Hi
My customer is using TLC5628.
He has a question about Full scale error at 1 gain range.
How much is the full scale error at 1 gain range?
In Data sheet, there is value at 2 gain range.
Shimizu
Hi
Shimizu
Hello Shimizu-san,
This is a very old device, so it may be very hard to find any information from the team that used to support this device.
I suspect that the 1x gain range will not have a Full Scale error.
Both Zero Scale and Full Scale errors are limitations of the output amplifier that occur because the output of the DAC is near the rails of the amplifier.
Hi Eugenio-san
Thank you for your advice.
I saw functional block diagram of D/S.
This IC has a buffer-amp with output pin.
In fact, user is using the following case.
- Code is FF <- full range
- REF voltage is 0[V]
In this case, I think output voltage is 0[V], but it has offset voltage.
Now I would like to know output voltage error at this case.
How much is output voltage error in this case? Could you give me advice, please?
Shimizu
Hello Shimizu-san,
masahiko shimizu said:This IC has a buffer-amp with output pin.
Correct. The "end-point" errors (Full/Zero scale errors) will be due to the limitations of the amplifier and not due to the DAC core. Amplifiers start to behave non-linearly near the rails.
If the output voltage is close to GND, the error is called Zero-scale error.
If the output voltage is close to VDD, the error is called Full-scale error.
masahiko shimizu said:In fact, user is using the following case.
Regardless of the DAC code, if REF = 0V, the only error observed should be the Zero-scale error because the output amplifier is close to GND, not VDD. The datasheet specifies Zero-scale error between 0 - 30mV.
What is the error value that you are measuring?
