ADS8365 + MSP430F2xxx
Other Parts Discussed in Thread: ADS8364, MSP430F449, ADS8365
I have my own sistem, ready to start debug,
I have ADCCLK=2MHz, and I have EOC toggling after an SOC ( siumultaneous at the 3 pair channels).
CS and RD are working fine too. I m using ADC configuration by HW, No ADD, and usin 16 Bits as Output
But happens that I have no significant outdata from ADC.
can you give an tip?
thx
reach me at: asilvaeneida@gmail.com
  • Hi Antonio,
    Can you provide a little more detail on what you mean by 'no significant data'?  Perhaps there is something in your software.  I put together a little bit of code for the ADS8364 and the MSP430F449 a couple years ago - you can find it here:
    http://focus.ti.com/analog/docs/litabsmultiplefilelist.tsp?literatureNumber=slaa150&docCategoryId=1&familyId=390
    The only real difference between the ADS8364 and ADS8365 (pin functionality wise) is the additional of a NAP pin (pin 20 on the ADS8365, N/C on the ADS8364).  The code may help, not really sure at the moment.  If you could perhaps share a snippet of your schematic around the ADC and maybe a scope trace of your control signals, we might be able to point you to a potential source of the problems you are facing.
    Hi Hendrick,
    Here is snippet of myschematic around the ADC.
    I added also the screenshot of the Digital signaling.
    The output data is jumping, ans do not reflect the signal input ...
  • Hi Cmos,
    The LogicPort is a great tool isn't it?  I don't see anything off hand in the schematic that would cause your erroneous readings from the ADS8365.  Have you looked over the code I pointed you too?  Is there anything in the way you are doing port reads from the MSP430 that might be an issue?  Can you try simply applying a DC voltage - say 2.5V to the inputs and let me know the resultant codes you get?
