Part Number: ADS7830
Hi team,
My customer is using the Ads7830 now, the schematic is below. The I2C bus have three devices. When power up, we find the ADS7830 i2c SDA is pulled down to low. We have checked the device, isn't damaged. The problem will be reproduced when power on.(before power off, the master will reach hte ADS7830, when power on we will not communicate with the device right now. When the problem happens, SDA will be low, SCL will be high. We pull the SCL to low, the SDA will be recove to high.
Could you please help check the schematic and help check why the SDA is pulled to low?
thanks.
