Part Number: DAC80504
The DAC80504 is a rail-to-rail DAC, and its data sheet has its INL test data, and the results show that its INL of 0-65535 is less than 1. After testing, we found that when code<813, the output of 7.3mV has been maintained. Since in extreme cases we require the output to go to GND, we want to find a solution. The manual does specify the output headroom, but I think if TI can get such perfect INL test results, there must be a way to output to GND as well.The third picture is our circuit, I think there should be no use problem.Looking forward to your reply.
