Other Parts Discussed in Thread: REF3130
Hi!
We have been using the ADS7870 for a few years. Originally we used the internal 2.5 volt reference. However we recently redesigned and started to use an external 3.0 volt reference.
We then discovered that the measurements became very inaccurate in the range between 2.5-3.0 volts. The internal reference voltage has been deactivated via the internal registers. Do anyone have an explanation for this behavior? Can this ADC be used with external references above 2.5volts? The limits considering use of external references are not mentioned in the datasheet.
I look forward to any reply and help resolving this issue.
Kind regards Jens Trydal
