DAC37J82: Unused IOUTx connections
Part Number: DAC37J82
What problems can occur if the user does not connect the unused IOUTx of the DAC37J82 to GND?
Thank you.
JH
  • Hi JH,
    Leaving the outputs floating may lead to undesirable spurious on other output channels, that is only if the unused output swings enough to creep above the 93dBc channel to channel isolation spec of this DAC. Tying the unused output to GND will prevent this from happening and is what we suggest when an IOUTx is not used.
    Regards, Chase
  • JH,
    This should not be an issue. Just power them down using address 0x1A.
    Jim
