Part Number: DAC161P997
We need help regarding DAC161P997, an oscillation waveform (ringing) is observed in the loop output current.
An oscilloscope snapshot is attached. The DAC’s output is connected to GND via a 100Ohm resistor when the DAC is commanded to output 20mA, and the oscillator probe is attached to the resistor, the voltage across the resistor is expected to be 2.0V DC (20mA * 100Ohm), but big saw tooth oscillation can be seen.
We initially suspected the PCB layout, yet we made several attempts to improve it but failed.
We are confident that the timing of digital signal (DIN pin) is correct, the output current’s DC content is correct.
All related schematics and PCB layout (4-layer) is attached in the PDF file, please help us. Our design progress are blocked at this stage.
