ADS1220EVM: how to know if the data is correct
Genius 9880 points
Part Number: ADS1220EVM
Other Parts Discussed in Thread: ADS1220, ADCPRO
Hi Team,
Good day, we received inquiry from customer and want to confirm if the output measure in ADC pro is correct using the EVM. Below is the query.
"I'm using ADS1220 EV kit and ADC Pro Software for data colletion, here I'm shairng my data's PDF. I'm using load cells for my weight scale measurement application. I have tried to capture data , after putting 2KG weights on my load cells. Load cell's rated output is 1mV/V and it will give output form 0 to 3.3mV for 0 to 10KG weights.!(For Full bridge configuration). PDF data which I have shared it's reading by using half bridge configuration, whose output is 0 to 1.6mV for 0 to 12KG weights. How I can know that data is correct or not as per my weights? Please advice about how to read and understand data which is coming out form ADC pro software.(by export data)."
7587.ADS1220_ADCPro_Reading.pdf
Thank you and looking forward for your kind response.
Maynard
