Yinon,
Yes, using a 1:N transformer will allow you to increase the signal swing without adding noise as this is a passive device. You will need to be careful when choosing a transformer as the linearity will vary from model to model. I have attached a couple of documents that may be of use as well.
Jim
Yinon,
I am confused about your reply. Are you planning on running the input at 10dbm of full scale? If so, what is this in p-p voltage? Do you then plan on gaining up this input to a higher scale? You mention SNR 70 dbm - ADC noise is -60dbm? Is this a measurement from your system? Are you referencing any tables or figures from the data sheet? What do you mean by reducing overall NF channel noise over gain? Are you asking for suggestions on how to reduce noise when adding gain, if possible?
Jim
