Other Parts Discussed in Thread: LDC1312
My customer want to use LDC0851 to detect the rotation of a round stainless steel plate, there is a lot of small hole on it (diameter of the hole is 3mm). See attached for its detailed mechanical diagram
As my understanding, to make the device to respond to the small hole, the sensor's diameter should not larger than the hole. However, I found it is basically impossible to design such small coil with Webench to work with LDC0851. Do you have any idea to design sensor for this application?
Thank you!
