DAC6573 Power-on Reset trigger
Other Parts Discussed in Thread: DAC6573
The datasheet states "The DAC6573 incorporates a power-on-reset circuit...".
At what level of Vdd is this power-on reset circuit triggered?
  • Richard,
    I'll have to look into this for you and get back to you.
  • Richard,
    I've looked into a lot of design resources to try to get you an answer to this verified "by design" but the database is old enough that we cannot generate simulation results concerning this POR. Instead I'm going to need to test this on a test board. I'm currently out of office traveling but should return this Friday and will be able to get something setup.
    Sorry for the delays but I generally prefer to answer these kinds of questions based on design simulation results whenever possible and it took some time to exhaust that approach.
  • Richard,
    The reset is triggered at ~2.2V. This was tested over one unit at room temperature. I would expect to see the threshold vary a little bit from unit to unit so to give margin I would expect the POR to trigger from 2.1-2.3V.
