Other Parts Discussed in Thread: AMC1035
Hello TI-support team,
I have a question regarding the delta-sigma modulator AMC1035-Q1. In the datasheet, section "7.3.4 Clock Input", it is described that the component experiences an increase of input bias current beyond the specified range, when no clock is provided in the specified frequency range.
I have a use/fault case in my application, whereby the clock signal will not be provided under some special circumstances and therefore a higher current will be given in the measurement path through this behavior. Since there is some additional functionality provided via the voltage divider measurement path, this behaviour influences my circuit.
Therefore, my question regarding the increase of the input bias current. Is it possible to specify the input bias current (max), when there is no clock signal given (or the minimum input impedance of the circuit during this fault scenario)?
BR
Andreas
