ADS1292: Inquiry Regarding Noise Suppression and Grounding in ECG Device Design Using ADS1292
Part Number: ADS1292
I am currently designing an ECG device utilizing the ADS1292, and I have the following two questions:
  1. For improved noise suppression, I plan to connect the AGND to GND using a 1-ohm ferrite bead, instead of a direct connection. Would this approach effectively improve the noise suppression in the system?
  2. I am using a shielded ECG cable and intend to connect the shield to ground. Should I connect it to AGND or DGND? Are there any reference design guides or application notes you could recommend regarding grounding practices in ECG designs?
Thank you for your support.
Aupu
