ADS1278EVM-PDK: Getting started with SPI Interface
Part Number: ADS1278EVM-PDK
Other Parts Discussed in Thread: ADS1278, ADCPRO
Hello I am trying to interface my ADS1278 EVM-PDK with an NI myRIO using SPI. I am an ME and this is my first time trying to use SPI. I have a few questions to help me start pulling data off of the ADC. I have hooked up 8 analog devices to the board and have verified the signals through ADCPro. I have wired MOSI, MISO, and I am unsure with the CS and clock lines. If I want to use an external clock from my microcontroller at 4MHz I believe the CLK should be wired to J4.17. Do I need to wire anything to the SPI Clock or SCLK at J4.3, or j4.5 respectively or should they be left untouched? How do I decide on the CLKDIV settings? Also I am confused as to which pin I should run my chip select line to. I am only hooking up one slave device so I believe it can be held low at all time as I will have no need to switch to another device. I have switched s^ to SPI Format, but I am only getting zeros for my output to the microcontroller (as well as Oscope). What else do I need to do in order to initiate the transfer of data to the microcontroller?
Thanks so much for any help.
Kory
  • Hi Kory,
    Lot of questions here, I'll try to answer them in order:
    Yes - the CLK from your microcontroller can be provided to J4.17 (probe TP8 just to ensure the correct clock signal is present at the device pin). This clock controls the sampling rate in the ADC modulator (fMOD) as well as the digital circuitry. The SCLK, however, is your interface clock and is needed to shift data out of the device. Your microcontroller will need to provide this as well at J4.3 or TP6.
    The CLKDIV setting determines the ratio between the master clock input (CLK) and the modulator sampling rate (fMOD). The table below combines information from Tables 3, 6, and 8 in the ADS1278 datasheet to illustrate the relationship between these frequencies and the final output data rate:
    Mode[1:0]
    Mode Selection
    CLKDIV
    Max fCLK
    (MHz)
    fMOD
    Max fMOD
    (MHz)
    OSR
    fCLK/fDATA
    Max fDATA
    (SPS)
    0
    High-Speed
    1
    37
    fCLK/4
    9.25
    64
    256
    144,531
    1
    High-Resolution
    1
    27
    fCLK/4
    6.75
    128
    512
    52,734
    10
    Low-Power
    1
    0
    27
    13.5
    fCLK/8
    fCLK/4
    3.375
    64
    64
    512
    256
    52,734
    11
    Low-Speed
    1
    0
    27
    5.4
    fCLK/40
    fCLK/8
    0.675
    64
    64
    2,560
    512
    10,547
    There is no chip-select pin on the ADS1278, so no need to worry about that.
    Once power and master CLK are present, you should see the data ready pin (/DRDY) toggle at the set data rate. This will indicate that the ADC is actively converting and ready to output new data.
    Hope this helps, let me know if you have further questions.
