Part Number: ADS8528
Other Parts Discussed in Thread: ADS8568
Hi.
We are planning to use parallel read.
If the RD signal is output earlier than the CS signal, Does ADS8528 out data?
Best regards.
Hi there 5093781!
In most situations, the /RD signal associated with the parallel data bus is what strobes the actual conversion results into the host processor. If /CS is high, the ADS8568 outputs will be in tri-state so any strobing of /RD will not provide the proper conversion results to the controller. You have to set /CS low first before strobing the /RD pin.
