Other Parts Discussed in Thread: AMC1304L25
In order to get the data coming from the ADC we need to implement a Sinc3 filter.
////////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: // // Create Date: 15:37:12 10/26/2016 // Design Name: // Module Name: sinc3_verilog // Project Name: // Target Devices: // Tool versions: // Description: // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // ////////////////////////////////////////////////////////////////////////////////// module dec256sinc24b ( input mclk1, /* used to clk filter */ input reset, /* used to reset filter */ input mdata1, /* input data to be filtered */ output reg [15:0] DATA, /* filtered output */ output reg data_en, input [15:0] dec_rate ); /* Data is read on positive clk edge */ reg [36:0] ip_data1; reg [36:0] acc1; reg [36:0] acc2; reg [36:0] acc3; reg [36:0] acc3_d2; reg [36:0] diff1; reg [36:0] diff2; reg [36:0] diff3; reg [36:0] diff1_d; reg [36:0] diff2_d; reg [15:0] word_count; reg word_clk; reg enable; /*Perform the Sinc action*/ always @ (mdata1) if(mdata1==0) ip_data1 <= 37'd0; /* change 0 to a -1 for twos complement */ else ip_data1 <= 37'd1; /*Accumulator (Integrator) Perform the accumulation (IIR) at the speed of the modulator. Z = one sample delay MCLKOUT = modulators conversion bit rate */ always @ (negedge mclk1, posedge reset) begin if (reset) begin /* initialize acc registers on reset */ acc1 <= 37'd0; acc2 <= 37'd0; acc3 <= 37'd0; end else begin /*perform accumulation process */ acc1 <= acc1 + ip_data1; acc2 <= acc2 + acc1; acc3 <= acc3 + acc2; end end /*decimation stage (MCLKOUT/WORD_CLK) */ always @ (posedge mclk1, posedge reset) begin if (reset) word_count <= 16'd0; else begin if ( word_count == dec_rate - 1) word_count <= 16'd0; else word_count <= word_count + 16'b1; end end always @ ( posedge mclk1, posedge reset ) begin if ( reset ) word_clk <= 1'b0; else begin if ( word_count == dec_rate/2 - 1 ) word_clk <= 1'b1; else if ( word_count == dec_rate - 1 ) word_clk <= 1'b0; end end /*Differentiator (including decimation stage) Perform the differentiation stage (FIR) at a lower speed. Z = one sample delay WORD_CLK = output word rate */ always @ (posedge word_clk, posedge reset) begin if(reset) begin acc3_d2 <= 37'd0; diff1_d <= 37'd0; diff2_d <= 37'd0; diff1 <= 37'd0; diff2 <= 37'd0; diff3 <= 37'd0; end else begin diff1 <= acc3 - acc3_d2; diff2 <= diff1 - diff1_d; diff3 <= diff2 - diff2_d; acc3_d2 <= acc3; diff1_d <= diff1; diff2_d <= diff2; end end /* Clock the Sinc output into an output register WORD_CLK = output word rate */ always @ ( posedge word_clk ) begin case ( dec_rate ) 16'd32:begin DATA <= (diff3[15:0] == 16'h8000) ? 16'hFFFF : {diff3[14:0], 1'b0}; end 16'd64:begin DATA <= (diff3[18:2] == 17'h10000) ? 16'hFFFF : diff3[17:2]; end 16'd128:begin DATA <= (diff3[21:5] == 17'h10000) ? 16'hFFFF : diff3[20:5]; end 16'd256:begin DATA <= (diff3[24:8] == 17'h10000) ? 16'hFFFF : diff3[23:8]; end 16'd512:begin DATA <= (diff3[27:11] == 17'h10000) ? 16'hFFFF : diff3[26:11]; end 16'd1024:begin DATA <= (diff3[30:14] == 17'h10000) ? 16'hFFFF : diff3[29:14]; end 16'd2048:begin DATA <= (diff3[33:17] == 17'h10000) ? 16'hFFFF : diff3[32:17]; end 16'd4096:begin DATA <= (diff3[36:20] == 17'h10000) ? 16'hFFFF : diff3[35:20]; end default:begin DATA <= (diff3[24:8] == 17'h10000) ? 16'hFFFF : diff3[23:8]; end endcase end /* Synchronize Data Output*/ always@ ( posedge mclk1, posedge reset ) begin if ( reset ) begin data_en <= 1'b0; enable <= 1'b1; end else begin if ( (word_count == dec_rate/2 - 1) && enable ) begin data_en <= 1'b1; enable <= 1'b0; end else if ( (word_count == dec_rate - 1) && ~enable ) begin data_en <= 1'b0; enable <= 1'b1; end else data_en <= 1'b0; end end endmodule
after the implementation of the filter we should see a signal with some noise. All we get is noise for any input signal. Is there an example code to implement in an FPGA?
