can anyone provide reference code to enable Voltage mode or the sequence of registers need to set in order to initiate the voltage mode and set output voltage.
your help will be greatly appreciated
Thank you for your support.
Hello Kashyap
The main reason why you might not be able to see output voltage is because device is High-Z mode by default. Hence you will need to write DEVICE-MODE-CONFIG register to power it up ( page 66 of the data sheet ), once you do that you should have no problem writing to DAC_DATA register and get output going.
Hopefully that fixed the issue.
Thank you,
Illia Volkov
Hello illia
Thanks for the response.
correct me if I am wrong but, there is not mentioned about power up bit in the DEVICE-MODE-CONFIG register.
Hello illia
It Worked:). I had set the DIS-MODE-IN as 01.
Thanks for your support.
