MSC1213Y5: Max thermal profile peak temp
Part Number: MSC1213Y5
What is the maximum oven peak temp for this components.  We are replacing a lot of these components because they are failing at test.  Please advise.
  • Hi Timothy,
    Welcome to the E2E forum! The reflow information is on the device product page under the Quality and packaging tab.  In the table for Quality and environmental data there is a column for MSL Rating / Peak Reflow.
    http://www.ti.com/product/MSC1213Y2/pinout-quality
    For the MSC1213 the rating is classified as Level-4-260C-72 HR.  The ratings are fully explained in the following document:
    http://www.ti.com/lit/an/spraby1a/spraby1a.pdf
    You haven't stated what kind of failures you are seeing, but what is seen most often is open packaging where the humidity exceeds the nominal for the reflow process.  If this is the case, you may need a pre-bake of the devices to remove any moisture from the devices prior to reflow.
    Bob B
