/3qFq6YNoK1sDf975jFW20Zx2x1XMjIrDo1op6a6nqjkbOIsWhC9LH7pUu7dVMDbj98YqGdP0xquOPd2jr73PS4cl4Qkuvj83vP5SvgLz95xKrEaACfLX72Zh6omMvvOs9EKIq31NVj1yWQl+uZLt617jzNu+YQb7ria5+98gD8+8D6XHZ2OJHr49tHzebPpBF5+4AKinbV89+6TPD+nnr9dewt/nVKAQfCG8Gtd9y5n3vIZt77yGdNz9/9+2bJ1J7t2l2A2dp/X6/Xy888/88ILL9DR0QF+T7HJZCImJobMzExGjBjB9OnTsdls3H///VRXVx/wYll6xcsGyd/HeL1urG2Nge2TDAZtUEcpo6Kmjeo632IiERwexMYYKcpP9Q1MJN8eyx63l/beFstSLFIiSRIel5PO1nq0kp24uPCLZZVWtVLb4LvmIjgwxMeaKByYAqrFsmKT0tEbTEGDQOUAUt4+SRsNekvw6sYyrSRJSF4Jj0sMHZEqz3s89l1D3ULNtzsohJPkMavkvwL9ZcnxLqfzoD/B0ht1mKJMQVat2+7F24ftk2y2OsxmkZp9Nhob7SHVIudRqhxSbYpjZVw4hMsjH9NNWl+hlren/N2ldyfTkaq/KEpERxkZNGhQYLEsFPndbrdv+ySTCYN/rCynK7Ftxx6amlpVsREcCNLSkhmcnwvKa8LfP6mvKWUbh7selOju2pD5u9xu1q5ZT7/IYlkHhCPGEBZFkS1rV7Loq4+589abyc/PDzJCOzs7mTt3Lj///DPXX389WVlZQQPbsrIyPvzwQ+Lj4/nrX/8asvJxX7F+/QZeeu1NRhw7g+FjJ6A3dD1ADjUOxhCuqqrik08+YcOGDSQmJoa0n0arIWNgNmNmHUVCUuIhM4SRvDidHgxGY4/jhkMNq9XKxo0bezaE7TbKd+xl/Q+rsHVYQ96KHg7ExMQxeuxEZkw/jvi4GPZt/IILr3iFK194nZNHpNO6+yf+eekT/PnplzkxdR/333oblblnc/eVf2ZgShQC4G3fxi0X3kDcXx7ipjNHoHc38vy1F7I291KeueEUYvxNK7rrefqfF7Fv0p3cf+EEdNY93PmPKzCc9SS3nVWMj0xlCIttzH74Ot5rOppXHrmEBJ2bNe/dw02zPTz/v8t4/7KL6TjhHh665DiMngaevfpithdew6P/HMkPz9/Ea1sTuP7GG5lclIZeEMDTyucPXccHrcfwysMXE691s+a9u7lptpf/vf0wg6L3/6LYsnUnK1etZsO6leqkACRJYs+ePSxcuDBowSxBEDAYDCQnJ5OTk8O4ceOIiorinXfeoba29gAM4dB9hOXOR/R6sAb2ETZhMPgNLVVHt31vI1W1naSlpQV4RHDo0Nrail7jYeKonKCBgWwIC4ZoYpNC9xFGMQiRj337CDcE9hEON+DYtruefY12UlNT/TER7A+am5sxGyTGj8gGQJL3EfavGq33rxqtvjtFSaJJsY+w3hz84kk5oLQ2OKha3ajicGSjZPd2Ghrq1NH7hX6F2Uz72xRQDIo9DtG3j7C+d0PYZBYpKWmjpUUkOTm5i3EERzwaGhqwWDQMH1aA2ZIYtGa01AdDWL5/VqzehNVqJz3N96IqggNDVfU+UpITGT2yMChePQpVP+eUfU5QfA9bBaJ6/rlcLtauXU+/fhFD+EBwxBjCToeDtcsWsWPVIu6+/TYyMjKC0uUtk+Li4vjLX/4SYuh2dHTwww8/dGso9xUlJSW8/d6HmFKzOXraLMyWUKPrUOFgDOHy8nK++uor9Ho9M2fOxGxWrT4rgE1w0aqzYjSb+mwIDx82rGdD+FeCzWbr3RB22BEcIkneGHS/0Kx/m93Bzl2lge2TPJ01vHHvDXxREs1JfxxPxZK5VMZO4dG7z2HVizdw/ctrOf6cM8iNNSAA8Wlj+dMFk9j86l3c+cFe/nDWLIz161m0wclVTz7JjCwHbz1zL3v7n8ddZ41ly9dPcuPTP3PMKbPQV69iWUUK979wPyNT5I5OZQhrJGrXfs5Vt75OyriZjE6z8f2Xixjzjwe48U8j2PjpI9zy1FImnvlHUjt3sGCtnaufeoK8qk8459x7SJh+JpOH+DxvgiaDP158OkkV87j61jdIHe/n98VixvzzAW768xi/Mb5/2LJ1J5VV1RQM7q9OCsDpdPLVV1/xwAMP0N7ejk6nIzY2luTkZPLy8pgwYQITJkxg8ODBrFq1ittuu42qqqoDNoTl1TKVnZC8fZLH2kysYvskdUe1fU8DTe0iY8eOVcRGcKiwa9curO2N4Q3hDgeCLppYlUdYicBAUJJwuxx0tjaik2zExppAMV1XaQi32QRGjx7tj4lgf7B9+3Zc9tawhrDsEQ4Hn0e4hQZXc8AQDkpXGsL1DmrWNDN2zIigmWRHIjxeD2vWbmTzxvVotXD00UerSQIQRRGhm0WJ1qxZg2TxMvOiGaC4rl12L96OLo+w8o214K9Xu70Fq7UOs8VnCLtc5sD6HBH8NrBp0ya8Xmt4Q9j/6ZxbNoQNhqCXtSiebytXb0Kv1zNhXOT5djBYsnQlRoOO0SOL8Hi9tLW1odVoiY6O8m0LJUnYbHZsNivR0dGYTCY6OzvRaLSYzCa0Gg2if4cMrUaLyWRE47e5Qu/+iCF8KKG99tpr77ZYLGGnALs9Xpo7HThFMBiNYWkOFRw2G+Ulu8BpZdIxRxMVFRVIE0WR3bt3s3jxYqZPn05ubm6IUa7X67Hb7WzcuJGsrCwyMjJCaJSQ37aoYbPZ2LN3L+12B3mDCzEcRo+wJPm+Z9XiJT0+Gp227/Xb1tZGSUkJ8fHxjB07lsTERGJiYgIhOjoaDALtHitanRadVhdWXxlel4e2yibS0tIOaFr54Ybb7aauro647CR0xtB9DyVJwu3xYNIayE5IJz42Pqg+DlfQaXVUVNbQv38/34PLEMOw8RNIEJvYUVJN2ugTuOoffyLT5GRvZSXGhDTMggenw4HD4cJgzmHUxCIKho5hSLKH3bvKEBOLuehfV3B0fhIa0U1tTTWGzKGMzEslLX84xdk6SnaVIqSO5tJ/XcKIzJgg77zH6cSYms/o/AwEQSAqfRBji9OoLdlOgzOKWRdcxV+OH45ZpyNj8GhGDoimbNceOqMGcP5VV3BMfgLNNbtoFOJJj9b7ZXXg9kRTPGEE+fnDGFuUSu3u7TQ4oznxwiv5y4xhmLTdX189ob6hCbvNTnFRQUj9xviv5Y6ODpYsWcL27dtJTk6muLiY448/nvPOO4/zzjuPY489lvz8fBISEigvL+eHH36gvb2dwsJCTjjhBCwWS4/XP/57ymq1kp6WElh/IGjgIIm4HDa8bjsmox6N6n6VaRtbbdidEpmZmUHpERwaNDU14XbayM6IA0W9i6KE0+kBrQFTVAwawdc+gioE3sALAqLXi9thQyO4MZl8W4AoPfwCUN9sxen2rUURwf6jsbERr8dBdnqsv37B5fIgCTqM5ugQz33gxYUAdrcTq9eOYACNvqs9lRAAl81DZ62T4cMKiY2NwWIxH7HBaDSwZ28Z9XW1mM1Gxo4dG/LMi4mJwWKxsH79ehISEsjOzg5JLy8vxyO4yR81IFAPkgSiWwIXRGktWPSmwHNMWW8ejwO3x4peL9Hc7MTr1ZOeHrxdXwRHNurq6pAkN2lpyej1Zt9CaXKiICCKIqIootPpAtsboTCg5FBdU4dGqyU7K/j5JnltrFy+BG90BvFm3z3qsTez6sev+XrOAtbtrCU+I5uEKAMCbvYs+pyPvp7PshUrWblyJWub9AzNS0Ov6ic9HdX88MWnzFm4ijYxlqyMRHQa39octbtX8/kns1mxqQJTahZJMSY0Angdraxd8CVfzlnE9n1uMrMziPK/iPbBS82GuaxriSYvJcYXJXko2/wzsz/7mqVrt+OOTiMjMRqtAC1l6/nkg49ZuMwn68pd+8jO7U+s6UBe5ftQUVmNTqshPS2Zzo4O5v4wjx07d5KcnExMTAxer5dVq1bzww/ziI2NJTExkWXLV9DS0kJiQiIGgwG3283Klatobm4mISEBo9E3Fg/qtxRlym3o9XrZt6+WuLh44uPjFRQR9AVHjiFst1GxZxeCy85REydgUXhiPR4PVVVVNDY2MnXqVOLi4kIGtYIg4Ha7qayspK2tjYKCgm7fDDscDurq6gJvy5S8rFYru0pKaOm0M7BwaNCUkkONgzWEd+/ejdlspqCgIOibRhkOr5M2d+d+GcKpqam/aUNYh5YEQyw6TfcvQQ4lnE5XkCEMoDXFMmTUBKZNn8bEUYXEW/RoDFEMGTmJWbNOYObMmf5wPMdMGIxFENDoLeQWjmbK9Okcd9RospKifCs/68zkD5vAyLxkBAEErZHM/OFMnjaN444aSUaCRTVFXUNCTqHfCPbFCIKWxMx8jpkynamTj6EgNxWD32gVtAbSBxRz7NRpTDlmHDkpMWg0GpL6DeOEWbMUss5kxvRxpEcbu/hNnc7UyUcH8TsQ1Dc00dlppV+/LHUS+Nt27969rFu3jry8PP785z9z/vnnc9JJJ1FUVERKSgoWiyXw1nXXrl3MnTs3YAgff/zx+2cIp6eh0fq+RwyCJOJ22BDddoxGPVqNwlOjeLHW1GLH5pTCGk6S6KW9uZ66ugbaOh1ojSYMYe57r9tGbXU1jc2ttLa20tphRW+0oA9Tz5Kzndo2DxazPkhm0eOgsW4f9Y2tuCQtZqNvFoIafaET3Q7qauoRzFHog7Z8EuloqKPFpSXqIAYR+4Pm5mbcThs5CkNY8H976nJ5QNNlCCvfmsu/MgT/dHeXw4pG8mAy6pD8qimvlfpmKw4XYduzvaGCffUtvjZqbaWtrQOnqMEk16Ek4uhspb6unqbmFqwOD3qTyTfwU8De3kh1XSemGAthmvg3DaUhjN9Yc7o8iJIOgyXUEEYe7Elgdzuweu1ojKBVGMLqdnTZPHTuc5A/MC/s7LZfFiI1G77h5quu4aV3PubDDz/gwx/XkTJ4DAOSLYiiGDCE9XodQ4YMUTPA4/Ewb9487rvvPurr6xk9enTIrK89e/YEDOFAnQggeiQkd7AhHHT9C+BxO/C4gw3hcJ9ytNbX4NKZMcrPKMlL675qOrx6zEbVCwxHK/uaOjGZtTRWVtHQ0nVfdNrd6I3B173osdNUX0dDYxOtHTbQGTHow/fbXredhtp9NDS1YHVKvpfOYe4Te3sT1fvqaPGXa3V4/M9+P4HkoaWmhg7REEb+FvY1WzGbzQiChKOlGqtkxqiDjuZ69tU10OnwYjSburlHxT7SHRrU19d3GcI6c8g37gFDWK/3bYmkuG+UlKGGsISjrY4f33uEfz01m+JjT2JIWhSSp52vXrqXpz7bQHxyAvvWf8/sxXspPuooUk3NvH3bzXyytROd10pTUxOuqCwmjxwYZAh72/fyzK138sWGOqINVma/8wVtqUMZPTCZ1u1fc8ct/6XMa8FWtpz3PlrN4ElHkx3tZcFbj/PY+yuIijOybcHnLCnVctTEYsxaAdFtZdeyz7j5tnvYEnssp4/JBryU/PgqNz30Hp2GBITGrXzy1gfohxxLcbaFTV//j4deXoyo9dLW0kyTU8vQYcNJiz3w8b7PENaSkZ5Mc3Mzb739DkuWLCUvN5fsnGyaW1r4+ONP+fiTTykqKmTAgP588eWXdHZ0kp8/gKioKOx2B99++x2tbW3k5eXhdrtobW2lo7OTzk4rHrcLnU4X8BQj931eL/tqaomLjxjCB4LQEdivCHnwof60U6fTMXz4cC644AJSUlK6HdAmJiaSl5fHzp076ejo8L3ZD4Pq6mo++eQT1q9fj9PpVCcHBAhfSgQRRPBLQvJvtXXeeedx++23c9ZZZzF06FCSk5Mxm82BF3Qul4vy8nK2bt2Kzb/qe1NTE7t378Zqtaq49g5JNeCWB5GBOMUAUx5symnhnj2SJFK9+Xtuv/7f3HrH3fznumu479n3qehQLg0OIFK3bS7XnHU6f//n5Vx55ZVc+Z8HmLutQUXno61a9TGPfbgE5frlksfGmq9f54Zrr+euu27j2hse4Pt1lajXkJM8NtZ89RrXX9MTnYSjYQdP33wpry8qCaoT0VbHe4/dxJNfbsAbqvJhgbJuuxvcCaqtYQLxioB/8yR5Z99wbRmOhwyvs5PPHv4Lfzjzb/zziiu58sor+ec/LuHvl9/I1xsqkCSJ1vINPH/Hv7jokr9z5ZWXcdGF/+Se/31DTUdXa0keOwvevJlTTr2IrzfVBpXxu0bX+lGgqG9lOwavla5qY1X7HzGQvOzbvZ5y1wDO+st5nH/++Zx32kzyk1WfL3UDSZLYsmULL7/8MjU1NXz//fd89dVX4ccq4a5/RZWp6yaobru5R2S4bS28c9dlvPL9tq5ni2hl0Rv3cuNjn9MS9NjysOWb/3LtnS+xo2ojd55+Bmef/3euuPJKrrzyUs477+/c+vgHlDX5trf02hr55o0nufLii7js8iu55KKLuPLm+/l5d32ITJLXxorPn+HfN9zMHXffzrX/uo63vl2HXb1jntfB8g8f5eyzL+Ay//1455OvsFe5DpRo5afX7ubmJ7+gVSX/pi+f4t93v0KFTQKxkx9efoov1u+jeec8Hrz1Om69626uv+7fPPLhMtqc6sIlmnfO44Fb/81tfrpHPwpHd3ggqFZgVx4r0fXs8yHcM87jLOe1W67h3g9X4XJ3xdvqNvDVvFLOv+k+br3pBu66/y5SS39mwYZy3M317OiM46I7nuCpp57iqaee4u4Lj8cc5LWVqFg7jx+qE/jPY49y++13cuOf+/HVR1/RaG9j8Qfv01H4Jx566G4eevxBpqfs4OMft9PRvouvv9vAGVffwR233cHdN5zO7p+/Z3edA+hk8f8e4er/PENVowODbNG4G5jz0TekzriCB++9hdseepTzxxn48osVtHtcVJTXMPpv1/Dk00/75L3tSoqz/J7kg4SEb30DURSxWMyUlJRQWVHJxo0bEQQBk8mIx+Pb0cVus9PS2kJzczNNTU00NzfR0tqKw+7A4bCzdt165sz5nm+//Y7333ufBQt+orm5xffiXfH86669I+gbjhhDWKPVotPrsTvsSFLwaE0QBKKiosjMzAzr+ZQRFRVFv379cDqdlJeX43Yr7mI/vF4vdXV17Nmzh6SkpBB+Ho8Hh9PpXwzq/9/l5XA4sNvtR1xwOBwhD+wI/n9Ao9GQlpZGcXExmZmZvinpKq+PKIqUlpby8ssv89prr9HS0oIoiqxbt45nnnmG1atXh30eKOGzr3xbJ6k7mi4i5Uno4CN4oBm8F7bXUcMXr38Aw//CA48/xgN3X4W09ks+nL8Tp5JWFGmpLkU/9BQefuoFnn/+eZ5/8FZmDEkK4Sl5Oti0ai8D+udiDMSLtFSs5e33fuKYC27m0Yfv54xiB2+8M5vGTrciv0hL+Rreen8Rky68hUcfvo8zihy8+c5sGq1KOjCl5HH0qBxWLFhFm6crf3PFFtaUw+Txg9Cgku0whXAIxCoMAHXbyOji4Ns+SVAQdPHpav+uKLUs4HXBiJkX8sQzz/P888/x/HOPcNoAK++9/BXVdgdLPn+eZY5B3Proszz37LM88O8zqJv/PJ+tKg/wcTRvZ/HaBkYWRzF3zgo6vOpyfvtBDYGuW61b9ND99pD068Proaa8lqwJx3D0hLGMGX8MJ86cRl5y6NoW4dDe3s5XX31FdXU1sbGxCILA119/zebNm3tfZbqb+gyqLz9Nl5fU/xOm3bwuGy7/NoySJCFpohk95Sgaty5ia42ti866jx8X7qTfuGlkR0m4hCROu/wOnn3+eZ579jkev/U8PBvf57/vLaTD66Vq0zze+HQrJ151N88+/xwvPH0vk8x7eOXVb2lwBcvQtnshr8/ewPF/v40nH3+cmy8Yz9fvvsW6Sp+zIyCD20lFRQNTLrqJZ55/nueff567r72IfrEKfpoYxk6dSP2WRWzfp5C/s4b5C3eRN24K2RZwN5ayvDaRwRkuPnn1PRr7ncIDDz/M7Rcdy8ZPX2VDTWdQ2ZJ9Hx+/+h7Nuady/8MPc9tFk9jwyWuhdL0E2UCSg+zVVdPJQdWkgXYO7rOCLwplvnBwWFsR4o/i3gduY0pu16xKY0IxNzx4PyeNzsag06LTuBG0IlqvSEdTDbUdIrt+ep4rLrqA6+57me2NqjGb6KRs53YM/YcxODkGvTGaoeMnYKraTnljFeu2NzBw/BhSzHr0Mf04elwepWu2YrP058p7H+aMo7OoL9nMvG9+Ji4rn5RYI2CnxZHIxXc+wkVTh6CTLRptAqdc/zA3nXccMQYdWgHsTg+SR8TjdlBR0Uhz6VLu/NclXHjZzcxZXx54IXooIAAGg56xY8bQ1NTE2nXr2LhxM9nZWeTm5gZsC6/Xy56SPSxctJgf5s3nxwULKd1bisvlQqPREBMTQ0JCAi6Xiw0bNlJdXRP2GdBzi0bQG44YQ9hgMGCyRNHa2hZ2wCoIQq9TszUaDampqeTk5LB169ag1WVldHR0UFpaSnR0NJmZmSHfEdsdDlrb2omKiQ+afvD/AxIlJSVs3LjxiAu7du3q9QEewe8TgiCg0+lCXlop0d7ezuLFi/n888+prq7G6/W9iZfj3333XRYvXsyKFSt83wSFCRs2bGDPnj2UlZVRVlZGaWkppaWllPl/K8oraG3tci+oBx2SqkNSD1pEl0j22OM578wp5KQkkZ0/jII0gbp9TXiUtF4vteX7MKQkUbJ+EfMXr6UTC1EmbQhPd2sdaxv0DB2SpogXEQwxHHPWxZxx3FAS4qIw68Cg0aLV+Pf19dNhjGHSWRdx5nHFJMRGY9aDQaNT0UmgjWXC1Mk4dy5ibaXVL6eHXasX48gaz6icuBDZ9ifYbF2DUkmS8Hq9uN1KY7wrKCH52yEwhBF8OwxUVFYEtZ0yKOOqaqrp7JRnD3VZZuFegqrl8P1piIlPpV+/fvTrl0v//OEcc3Qh9oYyWq0e2htbiO83lOGFA8nNG8iY6afwjwvPIzXQlh7KV85np6uQ8y84ibqV37Gm3F+/R3BQt5e8MI+aTgozWJePbTYbNTXVgfYoC2mvMpqamvB4fPdy4H5T8QxtqV8XXo+Nsl2b2LzsOx6+6xYuv/gi7n3xM+psffMOajQapk2bxkMPPcRjjz3Go48+yuWXX05iYmLY61IZI/hvBo/HQ2NjI+XlXc+xwPVfVkZDQwNOlytwvavbTJJ894L/x3/sO08umsIYczVLVu3E6ZWQJJHGPRtZXR/DCdOK0SEhafQkpmXRr18/cvPyGTXldK46/zi2LfqSnXV2nNZWXOZkxo4cxoC8XPKLxnHGRf9gQkE8HpUh7CKWSX/4G7MmFJCUmELBiGLiHfU0tduD6NzuFiqbW0nVt7Hip/ks21yFPjoevUbJD5KLpzLSUMGStbsD8jeUrGNNUwInTC1Ci0hd2XacmWkMijHT/+iT+Pvf/khOSgJGgxlRY0HQqZ7FXg39jz6JS/7qozMZzIgacyhdD8HtdrN58+ag+6iyspLGxsYQWsnfbqLXS0NDQ0h/VeZv5/LyckpLS9m7Zw979+5lj/zrD3v37MHunz0lIzpxOP+4+0qOHuRbJFOGzpJE8fBiYo1avI4mvnntRbbHj2PS8Gza6ypp7OwgKn0cF1z8V2LK53D7rf+jSjHzBUnEbrWSlpqCTqMBBN8aAZ4GGhrs2LwSOYGVqzVEx0bR2VyNwxvH4GGFaFq28MYDj/LmdxtIHzqEOCNACqdccyV/On4U0Urvs8ZIbsFQ8hIMIInsXPQx72wyccIZR2NxNlBdVQbmdM644B/MHKrnhTvu4cfdzYSamPsPwf9c0mi05Ob2IzU1laVLl2Gz2ejfP4+oqK4XYhISVpudpqYmGhoaaGpsxGb3PVv1egPDhw1l7JgxCILAwIEDOeaYo0lOTuqaPavs/0IfDRH0EUfMN8IajYbW5ib2bN3I+LFjSErqauz9gVarpampic2bNzN69GhiYmKC+FRVVbF48WLy8/MZMWJEYC9iGeXl5Sz6eRkDi0eSlpUdYigfSkhH0DfCWq2GqOQYYrMSj9gQl5WIKdYcVg/pCPpGOIL9Q2/fCPcGSZKoqKjgyy+/ZNWqVbhcyknCvinTdXV17N69m82bN7Nq1aqwYe3aNeyrqcbpdFBRUUGp3yCWQ3V1FYgekhJiMZv0aLW+b1D9QiAvsNTYYsPmEEMWn9EYYhkybDgZsXqQvNRsmsebc7cx/tSzGZ3dtVK76O1k8cfP8VOJk9SEKOp3LOXLH9aQNuIocuKU97lEY+kalu9qYsa044gJzAsTMMakUVw8gPa9i3n8+nv4Yn0jf7z0ciYMSFT0lwKmmDSKi/vTtmcRj99wL1+sb+QPl17OhP5KOh8M0XFULvuKEk0BRxWng62ST975jNQp5zJtaPCgaX/g8XiYP38+iYmJmM1m3G4327Zto6GhIeyWRc3NzXhcdnIy4oLKFEUJp8tDZVUd6zZuYc+evZSWlQWCPFhUtmljQz06DSTGR2Ex+RcmUQ0yGpqtONyEfEMpel1smPcuO10DGDYgEWt7K/VlG/ngg89oTT6WP/9hNGnRXlZ++wnfzFvG3roOvIKRASMnMDY/xTdgstfy6RtvYy86iwtOGkrJnE8pNxczcWgGv8wTbP/hdruZP38+SUlJgfbaunUrra2tYbfgaWpqQvQ4yVIsluV0eqiqqWfzth3s2rU76F4rLS2l1D+It7psWBKiMEbrA98Io2gjuf2PpG+EPfZ6Vi1cTebUi7jxmouZMiqD7194gbqUcYwdkorQyzfCRqORfv36MWDAgKCQkJAQ1PcpvxEOQAKvS8TaZqd0Ryk7Nm1jr78+5botLy/HamsjyqIjJsZES6sLr1cXcq+JHger53yKZ9AMjipMD3hNNDojuvYtfL2qk2nHjcSidbNmznts0w3nvD+MQ+uqZs57i8maMYtRuQmBNtIbbHzz6TIGTprBqPx02nYu4oPZc1i1tRyHRyQqbTBTjh7lN3C6YEnKYcSwQUTpQHS3s2z2myyvT+D0M2aRbO66JpyNW3j/uU+o1SYQY7CzfsEX/FwiMWZ8MRbFzaTVGtG0buLrtXamHzcCs8bNqm/fZZdpNOfOGo0JN5sW/URnVDFHjytiUEExGWIVrzz7CE+/M5/siWdxzvFDMSmHa/ooBgzx0b38zMP8950fyT76T5xzfHEwXQ+w2+3Mnj0bl8tFWloae/fuZd68eSQlJZGSErq1ke9lho3a2mo2b95OaWnXc04O5eXlVFRUUFZezt69ewPPv72KFyNut0RScrLiG2EBrU6Lx9HA3G9/YtCxJzMkrWvxWmdLKZ+88gRvrRa4+uYbOGZQApb4TI6afgqnHD+eAQMGM3qghc/efY+sKWdSkOz3KotuSlbNZbNzACdNKsCgFXA27mb2N+sZO2syFYvnEz/xLMbm+sqq3fw980uiOOXk44jTg86UyPDJM5g0Lps5z72Gc9AkRuQmoNNq0QhOtsz/gvLkSfxxlG91egDR1cma71/n3pd+ZNJfr+WSWcUYdCbyR07l1JNnUjRoIEXFhZT/+DpbDaOYMjyny6u8n1B+I9zR0cGyZcsYNGgQRcVF7Ni+g4LCAoYPG8rSpcsYMGAAgwcPYsXKlfTLyeH0007lqIkTGTx4EFWVVcTGxVJUVIhOr2f16tWU7C7hmEnHMHbMaAwGQ8jzz+P1UlNTS3zkG+EDwhFjCAuCgN3aSXXZHlITE+jXLyescdcb9Ho9NpuN9evXk5OTQ3p6esCY9Xg8bN26lRUrVjBr1iyys7ODdHK73WzZupWVazYwdvIM4uLDv4E9VPglDOFWV4dvgC74PDzyVBt1kJDQGnVHfOhOB6/oxe3xoBd0EUP4N4aDNYQBampqWLx4MTt27MDjCf7mVhAE8vPzueiiizj//POZOXMm06dPDwnDhg1j4MABTJkyheLiIgoKCigoKKDQ/zto0EAS42LQCp7AqtGC/EZWscK0bAiHW1zJB5GqzT/wwGPvkznlEi76wzBMykVkvHY6Oo1M/OO5nH3q8Uw6Zix1P73PkoZUjh07sOs7KMnLzhXz2OsZyrSj8lHYCf500OoMpA0YhNGxl/kLShg+aQIpUapnhSSh1RtJ698znaAzobfu4Kvl9Rx37Gicu+by1oIWzr74bLKjD/x+83q9LFmyhF27dpGZmcmuXbv46aefyM3NDVuHsiGcnREHikXK5MWyomMTGVI4jILCwkD7FRYUMKSggILCwkB7FhQUkJfbj5goM0Y9mEy6wMsMJXyrRhPyYkPyutkw7xU+nr+JNcsWMXfOHBau2oFlwCQu/cfZDEw0E59dxFETRhIt2qgo3cnP389m9g8riB0wgoFp0TSVrOC199dw4qUXMSwjGVpW8f7iRqZPHU+c6cDr9HDC4/GwcOFC9u7dS1ZWFlu3bmXRokUMGDAgxJhCYQgrF8tyuTyYLHEMHFxAYVFxoH0KCwoo9LfRkIICElOTkIygNWkCq0bLbST5mQmCcEQZwlpjHKOnzuLY0UNIiIkmKSUD667ZLG7pxx+OLkJHlyFss1kRRZHa2tr9DtXV1ejM2oAhLPmqBq9HRCPqyE3vx7DCoRQWdNVnYWEhBQVDyEhPwWgUMBoFmlucYQ1hr9vO6u8/xZ0/g6OKul7MCBoNMWaJH7/8joxjZpClr+fj1z6m/8y/cfSgFLwOnyGcPX0Wo/ISAga0x1rBt7NXUzj9RIbl5TBiwlEMTDXRWlfOppUL+fjDL2kkmaIhuRjDrDIleqysmP0cz8+v5/TLr+HY/ISgBbNc1k4cMbmcef4FnDhtChOGJvLZqx9gLD6GwsyYgByCRkusycv8L+aQdcwMMnW1fPTa5wye9Vcm5CcjuZpZ8ONc0safRFFmDALglTTEp2YyIMnL0jkL0A2ewNCs4BdxAF5RQ0JaJgOSPSz9rnu6cBAEAbvdzsqVK7Faraxdu5bY2FjGjBkTduHXhoYGNBqR4uICCgqHUeBv5wJ/Ww/Kzyc/P5+hQ4cydOhQCouKKCoqorCwkCJFcDi9GAyGkFWjPY76EEPY1rCTF+6/iS8qsrn1zhuZNjQdLRLV21exqlZLYW6qb3Esay1ffLuQQdPPYXi6LLuXum1L+XqnjjOOH41Zr6G5dDWzlzTzx3OnUDv/e+pyjmF6cRoCHrbN+4hNrhGcelwcS35aS1x2Psnx0SQlp7Ln5/fYl3gUU4ZnoxMAQg1hyWtl8fsPc/cH2zj50lv4+6mjidIKiB1lLFxdSvaAfGJMWjSSyOYln1GbfAwnjM47JIZwZ0cHS5ctI39gPhMnjCc7O5uiokKioqL4ccGCgCG8fPkK4uLiGDN2DMnJyWi1WtauW4/JZGTwoEGU7C7hu+++Z+DAgYwePQqj0ehbAVxhtwj+PrSmppa4uDgSEhKC5Iqgdxxgkx8exMQlkJiexYZNmw9ocRv8nuWMjAz69evHunXrAovmALS2tlJSUkJSUhJZWVkhHWZLSwt79u4lMS2dmJjYw2r4/xLQ+P+8bg8Oux27zfa7DU67E7wSWkGreE/2y8FmtWGNhAMKHk/opxD7i8TERPr37x+ysir+l2O5ubmMHj2avLw8/zTW0JCVlUlSUhKJiQkkJiaS5A8JCQkkJCQQH5+AScVfnqKGPDBXQD2VTZIkRI+d7Ys/5MFnPiZt2t/513mTidEG02oEA/kTp3J0cTYGrQZjVArFQ5PZV1uGw91F53W3s3PHdrJHF2MOmv4n4bK1UtvcgSE2k2ETJnH+JReT0r6BjZWtYeg6fXQTJ3H+JReR0r6RNZs38uLdl3DKySdzyuln8PhXG5AEHUPGTyelZQNbKipZs2QNSaOOZ1iKPkTP/QlarZYZM2Zgt9v5+OOPWbRokc+ALSwMoZVUU6PVK6UCGA0GEhPiSUxMDAlJiYkk+ENiYiJxcXEYjAblrOgA5JccMtRySJIEkpkJJ13C408/y7PPPsfTTz7OvTddxpjcWPDYqa1pwJSSz0l//Qe33n4XDz/yAKcN6OD9N+fR6HWxY/UCNpZX8ckTN/OPf17Bq99vp2rNDyzZWRdS1pES9Ho9xx9/PJ2dnXz00UcsXbqU4uJi8vPzQ2jloIbkvy/j4uKC2kdum4TERBITEoiKikajeKkpt4fM8XC+qD5Q2GvXcs9/7mXhnjYkQBIddFghMTYK9bvulpYWlixZckChrq4umJlsDCOg1WiJskSRkBB6DyQkJBIdHe0f/3St/hfSZpKiooPSBOIGjGLyYA0LlpXQsHUJO1z9OWZ0vn+dAN+9JKnWDLBWldNmMhEfbaK9qZZOIZZRU07l6utv5b4HHuHOq49n4YfvsbK0JUQWZ8c+vvvfw7w8t4I/XX49Z47LCVmTwBCdzNSZx5OfFoNWoyUuYwhF0e3U1TbjVckfP3AMkwdKLFheQt2WxewWB3LUyAFokLA37KC6ykxBXiqS205NZS0uXTT5haM46S9/5+RigUU/78Cu4On107n1Mt0/+GNRKF1PQafTMWnSJCZOnBjYNmvWrFnExXX/2YngXz8nMUw7+9o6wXcvJSWRnJTk69/8QT7u6y4hXts+3n3yNr5pHMD1115MQbKW1uYWHF43nVXref3Bx1m+swZrewPLFvyEI2kiI3PN4GihoqYeD3ryR44mau/PrNpdQ0dLNUsXLsdUOJz+iTlMPHYQ2xYsoKSxk8by9cxZ2cTgCcMx2Gr58JHHefuHjbR2tFOxdRnbaywMzEnq3mgVXaz+5AnufX8dp1x8FadNyMLZ1kK71YnN1sI3zz7G61+vprm9nb2bFrC8xMKEoXkEre11QPDdMFqtlvi4eEwmI2azmaKiQjIzM9DpdSQkJGAy+1Zzj4mJISoqCq3/GeeLi8Zi8a0gveTnpb7Vz61W1q5dx7r162lt9fXhhBnpHonPw98CjhiPMIBOr6ezo4NtG9ZQXFhAclLSAZWp1+tpb29n5cqVFBUVBd6Q7Nmzh0WLFjFmzBiKi4uDHgCif6/ieT8tYkDxKPoNHIwujJf1UEI6zB5hCQlB0GDWmrD83oPORJTOTLTeQpTOFNhD9HDD6XRRXlFNzb469uwtj4QDCC0tbRiNhgP2CAuC4N/yQqC8vJzGxsbA9Gij0cjgwYM544wzmDp1atC0IjV82yd1kp6W6nvuyPtv+mdUqLdP0ml9ew37Bp9daGyxYnNIIR5EJC+7Fr/Nfa/MY/w513H56eOJDbh3u+Bq28Uj193OntgRjB6YhOBs5PuPPkfMn8kJ4/uj9xfmadrKF7MrmXr2H0gzKSSQvFSs+oTbHvyKwkkTSYnS075vJ1/PWcfwE09mSIp/mpvkpWLVx9z24NcUTZpIcpQuQDds5gnEedrw6uNJz8xi8IgJFGXHYzRH0b79J1bsEyndvpuJZ/6V4Rld07oPBIIgEB8fT1paGqWlpQwaNIgpU6aE9YLgNx4CHmFF3Sv3ETZGxSAIPo+9jMCxfwAp+b+x624fYTlPQ7MVuyu0PSWvm43zPqAx7XjOmjWe1MQ4YmMsge1CHC3befBfN7PDXMCo/DT0Wi1Gs4n6LT+zvDqJWdOSmf3UayTNupTL/3YyR0+cyKSjxyBUr2HFviSOn1KMMfyl+qtCEAQSExNJTU2ltLSUwsJCJk+eHPKZkYympiZEr2pqtMuDKOgwqPYRFhQBwOa2Y/Pa0BgFdIrtk9TteiR5hCXJw5oPX+DLjVYG5MSw6Yd3eX9+M3+67BKGZkQjKqZGW62d6uz7hbiU2KB9hAUJvB4JSbWPsJzug4TH48DltmIIbJ8U3iO85vvP8OTPYGJRetBUfUFrIUas4qsfttBeuQX7gD9w1tR89AK4HdXMeW+JwiMs4bU18PmbL1GiH83f/jiKlW/fxSNf1zJx/FBizXp0BhN6ZwXz5m9g+IyTglbYFl3NfPvCw3yxy8RFN9zEjOJMdGGe4fvWfsQ1D3zOwInHkRmrx1qxgg+/38r4P5xJUUZ08DWjtRAtVvL1/O20lW3COehkzpg8EL0AlStn86O1mNOnDUFo3MpDt99DY9Z4hmfFIjoaWfD1N7RlTeLEcbmBOnHXb+HB2++lMWtCEF1H1iRmKeh6g1arJSMjg5SUFEaNGkViYqKaJICGhgbA49s+yeDbR1gJb5jtkyD4+QdQU1Mfdh9htUe4fs0HXHPL6zRaO9m2fB6zP/uMzz5bhrlwNEePLcZdvYJX3/icBT/O4afNnZz3r6uZXJBG47JX+MOtbzP62FkU9M9B07SZ/736LnPnfMvyUguXXn0JI3KSSUxNZtO3b/P+598w55sf8Aw8iasvnkVmQjIpllo+eO1tFv28iNnfrmTQiRdx4alHEROYBhXsEfY0bubu/9zPzzubadyzhq8//5zPPvuKPS1JHDNtHNnmej567S0WLvuZL75ZScFJF3HeH8cTLXeuBwB5H+GMdN80dq1WR17/XBITE331L/j2StZoBAYOGEBycgogkJ2dSWZmRmAMLyCQmZFBYmICTqcTS5QFs8mEx+NBbzCQnpFOdFRUUB8V2Uf44CCUlZVJSUlJYTsPq8NFSW0L7W6Iiok9rN/L4h+AVJXt5aevP6F4QD/+cs7ZB+TmlySJ7du38+677zJ48GBOP/10JElizpw5rFmzhiuuuIL+/fsHGdktLS189fU3LF61jpP/egnpWdlB0w8OB0SvSGdnBwbJxYi8NEz60DboDuXl5Xz77bckJCRw6qmnBu27LENCwhtmhbnfMwRBQKMaAB9OeL1e2to61NG/K0hI7Nixg59//pnioiLGjR+PXqenqbmJVStX0d7RzjFHH4PRZGT37t3EREdTUFiIXqenrb2NXTt3Img0jBo5qttniFanJS724LYvaG9vZ+nSpbz55pvMnz8fu93OkCFDuOSSSzjttNPIysrq1ggGqKgop66ulhHDhwa9BBPwO0e8HjpbG3DbmomNNWPwvz5WGsISsHNvI/UtbkaOHBngAeBq2Mht/7yGZd4BnDJ5GEaNAJgpPvYEJheY+OjlJ2kcci7XnjCQn157gKe+q2fWqVOgZgMrdwlcfv89HJUj3+cSFUte57HliTxy0+mo735H03aeu/8R9piKmDoyk01LfqItZSp33PxX4utXcPsrP3DSRTcwMbaS5x54hD2mYqaOzGDT4p9oT53K7bf8lVRjuOefSMXPb3HZ/R+RMHQ6D9/1b3Ji+v7c6gmSJNHa2orFYunWqML/QtNhbeGoUTmBupcAj9tLe4cDdNHEp2QiaHxyqVtc9qRIkoTH5aCztRGtZCMu1gSCIt1Pv213PS2dEsOHDw/i43VZeevmP7I263oeufaPRKuqQfR08vPbT/L0x6tIzC9m0IBU2qt3smO3jZlX38EsyzKue2whlz/+PDPy5ZcJXrZ/8zTX/G8ztzzzPNP6d32bd6RBkiRaWlqIiorqsb12796Nx9nOhBG+KYuiKNHR4cCDiZjEdPQG3wsPub677iWJRmsLDa4mtDECerPfaxJI76LvbHCwb20rJxw/udsXKL8YJC8Nu5fw4rNvsr6qHY0lnVPO/SdnzxyBSev7BGvuvIVs3rgerRaOPvrooOwejyfsjDij0Rik25o1a5AsXmZeNAMU94Hb7kXsgBRDEomWeDSqZ54kSdjtLVitdZgtIiUlbTgcRoqLi4Po3LYWXrr2RH4Uj+XY4szA9MH+4//ArAmDkVq38sBVV/BT/RD+8+Ij/HGIb6xma1nFNdOuwTZpOmMGJCF5rFTs2MGe9nguvuU2ThudSvP2+dzz8EvUCakMGTwAi6eFndt3oy88lQduPpfUwIe1EmWL/sclN/2P9HF/YOzAJF90XCZ//MMfSOncyDMvfMa0K+9ibHw9/73jFjZohvOHo/qxbelPNKUdz/03/Y2UMB/q2hq2cP9VV7KooYDbXnqEkwbHg9jOl4/dRdW4f3HFtP4Ink5+eOthXl1uZcrkiYiVq1iyx8yVd9zE0ekCn/73NtqG/Z0LZgxg8dsP8+oKK1MnT8RbuYole81ceftNHJfn+yTgUGPbtm1Ikp3hwwowWxJDDGG3243b7cZkMvl2QfHHK5+ZAKtWb0Kn1zNh3GhFbvC6O9m7cw/JA4pIsOixNZaydntVEA2YGDC0mKwEC472enbtLKHDrSU5awADclLQa8DVUsW6slaKi4qIMWpw21rYvWMHLQ4tKdkDGZDt9+xKIh2NlezcU4VbE82AIUNIi/Nd76LHTsXunVQ1WYlKyGDQoP5EG5T6eqkv3UmzJZeCtChERxtbtm2nzaqcbaYlPmUghQVpaNw2Kkp2BfgNHtyfqIMwggGWLF2J0aBn1MhCJFHE4XCg1+sDYwkhcO/Z0en06PU6HA4HGo3G55Tz90kupxNBENBqtTgcjsCnXpJ/K1mzyYROpwtqR5fLxdo16+mXm0deXp5Ksgh6wxHlERYEAYPRiMPuYMv6NeTm5JCWltrt4Lk7CIKA0WjEZrOxatUqYmNjKS8vZ9myZYwdO5bRo0cHddxut5tNmzfz3Q8/MnDoaPKLhqHv43SRg8Hh9ggL+IzC/19B3R0cXmg0Gsxm0+87mEysWbOal158EZPJyJgxo0lMTGDPnhLeeedtKisrGDt2DAa9nhXLlwMwYsRwYmKi6ezsYOXKlbS3tTF27BgkScTtdiGKXkTRi06n9U0FCjOleX9hMBjIyclBo9GwfPlyOjs7Ofroo7niiivCrhCvhtIjHPQG3Q9JEnE5bHjd9qBvhGUI/tDYYsPqEEMWV7I3V7On1UtGciyi243T6cTpFEjLHczAzGia6usxZRZRmJVMv6KR9I93s2dvFdrkofztHxcwMtv3vZoPHtoaGkgZPIrBaaEvEHTmJIaNKMRdX8qemjYGTDiJC/96AqkWHR57G3vrrQwpGkZWajpDRxTiritlT007Ayb8gQv/OpNUS3fGrYAlLgFdp8SI405gZH4qYT7nO2CYTKZe26mlpQWP2xF+sSzZI2yJQaPpah+l0RQwcgUBr9eLS+ERlvzpMi3+b4QdLkI8ZpLowe10kNx/FIV5KSH1IGgM9Bs2lhFD0nF2dtDZ6SA6o5A/XfJPThqXSVNFDabsiUyfNEjh+RWISU4Bq5eU/oPISTr4++Jwwmw299pezc3NiN6ub4RF2SMs6TBaotGoPML420sC7G4nNq8drRG0el97BrWl/9hlPXI8wggaopLyOOb4EznttNM587QTGVWQFfi2X+kRNpuNjB07lpiYmEBwOp188MEHfPfddyxfvpzly5ezceNG+vXrR0FBAXFxccTExFBeXh60WJaAr3JEt4joEoI8wuqXDB6PA4/His7vEfZ4dCELMkmiG7ezDZtLh8ftwuXyhYTsfArzUjEYooiLBnPBUZx2TGHgu16v243L6kAyCrjdLjxeLZlFx3DxZRdw7JBUNIKAJWUA48cMxeK10t5hQ9LHMeGkv/D3s48n2f/CwwcPDRVlWHUJJETpcPtlcGksDCooIsngprHFTv/hY0hPSmLE6OHoOmoo3ddB/4mn8Pe/nkBKN88yrd4nf1ThMZx2TIHvxaTbRlNbFMPGDyPJpAWNgX5DhpNjaGfPnko0qcM47+K/MjY3HsnjoLmmFHPmUAbnpJFbMJxsQ1sX3UU+ukP4eAxCY2Njl0dYH+wRliSfE0QURXQ6HVr/PaG8Z+Tfqpo6tGE8whqtgaTUdMx6X3voLQnk5uaqQhaxZt/YU2eMIi0rh3452STHRwWeh1pzLNkZqRh9H/Oi1ZtJycihX04WSXGWru+8BQFjVDyZ2f3IyUon2qR4Lmj0xKek069fPzJSEzCoH7ZoiEpIITnav+ChzkRaRrZK1hzSkqPRAIK2N377D/kb4cz0FBAEDApPfJeKQsBDjyCg1+t9bePvczT+HTK0Ol3AQDaZfGMws8mE0WBA8Pdrynb0er3sq6klLrJY1gHhiPII47+B66orWfz9l8ToJM7/21/Jzc3d77JFUaSiooLPP/+c0tJSdDrfg/7cc88NWiRLFEXKysr4+NPPqKhvYdafziU1o2fP0aHC4fYIRxDBoYAkSXz88cc8/fTTTJ48mXHjxjF+/HiWLl3KJ598QmxsLJdddhnR0dF8/vnnpKSkcNppp2E2m6mqquKbb77BbDZz9tlns3PnTqqqqgJej8zMTCZPnkxcXNwhu+fmzJnDddddR2VlJWeccQZPPPEEycnJvfJXeoTlF0vyABJA9HuEPX6PsF6eqqmYHi1JEjtLm6hvcTNixAhF7ggOFfbu3YvD2sLEUTmgGBC43F46/B7huOTMoCm3gXZULK7V5RFuQCvZuzzCCp6SwiM8bNgwmUsE+4GSkpKwHmG35PcIG02+e8dPL9e9KEk02Vp9HuFoCYPKoFG20xHlEe4FSo+wxWLk5JNPDkp3Op18+umnPP300zQ3N6PT6TjxxBO56aabyMzMDND98MMP2DVWTvB7hMFXKS67F7HT5xFOssR3Xe8BmvAe4cLCwi4+ERzx2LFjR7ceYcl/nXkUHmEZymcbPXiEI9g/yB7h0SP7dh+pn3fK55ky3XfS1W8FohT0TpeLNWvWkxvxCB8Q+u6C/IUgCALJ6RkMHXs0VXWN/DBvPvX19Yj7OcVXo9GQnZ3NmWeeyfHHH8+0adP429/+RmZmZpAR3NDQwE8LF7G7vJpxx80gMTk15IKLIIIIIDs7m4yMDNauXcuqVasoKysL2oJMkiSsVivbt29nwYIFzJs3jyVLlvg8F/7pPYJ/P/D6+nqWLl3Kzp07kcIspvPrQfBNUeo6CwmBNPnbYWW84tkhhVncJBIOPsiQ20MNZbx6sCFPP/MdKls1GCH5Iu15UEGuU0mSfL+K+g3UsZJOjpOhvK/kqEDM7wtGo884PvXUUzEYDBQWFnLxxReHXUFdCQmQBNU1qzjugj9WRRvBbwvyfeU7CW5r9VNN/RyT4yLt/8tA+UxTt1MAqmcjyjb6f/T8+zVwxBnCADqdnv6DChg+4TjWbNrKD/PmUVtbu9/GsE6nIzs7mxkzZjB9+nRycnICnm9RFKmvr2fuvHksXbWW4rFH039w4S8yJTqCCH6LsFgsDB48GEEQWLhwIZIkkZ+fH/TJhMvloqamhm3btrFlyxZ27txJQ0MDoigGtoI46qijiI2NJSUlhcmTJ4fs9X2kQN0phR9UdiEysPh1EG5gEC5OeR7SlgpCJU0IXQQHDAH/yyN1pFzPqrSe7qffe7vExsZy4YUXMmPGDC644AKGDRvW6zNSri/1QJpu7gc1N/XLi0g4skMQFC81Qp5bihlL6jaP4PBDee/J7aCGpHo2qp9v6jzh0tU0EfQdR6QhDGCyWCgaPY4hoyawePkqvv72O0pLy3C792+rFa1Wi8ViQfkdtNvtpqysjG++/ZZFy1YxZPQEho2dgCkyvTiCCLqFRqNh4MCBDBkyBIAJEyYEGbGCf/XfyZMnc+mll3LFFVdw3nnnMXLkSN+3MP7PG3bv3k1tbS0zZ86kuLg47GcZvx66upjAwFLyvamVU33aqruiUKgHLpFw6EI4SIF/XefKdpM9jl1TReU/H4F8LOcJtH+kLQ8qKKGsW/lcvqfkOHUa+FZDlqEe8Mnt93tDVlYW99xzDyeccEKPRrDyGg+u7q7nlu80uPYlhRdR3U4R/HYg3z89tqDiXhT8hrEyRHDo0Fu9Ku9CmU55dyuPw/FRPwnU6RHsP45YQ1gQBKJjYhk1cRIjjpnGmo1bef/Dj1i1erVvO4b99A7j/6C8ubmZNWvX8uEnn7J0zQaKx09izNGTiYnr+pbmF4Uk4Xa76WjvoK2trcfQ3t5OZ2cnVqsVu92O2+0+oHqIIIIDRVxcHMcddxx/+ctfGDt2bMgehFqtlujoaJKTk0lJSSEpKYmoqCgEQcDpdLJx40aWLFlCdnZ2IP8ReQ0rp+Aq3tR2PSF+hWdFBGER1BKKk3CDi8Bg0P/f96dmEtz+ERx6SPhm+4VUu/9X8KcH4lWEIW2rZvQ7gODfpqq39T+6u/57fVop6l8URex2eyT8hkLws8yHsE8tqWs7ODUEf/C4PXRarZFwEEESfWarXKfhalyOUz7nZCiNXiWPnvgojyVF/xbB/uGIWyxLDUmScDrslO7awdqfF+DqbGXCmNEMHz6MrMxMEhISMBqN3Rqxkn9l5paWFmpqali3YSNr1m/EEB3H6GOmkJs/BLPFN1D/pSF6Rdrb2miqKUdsqQHR9x1ld9BoNOj8q8nV19ezceNGhgwZwvnnn0909MHt5RlBBN1BkiRmz57N/Pnzuffee4mPj8fr9aLX61m4cCHfffcd55xzDlFRUXz77bdkZmZy+umnYzKZqKqq4uuvv0ar1TJr1iw++eQTtmzZwqxZs8jIyCAhIYG8vLxDOj364BbLqmPE8GL0en1IZ+X1erC2NuCyNRPn3z5JCrOIxfa9DVTX2Xr9pi+CA0NzczM6wR3YPkke6Ln9i2UJ/sWy5NWIpTADEPnM4/Rvn4R/+6SgVB+27q6nrskRso9wBH1DU1MTRp03sFiWV94+STIRk+TbPkndPgL4t0/yL5YVQ2D7JBk+Gl/7Wxud1KxpYcjggeh0v/w4ZX/g8XjZsbOEHds243Y7GDp0qJqkT9i1axfGRD0zL5we8PIBuG3Bi2Upp5zL9aVeLKumxnrYdwWJ4NBCkiQS4s0MG16AxZIYeMrJ94VHsX1SYB0PFQ8BWLF6E7W1Db/K+P73BFEUyclOZ/TIIlD1O0qoxxXh+if1uRrq+9nldvsXy8olL69/MHEEveKIN4RleNxumhvr2bVlIzs2rgG3k8LBgygYPIj09DSioqMxGY2+5coFAY/Hg8PpxNrZSX19Azt372b7rhLcksCQEWMpGjGahOTUoP1Cf2mIXpHW1hbKd22leuta3E67miQIkt97LIoi7e3t1NTUMHHiRK688kpiYkK3UPFKIm7R8//qLZFW0KDX6EKMkwgOHJIksXbtWrZs2cKZZ54ZuNYk/37dGzZs4KijjsJoNLJhwwbi4+MD3t6mpibWr1+PIAgMHDiQH374gT179hAdHY1GoyE3N5fJkyf3aXujvuLgDOHgVaOV8HrdWFsbgwzhcNhb2UJFTWugg1P+yuhrfLhfGX2JV0MZ311tdJcejh8Kup7kUMvT1/hwvwBxMSZGFfleNEh+Q9jj9tLe7gB96KrRMtRlepwOOlrr0XWzajRASXkTVbXtverfG3qrV3X8wUItr7KdlOdqdJeu5idDTRcOCXFmRhT4XiSo9xHW+fcRVson+Nu10dZCg6sZXQzowhjC+OnsLS5qNjQHpR/pKC/bQ2NDnTp6v5AxMJ1jzzy6yxCWfPsIezshVbVqtAzJbwjbbHWYzCKSCC6X11+hPtquHL7p1fI9IxC8kKDk94D5/oe/xnw0vpRw15Y8gVtN01Wi8iyUh8xfLamSxkcXLJ8yP36nqVqPcNKE6haaL5QmWLdguQ5Af0nC6fTi9QokJeVg7skQNpsxqmZuKfVv7+jE5fJ05zTugjLT/kCRLyyLcJUix6vjwkFZMf5f9aJxPUEeHh8K/Y0GA9HR3c/gCMdCrb6SJtxxCL3fLlgT2Uf4gPGbMYTxN7jTYae1uZHykt2U7thCXXUlOq1ASlIS8XGxmExGBATsDgctbW00NbXg8nhIz8ml/5BicvMHE5eQhMlsCekgfmmIXpGOjnYEZycDkqIw6Hp+IyspvruqqqpiwYIFpKenc+aZZxIVFRVMi4TVbafO0YRXOgKnnh4mWLQm0sxJ6DWh13MEBw7fnrfOgAErw+Vy4XQ6MZl8+1U6nU40Gk3g3Ov14nQ6AdDr9Vit1qDv/PV6PVFRUWENzwPFgRrClZWVVFZWkJubgy7Ms863fZJsCJu6NYQlCURJ9PdcwWVKSL7vHQMdtzywUsd3pcs5ez4PA0UP31Wu0EvPL/kdrGHSpK5vDgXU+dXyqM/lWLWeB66/VuXBcru9tHc4QR9NfHIGGsUzQGaphjto+6Qur0mQZpKEb9bbkaV/OP5BOMLaX6vxf5soSnR0OHFjJDaMISxDwrd9Ur2rCV10qEdYDckbLJ98rIQyXl0eqjzq9HD86IanmjacPJIk+vpzBc2BQKfadlE2hAPbJ/mNt4BskoTd0YLNWofZLGKxBD97lbRqHKys4XgfLM++IFy53aEn2oOVNRzvA+EpSWC3u7HZJaKiMrCYuwxhGW6FIWwwGPrMP5yMMg5EViXC8T5Ynn1BuHK7Q0+0BytrON4HyxPA4/FQsqeU/PxB9OvXT50cQS/4TRnCMiRJxOV04bDbsFk7aWlsoLW5gc72NlwOBwAGo4momFjik1NITE7FEhWNyWzB0MM06l8ah3MfYQmJFlcHZZ01iIhotZqDvNWObEiShNfrJUYXRf/oLIzaQ2dYRfDbwoEaws3NzezatQubzRb2TvF63bQ31+HqbCQh3ucRDkcXwa8Dl9tLa5sdDLEkpvYL2UdY3VYS4HbaaG+uRSfZSIg7svef/b3AK0q0tTtwYyY+OQu90Qxh20eirrOJWmc92jgBo+XAxx/h2r879ER7sIPWcLwPlqcSkgRumwdvO6SbUkmNSgo1hJGwWRvp6KzBYvESHR3ZKeO3BkkCm9WF1SYRHZ1DVFRKmH2EXbhcbsxmMyZT1z7CEfz+ICBgNBkZMqSAlJQUdXIEveA3aQgrIUkSXo8Hj8eN1+tF8i+8I2g0aLVatDo9Ot2ROVX28BvC7ZRZ96HT6zAajpwXAIcDXq8Xu9OBGQMDorMwaiOd+/9XHKgh7PV6cblceL1edRIAHreLptpSHC1VpKfFYDZFXrYcSXA43NQ1dKIxJZGeV4hW1/szwGHroGlfKXqxjfTUyDoLvwS8Xon6pk5cUjQp2YMwWUI/68Hft5e3VrPXVoEhWcAUF7nfeoMkSTjaPXgboX9ULv3iMkKee5Ik0d5eTUvLbmJjvSQkRF4A/dYgSdDa6qC9XSQ+voC4uJyQdnY4HIFZXBbLrz8DMoLDC41Gg9H/eWgE+4ffvCH8W8YvYQiXW/ehNxr+XxjCNocdk6SPGML/z3GghnBv8LidNNbsxd5SSWZaDGZzZGB+JMHu8FBX34FgSiazfzFafe/PAIe1nYaaPRjENjLSIobwLwGvV6KuoRMn0aTlDMEUFasmAb/BVtpaxR5rGfoUAXPEEO4dEtjb3HgaYWBUHrnxWWhCDGGR9vYqmpp2ERcXMYR/i5AkidZWB21tIomJRcTF5Qb1b5Ik4XA4cDgcxMbGhnw6F0EEEXSh549SI4gggggiiCCCCCKIIIIIIojgd4aIIRxBn+F0ONhXVUNVWSVVpZVUl1fRVN+I0+EMLOLlcjhp2FdPeUkZpbv2UlVWSWtzCx6PB7vNRk1FNVWlXfkb6xpwOn35I4gggggiiCCCCCKIIIIIfglEDOEI+oyaiho+euU9Xn38RV5/+iXeePplPn3jQ9YtX0NnewfWDivrV67j49fe59XHX+R/jzzPG0+9zLwv5tJU30jprlLefu51XnniBV7/7/94/Slf/k2rNuD0L3IWQQQRRBBBBBFEEEEEEURwuBExhCPoM1oam/n5h0Ws+GkpdVW1lJeU8fX7s3nrmVfZvHYTOzZv483/vsL8L7/H6XBiNBqo31fH5jUbaKxrpL6mloXfzmf1ohU01zdRurOEz974iE9ee5+GfQ1IYsQrHEEEEUQQQQQRRBBBBBEcfkQWy/oV8VtbLGvNkpXcddWtxCfGc/Wd/8brFXnnudepKqvi9PP/RHxiPC88+F9S0tM476qLyMrNxuvx4HQ46T9kINs3bOWeq28jp38/Lr35Ssp2lfLei2+RXzSIf993MwMGD0SjPbB3M5HFsiKQcaCLZclbcHm93rBT9T1uF037SrG3VpKRGovZ3Pf7NYLDD4fDQ12Db7GsjLwitLreF1dy2jpo3LcXvdhOempkQZlfAl6vRH1jJ04pmrScwRi7WzUaifLWGvZYyzEkE1k1uo9wtLnxNAoMiOpHv/jMoG11fJBob6+iudm3anR8fGSxrN8i5FWjExIKiYvLCdmAS7lqdGSxrN83BEFAo9EcsTvkHOmIGMK/In6rhnB0TDT/uPFyRFHik9c/oKG2nnP+cS5JKcm8+PAzNOyrI2/QAPKLBjN4aAFDRw8jb8hA1ixZyd1X3YolysKk4ydTW7WPXVt2MPmkaVx83WWkZaYdsIwRQzgCGQdqCNtsNhobG3E6neokALweFy0N1Tjb9pGSHIXJ2Pf7NYLDD6fTQ1OzDYzxpGTl98EQlnA6bLTWV6ITO0hOsoSYDBEcenhFieYWG07JQlJGf4ym8IN0SZKo7qij0l6DPgGMMcr7TW6p0BdWhwZq/oL/WPkbLl2GOr039Ja/t/SuU2enB0+LQI45k8yY1JDnniRJdHbW0t5eRlSUSGysEUHwbcmj/pWhju9ruppOpoWu+O7O1eipPDlOplOnq3+VUJenpjuY9J7KU+dXn6sRzEeio8NFR4dIXNxAoqPV22RJOJ0uXC4XUVEWzGbfXt1dCKYNRjcC9AqZj5q3ml9vdN0dh4OaFv+5HN/drxJHqv7h6NToyqfX60lNTY289DgAHJAh7LJ14mxvVZNHsB+wJKUiaHS/SUO4s62dQUMLEL0irc0tFI4s5rwrLyI2Lo55X8zh53mLaG5sxm6z4/V4GHXUWM6/6mL2VdZw7zW3IwgCxaOH4bDZ2VdZQ//BAzn/X5cw5uix6PS9DV7DI2IIRyDjQA3hmpoaSkp2Ex0djUajoPX3R16vh87WelzWJuLjzBgM2vD9HGH6XWVfq+zvlOdyXDh+dNNfq8tR0oVL70keGeHy7086fSxPyUdGd/xQ8SCUv8vtpb3dAfpoElKz0Wh7fp5KErhddjpb6tFKNuLj/J6x3vTrLZ1fR/+wfNXpPckjI1z+/Umn5/JESaK9w4FbNBGXnIHeqB6k+yAh0WBtpt7ZiDYG9Jau9lRXmTKuO5GU6E19dVXSDf+QshS6KvP2BEH+Jyn4KQoIx6d7/SVcNhGxA1KNySRbEkKee5IkYbc309m5D4tZJCpa1edK9GydyRae+lhdW5IUoofKVvOTdpNfjlPUZyC7Mo+6EdTn4RBOHkXaka6/BNhsbmw2kaiobKIsSSHKuFwuPB4PJpMJo8HYe50cAggqLfoKAQFJkVOexaCM+y3g19JfFEVaWtooKioiOztbnRxBLzggQ7ijrpq2yr1EWSy/yM31e4IkSlhtNtKKRqEzRf0mDWGb1cbICaNJTU8lNz+PMZPGk9O/H9YOK00NjbidbvZV1bBu+Rp+/GouMXGxXHzdP9Hr9Tx4/d30HzyAGx68lc72Dj5+7QN2bt7Gaeedxd8uvxBLVLAefUXEEI5AxoEawhUVFezbV01RUQG6ICPK1xmJXi+dbQ24rc3ExZrRG7RISP5HoJp3YJQTpmsMOxpSxKmhpgnHW32spguH7uSSwvAIn74/+nflOjD9JcXwwIdgnd1uL+0dDgR9NHHJmWg0/jZUs/ZnkZDwuBx0tjaglezExcpTRPuuf/fyh8p4uPUP5aU+D0ZX28noSb/e0tVlhMol5xIl6Ohw4JFMxCSmozeYwrKWJIkmWwsNziY0MQJ6szZYf0HpblPpLxDeiJEhhdE/yPhR6yeXJ8f5ypAkPw91Gcqy/ccBrgE+cqyybEXRMiR5OKxq/270d9tFvJ2QYkgiyRIf+tyTJOz2FqzWWsxmEYtF31Vn/vRuZZT1D6qrvujfJV+3vOVTJSu5PFBd/6o2DvD3Z5bT1HLJULe/snxZv3AyHjH6+wxhu13CEpWJxZwYktHt8eB2uzGbTBgMRkWaTNHFsWco61g+70s+NfYjn7KokF5GyWc/eKpwROuP8pLpXX+328XGjVvI6z+AvLy8Lh4R9AkHbAh7mmqZNvWYyHTp/URHRyc/LVpK8pARv1lDOD4xnmvuvoEBBfmYzCZMFjOdbR0snb+Yreu3UDCskPjkBMp27uWrD2YTFRPNJdf/E6fdyf3/vpOMnEwu+NcltDW38f3n39Lc0MQ5/ziXMy74MybzgX2vFDGEI5Bx4IZwOXV1dYwYXux7Hvrp5VxeryfIEDYYwj/7QrpNSQpbtro7C4JiEKfMqeQdUk6YtHDncpyMHuXoIS1UIx9C5Oqr/sqB6wHo73J76Wj3GcKxyZkBj3BP+rudDjpa69FJduLiTCF0qGUME6+GWq4D0l+BvuofLi3cuRwnI0QOFbpLC5XUhxC5VPqLos8j7JFMxCb5DOFw+vsM4VYaXE3oYkBv1obVUS2fWl/1uRwn45fWX0ZIuYei/SXw2L14OiHFkEiSJQGNIATL7jeEbbY6TH5DWK1jt/xVceEQku8g9Ffn6ot8yrRw53KcjBA5euGvjAuHkHyHQX8ksNnd2O0iUZZMzJYuQ1iW3e1243G7MZlMGIzBhvBvXf+e5FOmhTuX42SEyNELf2VcOITk+wX0d7pcrF2znn65eRFD+AAepwf1AABv30lEQVRwYCsT+aHVagNBcnWyr7Kc0tIy6lutCBpfvEbwUF9VSmmpP5SV0+bw+vIJIq31VZSVllFT344oaAL8BK+D2qpySssqael0oVGUpQxBdFYlnQaPvZ2qijLKyitpsXsCaYLkpqm2irLSUir3NeKWBH8egc66ii5ZS0upaLZ3W/aBht8qjGYTGTmZZPbLIjk9lcSUJKJjY9DpdD69BIE9O3bz6Rsf8trjLzHvq7nEJyVw3KypDBlWSHRcDJn9snDY7Hz48rt898lXiB4vR009hrGTJmAwHNi06AgiOFQIDBnDGGFCmA5U3cGioAukKwf3KroQBDwcYfj0gHDpyvzKc3qQQ6aR48KlycfhyqQXubsrNxx64qNGIF3BVK2rUn4J3wDFFy97l4Jp5DzK477oTw9y91l/v6exOz5qhEvvTX8Z3enYU9r+6K8cBCpl6RGSFDQmVNwWYREuWa3r/uofri4Olf4yjTouAFX794YAjd/Z6Mvr83d1nfvL9Bfcdf13QVlmgF6VJqMnuWQe+6u/HKcsK1y6GjKNWl45TebXG0+Zpif9w/FQQsnjl9JfhlpeJfrCUym7kl5JF46HEkoev5T+Mk04eZW69MZTKbuSXkkXjocSSh6/lP70IE8EveOgPMLHzzgOrVaLp72cV594iK9W7SM2Wo+NeM676Q5OH5NLR+WPXH7q5ewxp2LWayA6lb/c8AiXT+3H7kWfcM8Tb9OuNeJxx3L2v2/lL9MLMbibmf3Mw7w6bzNGsx5N0nhuuftfjMmJDb4QXE18/szDvPbDFoyWYDpn405eeeBh5pW3o3NY0fUfxy233syoNC0rv36JR15dgM5iwtHp5Ki/XcOVf5pKnLGRp84+g1d3eUiK8XkU+592I6/86w8YdAf1ziCAjo5O5i9Y/Jv0CDfWNbJh+RqMZhPDx48iNj42wFMURdqaWynZvpvqskrsNjtRMVHkDMglb9AAYuNiaaitY/3ytTgdTgRBg9FkJDk9mZwBuSQmJ6E/CEM44hGOQMbBeYRrGTF8aGD1RblDxO8RtrY24LIFe4Ql8A/cu+ev5COfq9F97vAI1/nLCJemjgsngxIC3b/NVmJ/9e+u3O5zh4daH3lqNLpo4lJ8U6N71F8KnhodG6uYotuD/mHbMgydEr+E/kqES1PHdSeHDCGMroSJ21/91R5hncE3C0idW0KiydpKvasJbQwYzMEvkdX6KBEuTR33a+nfXbnd5w4PtT5ynNvuxdvh8wgrvxGWZZCQsNt8U6MtFgmz3yPcld7FV62rko/ynDB0Sqh5y1CXtz/oKV+4tHByq/VWy6POo8ynPCcMnRJq3jLU5fUVkgQ2mwu7XSIqKhOLwiOMn2c4j7BabrXeannUuirzKc8JQ6eEmrcMdXn7g57yhUsLJ7dab7U86jzKfMpzwtApoeYtQ13e/kCZz+VysSbiET5gHALrzs22H95l9hYzNz72DM8++zgXjIY3nvqAfS431soSnHnH8+iLb/P222/z9otPcfb4HBytpbz+4nsMOvXfvPDSS9zwlyLe+99rbKuzUr3mC95aUM8/7n+G5566n4mG9TzzznzsHlFRrkT16i94e0EDlz74LM89dZ+f7kfsHhfLP36eRR39uf3RZ3nxf49ztKWG+ctLaKhew4uv/MSUv9/G8y++wL3/Po1lr/yPJXsaEVuq2N0Ry5UPvuqT9e23eeD8KYfMCP6tIzE5gUkzJzP+uInExMUEdfwajYb4pARGThjNzDNO4pS/ns7xp85i6JjhJCQloNVpSclIY8pJM5h5xknMPH0WU06axojxo0nNSDsoIziCCA4pBKHLixvGFSVf9ZKyM+phECwjlFMoZC+NzFs+7w3qfPTQWXfHsXcNuhCQz3/eF/1l9ESp1iOc/qEx4el61V8Q/DE+j3BPcqlxMPr3hBD91QS9IEgmVbwc1x3PsBqEqVfCyHdA+ofJIvOT/EXLX8f2FT3pL7f2fnHsg/7CgeofBkH6q9LCIaRUf0afrl2pspyBEwiZqRLCqweE6K8m6AYynfwbEEWl84Hq351MSv2UfJXlqXn1hCNCf6HroSVfpsp8apnUZSqPey1LhSNC/zDldieTHCcfK+PVcX3BkaZ/N4+pCPqIg7fwvF50SYO44LLzObaoHynpuYweW4Snro4OCerLSpESUyhfP5+v5iyizmUgNkpPe9VGNnakcsKMo8hOz2DCjD+Sa9vJlooqNi5diTR0KjNGDiSz/1DOOHUC9avXsM/l7SpXtLFp6UqkYdOYMWIAmf2HccapE2hYvYZ9HXtYuHgPx5w0hX3Lvuajb9Yy4aK7uPLkoegxc9zZF3LmtNGkJqcwZMRY0mmhsdOOrbacKm8Gus7NfPPlt2wobyc+LrIUuQyNVovJYsZoNqHRhF46giCgN+ixRFmIionGHGVBr1gFWqvVYo4yY4myYI6yYLKY0Rv0h2wQEUEEhwSSFOhZlNem4F/AU9l5qTtBSZKoqWth47YKNijCpm0VbNxWzoZt5Wz0n2/aXoHT6Q7i4exo5NuP3+KZF3zhvy+8w4tvfMnSHXV45DLCdMCynEqZwskqHyuhTgvH19pUwewfVtBs80mhpFPykwIL+/jP/b+CP02GOn+Ah1oPv1de3c93p7+M7tpKPg5G18qsanmUfGXdlDRKWiVN4Nz/Kyj0D5c3wEOtv6odUZyry6aHfGHL6iYt6Hx/9Q8jK7I8Ydpfea6EgNJOC17U6kD1V9IoocyjDNA3/ZXoi/7h8qv5KNPC8ZTlUENQMQ6nvxpqPbqTqyf5AzRhZMVPp8wv/6rLVR7L5+F4dqt/N/nUvJUIJ4dSRhlHkv4yTVBCGJ7K+HDHAJIo0trSQsnu3WzYsIH169ezc+cumpqb8Xp8z3un00VlZSU7d+6itaUFSRRBkmhubmZ3SQkVlZW0tbVRWVnJtm3bQ8KOHTuoqqrG4XD46sK/+GTtvn3s3LGTiopK7HZ7V7/bi/5SGD3oIV9P+st55Hj1sYwjqf3V+gfu+wgOCKHWzP5Ca6Jo6p/56/Gj0GkEXK3lfDNnGQkTR5Gl91K6fQO7d21m775WarfM495rr+HbjXU42poxxCaRFBsNgN4UT5LFRlVVI43NLeTk5GDQaAAN8amZCO0V1LYrPMJeN80taroM6Kigdm8Va0v38Nmbr7OspJH6bQt48MZbWLi7lfjcsVxywRlkxxmQPHbW/fglJfH5FGbEU1e2m5p9W9iwuRxrSxmv3HUND7+9CLtXeRlGEEEEv3fIA2BlJyQJoQNyJY18XlHdxMoNe9lWUh8IW0vq2VbSwLaSBrbsrmPTjhpWrt+Dw+kOyutsqeHD/73EN6t2U1ZRQ3llJWsWz+WO2x/ni02NiOrOWXGsjJPjg2gVhoi6Iw3Eq14t+84kOmp38e5nP9Jil83xYBplmXIc3ZRBGNre6LuLD6c/3fBT6+8bdPlrIjDqCKd/F8LJcbD6K8+7o+8uXs1HjgvHT61/dzyVCOIvhF9jNUh/Vf0F0as8kErScPL6IgXo+nI/BOHi+6p/X6CkEw6x/kqEk1eGrwZC4wjHJ0iY7vX3RQSfhoNafzWUxUk9yOk7Ofz6y3Hh+Mn6K2VV81XjSNUfhT4Es/bxUr6QEwTfSxyF/jJEr5eKiko++3w299xzP9ddfyPXXXcDd911N++//wF795bicrloaKjnnXfe566772Xp0uW+adceD0sW/8yjjz7Om2++zZq163j77fe4/Y67uPW2O/jPrbfzn1tv57bb7+Suu+7lww8/pqZmX6DcvXtLef31N7n9jrt44823qCivCL1Gu9H/YNtfhpqvGkG0h7H9Zajzy3Hq+LD6d8c0gl5x8IawAu62Cl578n6+rR7Cv/9+MrE6kewJ53HvAw9yy43Xce+Tz3B2oYv3PviBJocXjU4X2K9TEECj8eJ2efF6RQz6rm88BY0GcOF/OeWDJIWnk1x4HC5avXqKp/+NW2+7mbsff4JT8+18PHsJ7X6nsuSxsfLrF3jg7R2ce+U1jMyKwpwxgqv+cz/33HIdN9x+Lw9dMYVl77/DthZ3V7kRRBDB7x7qjtTXyXV1R3LnJHd+geDv7JKTkjjzjDPChtGjpqPRDAzwkiF3plp9Emde8k8eue8GHrnvZp77712cnNzC9/M20+kFV3sDP33zJc++8C4fzl1Lo82LvaWar75aSGWHC0GSKN+wmLfmrqPdKSJJTtYuXsCaig5Er5Pda3/m1Zff5aX3f2B7TQcg0dlYzuy5S/h53re8+NocdjXasDeV8/WHn/D8m9+ybZ81IKQkidSXbuODt9/nuVc/Y8GmKlxeL3VbV/D1kl24ANHeyo/fzGbetnoAbM1VfPXDckrLS5g9dzlb1i7ntZff5dWPF7Cnyd41mAhjrCjbQFnfyjQ5PRCpSAjkU7zc8NEpWjHAONgDLbexnF+Zhkoeuf0DXNVGkWL1XqXc8nk43nKafK4sT5nWXXpQvFp/FW8ZSjmC9O9GxoDu/jICPNX6q/gqheyOd7h0pX5h9ewuXqW/kk5drpJGeR5ORpmP4C8jwLM3/cOkqXkrEdBDFS9DQq28j0Mgn2ogH2I8KY6VcirP1TLKNMpiD6f+hMkrI6CniiYQH8aQkaEuV1mW8lwto0zza+iv1EdSzIAR/GmBVMm3GnEQvf+3paWFjz/+hOeee4FNm7eQmJhIeno6u3eX8MILL/H+Bx9SXVNDZ6eVzVs2s3jxYqqqqhBFEVEUqaysZMWKVWzetJn2tjZE0Yvo9VJfX8+aNWtYvXo1jQ0NiF4v4PuOXpIk6urr+eTTz/jss9ksXryETZs20d7evl/6qxGkf7h4lf5qGuWxsizlufJYhlxeoF38v/vT/oThrS6np7wRHBy011577d0WiyXsVFe3x0tzpwOnCAajMUDjsnYg2jsZOCDXHyfRXrmBFx+/h5/qB3Lr3dcwoX8iGtGLYIojPz+POLMejc6Mt24Zn292cOzwFH5cvJepJ84gLVqHx9bE3Nk/kH3cLOL3rWa1I49TJxWg0wi07V3BV0s7OelvJ5Jh8i+YIbrYtex71jj7c8qkIQo6K384azSbf1zG0NP/zrTBiWh0Fjr2zuOnslhOnDEOk6uJue88yiMf7eaMq2/ivOOLMQkCos5ExoDBZMSZ0Wj1xGpa+PT7hRRNO5vBSX1fyKonuFwu9paWY0lOR6Mz4HK50OIlPT4anTa0DbpDW1sbu3fvxmw2U1BQEDQFWYbD66TN3YlWp0Wn9S3+0x0kScJtd+F1e4/ooNFpw+ohSb5983RoSTDEotP8MqtzW6021q7bRGVlDZVVkXCgoaW1jbS0FHX1HhBKSkqYO3cu7e3tFBYWcsIJJ2CxWMJeN0q0tbVhtVpJT09Do9GEdjiSiNNpQ3LbMRr1aLVhaICqfc102DwUFRWh0WiCgssl8vzz63j//Y2MHqOjaFAWJpMhwMfZWsvcbxbQb9ppjM+NQ6sVkNx2Ni5fQI25gKlDdLz59HN8vr6FrCQjy+Z+x4JdLkYNiuKD599CKphIUbLEl/+9i1u/auaPJ04gwVbCk49+TOzYY2hb+hH3v7Ucc3wC9qqtfDVvLSlDRxPVvJF7bniMbVYLqWkpZKVIvPPMc3y73U1GgotlS9awxR7Fn06YiLPkZ25/5EMqXBYsjhpmf/AVLQmDyXNv4aG3NjPh+Ino6rbw0J338KO1gLOOy6V06Tf877sKRuZJPHnPU2yqcmOON7Fp/lfMLROYOq4Ai95XC3I7KetWOSiQBxTquhdFCafLAxoDJksMgqoNQ44lCdHrxeWwoRHcmAy6ICI1/5D8YWhCoLjmhG50CuKhWHSpO97d6a/mL8d1d6zkoc4XLk6dXx0XFipdBJ+KOF0eREmHwRIdvGe3atEpu9uB1WtHYwCN3tc/qmWXIXQT193xr6W/jANtfxlCNzKJHgnJBVFaCxa9KUgGyX/gcTtwua3o9BIGvbw/czDUceHKUtOEtMt+6t/dsTJOmU9Nr86jTpflUx6r6WSo49S81HH8gvpLSHg8XtxuMBhi0BvMgVXC8dN4/caqTqdDq/MtHKjU3+vxsHLVat59933Kyys455w/86+rr+KEWTMBgQ0bNlBWVs7gwYOIj4/jxx9/oqRkD5OnTGbUqJFoBIFVq1azcuVKkpKSOP74Gcw8YSbTZ0wjLi6OnTt3YTabufqqK7jsskuZMGECycnJdHR08O033zFv3nzcbjcOh5OUlBQmTTqG7KysHq9/WQf5WF1f6jzq9N9L+8vHMo3X66VmXy1xcfHEx8crckTQF/Td8uoBjoatPH7Pf1ilPY4H77+OowYmoREAVw2v3no1T3y6FqcIeNrYsLacjJwhZA8YQoKjml37WhCBjtqt7HHEMig3kyGFA2neupEGhwdEBzs2bIb+BWSbFeLqzQwuHEjT1o00OrwgOti+YTNC/yFkZQ9kTJaR3Vt3YPX4yt29s5mE9CyMtDP3tdv576IO/nXvg1w4cygmDeDtZNlb93Hlf/5Hvd0Dkoc9W7fgNA0hL+XQGMFHMlxWJ+XLdlK2dMcRG8qX7sDV4VCL/qvC6/XS3NJKTEw0ycmJkXAAAQHa2zvUVfsrwdfNyB1OSMfZ9TlpIF0+V8aFgyTB2rW1fPbZTux23ywT+c19oBxBQBI7Wfjl5zz9/Fs8/dybPPjA47y9wcj044qp37SI73ZFcdPt13D1lRfx0M1nY189n/WtBkbnGVm/ow6vtYqdO7XkeK2UNFip27mJctNghic18Onnqxh20ln85fTp/PmvZ1Lg3cMn32/CLoJOn8WZl17MVRfMxFi1geXVGdxx99Vc+8+LOP/4wUgOwNXKdx9/jafgJB6+81JuvOUabjqrgO8//wln3lDS7KVsreigoaIMUczEuWsPNXYPO7bsIKVoJAkWLVoxkRP/fjHXX3EB/7nqFJrXb6Gu0/ftmKDwuqrrV9kOSgTVuSpRmVc+l4/lAZfyq15JvW2R4hz5VzXFUllkkLwK77CcXwl1fE/6y3L3pL9aDuVvWP3lOKUXPsy2PYdC/+7QF/0BJP/s9d+T/uq07vSXg5pehlyeJP8LCNR1ZYfL59MlWP9AvFKPHvRX/soI5DsA/Qmjtxy64xNODrVM4fIGyvsN6u87DuaslqO7cmWIosiuXbuprKwiOzuLCePHMWhQPv1ycph83LHk5eVRUV5BeVk5DkfXuEtdP75IAZ1eT1JSEpmZmSQmJqLX69Hr9SQlJ/vjEnC7Xfy8dCk/zJtHfv5AJk8+joSE+K7JOWH0Dqe/ErIcSnn6UhcBPX6D7a+EnB7BgePgPcKinXmvPcgj726k/5Bs6ratYfHixazd3EbeuJGkeMt57ZVPqWppZcO8j5i7ReD8ay5jbF4y3srlvPPpAlpaKvn07c/RFZ/KeaccRXZ6DJvmfMZ360up3LKId7/cxQkXXsKUIWlU/fwal72wgBGjxpPfL46Ncz5ljoJu5oWXMKVwAAnGVj568W221jWxc9Fs5m6Bc6++hKSqOVxz/YuI6QMwte5h6ZLFLF68g6jBQxjaL4rFX3zE4m211O5cyuvvLWbcX67g1Al56Lq7CvcTR6pH2Ovy0FrRyJDBg8nLzSUzI+OICvFxcTQ2NhKbnYjOGKrrr+URdjpdVFbVMHbMCHL7ZZOWlhIJ+xmsVjudnVb69ctSV+8B4eA8wp2kp6ehlZ+HCg+NJIm4nTbEMB5h5W+13yNcUFDgz+fj4XZ7ee65tSxaVMH06Vnk9HNRPDgbo8H3ok0QBJxtdXz7xZfUa1Mwik7aOh1EZxdx0YVnMXNkBpUrf2SFpz8XnDSaaL2GKIOWdcu/p73fdCanNPLF6k7G5Nj4bm80Mwrs1OmyEHauYF/6UZyR3cJDr8+hqrKKFUuX8+PiNZTsayEqcwBj+xn4aWU1x585ndwYHXuW/8hKzwDOnzWSKKMOg2BjxdZKZowbwqIffyZnxulMGxSPVqsnjmbem7uK0TNOQ7/zR3YK/Ylq3Ex9xnCSGnaTUNSf9XN+ZvBJp1NoqOW7ZXWcdM5McuNMONuq+eHHXYw76Tiy/VvWyQOE7gYK6mP5vCePsPoXf7uIXi9uhxWN5MFkDP+MDBcXNK+0G/5hcoWFJE9dVMQdiP59iVenByAP2tS6drctkCIunFxhcgQgSeByeRAFHQZzNBqNbw/6cHxsbgc2rx2tAbR+j7AyXT4OV264+G7l+gX1V0PZ/urBt5q3Ml0ZL/8KAnjdEqLCI6yUX8DHxOPxeYT1egm9XtNt/Xerh5qn6rjbfGEgPx/x6yfrLQcUv8p0GWqanuLVNAH8xvQHAbdHxOOWfB5hvc8jrIQ8fVmn0wW2R1VSuD0eli5dyvLlK8nIyGDG8TPIze2HRqPBbrezdOlSSkr2MG7sGHL65bB8+UrKysqY6vcICxoNq9esZfXqtaSmpnDspGPIysxElCR27drNsmXLEUWRqVOnkD9wIBKwecsW3njjTdra2pk6ZTIer4dNmzZjNBoZOrSY7JxsjAbfDKme9FfqIQTVS8/xahoZ6ntcXW4IfuX2V5fp9XrZF/EIHzD6bnl1A9HjRp8xmDP+/AcyDR6sVitWqxW3R0SjMTD2zGt4/JYzMbTXYIsdzi1PPMxJxSloTUmcdd19XH7qCOor6yk66VLuu/HPJJs0GNLH8p8Hb+WoVA9NthguvusBLp5RiEYAfVwWwwblEWXQYMgYx60P3sZEP90lATqBwpl/57+PXEGG1EqLaTDXPXw/s4qS8WgsHPvnc5iYF4/NL6vV6kLyCCQWzuKBh25maGwn1S1a/nLb41x39kSM+3NV/8YRExNDXFzcERdiYmLUoh65cHeyaeGXPPffJ/nf218GvoEEkcay9bz38nM8/d8X+PrnrdjcvgXgHK0VfPHqUzzxxBO+8MKrLN/bomIMeF3sXTefl5/9Ly+99SUlDf5vNwMQadm7ki9X7kKUR02SnXVfv8GTMu8nnuSdRTt86aKHup0reet/z/D0c6/x8459yGuzu9prmPfJmzz9xFO88ck89nW4fOwkO2uV/J708VO9WP2NoqtDQtFBKlULpMmdmD9ODkrU1HTy6ac7aWtzsmNHE99/v5eEBBOnnDII5I7N//2WnF+rT+IM/zfCj97zb26+7Eymju6PSedzi3k9HkTR5+3xiiJeUYtBp6f/8GEYqzYzZ9E2YkaMYOqodDatWcvSXXbGj8tHI2iIycjjirvu462XH+XtVx7js8/f4r/XnEiCbytXXwcvgEYDktcduIYkSUISfekaQcTr9Qb093o9COgxGqMYMTKP0g2r2bCzgqKjjqE4z83SH35ihyuHcYOTusoIU1fh6g9Fxy+nKwcF8nkgn4JB4LHtXzhGkvUIEMgUXe5GdfnqAZIcJ8tEmPYXAEHpZVRmVsQF6BVGkJxfib7oL9PJ8crz7vSX45SDOrWsfdEfBa9w8qt5KuOEXvX3xUr+tlGmB+T3Q61/AEeo/gH6MEawEnJZ6vSA/ArIl52Sh6yz5D9WQqBn/cMhSH8/lLKo5Q/HU62/HBcOSn2VCKe/HB903kP7w29X/6AON/xhUJxafwGB6OhozGYT7e0ddHR0IIoikiTR0tJCZ6cVvV5HVFQUFrMFrdbnXHB7PHhFESRwu1x4vV60Wm3AUabWX5bT43bz88/LWLVqDfX19fzwwzzmzp1HXV09e/bsZc6cuezdW6rO3a3+3dW5kk5Q6KzWP0CnWLtBXUY4HCntrywTgi+HCPYPB20Ia0zxzDj7Wh57/DEefvjhQLj52tNI02nQGuMYf9K53HbPvdx2/T84qiADeVteXXQ6J513Nffefw9XnDeL7Dijv9EFUgaO5Z833cXdd9zA6ZOLiTb4MqUPn8Wtfz+LzFh9CN1pCjpBZ6Hg2FO54Y67uevmKzluWDY6DeSOPY2HHnmURx7pkvXhh69mXG4igqAlZ+hkrrntHu6540bOmDKMWOMv41k8kiD5Vxg80sJvAZK7nR9efZD7nvmEBpeHHfPf4rp7nqW01Unz9nn855b7mbe1AWdbJW/e/S+e+mwVbkmicc8S/vffD9i4Yy/l5eWUV1TT2ukzPLsgsnvxO9xy89NsrWlm56J3uPXWZylp902zlbxOKjbM594bL+fh2esCdeZ1VvLRf19k7qpdft4V1DZ1ICBRvvITbvn3vawsa8FWuZpHb7+Rb7c042or4+UHb+H52avw4GXFp89ww32vUtXpQXRU8NHTLzB3tZ9feQW1zUfK1OaDRdfWSf4zX2cjx6kuQ9mADQe73cP99y/lhht+5IMPtvHxx9upqengpJMGMmy473toQcVS7mC1Oh0GvR69Xodeq/GN1QQN6QPzEXZsYMX2Kjo72tm6YS0l9QkMzYvGlDGI4ugyPviyhOL8XPrnD6Zh2WJ+csQyun8s+vQBjIt2s2DeapodXuxttXzy4vO8PrcER2BBfgkEDRmDBiPs3MCKndW0tTay8udlbKoDLLGMGpTO2vnL2dvUQXtLLQsWrCcmdSh5qVryhhbj3DmXddtNDMvPpjAvlW8/noNryCgGxSm6dP9ep2qEi1Oit/SeCAR/ewVIJLl1u1aaUWcPUIS7Jnpof3WbhkA15VqG+lyN7tLVMoSjC9FfER/uGKX+qjgZ3eqvqC81z54QRBsmY5goOEj9lVCnHQ79JXpv/3A86YY+SL5wTBXRQYZ9mELUWXvVPwwbNX0IT8n3jA0n6kHr300VKPVXpymhTjui9fe/tFQnCBDWKlLrr9EIDB40iOzsbKqqqlixfAXbtm1n585d/LRwEWVlZeTk5NC/fx5paanEx8eh0Qjs3r2bbVu3sXv3LkpLS7HZrCQnJxEdE+OTSQ1FXHx8HEOGDCYuLp6W1laam1twOp04nU7a29tw2O3QV/0V9a+u73B0av3DQZ122Nq/BzkJw1NGOHqZVp0WQd9x0IZwBL8v9GZwtpat5usfVxFio0UAQFvNJj75cRfn3Hw/t//7Ou5+6F5OL0zB7Wxl1bef05R1Eo8/fBs33Hont5w3liWf/Eit10tL2V4sR/+ZBx73e4Xvu5WZQ1ODeIveFuZ9/CUZp17H/ffcyYOP3kV2yyI+/7kMLy52zn+Pf199Oysr3fjfBwHgra2gwjiQ6x982sf78ce49pQxILYw75PPSPjjtTx0123ceO9D/OuMYxFsndTsWsbczVpuuO8+rr32Wu6540pcy75nfXUzntoKKkyDuOHB/3bxO3lM2D7wtwch0HEHOk9/Bwq+bxV9CP7+ThlkGAxaxo/PwGp18/DDy/jww+2kpFg455wioiy+6f3K71N95+GPARA0ZI+YzCUnZ/HmE0/w7xvu47YXFzHh3D9zdG4sWkMyo4ams6fNQuGAeMxZ/RkitJGZNYScOBO6qCzOvfSPdCz/gH/feD//uu5h5taZGD+6n2+dBF8hSIKWzGHHct6Jabz28ONcc/PDvDxnF3ojoIth6p/PYrB7PTf9+17+dd1DvLddy8X/nMX/tXfegXUUd+L/7OtN76k3W5IlW25yN7jRbcCmB0i7JAcpl3JJLj/Sc5dcIJUU0hMghTTSLoQECJgauo2NMbZxt2VbkmX1/nrZ3d8fb/dp3+qp2NhG2POBtd7OfHd2ys7OfHdmvlNus1A8ZQaVzhidxXOZXmqjqn4ant4k5y+fhWNEWkekMONi7kzoGP31/M6S004k4wiiacQxI5b+umAqtWEZc/lnwjPd1xhCxt1UGVTVlFrTWlAdY/yy5A3u+l9zPHT0O2fiO1r6TfHWMfoZj0x4o8jpv1VypD9HPHUHo7sxful7pUOXTLJ6PE5G+o3xH83PeL0xfKOc/luFMdMvaf66mzH+o/02uxnjkYUpQFVLv/47Cy2Ak5n+0TBGS5LS71jdbUS8NEZzZ6z0G8jEN0f6jb/N8TenazKmP+M7ilDWBw9D/HVU7WPrwoULuPTSNRQXF/PAgw/xzdu/xTe++S3+7//uQ0LimquvYsGCBeTn57N40SJqamp49tnnuOOO7/ONb3yL5194kYKCAhYuXEhZaemI+xixOxzccP1buPNnP+aee37Oz372Y9733puorq5i3ry5vPvd76KhoSEjP1o4mMphNDLlNRnL3+A2WjpHc2e09I9wEEyU179GOMd1gtGZzGuEB4/2UllRgcMxvCWVkUT/Ae667Qv8dXeSy1ZfgD+32CkhmUzS1tZGYGrRpFsj3HK0jdraalwuB62vPMD9m4eY4uzm1z/9Keu3dHDB2/6NJTXFFFbN4bwLllNV4MGCQtO2J3nhkIerb1zJoUf/wHNHErRufZBf/f6f9DtKmFtfhcM6XGbKwD5+8+snWPRvH2bltDxsznyGdj/Cpt5qLj2/iuZXdlF4zjWsm55kd7Kad140D4sk0bXrSe59rBFLfAe/vev3bG6KMqNhNoHwHn75q0cpa6jnxT/8lF/86UnyF6/jugvnEgiUsPT8C1hQV47daiXctY9H1m9lybXXEmjfyL2PHcIS354OrzlKfcNsCt0nZlSuq7t3Eq0RDlNeXpp7mpe2RlhORnFpa4R19IYSbY1wfzDO1KlTmDLVQ1GhndJSJzNn+lm3roZLLplCMBSkqamJeTOn4nLaM/exewLMP3cZi2ZX4zVYydWR7G5mNMxj2cIZzJk3nyuuWce6lTPx2S0gWaisn8fay1eytLYEuzOPhcuWsOaCJVTkO0GyUFxVzwXnLWLerHpWXHABN1xzCbNKPbj8xSw+dwGzq0uwWyQkm5sZc+dzzvzpzFu8lBveei03XLSQ6RUFuPylrFy+kPlzp7Po3GXceMNazq0tRJLA6syjYcly1qxeTE2+C1/JVM5fcyEXLKnGbbWk73POAmZVl2C3DJ/PrinGppWPuWNhLjWzv+4mKyoJbY2wM4fVaKOsBKCqKHJq2Gq0c3yr0WY33X2scx3j86f/Mv/Vf5vPjZj9dTdjx8zobsZ4vf43V8cq17nZTXcfl6y19prVaG2NsNWatmirk7mPCpFklIgcxeLMthptvqf0Jko/hrDM8TD6md11csVD0tMvjbQaneu9l0rFSCb0NcLWU55+87X6udnd6Kf/NmO+Rj83KylmOZ1c4b9R6dd/GxnLb9hNIpVSSOprhG1uMIx2qjmsRhuvlwAkCafTSVVVFYFAgEgkQm9vH6FQ2k7Gddddyw03XE9t7TTsdjtlZWX48vKIRKL09/cTiUaprKzkLdddy5VXXkF5RTkWiwVFUejt6aWru4eS4mJWrlxOVVUVFosFp9OJ3+8nEAjg8/kIhkIMDAxQW1vLBRecT2VlRebDlR5XM6Pl5WQo/1z+5Lg2Vxwm4qe7mcOSZZn2tg4C+WKN8IkgNTU1qUVFRZnF9EbCsQSNHf0MJcGb58+sEQh2HiPV28Fll16YcRNMjGAwxFNPP0/xrIXYXF5CoSAONcHCaWW47CPLYDSam5v55z//idPpZO3atbjd7ix/FZUwcfosQZxuF06HM2eDqBMPxWjeuJ8lixfj9/vN3sjxAdbfcwcPbNlJ0L2S73/7C0w9jct2Q6EQW7dupWpFPS6/x+yNLMtEYlGscSjBj43T81yGI1H27G1k9SXnk+/3sf3PX+CSTzzADR/9JDevm8eu9b/j76/5ueMXX2NRuTdzXefux/j0Z39I/fu+zhevn86vPnYdfwpeyH9/6AqSLRv43W+eYvXnf8qH1s1EV/tT7Rv40H/czg0/+AdXz7SjKike+957+WXHGn55+/sosMmoJHn511/g9tYV/OPL78BqSbHtj//Lh+46wAc/+1/MdnZy390/J7zwP/n2O11cef3/wzHvRj794etwdmzil/c8zVW33c37Lq5BfxoTQ83cdevnedpyMXd/5SbaH7iND999iA999uPMcnRy389/TmTRR/n+l99KQNsX/HjYtXs/ra3HaJibXjd7okiShMvl4oUXXuBTn/oUR48e5YYbbuB73/sexcXFYz7/AC0tzXR2drJwwTzsdlumY62jyCnCA90kIn0E/C4cmpErvRHV5Te/2si23c2Zd6osqyjaYltJApu2NkRVFd5+9XLyTc+zsUNvjIOENmPDoDAySiOu5jDAYf5txnhf47mOHh/z9eb0m/11zGkZjRNNfzIpMxSMIdl8+IsrsWrb8oyVF6l4jNBAF1ai+PNcYJhtmCv9uZgs6TeSleZRDD6ZrzPH/1SlX1VUgsEYKVzkFZZjd+gL1LPlQKUnPEBXohdbHjjc1jMi/Ywhgykc8zUTSX8iIiOHVEodxRR50p1iY/pVVSUa7Scc6cTjVvBkZqekyZX+8eJ7stNvjoP53OxmDu9kl//Iq4d5Q9KvqkSjKSJRBa+nErenMMtYlqqqpFIpkskkLpcLp9OZ8cvIaOEqikIoFGZgcFDbC1jB7/eTX5CP1+vFpm29JMsyoXCY4NAQQ0NBJAm8Xh9+vx+fzzusbKsqsViMoaEgqqoSCPhxu90j0q+qKpFIlGAoiMViIeD349DiaU6v+dzsZs7PM778TW6JRIJXXtlGdXUNtbW1BinBRBCK8GnmZCnCra2tPPDAAxw7dowZM2aMHMW1SHiL/VTMryYv339civAIw1Rqkj1P/olfP9PLpcvs/O3pKLd983OvWxHu6enB7Xbj9aYVREVR6OnpoaSkZERcQ6EQr7766tiKcDRKX1s3XbuOkoql182eaqxWG4GCUtasvoB8v48df/kCl/6knX/+5U5WVOcRPvYqt7z/M5z7xV/xHxfWISkJmrau5/Yf/hnHgndy6yeupcQl03bwAIn8adSU+iAV4e9fey+/C17GPd/8ICVaPzHVsZEPf+CbXPu9+7luthNVSfHoHe/l192X8fNv3EyRAyDOS7/6vEERVgl2NtM06GZOfTk2SaH5qZ/yvu9s4Stffhuf/vQ3ue6Lv+O/r5mFJIf44xdvZr3jHdz55beTb1cZat3BPT/9Ic931fLlr3yaRVUegp3NNA96mFNfhk1SaHryJ7z/jq3cfu9vWV468VkNOrt272fX7t0EB3vNXseFzWajvr6ezs5OPvOZz5ygItyhKcL2rAZOAmQ5SWiwh1S4D7/fjcOR/e7TG6lgKEokmgBDpzULbZqsRZIoKfJjMX08MDZ+ozV85lBzyemYG1Zzo2qWN2PMB8aQH89fRyWdB6OVx/GmX5dJJmWCQzEku49AcSWWCSjCSU0RthEl4B+pkOlxGCv94/nrZMmdYPpz3cMoQ477j5V+csjrnKr0K4rKUDBGSnWRV1SOYzRFWFXpiQzQnejF6gOHJ/fIpTmPzEy29Kuk0zZe+ZsxxsVIlrwKqZiMHIQSR1GWImzMV10RdrtkvN7cU7smmn6difhPNP3G+2EIc7z0m/1guPzN8TOfj8d48uP565yM9KsqRKPJLEUY4z7CmiKcSCZxa4qwOX4jzlUVRUkbi7BYLJk8M8ujqiiqtsZZSht6NPrnTtUwJyP9RnLJGXk95Z8r/aPJj+evcyrSryvCNTXTmDZtmklCMB7H32sVTAry8vKYM2cOVVVVxONxQqFQ1hEOhYjFY+kvyMeBOsJIlcJA04v8fv0B1rz7XcwsdMIImRM7du7cybPPPkswGCSVSrFnzx4ef/xxZFkeITsx0i//SCQyIj9O1RHVjDvoeIormJaXR55mZM3q8OJ2QEpB+6DwKz751V8w9dIP89VbrqXEbUWN9fLqqzvpjWqNi8VJQZGHeDwybPkZwJOHhxRHu3rS52qCvp4wxeVTcI2cLZ5GjnNk96sc7A5pY+QW8gJ+UCMkvMXM8PrIC3jT+35bXPgDDpRkClAYOPIS37z1f3gptZyvf/NTLKryIclxjuzaSmOPKTwlTPx1fHuQZWVE3p7IEY/HzUGfEMYGZ/hveq1irqdRl5eAPJ+bspIA5aX5lJUEMke5fpTmU6H5mZVgHUmri+gdDu0e5oZZrxu6zFgY422MrxFVHbawqWPMB7M8pngZ42n0M4c3WidA53jSr/tL2oW6heHhwNJXmNOPKT3p2w2n35hu/e9YsTbHE9PvrHBOMP26H6OkP2eoo6TfLK/H1XyfrHhrv3NhjOdY6c/IGkbfzQy7a1eby3SU9OdkkqU/nfaxQtJkRyl/HVWT0f0l7ULjPYHcH+My8Rn2O9H0G+X1eL7e9IOWfsN1OdNvuO+oIea4l5pD3px+M6PdwxyP0dKvc9LSrw43RqPFbTRypR9JwmK1YrFaM/Ezyuj3kCQJq8WSpSwb/U9b+rW/mXiZ/DPkuFeu9OtxNd4nV/rNmOMx6dIvGBexRvg0c7LWCDscDiorK5k7dy7z588fcTTMa6C8qpKEXcZqs014jXBFeXnWNJpUqI3f/+CHdJStYs28YtoPvMLGXX3Mnjef0iIvtlE68hMhHo+zadMmBgcHicfjPPnkk0ydOpWZM2eOiGsymaS9vX3sNcJyioDHz9I5i1gwb8GIPDkVR3V1DV3dvdoaYSdWKckr//gjweL5zKnyc3jzo/ztuT6ufte12A88xBe+/Tvqr/8sH7pyIdZkjHhCxW4P84/vfp3HWv2cs6CKaMdr/P6eR6m85N1csbic/o6jDCku8nx+BnY9wbONdpYuriV8ZCO//etmFr/1JlZOC2gvQpnWV5/ixaGp6TXCliT7Hv8N3//ja8xftQRvsotH/3QvB+3Lef+7Lia6/Z88e1BiyeIZyN07+dPvn6T0orexqryXH3zpU+wMXM6XP/o2KtwqkUgSm1vi4OO/5ft/2smC85bgTnTx6B/v5aBzBe9/63K8hjXNE6WruxdZllmz+uIR+Xs8R0NDA1VVVTQ3N7+ONcLp9VGWHOtLFVUhGRteI2yxDH8NJ0dDNN75WEiGxtLc2TAywi/Hl2b9zPjXHA7GhjZHJ2gszOGb3Uc7H4sTSb+iqMTjKSRtjbCxbTKmWf8tadPdk7EIFpI4ndqMnONMv45ZfrzzsTiR9EujdPB0P3P6c5Jj6u1EMcuPdq7qa4QZXiNsRpfV9xG2OMFmz66Teh4Z0zxW+o2/c8nAyU2/mfH8jWTF15BGczowpR9VRU2pKMnhNcLksJSbSsVIZvYRHp7ZMiL8CWKWlUwdd91/tPIxI2npNl+XK36vp/zNsma5iWKWlU5C+mH4HZAr/cZ9hG3aPsKZ8CUJWVFQTfsIcwalP1eYo4Vvvi4TvsHdfG72GwuzrHSa0y/WCL8+TnhqdKyzlfoZtUivQxE6G4nF4hxsPELpnEWva2r0eKio9CeGaA63Y3c6Jjw1etHChVlTo0Odu/nN93/EawMWbBaJWN8hth+KcdEV7+a/PvtBpvsnrrybUVWVHTt28Pjjj5NIJFi0aBGrV6/OTJU2Eg6H2bZt29hTo2NRXKqdOt8UnNbc071ONkNDQV7cuCW9RjjgR02G2HDfnXz/t09jLykk2Bvhkn//DB++qo5ff+Emvn7fQeoXzNAURonK+hv4xk8+SHzTX/jS139PIlAC4UHKFl7NZz/7AeqsHXztUzdzYOEX+e1HL6F71+N8+cs/otsWIDk4RN3FN/PFT72dMrdeDuap0RKRjh185yu3s7E5SbFPJWKp4qNf+m8uayilfcd6vnbrzzhm92OLDlE8/1r++wvvp/+Jr3PtB+4kf+4cyvPSUxettjl87q5bWeFq5du3fYtNR5MUe1Uitio+9sX/4dJ5ZRN6yZvZtXs/HR2dnH/eMrPXCfHoo4++vjXCC+dhs1ozHWK0RkeRUwQHuklG+sj3u7FpU6ONDZJRHu0ZNzZmRj/dbexYjeRErjFijCejhKUaFAJGacjN6Tne9JvPJ8po6U8mZYaGYqBNjc6sEc6R5/qv9NToHmxEsqZGn670m+OVK11mJiqnY5Y3xpNRwhpN5mSkXzVMjfYXDa8RHhnP9Brhbm2NsN2drm9mufEwy4+WNiOjyZyM9OcKK9f5aIwpp0IiKiOHoFSfGm1ShFV9anS4E7dHyViwNzLR9Jvjr5NL5rSkPwdmef3cHB8jkz396FOjIwpeb441wtrgQUpbI+xw6luTnhnpn4icjln+TEx/Zo2wmBp9QpyQIhzu6WSovcUsLjgOiurmYHN5Jr0irCpJwsEwKa0WH33p99zx4CBf+PInqS/3ZfaEPlFkWWbXrl10d3ezatUqPJ6RSi5vIkUYQE1FOXqokba+MK6CcmZOr8FtSdB0cDftfbGs652eKTQsqsGpJOk+epim9j4srgLqZs6g0GMDOUHL4f1E86YxqzwPVJm+tiMcOtqN5C5kxszp5GdZa1YZ6jhCSyKfedWFGbdIfzsHGluIqQ4qamZQVepPT4dWZfo7Wjjc0onsyKOufibFXhtDHQfYdSR7za5k8TNryWwKHVYi/W0caDyaDm/aDKpKtPBOgMmlCKfXCNtsthEjQ4qcIpQxluXGblCEjY1cc9sAxzq1fZVVrdka+9aTj5MV77HCydWiT5CAz0lDfWlWEKMay9L8zbdSNWNZwYFubKqmCOtTcA2KcFNrP+3dIdPVE2Ss9E9mTB8CThgtnHy/i7nT03tnK5qxrGQORRhDfVJVld5IP92Jvqw1wrqMfo0EKLJKKiZrrmkPldxrAzXvLNJLHjR5bUqiuf6jX2fyN57rcUdPhzZ1ecTILRCPx5AVZTgtumyu+JE7DJvDhtfUHiajMqlgtiJMVp6pRCP9RCKduNwK7W0RenqGl/iY740pv/XzXL91jPK5rh3t3OynY3bPdc1o5LrGiPl6sz85rn2j049Wj3w+JzPr6/Foa4R1VG0XjVyKMKZ77d7bSG/fQLYnOTLmeDlZ4ZxuXke8y8uKqZ8xbUKXmm9zPOVvviaRSPDK1m1UVwtF+EQ4IUUYQNUW1Z+JKIpCJBwiGgmT5/fjdKWnVaaSSYYG+lFVhfyiEmQ5RTgYxOP14nCmtylIJZOEw0HsDgdutwdJyq0pShYJRVYnnSK8cMGCkcaydFSV5hfv4Rv39fPlb3z2dRvL0lE1Iw1jGV4Lh8Ns3779TaEIC46PyagI69uRZXU85CThwR4S4ZGKsJG9h7s51hmhvLzc5CM4GfT19WG3pFixuArJUEa6sSzsPgIllVgtI9+nWSN0qkoqEU9bjVajBALZRpvQwt59sIvmYwPDCpLguJAkieICD8sXTkU1KML6iLBNU4T1shzu5Kn0alajrdqIcK4OoQqEu2IcfUWznfAmofHAXnq6O8zOx0XVnCrWvOfi4XqgqiSjStaIsPG9l863YUXY7VY42DhIW1tYPN9vMiRJorDQw4L5szPGsjDUCeOIsL7czVi/dDZveY32ji5QDR+SBMePZKW6qpIli+aCIa/N7yrzb/2cUcpHd8ckp5+rmiK8VYwInzAnrAifyUQjYV57ZTO7t73CouWrmLfkXOx2Bx2tLfzrkQexWq1c/Y73EBwcYPvLG2hYdA5Ta+qw2mx0d7Tz2iubqJhaTf3c+djN1pwNKLIyKRVhn89n9s6QCHbS0p2iZtoUtG0dTwvhcJgdO3YIRfgMZHIpwtrUaG3LCGNjla0Iu7A7hvc/NTZgew/30Dsoc8455xiuFpwsDhw4QHioZ4QinNKmRkt2H/5RFGEjamb7pG6sRAho2ycZy1IF9hzs4khrv1AUThBJkigp9GYU4czUaNP2SebamR4RHt4+yWZQhDF1NMPdMVo2daMqCVOtnZxIFgcH9+/FZpNYtWqV2TuDoiij2mHZsmULqkfm8vddCnpeqCqpmJI1IjxCETZajXYrNDYOcuxYSDzfbzIkSaKoyJulCBvfW8elCLd3aHVHcKJIFifV1VMyirCOuVbp7yxjWenuY2EuO+P7TyjCr4/cb9iznGQiQdvRZl5+8Rk2PfsUocFBYtEIh/fv46VnnmT7yxtJxGIEBwfYv+s1+nt7M2bnw8EhGvftprP9GLFYlJ7ODjpaj9Le2kLHsaP09/ZkZCcj4zWGjrwyZtSdXiVYIHgjMDZQ6WN4mqXe6cjZiI1ThwSnEHPvQvupH9mo2n/6WRpzECOvE5wwxrqhGutWlnPO32N2FFXtH1V5ExzDqXI4HFRUVOQ8SktL2bdvH8lkcoRfRUUFLtfIGQy5PvYZn//s95TxRPBmx9wGmeuUufyNz4Xg5KPna653nPm3uVyMv43hjMm4AoLREOpMDlRU7HY7ef58goODNDUeoL31KIcO7KGiqgpVVVFVBUVRiEbCDPb10tfTRV93F/29PURCQVLJJMGBfl7d9CIvPPUoTz/yIP/8vz/wyobnSMSy14lONtLpm1yHQHA6kEhvWaJ3Vkc0UDkexRxOMEo9UuQkA91tHG5s5FBTK0PR5AgZVVVJxUO0HmmksVE7jjSPKqvEBjnWHUQ2ucuJCJ2tTTQ2HqKtZ4iUMvLaicrJiQjHmo8SjKdMfjJDncc41htGyRH2qTiy8jhH+28uj1wdkeHSHR5FMeoQE+18hAc6aW9vHz46OukPGrY9U1US0SDdnR20t7fT3TtAQh75ITQRHqC9o59E1n5pZx66oiaZ8ns89GLPVf4wgYI6BSjxAbY//zA//8mP+MEPf8rfnthMfzQFqPQd2cIvvvt1br/9W3zrW9/i23ffy862ia8zT6VSPPbYY9x6663cdddd9PX1mUVyor+6jNmR6/nXPUa4mQj2p59b/ejo6iEcT2XyPRUP09UzROqE2miZwd5eYqmR9SEVD9M1EM7ePnBcZAb7+0jKx3XRGYeKqXKNWCNu8Mr1XAheN4lEgkOHDnGkqYmY1t9XVZWuzi52795DX38/iqLQ1tZOd3c3yWR670lZlmlra6O7u4dkMjWizTq7n+xTh1CER0GyWCitqGTqtFpe3fQiB3a/RnBwgOmzGrKmO4eGhti5dTMvPvUYzz+5nq0bn6ensxNFUXA4nZRPqaKiqgaAliONxGKxSf0wmzsak4XJGi/BmYWKlDZ6YzJ8A2mDOsMdh7RSpp/rz6feCcn1vKqqQuuOR/mfT32K//3K1/nyZ27hKz+6l+ahlElSoXPvE9zy9rfy4Y/+F5/4xCf4xJdu58k9udZAKrRu/j/u+OuLGCe2qakwLz/0Kz79yc/wta/dyic//TUefaWFpKnPqabCvPzgr/j0LZrcZ77Go1vNciqxngP86Asf5p7nGrPyRI508Ifvfo4f/nPHcXZaTxw9b82d/czttULROw6ZQ83eI9hYltr/mTAy5aqHmQMlGWPDfd/mttvv4Gd33c3dd9/NnT/5ET/8ya946VAXKiqhrkYe+t1d/PDHP+Huu3/GD77/Y+59eDO90eEyV+UE25/6DV/92vfZ3NSfdY8zlXR5ZOe57p7xN7jr5akbjNLLUPN6A0hy+KX1PLSxlbnnX8a6ixcx8OqjPLrpMElVpr+jmT4qOf+i1axevZrVKxZTkTex5TqqqrJz505+8Ytf0NHRwWOPPcaDDz6Y6VCbyXpWsx7s4ecdLVxjno73fMvxEM/84et89dvf58677uauu+/mB9+7g7t/fR8HOoYAhb7Dm7nnnr/THjn+TeSTkQ4e+vUveH5/N9mvJYW+Qy/xm/ufIBQ3vxtHJxnp4ME//Y5tR4fMXmc+OeqSmVzlzzjXCI6XdNvf39/Pb3/zO378459x4MBBZFkmGo3yyCPrue22r/Ly5peJxWI8/PAjPPPscwSDaeOasXicxx57nGeffZahocHc/Qjtr15/M+U4UlQwQYQiPAb+/AJqps+ktekQu7ZtYdqMmeQXFGat2VEVhUQ8TiwaIRYJpy1ByilQVby+PGY2zKeyqoZUKklNXT1LVpyHM8eUpsmEPvIymQ6B4HSSq1OhSiO7EfqzKeWwTmt+huVYGw/85i/Yl7yH2+/4Lt/86v/Duv1h/vLUPuJGWUWhr/UIzgVv4ds/upM777yTO2//EpfOKRoRppoKsuPlI8yom4Yz467Q37yVe//8Ahe9/3/4zre+wdsXpvjdH/5BT8g4qqzQ1/wK9/7lRS7+gCa3IMXv7n3AJAeu4mmcv7SGl59+mYGU8fpdbG2xcsmymVi0jwOn+jBi7MxnFCI1/dHCKGP8nVU+aVvBmkO2rLn8c6HKEjOWXM6HPvpxPv7xj/Hxj3+QC6Ymee6xzfTFk+ze8Aj7lWre9cGP8bGPfZwPvO0iQjsfYcP+rkwYqWALuxqHmFnr4dUt+4hO5MZnCMb8huzenFbDDL9HMpr7KScVo3sgwazzL+O8xXOZs2gl5y2eSsu+ZiKKQn93P4UzZjK9tprqaTOY3zCX4gkqwoODgzz00EN0dHQQCASwWq088sgj7Nq1a8xlVVl5oWa7qNo7Kuv5nsBzpshW5qy8mo987ON8/GMf478+/G5mWFr4+wPP0BUF/5Q5rF13PiUeO6gphvq6MzMfhkdmFaLBfjrb22nv6KAvGM18NJOTCZKxUHoJWVcfscwXuLTVY51kLERXRzsdnd2EYslM3VTlJIO9XXR0dBGMpZCTCd7MA8Lm95v5fFRMo/sj6oVmJND4/mOC7zjB8aFqFrvbOzrYtm07u3bvYXBoiKNHW9l/4AB79u6lf2AAWZbp6Oigu7ubVCo9y0JRFLq7uunu7iEajXHo8GG2bdvGq9u2sW3bdg4fOkwsGh3R5pnLVXB8WG+55ZbbPB5PToMMyZRMXyhGXAGH05lT5kwkHovScriRUHCIBUuXk4jHiMdirFq9ltDQIE2N+1lx0Roi4RBHGvex6pLLWXnJpcyev5hAYSHdHe2UVU6lZvpMotEIO17eSH9vNxdfcQ1Ta2qxaobJVFUlkUhgRaY834fNenLzNybHGUyGsNqs2Ky2nOuHdOREisGjvZSVluIYw8DXG0UikaCrq4vA1CJszhz7HmovHxtWChx+bJbTY9gtHk/QcrQNi8XC0NAQvX394jjOo7u7F1mWqa6eYs7eE6KxsZHHH3+coaEhpk+fzooVK1BVlWg0SiQSGfXo6upicHCAosIC5FSKZCJBMpEgoR3JRIJEPAJKApfTjs1myapT+q+e/giRmEJFRUXGD0CODdETsXP+2rXMLA/gyw9w7KV/0uRcwEXnVJMx7SSn2PXMg+xOlOFPtLL7UDeltTOZUjjSSFyy/yj3PbWbZZevoTpf/8CmEI8NIftncuWacwk4FZq2vcC+oRKuWHMOHpseU4VELIgcmMmVl+pyz7MvWMoVa5Ya5ACLkwJ3mIf+8TRTlq+hNt8OSoodj/+eTdHZ3HTdKrz20d8v4xGNRrMMNiqKgizLOducvr4+kokoUysCWe6KohKPp0ipFhTJRiqZLkO97JLJJIlEgnjWeZxUPILNquB02jIdStXQcezqCzMwNHI0TlVSHN72DIOBJVxwziwCPi++vAKciVa27O2nYel8unc8S19gEWuWz6YgL4/CsgoK3S4UbynVxV5AoX3H0zx32M2Va+eyfcN2Sucsosw3tqGvN5pkMpllPFNRlEyemZEkCa/bwdRyf7oDp0IikSIhgyrZSKXk4TqWTA7Xu2SCcCJKjDgWp4TNbsl0+CRTJz4ZSTHYGj59lm8tTqbUz2N2dRE2SUKJD/LKCy8w4J/DstkF7Hl+PTtbh2hv3MnGFzdwLGqnpmYKLls69pLFRl9vD3a7jVmzZmUFnUql8Pl8rF69mrVr13L55ZezbNkyKioqKCgoyOTxoUOHSElJpi+uG84PFZSkihxTsMtWLIo04j2WzucIshzFboe+/jjB4EhDSaqc4MArz5CoXMmqhXX4fV78BWVMqfSw4V8b8NY1kDe4m789spMZi2cR2vkM//f39ezct59XNr9Mq1RE/ZQiIq2vcN99/2Dzjv1sf/kFXnz1AIW1sylxJ9j5wrPsOdzCvj272L5lM61RO9NqppDqO8LWlhjLF81BCjaz/oF/8MxL29m5Yys79rdSXF1HocfGke1P8ts/PcLO/fs5eKSDnv4Bps1fTlXB5B5syIWiKHR2duL1ejNlPDg4iCzLOftkkiThdtvJz/ejyJbh95xWxrFYjHg8jqKkl/HpZR+PxzPvwmQiQXtHN5FI5PTVnTMUSbIRCPipKC8hFAyyYcNGiooKkSSJvLw8du3ajZxK0d3dw+LFi5g5s54XX9xAOBwhPz+fcChMR3sHmza9jC/Px7Rp03j++Rd48smnePnlLaxfv57+/n7q6mrJDwSypr/Lskx7eweBQD75+flZ8RKMj7AanYPBgT5efOox2o42c8N7PkAqlSQ0OED5lGq2vPgs/3rkH/y///0G3Z0d/PP/fs+lV9/I/KXnYnc4OXxgL+v/9mdmz1/EkpXns2PLJl7Z8BzLzr+EeUvPxeP14XKnt2OafFaj9+Fx5/4o8kajKArhSISalTMnldXoYCjM1ldfm/iX2zcpsViMcDiMx+3Gre31LMsykUgEWZbxeb0gScTjcaxWa8aQiyLL6Sl9kjTqHtEAfn8eSxfPNzufELrV6JaWFpYuXco73/lOfD7fmM8/QG9vL6CwZPHCzPswM9KrqlitFvLcNkoCLgIBNw5t+yTVoASrwP7DPXQPpFi8ePFw4GZUmaPbHubWO+5j9S138O5l5ZkwlOQg9/73O/htcy3XXtBAsOU1DvQH+Mj/3sp503yGL78qXXue4Kd/28mHP3kLU/LM7w+Vzn3P8LOv/5ytPUne+sXvctP507GOyAaFjr3PcOc3fsHWnhRv++J3+PcccqlwKz/6/GcJnfdZvvDOJVgjTfzof/4XLv0fbrlmDifaOujrIVesWEFxcTHJZJK9e/cCsGDBArM4jY2NREN9rFhcBYa81/cR7umPMhBOomjTBXUkTcHFUK52qwW/x0pZoZdAwA3aXrJGdh3soimH1WglGePJe77Idvtq3r52MU4LpMJdPPfoQxzzrOJj77uE2MEXue/hF4nZC6ipn8vMGdOYUlFGvs+NRQI13scjv/8lLWXreP+lpdz3o7th+bt55yUzeR3fFU4psixz4MABampq8Hg8yLJMZ2cnNpuN0tJSszhSLqvRQzG6+iIMRpIkU0qmPDJlpJWB1WfHXuLCU+TE4c5+woyjIqHuGC2bulDluElFPvXI8UG2Pf8YT+4Ic+V73klDIMwTf/kLkdpLWLO0hkjnAf7xp/VUX/FerjynCpskIVmdHNy/F4/HyTXXXGMOckI88cQTRC1h1mpWo3USEZlob5xEdxQlnB5pyryfVBVJAo/HSiBgobDQxaFDQxxrG2k1Wo6H+OddX6J75vu4ed1CHFq3IBnt4q/f/RGuyz7Ayvwj3HP/EW7+2NXs/Muv6ahex/Xn1zHYuJln9sa45sbVdG14lJfDU7j64gU4Et08/sd76Z/3b7xvlZc/3f4tBmZfw1vXrcA60Mj9f3mCWW95H/Ok17jnhQE+8e9r2bv+j7wQrOLGy8/Fa4my419/p9FzPu9aXcT9d/8F34rruXxJJR17X+DXD+/g+vf/Fytrsz+SvRlIJBJs2bKFiooKqqur6e/v5/Dhw9TW1o5arwIBJ/48F5FIetqzZGiPZFlGlmVsdntmFwQzKjAUTBCPJ4TV6NdJ2mr0VBYvnM2xtja+/e3vMHfOXLq6uvD7/QwNDTFr1kwefewJrli3lquuuoJv3v5t9uzZS011NR6Pm0QyyWs7XuOyyy7lPe95F263m0gkwvYdr/Hkk0+xcsVyrrhiHYFAIOv9F08k2Cr2ET5hxIhwDpLxOB3HjpKIxZizYDEFRcXkFxRhsVrpbGulo/UoS1ddSDwW5eiRQ9TNnE1xWQVWq5WhgQFamw5TUl6J1WrlhaceI5VIkl9czEBfL5FImMLiEqxW26QaEU5b2JCweR1YPfZJd9i8DtwFXryFeVhsI7vcb9SIsNPhoGrqFGqqp56xR3XVFNrbjvLgA3+nvKyENasvYnrdNOw2iRdfeI4jhw+ycuUyykqLOdS4H5/XxXmrllNXW4PH66LpyCFUJcnqSy6kdlrNiPBrqqdSXlaKxTLG83kcdHd309TUhN/vp7KyEr/fTywWIxQKjXn09/eTSiYoLCwgmUoRTyRIxOPpQxutctgs5HlduFx2LNbhESq98yGNMSKcQVU4uuMxvnbHn6le80Hee2UDTkPaVSVOJOZhxdXv4a3XrOb885fR/dyfeK6rhAvPmZHpkKLK7HvpSY4o81m9YsZIS+4qWO0uKmfMxhM/wuNP7Gf+Bcsp8Zo+Ehnk3PHDPP7kAeZfsIISb/bMC8nmwhE+wEMbO7nogqXE9z/O758Z5B3vfztTvSde32RZZsOGDezbt4/Kykr279/PM888Q21tbc69mPv6+kglolRpI8J6zukjwgPBKH0DIaLaiIhehrF4PF2miUT6dzyOqqRwOWzk+Vy4XXYwTB/Vy7R7zBHhx3h++xEO7t3Fq1u3svNAG56p87lq3YWU5znxFlczd3Y9PkuSnu42dr+ygRdf2Yu7so7KAg9DbXt4/JmDLLtyLdMK/UihAzzz2iCLFs3Cq31omWwoikJTUxO9vb34/X46OztpamqiqKgo59Z7xhFhCVBUSMRTDAQj9A+GiUaHyymu1TW9zqk2cOQ5cXhsWLQRYWNd08sqcbpHhDVSkR5eWP9Xnt6vcOWN17FgagCr3UPdvEXMnlaB1+Ukz19AvO1l9oaLWTJzKjbL8IhwOBzSRnMMBtcmeBw7dgybx8qMxXXDEVJBTiokwklCfWEig6FMvurPfzKRwGJV8LiteL0O+gfGGhF+mkjRYhbNKM98GFPlGAde3oBavZhq9yDb9g6waNVCLL1NbNx6gMFwCFthHeetWkqh10tJzSwa6sqQo0G62ls5sH8f/a46zpnpY8+uQ8y66CoWVBfizQsQObqFxngp0/0RdhyNsby+iGf/9TQtA3H6Wg+x70AjLUdbae2VmVVuYXNjmLVXr6Ui4MFf4KV1zx5KZ5/zphwRRnsXtrS0EI/HOXbsGB6PhylTpuQcqJIkCafDiqqmGBqKZMo5HosRN4wIJxOJdHum1y/9WdB+J1Nqepr8aa47Zxr6iHB5eTHBYJCXNr7E7NmzKCkp4YUXN1BSUsLSJUvYvn0HdXV1zJxZz0ubNpGXl8eFF17AvHkNVFdV0dnVRXlZGfPnz6OwsJDe3j6ef/55qqqquOTiiykuKcFimuYuyzJtbR3k54sR4RNBjAjnIB6L0nzoIMGhARoWnYvL7Qb9JXWkkcP79rDi4kuJhEPs37mD6bPmUFo5FavVSn9PNwf37KSorAKX282m554iGg7jcDqRJAtllVNZdsEluNzu0zIi3KSNCLvGGRF+s/NGjQifDaiqyv33389Xv/pVLr/8cj70oQ9RXV3Npk2b+MEPfoDH4+GWW24hLy+Pf/7zn1RWVvLWt74Vl8vF0aNHefDBB7FYLNx0000Eg0FCoWHrqV6vl5KSkpxTv06UUChEZ2cnqVQKp9OJz+eb0Ee81tZW+vp6WLhgHjb7sBI4rGjJJMIDqMkgAb8buyN7X1OdfdqI8KJFi8xeKKko+zb8jZ/84VmmXnAzH33H+RQ4TXGToxxr6yaveCp+twWUJM/8/BPcfXQpd375PyjS+nhKsp+//uBWEhd/kZuWlWUFkYwM0BORKCsKYJEg1LqF//7ENzj/f+/iHYuHFfRccl/4xDdY8fHPM/jsL3h0axdY7Vz8H7fxqWsXEmp+if/98j1c/fkvknzyZzzF5dz+ibU4c2XEBFFVlZaWFtavX08qlSKZTDJ37lwuueSSzP6XRg4dOkQ01MfKxWkL/vp7TR8RTuHC7S9GsozcdxbDhwtQkZMJEuFBnLZEZh9hs/xo+wjrI8KvuS7nHeuW4LaCxebEl+fDabOAEqevL4Q3vwCnzYKqpIgGe9ny6B95eXA+H/rgxRx9+l7u/NtOquqrcEoqyVAPh44pvPOTn2H17JKs+00WVM0YzP79+1FVFVmWKS8vp66uLmcfwTgijPbBIhiMEUvZcfoKsNlHljFaGzaYCDGgDmHzW7AbRoT1YtKV4jdiRDgZbOOZR/7B9sEirrr6SuZM8WMB4v2HuP8fG2lYez0Lp/hQ4oM88Yef0TblKv798oXYLcMjwl1d7eZgj4vqOVNzjginggr5kp+AfXgmTGbEUFVJJIdIJvrxelUaG49vRDgxuJ9ffPfPTH/bB1ns2Mcv7z/CzZ+8iXKCHNq/j107drCvuQMK53DTv18LRzaw/oXdRFUrHo+bUNtB5BnX8583VPP3X9zLjGs+wvnT80GOs+kfv2S7ayVX1fTxu40DfOL6pfzxnl/gWHA9F9QXZOJmc3rxR/bxs4eb+cB/vp+pPkhFu/jr739H7eUfelOOCGNQhJuamigsLGTmzJm4tf6nGUmSKCz0MHtWHXaHP2P/Xp9RkUomM22gw+HIfOTLzLjQynvHzgN0d/eIEeHXiT4ivGjBLNrb2/nOd+5gzZrVLFy4kAceeJA5c2Yzd+5cbvvKV7l0zRquuuoK7vjeDygoyOeGG66ntKSEcDjMz+68m8KCAm648XokJB588CHC4TBr113OrFmzskb39TodTyR45ZVtVFfXUFtba4qZYDzG7x2ehTicLmrrZzNv8bIsw1ZWq5WqmjpWrb4cj8dLYXEp55x3ISUVUzIdgEBBIQuXraS6bjrllVNZ+5a3c+2/3cy6G97J2uvfzjnnXXhajWWlOyopEsnkGX0kU6kxDYkIXh+yLFNUVITL5eLFF1+kqamJw4cPk5+fn5nyrGrrcLu7u2lpaaGlpYVjx46lR1pTKQYGBnjppZd44IEH+Mtf/sLdd9/Ngw8+yODg4EktO6/XS21tLfX19dTU1FBcXExhYeG4R35+AK/Xmzl82uHxePBof40KMnqnQmuQxu1+qzL7n7+Xr/3yCZa+7RY+9e4cSjCQCB7hp1/4LL999iBJFZR4L3v29VE9bQYew/cCub+R/YeLWDzLNG1OlWnd9hCfu+Xb7OuOACqx4BCDcUd61DNL7kE+/8nvsL9HlxtkKO7A689n2qxFLFu+nOXLl1NXUYiERF7FLFbV2/nXU8/z3L4hzr9o4etSgtE6dDU1NVxzzTW4XC7mzZvHxRdfnFMJNqJCZgpt5hyw2Wx4vB68Xi+eXOWZOffhcXuwajNMzOUnZSnNoyHh8gYoKSmhpKSEogJ/WgkGkuE27r/7Zzz88hESiopkseHx5eP3eIgnUiiJHl575RDzL7uet994Izfe+Fbe+e53cdEsF5s37SFy8qrESSXdAS9kzpw5WK1WKisrR1WCjRgVLVVrTz3udDnpZZV1eLw4HOkPyBjKQ79+7HI5xcgRtv/rIR7f0U9DwwzUgaPs3b2bwy3dKK4A7tBhHnvkaQ4caeLVFx5nW6uLhXNr0R6NU0ImTySwSBacDseI51//7XK6sFothhydIEqcxpc30+4oYfrUokwHUo0PsW/3ftw1S7jxpg/xyQ/eiHtgJ4dajvHcsxtxzr2CD//nR3j/e65jerEfVX+2g4N0dA+QUkGO9dPcFqSsOH84n1w+pub7iMZt1MyYycyZMyi2h+jtj2EpKMYT6aGtL4QKxAeO0tx5/NarJxNWq5Xq6moaGhrGVIJ1JCScTidej+G95vNlytrj8eD1+bLLXz/3+fD5fJn3n+DkkP7wlK5XFouFqVOncPPN/855560a0aZJgM1qw+l04nS5cDidmUHJWDTGs88+y9atr1JUVISqqLS3t2eMZRnff/odz+TBrlOJmBqdA0mSsFqt6S8vpgfLYrVitzuQJAmLxYLNbs/KF8liwWazY7VasVgsOLQHXD/sjvS1aB2DUzk1OiEnCSbCaWMJqRRy8gw+UjKSouK2Osl35GE9TVOjzxZ2795Na2srixYtYu/evUQiEdrb26mqqmJwcJBFixZht9vZvHkzhw4dyowY7dq1i8bGRsrKylixYgWBQICysjJSqRRNTU2Ul5ezdOlSHIZ68XqR9O2PtGOiDA4OEg6HtGnalswXdEmfLqsqJGMRlGQUp9OO1Zo2lmXukPf2hQnHlBHTehNdO/jOl77D7lgRlc4hXt28iY0btzNkK6IqEOUPP76Nf/WVc97cOqwDu/njnx6jLzTA5sfuZ0tHITd/6F1MC+iKrErr1kd5MlLL21fPxjSJGZfHydGtj7F+cyPBrkM8cN/D2OZcwb9ddS721g187ju/xF67jDlT/LRsfZT1mw8R7GrkgfsewTbnCt59/UUsWryCiy66iAsvOJ85ldoIi9WJ39rDr375ZxJVy7j5+tX4M3O1Xx95eXlMnz6dGTNmjOgwGOnr6yOVjGWMZeklrCgq8UQKLA5c3jwkKT2VdiwUOUUyFsFCEpdmLAtDJ0Mad2r00/R65rJkztQRU9MtNjfORAfPP/Ek2/YcornlEJuf/xdbD0ZZevmllA3u5MnXhlhz/Q3MrSpOT2srLKHA2s8Lm3ZSPncpFSPWfU8enE4nRUVFFBUVjakES9rU6Cll/nR9UUl/CJBsODw+rNbhNGY6dNp5JBklIkexOsGqZbDRXz8/3VOjU+FuNm7cwLHeCD3HDrN3zx727DlAb8TP3EX11E4rY+Dwa2ze+hpHB2ysWHc1S2eUatOLh6dGBwJ+1q1bR0NDQ+aYNWsWVVVV1NXVZR1z5sxh4cKFGblwOAx2NTM1Ov2OShvLUhPgtXrw2F0534GpVIxEMozDro5jLOtRdh6NMNB5lL27d7LxuSfZvKePJZdfx7KZxcR6mti6d4BFy2fTvuVfPL75IJHoEI27X6M9Uc6qVQ1EWvZx6NgAqhxi75ZNvLr3IFJJA8saCti38RkOHu0lFOpnx0sv0Jos59JLV+AINqeNZS1dRLEnxYZ/PcOR7iH6Wvbwr+deIl40m4X1VUi9+3hm424ioW62bNzAtmNxlixf+aadGo2mPHm9Xuymj65mJEnC43FQVlaM3eE27Iiefn/JmpEsm82G1WrNeg4kwzuura0rPUvrNNWdM5X01Og8KspLiMXjtDS3UFtXR+20abhcLux2O8lkksbGQ9TV1VJdU8ORpmaKCguor5+B2+1OzwhobsEf8FNSUszGjS/R3dODqqocbW2lv3+AkuIS/P68zEdgSZ8aLYxlnTBCEX4DObWKcLqSWCUrXqsLr819Rh8+mxuf3UOeLd34W7RRBMHJYffu3Rw5coRLL72UtrY2du3aRW1tLVOmTKG5uZmFCxficDjYtWsXAPX19QQCASRJor+/n5KSElatWkV+fj6KorBjxw4kSeK6666jrKxsUrxbjIpwro69qiokYhHkZDRtNdpQX40d+J6BKOGYQllZ9nTl2EAHzUGYWpqPpMikUilSKSvlNTOpq/Ax0NuHZ8pcZlcWUTV3MdOLFJqa23CUzefd/3ETC6bkGbo6KYb6+imbtYj60rys+wDY3EXMW9SA0neUps4Q9Suu5qZ3Xkap20oqFqS1L86sOfOpLClLy/W00NQZoX7FVdz0zssoMRkmGkbCHSjEGbWw8MLLWTi99ISNZOXC5XLlzHsj6bXcMaoqAlkdOqMi7PbkIWnP1Eg1QC8rFUVOkdAUYaPVaOM1o1qNVhUUOUWgYgbV5fmYl7hLFhsl02Yxo6YYOREjnpDxldRw0borOXdmEcHuflylDSxqqMSRuVbC4y/AmoD8ikpK/M6c8Z8MSJKE3fQhOBe6Ijy1PP3hQtWsRqvYcLp9WKwmQz76dHcJIskYETmC5JSwGBRh/a9e/qfbarTFmcecxStZvfpiLrjgAu04j4Vzq3DbrLh8JcxesJhzly1j+TmLqKkoMIwGDyvCLpeTpUuXZkbnfD4fsViMP/zhDzz88MNs3LiRjRs3smPHDmpqapgzZw55eXn4fD6am5szVqPToab/UVIqajKtCLvHUISTiTA2u0pfX25FGFVGURKokgtUBUWFvJJpXLTualY0TMVukQAFm8tPbf10ptXW4Ir109nbj+Sv4tK1a6gtK2RKdSWEe+gbilNYt4gLzp2Jz1PI1MoCrA4/sxpmEOnpwlo0ncvWXUpVgRNUBbs7QN3UCgKlVcysCRDs7SKYsDF7xaVcsnQ6LoeLqdPrybdGaO8JU1a/kMUzyplaXUu+Z2wl8kwgSxG2ZyvCkraWP6MIm4xlGd9xrW2dQhE+CaQV4QAVFSU4HQ5qamqorpqamQEqSRI2m43a2lpqa2vx+XxMmVJB3fQ68vPzsVgsWK1WKirKqautpaSkmGnTpnHO0nNYsGA+M2fNoq6ulpLi4vTAgeH9J8sy7W0dBMQa4RNCrBF+AzmVa4QBVFQUVRkxYnUmIyFhFUrwSUVVVf7617/y2GOPceutt7Jr1y5efvll3vKWt9De3s769eu56aab8Pl8/P3vf6e0tJTrr78el8tFa2srDz/8MC6Xi4985COEQiGefvpp9u3bx9q1a1mwYMGYo3+nk5aWZjo7O1i4YF7W13hVa3BkOUVooJtkpC9rjbBx9BBtjXBXf5KFCxdmwhCcPA4fPkws3M9KzWo0WhmkkjJDQzGw+wgUV45UsAyyaOWVjMcIDnRjI4Lfr3VYTLK7R7EaLZgYkmmNsKytEU6pLvxF5dgcw6N3kva+SY92qPSEB+hO9GLNI2M1Wq+POioQ7orRsvn0rhE+cca2Gh2Px7n//vv54Q9/SG9vLzabjSuvvJLPfe5zWQb4dKvRl2trhNN5B8loCiUkUeIoosiTP0IRVlGJRvqJRDpxuRUaGwc5dmzkGmHB5EaSJIqKvCyYPxu3J710RUfVjIemkklc2pRb3ddYf1Rg85bX6GjvEGuEXycZq9GL5gCgKgpIEhbT8h1FUZCQkCxSWkYrS30GmqwoaSVXkjLb0mXuoc1ENdZpVbM4vvWVbVTXCKvRJ4LQGM5g0kqhFdtZdAgl+NTi8XhYtWoV73vf+5g7d+6ID2gWiyVjoCovLw+v15sxhBWJRNi4cSPPP/881dXVlJaWEg6HSSYn/7ouc+cbVFDTW1Zg6MBnrYPUzsVxcg9DCWTnf8Ynu7D0a1Ttt5SRT4cgkd5nadh9GN1N8PoxlpWk/zDlsap19kbkuaFQjLKZejnigjcvTqeTq6++muuuuw6n00lDQwMf+MAHRiy10Bn53GZnhvH5z3Y3SwrezGS//0aWrLH+5ToXnBz0/JQslhFKsARYLZbMDhmSxTJCsU37p5dmWbQlmvpSTeMUd/P71Fy/BRNHaA0CgWBcvF4vxcXFWK1WCgoKqK6uxul04na7KSwsxOFwYLfbCQQCWVaabTYbfr8fv99Pb28vO3fuZGBggGAwyAsvvMCrr77KwMDASTWW9fpIf5k1K0Mjf2trkA1+uTofglOH3gEY4QhIWgGqmMolq4z0EDQ3Q6GLTsWpRc38MwZGoREFPUr5nyH4/X7e+973ctlll3HzzTfT0NAwYmQ3J6ZMUdFGmwznQgM6AzHVJXPd0H+bq5x4BE4NE81Xs9yo5ZOj7htdzNcJjg+hCAsEgnGZPXs269atw+PxIGnG5ABqa2u57LLLqKyspLi4mJUrVzJv3ryMoTm/38/SpUtZsmQJPp+PxYsXs2bNGoqKinA4HDkN0k0WVFMDM1pjo8deMnc6c4xmiuPkHEb0c2M5qIbOoPlcL9esp073NLjrcqOVu+D4GK2WG8vDWD6qRNZVejmYy8T8PJwpVFZWctttt3H55ZeP+Y40Pv8S2ZljfJYNj3jG78zMubMIrQAlzbaB7mQuV3P9wvRsCE4+5vIYrQYb/fXyyVUmupvZTzXMchKcGEIRFggEYyJJEtOmTeO8887DZdj6S5IkKioqWLZsGcXFaau38+bNY/r06Zkp016vlzlz5jB79myKi4u58MILueGGG7jqqqu44oorWLZsGQUFBeMa3Dmt6J0LvWFS09OgdUSDM4kx9RLMnQaMHRRVJf1fdu9Dv0Z0Lk4d5k54znzOFMwoBWlkPP83IZIkUVBQMO4WOkZUdbTMNKD5n6HfD84uDGVteIVlk+Mjii6XLa+/8cRxYsdwno5aFibGfP8ZwjH75wo7l5tgYkzIWNZAXMHjy5tcndUzAEVRiITDuEixsPbkG8sSCAQTJ2Msa+F8bKbtJtC22gkNdpMIp41lORy5jQfuO9xDa2d41DV9gtdHX18fdksqy1gWQCIpEwzGkGw+/MWVWK22EZ0IVbNIrHcaUvEYoYFurETw57kyfUZdDmDXwS6ajw2csSOPpxpJkigu8LBs4VQkzbr3UDCGrLrI04xlSTk6hSoqveEBuhK92PLAPqolcwh1x2jZ1I2qpia9hidJEkg2Du7fQyIRpaGhwSwyIQ4ePIiryMFazViWnupkREYJQYmjiEJPftY6xbRc2lhWONKJx61wsHGQtrZwlozgzUFhoYcF82fj8RSSHhdM1x8VSCWTJJNJXG43Ts1Oh46xrm3e8hrtHd1Z/oITo7qqkiWasSwjxvwe0SaN4n48JBIJtryyjerqGmpra83egnEYUxGOxJMc6uijKxjD5nCO6BgKXh+qqpJKJgk4rcyvKcUpFGGB4A3DaDXaZrNlvqTrbz1ZThEe6CahWY12OKxZCpPOkaP9NLcPZrkJTi75eS4WzSnP+gqezKEIk6ODkblGVUklYoQGekYowka5Q819tHYODXsIjpsCv4uFs9MfhnRFOKUpwvbRFGFVpSeS22q0Lqf/jvbFadvRp529OWhpOkxPT5fZ+bioqCvj/BtXZbklozJKMK0IF3ny0a3RoueXqhKN9hMOd+L2KKBCIqlZrzWEk+tzgrHDng5r7N678b5ZccjhZ7yfWfZ4MEcn172N5Hr2GEf2DU+/CvF4ilRKorCoCo+nMHOVHlZGEXa5MjszmMOTgGAoTCKZypmMMZOXtjGYa8D5lGKOk/l8whguHC2M0dwhd/odDjs+r0f3HlHG+m9y+JnddczuucJKJBK8IhThE2ZMRTiRkukcCNIbjKLoOS44qVgkiYDHQVVx/kneR1ggEBwPLS3NtLW10TB31rAibBhdSo8I95AM9+HPjAhr/ua1wUp6yu1YDZxOLn/j69bc6I3mbryXTq4wzQ2q+V7GhtYslys9ufzNf43yZnL5m+NkdkOzrmn0SSYVhjRFOFCS3j5pxEU6EqCqJBPaiLAaJZDnHC7HzE1V0jPjRy/PXOk1/zXKmzH7m6M8UXfjvXRy5WmueOsY460zXnpy+Zv/AtisFlQVFFUlGIyTUp3kFZZjd6Q76ZIkZQ3mqqpKT7SfnkQvVp80PCJsjrR2oirpstJlzLanzfEedh+2Gj6iV28eXTbMJpB0//SFWWJG0h/LGCGjqumtUcxBZO6o/cjMUtDdNfTQrLbskfJkVEEOQolT2z5Jl8zkm0ERdit4PMa+n0GWHOkfkU5TJM1o9wND+RpFM/6S+XWbcR9BJh06upzhb65MM16XFQez0ORPv6qqRCNJolEVj6dSU4Q1T225RyqZIpVK4nS50iPCknTGpD+rXDNyhr9nePmb059IJtmxYxe1tXVi+6QTYExFWFXTe1rJk8ai65mJxWLBLpRggeANpa2tjSNHjlBUmI8lqz6mGyNFThLqT0+Nzg+4sI8yNToXmXbZtGVJjiZ4hPtEkLR/Mg1ppiEflhmBwcAK2tftLAwN7kSCGwtJC8vctJ/M9CeTMoNDMbDnkV8yBYvVarqBXgj6zVSS8RihgS6saoSAto/wsPypTf/JSjv69ebyHy+gN6j8VUVlMBjP7CNsd7gycVEZvokK9ET66IprU6M9E69vZy1qekRYDkmUOooo8hRkno1MKaoqkWgf4XAHHreMx2uYNmt8fnKR6wEYTdbEqI+kVinM5Z+T0SrKaHHIlR7tfjnJJW8kV9xGkzVxUtOvQiSSJBJR8Hqn4PEUDVcyLaRkIkkymcLtdqW3MNRmBoyWbcNX5v5rlNMxy43mPtr7b6zwJyKXy133I1c8csRTJ5dcrvDN148Wbtb12g9jWOOFPxE53V2RZbq6e6ivn8nUqen92gUTZ0xFWCAQCM4WQqEQ7e3tRCLm9XLp5kZOJRnsaSMe7KK4wI3TZX5nGpsu/dzYPJrdcvkfD+brxwvb7M848jpj+RmZSJjmOJj9j4fs6+Nxmb7+CDjyKa6sxTqiTcu+t6qqJOIRBruPYVPDFBVkT40eZqLxfGPTP37YZn/GkdcZy8/IRMKUkBWVvoEISdVDQVk1Tld6KqEZVVVpD3ZzLNaBLR+cvrHK03xu9jO7TSSuOmP5GZlImOY4mP2PB/P16fN4SEYegCnucsp8xYY1wml/VVUJh7sZGmrB65Xx5zmPMxa58lD/fSLkun6ibmO5TwxzLo7P5Eh/KBQnFFLIy6vF5ytDkiyZuKkqJJMJEokEHo8Hl2viBtcEbz4kScLtdlFZOYW8vDyzt2AchCIsEAgEpDveqVRq1D2NU8k4Pe1HiPW3UlGWh3uEIix4I4nGUnR2h7C4iiifNhebPdtAjBlVVYlHgvS0H8GuDFJe6h3R9RScfFKKSld3iLiaR1lVPS5vXo5OPyiqQvNAG4fDzdhLwOW3m0UEOYgNpkj1QJ23hur8CixS9mwzVVUYGjpGX98B/H6ZgoLjVZLMSpr5/HiZ6PWjyY3mfqow3898frxM9PphOVVVGRyMMTioUFAwh0CgSlOENUlVJRaLEY/H8fl8eL1eQziCMw1JkrBYLFitVmHU+AQQirBAIBBMgFQyTk/bYaL9R6ksy8PtFh3zyUQ0lqKzK4jkKqaytgHrOIowQCw8RHfbIRzKIBVlPrO34BQgyyqd3SHi+CirmoXL6zeLgNaZPzLQyqFwE/YSCXdA1LdxUSE6mCTVA9O906jJnzLSarSqMDTUSm/vAQIBmYIC05IAwaRHVVUGBtKKcGHhXAKBmiyjjboiHIvF8Pv9QhEWCMZAfDoQCAQCgUAgEAgEAsFZhVCEBQKBQCAQCAQCgUBwViEUYYFAIBAIBAKBQCAQnFUIRVggEAgEAoFAIBAIBGcVQhEWCAQCgUAgEAgEAsFZhVCEBQKBQCAQCAQCgUBwViEUYYFAIBAIBAKBQCAQnFUIRVggEAgEAoFAIBAIBGcVQhEWCAQCgUAgEAgEAsFZhVCEBQKBQCAQCAQCgUBwViE1NTWpRUVF2Gw2s59AIBAINFLJOD1th4n0tVBW4sPlsiGZhQRvGLF4iq6eMFZ3CZW1DVjtDrPICGLhIbrbDmGTBygr9iIK9NQjyyrdvWGSUh5lVbNwef1mEQBUVeXIQCuHwk3YSyTcAbtZRGBGhehgklQPTPdOoyZ/ChYp+6FWVYWhoVZ6ew/g96coKHBn+QsmP6qqMjgYY3BQobBwLoFADZKhnFVVJRaLEYvF8Pv9eL3erOsFAsEwQhEWCASCCaArwoNdR/B5ndhtYkLNZCKVUgiFE7gD5cenCB87RCrSTZ7PIfTg04CiQjAUx+ouHF8R7m/lYPAIloCK0yf6KOOiQjycQh20UO+vHVMR7unZj8sVx+cbv54IJh+hUIJoVKK4uEEowgLB60AowgKBQDAB5FSSgZ5jDHS1Ikli8HCyoWodQF9+KcWVdVht448gJqJh+rtbCQ/2IEkqolRPByqKAh5/IYXlNThduTvpqqrSOtTBob4WEmoSySLKZnxUVAWcFgfTC6qZ4i/LUpDQ8jUUaqev7zDJZAiTt+BNgqqqWCxOiotnkZdXKRRhgeAEEYqwQCAQTABVVZGTCVKpOKrZUzBpsFnt2B0uJtLDVxQZOZlAlpOiTE8jEmCx2rHZHVgsVrM3pFU6wokog7EgsiKbvQVjYLPYCLh8eB0esxegkkhEiMUGkeW42VPwJsJiseF2F+JwZCu6QhEWCCaOUIQFAoHgOFBVoTJNZswjYOOiqkIJfgOQYNyPFaqqoqiK2VkwASySZdS6oKoqqqpo8ygEb14kpBzlLBRhgWDiCEVYIBAIBAKBQCA4AxCKsEAwcYS1F4FAIBAIBAKBQCAQnFUIRVggEAgEAoFAIBAIBGcVQhEWCAQCgUAgEAgEAsFZhVCEBQKBQCAQCAQCgUBwViEUYYFAIBAIBAKBQCAQnFUIRVggEAgEAoFAIBAIBGcVQhEWCAQCgUAgEAgEAsFZhVCEBQKBQCAQCAQCgUBwViEUYYFAIBAIBAKBQCAQnFUIRVggEAgEAoFAIBAIBGcVQhEWCAQCgUAgEAgEAsFZhXTkyBE1Pz8fm81m9hMIBAKBQCAQCARvElRVJR6Pk0gkCAQCeL1es4hAINCQmpqaVIfDgcUiBocFAoFAIBAIBII3M7IsI0kSgUAAj8dj9hYIBBpSX1+fqqqq2V0gEAgEAoFAIBC8CbHZbLjdbux2u9lLIBBoSLIsC0VYIBAIBAKBQCA4Q5AkKXMIBILcSEILFggEAoFAIBAIBALB2YRYGCwQCAQCgUAgEAgEgrOK/w94Qr2i8/yBxgAAAABJRU5ErkJggg==" width="962" height="344" alt=" "&gt;&lt;/li&gt;
&lt;/ul&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;img src="data:image/png;base64,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" width="1090" height="331" alt=" "&gt;&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;&amp;nbsp;&lt;/strong&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>AM2432: AM2432 ALX VMON Pin Connections and Power-Up Sequence</title><link>https://e2e.ti.com/thread/1699646?ContentTypeID=0</link><pubDate>Mon, 23 Nov 2026 04:15:27 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:494f720b-f063-4380-8aa4-cecaae2e5c9d</guid><dc:creator>Lee Uie-Tae</dc:creator><slash:comments>5</slash:comments><comments>https://e2e.ti.com/thread/1699646?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699646/am2432-am2432-alx-vmon-pin-connections-and-power-up-sequence/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/AM2432" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;AM2432&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Dear TI Support Team,&lt;/p&gt;
&lt;p&gt;We are using the AM2432 in the ALX package. Because we do not use the voltage-monitoring functions, VMON_1P8_SOC, VMON_3P3_SOC, and VMON_VSYS are left unconnected on our current boards. We are debugging a boot issue: of ten prototype boards, only two boot reliably. The others boot intermittently or do not boot at all.&lt;/p&gt;
&lt;p&gt;Could you please clarify the following?&lt;/p&gt;
&lt;ol start="1"&gt;
&lt;li&gt;What behavior could result from leaving these VMON pins unconnected? Could this cause boot failure, abnormal reset outputs, or intermittent operation?&lt;/li&gt;
&lt;li&gt;The power-up sequence diagram shows VSYS and VMON_VSYS at the beginning of the sequence. Is a valid voltage on VMON_VSYS required before the subsequent power-up steps or ROM boot can proceed? If VMON_VSYS is connected to VSS as specified when unused, how should we interpret the diagram?&lt;/li&gt;
&lt;/ol&gt;
&lt;p&gt;We look forward to your guidance.&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Uie-Tae, Lee&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK5B12212EVM: 1PPS/100 MHz Fanout TICS config</title><link>https://e2e.ti.com/thread/1699538?ContentTypeID=0</link><pubDate>Fri, 20 Nov 2026 20:41:54 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:3393130f-8558-4b6e-a257-3e55bf8463ff</guid><dc:creator>Kevin Battles</dc:creator><slash:comments>3</slash:comments><comments>https://e2e.ti.com/thread/1699538?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699538/lmk5b12212evm-1pps-100-mhz-fanout-tics-config/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/tool/LMK5B12212EVM" class="internal-link folder tool" title="Link to Tool Folder" target="_blank"&gt;LMK5B12212EVM&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt;  &lt;a href="https://www.ti.com/product/LMK5B33216" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK5B33216&lt;/a&gt;, &lt;a href="https://www.ti.com/product/LMK5B12212" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK5B12212&lt;/a&gt;&lt;/p&gt;&lt;p&gt;Would like a TICS config file (.tcs) for inputting a 1 PPS and 100 MHz to the LMK5B12212EVM and outputting 4x 1PPS and 2x 10 MHz and 2x 100 MHz.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>CDCE6214: Additive jitter</title><link>https://e2e.ti.com/thread/1699323?ContentTypeID=0</link><pubDate>Fri, 20 Nov 2026 05:52:53 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:ceeb4ac2-0f45-4083-8fdf-6250dbd02157</guid><dc:creator>Daniel Baldor</dc:creator><slash:comments>3</slash:comments><comments>https://e2e.ti.com/thread/1699323?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1699323/cdce6214-additive-jitter/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/CDCE6214" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;CDCE6214&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Would you be able to tell me how much additive jitter the CDCE6214 would have if I had a 40Mhz input that was connected either to a LVCMOS output or to a LVDS output without using the pll?&lt;/p&gt;
&lt;p&gt;Thanks&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>CDCE6214: Few question for CDCE6214 EEPROM programming</title><link>https://e2e.ti.com/thread/1698997?ContentTypeID=0</link><pubDate>Thu, 19 Nov 2026 06:21:06 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:8766fda7-59c1-43bd-8b72-e30f541f6ce1</guid><dc:creator>Gibbs Shih</dc:creator><slash:comments>3</slash:comments><comments>https://e2e.ti.com/thread/1698997?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698997/cdce6214-few-question-for-cdce6214-eeprom-programming/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/CDCE6214" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;CDCE6214&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;
&lt;p&gt;Hello Expert.&lt;/p&gt;
&lt;p&gt;I create this thread for double check.&lt;/p&gt;
&lt;p&gt;Here is operation mode for CDCE6214 :&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;img alt="image.png" height="133" src="https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/1134.image.png" width="618" data-temp-id="image.png-56534"&gt;&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q1 :&lt;/strong&gt;&amp;nbsp;If customer want to programming internal EEPROM of CDCE6214, we must let device swap into &amp;quot;fall-back mode&amp;quot;, isn&amp;#39;t?&amp;nbsp;&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q2 :&lt;/strong&gt; fall-back mode default support I2C communication for EEPROM programming, isn&amp;#39;t?&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q3 :&lt;/strong&gt; REFSEL and HW_SW_CTRL should be both &amp;quot;boot strap&amp;quot; pin, and we need to set REFSEL = floating or HW_SW_CTRL = floating to swap into &amp;quot;fall back mode&amp;quot; when CDCE6214 power on, isn&amp;#39;t? there is not tacking effect when change pin status in run time?&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q4 :&lt;/strong&gt; What is default value (setting) for EEPROM?&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q5 :&lt;/strong&gt; I think &amp;quot;serial interface mode&amp;quot; also support I2C access, but it can not R/W EEPROM, isn&amp;#39;t?&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q6 :&lt;/strong&gt; I think EEPROM R/W cycles (Programming/Erase Cycle, Endurance) shoulod be much higher than 10 times, isn&amp;#39;t?&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q7 :&lt;/strong&gt; I2C interface is working when REFSEL = Low &amp;amp; HW_SW_CTRL = High, isn&amp;#39;t?&lt;/p&gt;
&lt;p&gt;&lt;img alt="image.png" height="297" src="https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/0576.image.png" width="543" data-temp-id="image.png-67973"&gt;&lt;/p&gt;
&lt;p&gt;&lt;strong&gt;Q8 :&lt;/strong&gt; If device operation in &amp;quot;fall back mode&amp;quot;, that is mean EEPROM reading will by-pass when CDCE6214 power up. Base on this working status, E&lt;span&gt;EPROM is not loaded by default and all the trim values will be silicon default. I think silicon default value is register default setting, isn&amp;#39;t?&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;Ref.&amp;nbsp;&lt;a href="https://www.ti.com/lit/ug/snau247b/snau247b.pdf#page=29"&gt;https://www.ti.com/lit/ug/snau247b/snau247b.pdf#page=29&lt;/a&gt;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;&lt;span&gt;&amp;nbsp;&lt;/span&gt;&lt;/p&gt;
&lt;p&gt;Thank You.&lt;/p&gt;
&lt;p&gt;Gibbs&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMKDB1202: SSC pass-through</title><link>https://e2e.ti.com/thread/1698987?ContentTypeID=0</link><pubDate>Thu, 19 Nov 2026 05:52:51 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:3b372fe1-c4e0-4b54-ad81-cf8ae1e25c0b</guid><dc:creator>Satoshi Makimoto</dc:creator><slash:comments>1</slash:comments><comments>https://e2e.ti.com/thread/1698987?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698987/lmkdb1202-ssc-pass-through/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMKDB1202" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMKDB1202&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Does your LMKDB1202 pass through an HCSL clock - provided with SSC enabled (ex. 0.5%) - while maintaining that SSC?&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMX2594: Need to procure more than 50 parts</title><link>https://e2e.ti.com/thread/1698879?ContentTypeID=0</link><pubDate>Wed, 18 Nov 2026 17:53:16 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:f879ec28-99b5-4078-bce7-099e3797247c</guid><dc:creator>David Goins</dc:creator><slash:comments>6</slash:comments><comments>https://e2e.ti.com/thread/1698879?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698879/lmx2594-need-to-procure-more-than-50-parts/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMX2594" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMX2594&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;Im trying to purchase 500 units of LMX2594 and the website is limiting me to 50 parts.&amp;nbsp; Can you help me get 500?&lt;br&gt;I tried starting a chat for this for about an hour.&amp;nbsp; Then I tried calling and the calling system is down for upgrades.&amp;nbsp; Then I tried a support ticket for an order, but had no order number.&amp;nbsp; This is the only way I (think) I can get through to customer service.&amp;nbsp; So my apologies if its the wrong way.&amp;nbsp; Please help if possible.&amp;nbsp; Im an engineer trying to buy for a build.&lt;br&gt;Best Regards,&lt;/p&gt;
&lt;p&gt;David Goins&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMX2492: Locking Problem with LMX2492 and active Loop Filter</title><link>https://e2e.ti.com/thread/1698771?ContentTypeID=0</link><pubDate>Wed, 18 Nov 2026 12:32:10 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:060c8f44-2c7c-4481-bf03-aa202ff47afe</guid><dc:creator>Joscha Hoffmann</dc:creator><slash:comments>3</slash:comments><comments>https://e2e.ti.com/thread/1698771?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698771/lmx2492-locking-problem-with-lmx2492-and-active-loop-filter/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMX2492" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMX2492&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;I was not able to send you the whole issue here, so I added it in this word file.&lt;br&gt;Can you open and read it?&lt;/p&gt;
&lt;p&gt;&lt;a href="https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/Locking-Problem-with-LMX2492-and-active-Loop-Filter.docx" target="_blank" rel="noopener" data-temp-id="Locking Problem with LMX2492 and active Loop Filter.docx-2029928"&gt;Locking Problem with LMX2492 and active Loop Filter.docx&lt;/a&gt;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK1C1102A: LMK1C1102A Inquiry regarding input signal magnitude</title><link>https://e2e.ti.com/thread/1698617?ContentTypeID=0</link><pubDate>Wed, 18 Nov 2026 04:51:54 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:ae34ca65-8a4c-4624-91a6-f6976e98ea2f</guid><dc:creator>Lee HongGyo</dc:creator><slash:comments>4</slash:comments><comments>https://e2e.ti.com/thread/1698617?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698617/lmk1c1102a-lmk1c1102a-inquiry-regarding-input-signal-magnitude/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1102A" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1102A&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;The LMK1C1102A operates with a 1.8V power supply.&lt;br&gt;I would like to ask whether the output of a 3.3V oscillator can be connected directly to the input of the LMK1C1102A.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK1C1102: oscillation at input</title><link>https://e2e.ti.com/thread/1698569?ContentTypeID=0</link><pubDate>Wed, 18 Nov 2026 01:34:31 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:ff1cee6f-5447-485a-8c50-719322b6bb13</guid><dc:creator>new2day</dc:creator><slash:comments>2</slash:comments><comments>https://e2e.ti.com/thread/1698569?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698569/lmk1c1102-oscillation-at-input/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1102" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1102&lt;/a&gt;&lt;br /&gt;&lt;/p&gt;&lt;p&gt;We use LMK1C1102 to shape the &lt;strong&gt;sinewave clock&lt;/strong&gt; at 10MHz and 100MHz. The power level is ~ 9.5dBm.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;We have AC coupling with 0.1uF Cap following by a 100ohms pull-up and 100ohms pull-down to the CLKIN pin. The other end of Cap goes to SMA connector.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;A interesting thing observed, when we power on the circuit or this device and didn&amp;#39;t apply the 10MHz nor 100MHz clock, a ~ 123.xx to 156.xxMHz signal is observed on the spectrum analyzer when we connect the input (SMA).&amp;nbsp;&lt;/p&gt;
&lt;p&gt;We changed the resistor to 1K and 10K, it&amp;#39;s not help. It seems that the Cap and resistor along with the input circuit inside the chip form a oscillator.&amp;nbsp;&lt;/p&gt;
&lt;p&gt;Any ideas? Would it help by using different value for pull-up and pull-down, such as 127 ohms for pull-up and 82.5ohms for pull-down (LVPECL term)? Thank you very much.&lt;/p&gt;
&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMH1983: PPL4 Alignment</title><link>https://e2e.ti.com/thread/1698274?ContentTypeID=0</link><pubDate>Tue, 17 Nov 2026 07:43:21 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:43892ab8-bb0c-4cb6-952b-d3267aa7e46d</guid><dc:creator>SR</dc:creator><slash:comments>2</slash:comments><comments>https://e2e.ti.com/thread/1698274?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698274/lmh1983-ppl4-alignment/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMH1983" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMH1983&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMH1981" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMH1981&lt;/a&gt;&lt;/p&gt;&lt;p&gt;I am not able to get PLL4 to achieve alignment either with TOF4 derived from TOF1 or CLKout4.&lt;/p&gt;
&lt;p&gt;PPL4 is locked and all other active PLL&amp;#39;s (PLL1-3) are locked and aligned.&lt;/p&gt;
&lt;p&gt;Waveforms out of CLKout4 and TOF4 are as expected based on the reference input.&lt;/p&gt;
&lt;p&gt;HVF signals are coming from the LMH1981 which is being fed by a PAL or NTSC B&amp;amp;B signal from a TG700.&lt;/p&gt;
&lt;p&gt;CLKout4 is configured to the default audio clock output of 24.576MHz.&lt;/p&gt;
&lt;p&gt;The evaluation board for this device is no longer available so I&amp;#39;m not able to compare to your reference design.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>LMK1C1103: IBIS model availability for LMK1C1103PWR</title><link>https://e2e.ti.com/thread/1698178?ContentTypeID=0</link><pubDate>Tue, 17 Nov 2026 00:56:35 GMT</pubDate><guid isPermaLink="false">cb01d8b2-d089-468d-babb-77d1d8683490:709d7d7c-223c-4331-83f8-abe7d2e0a9d8</guid><dc:creator>Yuta Nishie</dc:creator><slash:comments>2</slash:comments><comments>https://e2e.ti.com/thread/1698178?ContentTypeID=0</comments><wfw:commentRss>https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/1698178/lmk1c1103-ibis-model-availability-for-lmk1c1103pwr/rss?ContentTypeId=0</wfw:commentRss><description>&lt;p&gt;&lt;b&gt;Part Number:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1103" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1103&lt;/a&gt;&lt;br /&gt;&lt;b&gt;Other Parts Discussed in Thread:&lt;/b&gt; &lt;a href="https://www.ti.com/product/LMK1C1104" class="internal-link folder product" title="Link to Product Folder" target="_blank"&gt;LMK1C1104&lt;/a&gt;&lt;/p&gt;&lt;p&gt;Hi,&lt;/p&gt;
&lt;div&gt;I am looking for an IBIS model for signal-integrity simulation of LMK1C1103PWR.&amp;nbsp;
&lt;div&gt;Is an IBIS model available for LMK1C1103PWR? If so, could you please provide the model or its download location?&lt;/div&gt;
&lt;div&gt;Best Regards,&lt;/div&gt;
&lt;div&gt;Nishie&lt;/div&gt;
&lt;/div&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
