ANALOG-ENGINEER-CALC: Error Encountered in Analog Engineer Calculator
Genius 9885 points
Part Number: ANALOG-ENGINEER-CALC
Customer encountered an error when using the software. See image below.
Maynard
  • Maynard,
    1. Can you please check the version of this software? Go to the “links” section and press the “about” button.  You should be using version 1.6.0.   I think that you are on the latest version but I just want to check.
    2. Can you try this on a colleague’s computer?
    3. I suspect that the issue is related to regional settings. I have seen this tool work on many commuters configured with a US operating system.  What are your regional settings?  Can you temporarily try to change the regional settings to US to see if that resolves the issue?  If this does solve the issue I will work on a fix that allows you to run using your local regional settings.  Sorry for the inconvenience.
