Hi
①I require IBIS-AMI model of DAC38J84
②Replacement information and IBIS-AMI model of the DAC mentioned above
Best regards
Hi
Best regards
Please download the IBIS-AMI model from the link below.
Files:
Matt Guibord
Hi Matt,
We have been trying to use the IBIS-AMI model for DAC38j84 as well.
Getting some warnings and finally an error:
Parameter name 'RX_DFE_GAIN_CFG_bit12_to_8' in 'AMIvarName[13]' is inconsistent with the AMI file.
Error detected by hpeesoftsim during netlist flattening.
'Rx_AMI1': Index of AMIvarName parameter is out of range.
Could you, please, assist with the issue?
Thank you in advance,
Vlad.
Hi Vlad,
The DAC38J84 serdes block does not have a DFE so RX_DFE_GAIN_CFG is not a parameter in this model. Are you sure you're using the DAC38J84 IBIS-AMI model?
Matt Guibord
Hi Matt,
I confirm - we are working with DAC38J84 IBIS-AMI model. Here are files of the model : rincewind_40nm_rx.ami, rincewind_40nm_rx.ibs.
Both files are included into DAC38J84_RX_Package_Model_7_16_2013.zip package we have got from TI.
Below is the error output from the simulation tools.
Please advise.
Vlad.
Simulation Messages
Warning detected by hpeesofsim in Rx_AMI1 during netlist flattening.
IBIS model `rincewind_rx1' in IBIS file `E:\Project\2015\2\AVQ\box1\rx_ibis_ami\rincewind_40nm_rx.ibs':
Parameter name `RXLPMEN' in `AMIvarName[6]' is inconsistent with the AMI file.
Parameter name `RX_PVT' in `AMIvarName[7]' is inconsistent with the AMI file.
Parameter name `Record_Result' in `AMIvarName[8]' is inconsistent with the AMI file.
Parameter name `LPM_KH_InitDAC' in `AMIvarName[9]' is inconsistent with the AMI file.
Parameter name `LPM_KH_OverWrEn' in `AMIvarName[10]' is inconsistent with the AMI file.
Parameter name `LPM_KL_InitDAC' in `AMIvarName[11]' is inconsistent with the AMI file.
Parameter name `LPM_KL_OverWrEn' in `AMIvarName[12]' is inconsistent with the AMI file.
Parameter name `RX_DFE_GAIN_CFG_bit12_to_8' in `AMIvarName[13]' is inconsistent with the AMI file.
Error detected by hpeesofsim during netlist flattening.
`Rx_AMI1': Index of AMIvarName parameter is out of range.
Status / Summary
hpeesofsim (*) 391.shp Jun 7 2013 (built: 06/07/13 12:26:20)
Copyright Agilent Technologies, 1989-2013.
Simulation terminated due to error.
All,
I am working on the solution to this issue and trying to figure out a better way to support the distribution of the model. Thank you for your patience.
Matt Guibord
