The absolute resistance tolerance is +/-20%. In the data sheet above table 2, there is a line that says "The absolute values of resistance can vary significantly but the Ratio (RWL/RHW) is extremely accurate."
How accurate is the ratio (RWL/RHW)?
I interpret that as the voltage divider mode (?%) is significantly more accurate than rheostat mode (20%). I am thinking of connecting the part in such a way as to use the ratio (RWL/RHW) to set the gain of an op amp instead of relying on the absolute resistance values for a more accurate op amp gain.
Thank you
