Dear TI Team,
I am raising this query regarding the the SPI communication of DAC80501 part.
In our application, we have connected cs(Chip select) pin to DAC and shift register parally. I want to Send 40 bit data frame with 40 clock cycle contneoulsy without any gap. So that 24 bit(MSB) will be send to DAC and 16bit(LSB) will be send to shif register.
we thought that DAC will accept first 24 bit (MSB), ( 8 bit commond + 16 bit data) and convert to digital to analog, The other 16 bit (LSB) will be not be accepted by DAC.
but when we are sending the 40 bit frame, the digital to analog conversion is not happening. if we try with 24 bit, the conversion is working fine.
In data sheet also, there is no information on what will happen if more than 24 bit frame sent.
could you please clarify, is it mandorty to send 24 bit frame to DAC always ? or will it work for more than 24 of bits also. (Accept 1st 24 bit(MSB) and igonore remaining bits)
Attached tha waveform for your reference. (wave form from Evaluation board DAC80502-01 EVM)
Your quick response will be appcriatated. Thank you.
