Is it possible to switch off analog power supply while maintaing digital power supply? In the ADS7263 manual, there is said that DVDD to AVDD must be >= 1.2 x AVDD, otherwise:
"Exceeding the specified limit causes an increase of the DVDD leakage current and leads to malfunction of the device." This note does not say that:
"Stresses above these ratings may cause permanent damage to the device" as with some other absolute maximum ratings values. What DVDD leakage current increase can we expect? Will this increased leakage occur as well, if ADS7263 is put into Power Down mode before the analog power supply is switched off? The reason for such a solution is to use a single analog supply for the entire analog front-end of our device and to achieve maximum energy saving. I would be grateful for any information. Michal
