ADC12DJ3200EVM: JESD204B Rx lane buffer overflow issue
Part Number: ADC12DJ3200EVM
Other Parts Discussed in Thread: ADC12DJ3200
Hi team
May I know the scenarios where you observe JESD204B Rx lane buffer overflow issue? I have been trying interoperability of ADC12DJ3200 with FPGA. Once both the devices are up and running, i provide an analog input to the ADC which is successfully retrieved at the FPGA side. This works well multiple times. But sometimes I do see junk data on the JESD lanes instead of correct output. Whether JESD Rx buffers overflow the reason I get this junk data?
Rohit
  • Hi Rohit,
    I am not sure about the architecture of the JESD IP that you are using, but one condition the buffer overflow will occur if the core (application data) side clock is not derived from the same root clock that is driving the reference clock to the FPGA transceiver.
    The other possibility is that you have configured the JESD IP to have all lanes across both ADCs to release together, and the ADCs are not aligned using SYSREF. In that case, the ADC whose multi-frame event is lagging will force the other ADC's lanes to buffer extra data. There is a possibility that this can cause buffer overflow.
    Ameet
  • Hi Ameet
    Thanks for the response.
    My JESD clock is derived by same root clock that is driving the reference clock of the FPGA transceiver.
    I am using JMODE2 mode (sub- class 0) with 4 lane configuration. In our JESD Rx IP, once the first octet of the ILA sequence is detected on a lane, the data gets buffered and remain held in the buffer until all lanes detect first octet of their ILA sequence. When all the lanes detect their first octet, the buffers release this data at the same time. We do have RX controller block which performs re-initialization of lanes in case any lanes fail to detect the ILA sequence.  ALIGNED signal is asserted once the lanes are properly aligned.
    Though, I don't have SYSREF (as I use sub class 0) to align the ADC lanes but our JESD Rx takes care of the lagging if lanes are out of sync from ADC. What do you think?
    Rohit
  • Hi Rohit,
    It seems like you are connecting two ADCs to a single Rx IP in the FPGA. May I know the K value programmed in the ADC and the depth of the FPGA IP’s elastic buffers?
    If you aren’t synchronizing the ADCs using SYSREF, it may be easier to use a separate Rx IP per ADC. Or you will need to have buffers that are deep enough to hold a multiframe of data.
    Ameet
  • Hi Ameet
    I think there is some confusion, I am using two ADCs (because of JMODE2) but since my Rx IP is configured for only 4 lanes hence I am only using one JESD Block (one link, 4 lanes) to send data to my 4 lanes Rx IP. Analog signal is only provided to single channel. Hope this is clear or let me know if I am missing anything here .
    K value programmed in ADC is 4. The Rx IP is configured with same L,M,N12,F, K value as given in Table 19 of ADC datasheet.
    Rohit
  • Hi Rohit,
    Apologies, perhaps I have misinterpreted your information. By 2 ADCs I assumed two DJ3200 devices connected to an FPGA.
    If it is just one ADC device, then the only way you’d have an overflow is a clock drift. In addition, your buffers in each lane should be deeper than 8 locations of 32 bits each.
    Ameet
