Hi Team,
I'm running into a strange issue with the ADS7828 ADC. I'm getting noisy readings, but only when sampling certain channels.
Here’s what I’ve observed:
Channels CH0 and CH1 are connected to potentiometers (voltage dividers) — readings are stable and clean.
Channels CH2 and CH3 are both driven from op-amps (ISL28191FHZ-T7) doing voltage level shifting.
When reading CH2, the data is clean and if I scope CH3 while reading CH2, there’s no sign of noise.
But when I read CH3, I get a small AC waveform on the input pin of CH3 — looks like a disturbance or charge injection occurring during the read.
It seems like the act of sampling CH3 is somehow injecting or drawing charge, causing this noise. I'm wondering:
Could the op-amp output impedance be too high to drive the ADC’s internal sampling cap effectively during acquisition?
According to the ISL28191 datasheet, output drive seems pretty good, but maybe not for fast charge transients?
Has anyone run into this before with the ADS7828? Would buffering with a lower output impedance op-amp or adding a series resistor + small cap help stabilize the signal?
Cheers for any ideas!
