Hi Sirs,
We would like to know AMC1304M05 could support detect AC Voltage spike?
If yes, what is sensing voltage range?
Thanks!!
Hi Sirs,
Thanks!!
Hi Tom,
Update our spec as below.
Detect AC Voltage spike to 300V
Lamp voltage is currently used in 110V ~ 300V
Does TI have suitable solution can share?
Thanks!!
Hi Shu-Cheng,
If you were to use a resistive divider, you could attenuate the 300V to the 50mV input range of the AMC1304M05. What are you intending to use to filter the bit-stream output of the AMC1304?
