  • Resolved
reading +-3.3 v with ads7813
Intellectual 595 points
I need help immediately with ads7813.
i use arduino with  ads7813.
no problem about connections, i just need a code that reads data from adc and convert it to correct values.
so i need to fix these codes:
//below x[0] is msb bit
if(x[0]=1){
for(int j=1, c=16384;j<16;j++,c=c/2)
x[j]=~x[j];
val+=c*x[j]; }
val=-val;
else{
for(int j=1, c=16384;j<16;j++,c=c/2){
val+=x[j]*c;
ismail
  • ok, figured it like this:
    ___
    if(x[0]==1){
    x[j]=~x[j];
     val+=x[j]*c;
    val=3300*val*(double)1/32767;
    val+=(float)20;
    val=-val;
    else{
    val+=x[j]*c;
    ___
    but (-)  measurements are very noisy...
    ismail
  • In reply to ism aaa:
    Hi Ismail,
    Welcome to our forum!  Have you got everything worked out with the ADS7813?  Can you define 'noisy' for us and perhaps share your raw conversion results for the ADS7813?
    Tom
  • In reply to Tom Hendrick:
    Hi Tom,
    I still have a mess with ADS7813, but i work on other thing now. I will write here soon.
    ismail
