  • Resolved
AFE7444: LMFSHd
Prodigy 30 points
Part Number: AFE7444
I'm new to high speed data converters. The AFE7444 has LMFS specified in the data sheet. However, there are 5 numbers instead of 4. As such, I guess that the last one is for the "Hd" part. What does Hd mean?
Kind regards,
Imran
  • Hey Imran,
    High density is 1 ( HD =1) if a single sample is broken up into pieces and transmitted over multiple lanes. The only mode that uses HD=1 is Mode 1 which is only available for the AFE7422.
    Yusuf
  • In reply to Yusuf%20Agoro:
    Dear Yusuf,
    thanks for the quick reply.
    So do I understand correctly that the table found in the datasheet here:
    http://www.ti.com/lit/ug/slau783/slau783.pdf
    on the first page, shows a column for TX LMFS and in the first data row shows 84111, that this corresponds to the configuration:
    L = 8, M=4, F=1, S=1 and Hd=1?
    And a second question: "transmitting a sample broken up into pieces over multiple lanes"
    Using this as a reference:
    https://e2e.ti.com/blogs_/b/analogwire/archive/2014/09/24/jesd204b-determining-your-link-configuration
    Since within the JESD204B interface there seems to be a strict hierarchy such that
    1 link contains L lanes
    1 lane contains M frames
    1 frame contains F octets
    1 octet contains S bits
    how does it make sense to break up a sample over multiple lanes? Naively, I would think that this sounds like some sort of compression technique or coherent transmission. Is there any white paper or such, where I could read up on this? Or if it's simple enough, could you please clarify? Is there any description on the HD mode?
    Kind regards,
    Imran
  • HI Imran,
    I've forwarded your question to a device expert. You should get a response soon.
    Jalen
    I saw the message "TI thinks it's resolved". I have posted a followup question however, to clarify the issue. Could you please answer to the followup?
    Kind regards,
    Imran
  • In reply to Imran Khan46:
    Imran,
    Reference the following JESD format table for TX LMFS = 84111. Notice how the sample for channel I is 16 bits total ( i0[15:0] ). Yet in a single frame half of the 16 bit sample is in lane 1 (  i0[15:8] ) while the other half is packaged in lane 2 ( i0[7:0] ). Because of this Hd aka high density is set to 1.
    Hopefully this answers your question.
    Yusuf
