Hello Ao,
It seems like the firmware update did not happen successfully as seen in the image below.
Please ask customer to upgrade the firmware again following the same procedure as outlined in section 7 of the AFE4404EVM user guide. Please note that the switch SW2 must be pressed while the USB cable from the EVM is being plugged into the PC. Only release the switch after the application displays 'Found 1 device'.
Hello Ao,
Please ask the customer to try the firmware hex file located in the following directory: C:\Program Files (x86)\Texas Instruments\AFE4404 EVM GUI\Firmware Updater\AFE4404_EVM_FW_V1.5.txt
If this is throwing an error, please share the steps followed and the error messages.
Hello Ao,
Thank you very much!
I tried your suggestion again. When I repaired the firmware (GUI1.2.2) on win7 virtual machine, it didn‘t work. When I repaired the firmware (GUI1.2) on win7 system, it worked.
