question1:I AM PROGRAMMING THE IC from FPGA.
configuration:
1.Continous conversion mode
2.800 sps
3.PGA 32 GAIN
4.LOW LATENCY FILTER
5.Delay ...>1*tmod
how to program the ic for getting the data from remaining 5 channels as we are using differential inputs. can you help us in flow for acquiring the data for remaining 5 channels.
For acquiring the single channel data i am using following flow:(for single channel working fine).
1.write the data to configuration registers. I am using first five registers and writing sequentially one after the other(1(status reg),2(mux reg),3,(pga),4(data rate reg),5(ref reg ).
while writing to registers sart/sync low
6.start/sync high, waiting for 28 t clk cycles
7.start/sync low, checking for DRDY to be low
8.data acquisition.
9.going back to 1
For second channel reading:
i am following the same flow as shown above for reading the second channel with 9 step address increment.initilally i am making address as zero(before step 1) and send 01 value to mux register and completing one read.
so in step 9 ,channel counter will increment by1 and goes to step 1 i am keeping all reg values as same except mux reg which are 23 and sending the value.
but i am not able to get the readout.
hence request you to help me in complete flow for reading all channels .....
