I find 3 references to "configtbd" in the manual.
Are the correct register names available anywhere?
Hopeful thanks --todd
The first configtbd is the alarm registers located from config100 (0x65) to config109 (0x6E)
The second configtbd is located in config3 with respect to the DAC output gain
the third configtbd is located in config27 for external reference enable for the DAC current mirror. Most of our customers uses internally generated reference (bandgap) to match process and temperature drift direction with respect to the whole chip.
Thank you, Kang, for this prompt and authoritative reply.
It appears that the first instance of "configtbd" might have been meant to be generalised, as in "configX" for one of these values for X ...
The 2nd and the 3rd instances appear to be simple typographical errors.
As a follow up question, has anyone asked about "configtbd" before? I must have searched wrong.
