DAC5681 / INL,DNL, offset and gain drift
Guru 20090 points
Other Parts Discussed in Thread: DAC5681
INL, DNL , offset drift and gain drift of the DAC5681 is specified at the condition of over operating free-air temperature range.
Will these parameters be improved at the narrow temperature range(for example +30°C~+40°C)?
If yes, could I have the improved data at the above condition?
Ryuji
    Would you please let me know the historam or the characteristics of at fixed temperature (Ta=+30C~+50C) of  INL,DNL,offset drift and gain drift?
    Our customer is searching the DAC which has the following specifications.
    Since I can't find the device which satisfy the following specifications,  I suggested DAC5681 as close device to them.
    <Request>---------------------------------------
    Resolution:16bit
    Ta=+30C~+50C
    INL=<+/-4SLB(max)
    DNL=<+/-4SLB(max)
    Gain Drift =<10ppm(max)
    Offset Drift =<10ppm(max)
    Sampling Rate >10MSPS
    Then they request above data.
    Ryuji
  • Hi Ryuji,
    We do expect these parameters to have a tighter range over a smaller temperature range (e.g. 30C to 50C), however I have no data to back it up. I would expect that we're very close or better than the customer's requirements over this narrower temperature range.
    From the designer:
    INL/DNL will definitely be better in the 30 to 50C range because most of the drift in mismatch comes from the change in Gm and Vt over temperature.  If you hold the temperature more constant, then these mismatches won’t change as much.  Also, the bandgap reference, which affects the gain, has a temperature coefficient which also will be better over a tighter temp range.
    Matt Guibord
  • Hello Matt san,
    Thank you for your reply and sorry for my late reply.
    I consulted with my customer and as a result I got the following questions from them.
    (1) accuracy of external reference for Gain drift specification
    Could you please let me know the acuracy of external reference for Gain Drift Specification ?
    Gain drift is specified by external and internal reference.
    However there is no acuracy of external reference.
    (2) Gain drift with 1ppm/°C external reference
    Could you please let me know the gain drift specification with 1ppm/°C external reference?
    My customer use 1ppm/°C external reference for DAC5681.
    (3)Glitch impulse
    Could you please let me know the glitch impulse of DAC5681?
    LTC166x has the glitch impulse data as 5pV-s.
    Ryuji Asaka
  • Hi Matt san,
    Any update on this ?
    Our customer need these answer for using this device.
    Ryuji
  • Hi Ryuji-san,
    Initial measurements show that the gain drift is worse than listed in the datasheet. Still working to confirm.
    Matt Guibord
  • Hello Matt san,
    Thank you very much for your checking.
    I'll be waiting for your confirming.
    Ryuji
  • Hello Matt san,
    If you have some reply about the following questions, please let me know.
    (3)Glitch impulse
    Ryuji
