AFE5832EVM: I tested afe5832evm, but the quality of the results was not good
Part Number: AFE5832EVM
I am testing afe5832evm with TSW1400 and HSDC PRO 4.7.
However, I had some question during test.
-1. I connected the hardware as shown in the attached figure and input 5v power.
-2. I wrote afe5832evm firmware after running hdsc pro.
-3. The afe5832evm gui is run automatically,
4.I provide a 5MHz  20mV sine  input
5 I use the 125MHz clock on board according to the user manual
6. I press DUT RESET and initialize device.
7. I changed fsamp to 40mhz and clicked the ramp test pattern.
8. I went back to hsdc pro and clicked the capture button.
Its results are as follows
What's wrong with my testing process? It was simply a test for confirming the test pattern.
How do i set up to get the right result?
  • PS I use the on-board clock and 125MHz configuration. The user guide is 160MHz 13dbm clock. Is the problem here?
    Thanks for using AFE5832EVM.
    We will reply to your question very soon.
    Thank you!
    Chen
    From the captured graph, looks like your input signal freq = 40MHz (sinewave, right?)
    and clock freq = 125MHz, because on the left-hand lower corner screen,
    it shows ADC Output Data Rate (set as = 20MHz) so please change it as = 125MHz
    and also ADC Input Target Frequency (set as = 5.000 MHz) so please change it as = 40MHz.
    Also we can see the noise floor is too high,
    that could be due to the input signal cable and input signal connector
    maybe too loose. Could you please re-connect all the cables
    to make sure they all are connected firmly?
    Hope these can help.
    Thank you!
    Chen
