Do we have a DAC ( SPEC is similar as DAC6311) with a less than 1mm height ?
Other Parts Discussed in Thread: DAC6311, DAC7551, DAC161S055, DAC8551, DAC101S101, DAC121S101, DAC7512, DAC8531, DAC8501, DAC8560, DAC8881
  • Soccer,
    The only thing that I can find that comes in a low height package is the DAC7551, which comes in a USON-12 package. I think it has a height of 0.6mm.
    Read through the datasheet specifications to see if it will work for your customer.
    Joseph Wu
    I was also looking through the portfolio for low height devices. There are a couple of options that are NEARLY 1mm - I'm not sure how tight the requirement is. I applied a bit looser of a filter looking at a wide range of resolution / performance choices, only single channel devices.
    Matches:
    • DAC7551 (12-bit, DRN package, 0.6mm height)
    • DAC161S055 (16-bit, RGH package, 0.8mm height)
    • DAC8551 (16-bit, DRN package, 0.6mm height)
    Near Matches:
    • DACx311 family (8-16 bits, DCK package, 1.1mm height)
    • DAC101S101 (10-bit, DDC package, 1.1mm height)
    • DAC121S101 (12-bit, DDC package, 1.1mm height)
    • DAC7512 (12-bit, DGK package, 1.1mm height)
    • DAC8531 (16-bit, DGK package, 1.1mm height)
    • DAC8501 (16-bit, DGK package, 1.1mm height)
    • DAC8560 (16-bit, DGK package, 1.1mm height)
    • DAC8881 (16-bit, RGE package, 1mm height)
    I would agree that DAC7551 is probably the nearest match.
  • Duke, thanks for your help, it's pretty comprehensive for me.
