Other Parts Discussed in Thread: ADC1175, SN74LVC8T245, ADC1173
Dear Technical Support Team,
I have a question about ADC1175-50CIMTX/NOPB.
I'd like to use 3.3V digital interface with FPGA.
Datasheet page.17 shows below.
1.)
Can I use 3.3V digital Interface with DVDD 11pin supplied 3.3V?
For example,
DVDD 11pin: 3.3V
DVDD 13pin: 5V
2.)
If it is possible to use 3.3V interface, do you provide VOH/VOL/VIH/VIL specification with 3.3V?
Datasheet shows only 5V supply.
3.)
Pin 11 should never exceed the pin 13 potential by more than 0.5V.
Is it correct for power sequence below?
Power on: 5V(13pin) ⇒ 3.3V(11pin)
Power off: 3.3V(11pin) ⇒ 5V(13pin)
4.)
Datasheet page.2 "BLOCK DIAGRAM" shows DVDD 11pin supply for ADC output drivers.
But following description said "pin 13 is used only to provide power to the ADC output drivers"
Which is correct?
Pins 11 and 13 are both labeled DVDD. Pin 11 is the supply point for the digital core of the ADC, where pin 13 is
used only to provide power to the ADC output drivers. As such, pin 11 may be connected to a voltage source
that is less than the +5V used for AVDD and DVDD to ease interfacing to low voltage devices. Pin 11 should never
ttd
