Other Parts Discussed in Thread: DAC8760, DAC8771
Hi team,
Does TI have DAC solutoin combin Voltage and currnent output?
Due to DAC7760 having a separate output. thanks
Jimmy,
We don't have a device that specifically combines current and voltage outputs. However, you can combine the voltage and current outputs together externally with some external circuitry. Look at the following application note on this subject:
https://www.ti.com/lit/an/sbaa199/sbaa199.pdf
This app note is for the DAC8760, which is the 16-bit version of the 14-bit DAC7760.
In addition to these devices, there is the similar DAC8771. The data sheet does describe combining the current and voltage output and the evaluation module has it connected this way.
Joseph Wu
