I want to know the range of pulse repetition frequency that can be supported by LM96570. I mean, how much frequency signal supported at Tx_En pin.
please help me. Thank you.
PFR<=1/(DEL+n*F0) , where
PRF - pulse repetition frequency
DEL - programmed delay
n - programmed number of pulses
F0 - TX frequency
Mariusz
Thanks for your reply.
I request you to mention PRF range supported by LM96570 IC. like max center frequency supported by lm96570 is upto 80 Mhz.
Sorry sir, I did not understand your formula....
can you see once my understanding about PRF. plz let me know if wrong.
prf(hz)=1 / (Tx_en(ON)+Tx_en(OFF))
Tx_en(ON)=n*(1/F0)
Tx_en(OFF)= 2*d/c
d - depth of scan
c - avg sound velocity (typically 1540 m/s)
In fact there is misstype error in the formula I gave you. It should be like this:
PRF<=1/(DEL+n/F0)
The above formula gives you the maximum possible PRF. However, in medical applications you should follow the physics and calculate PRF exactly as you did.
Mariusz
