I shorting the A7 channel to ground to do the offset correction for A0 to A6 channels. There seems to be a "residue error" of 20mV after subtracting the A0 to A6 reading with A7 offset.
It looks like A7 channel is seeing a different offset level, which is lower than other channels. There is a low pass filter to 4.096V Ref Volt input, tried shorting the series resistor still having the same observation. This has ruled out the possibility of load regulation issue to the Ref Volt.
By introducing an offset of ~14mV to A7 channel, I am able to null the offset of the A0 to A7 channel correctly.
Can someone shed some light on this observation?
