Hi Team,
The customer use the ADS127L11(an ADC chip), to interface the analogue output of the Hall magnetic field sensor.
They have tried to separate the sensor from the ADC by 1.5 meters and there is nothing wrong. The ADC was placed together with the magnetic field sensor at this time, but during the test it was found that the ADC could be damaged as the magnetic field increases. When the magnet is close to the ADC, the timing of the ADC has an impact and as getting closer, it would be damaged.
When the ADC is replaced and placed in a 10,000 Gaussian magnetic field, the ADC will smoke. But none of the other components are affected.
Could you help check this case? Thanks.
Cherry
