  • Resolved
DAC7811: About DAC7811 circuit
Expert 2630 points
Part Number: DAC7811
Hi team,
 I am considering replacing another maker's multiplying DAC with DAC7811
 at my customer.
 Please see the attached file.
DAC_circuit.xlsx
 I think that DAC7811 is usable and the Cf can be used not only for phase
 compensation but also for LPF by increasing Cf value.
 Is my understanding correct?
 If you have any concerns about that please let me know.
Sincerely,
Tsuyoshi Tokumoto
  • Hi Tsuyoshi-san,
    Thank you for your query. I don't see any problem in using Cf for creating a first-order LPF. However, if you need a proper BW limit, I would recommend using another LPF stage after the transimpedance amplifier.
    There is a previous E2E post that talks about the multiplying bandwidth and a simplified model of the MDAC. You can use that to replicate the filter behavior by changing Cf.
    e2e.ti.com/.../671207
    Hope that answers your question.
    Uttam Sahu
    Applications Engineer, Precision DACs
  • In reply to Uttam Sahu:
    Hi Uttam-san,
    Thank you very much for your prompt reply.
    I will use your advice as a reference from now on.
    Thank you and best regards,
    Tsuyoshi Tokumoto
    Hi Uttam-san,
     Please let me ask you an additional question.
     My customer is considering using the DAC7811 now.
     In his current design situation, the DAC 7811 needs to be controlled by a serial
     interface with 24-bit width.
     I believe that the DAC7811 will be controlled correctly by placing valid data
     in the lower 16bits.
      *Please see the attached file.
    Dac7811_input.xlsx
    Tsuyoshi Tokumoto
  • In reply to tsuyoshi tokumoto:
    Hi Tsuyoshi-san,
    I think this scheme should work but I need to test it on the EVM before I can confirm. I will get back by next week.
    Uttam
    Hi Uttam-san,
      I really appreciate your cooperation!
      I look forward to your answer.
    Tsuyoshi Tokumoto
    Hi Uttam-san,
     I would appreciate it if you could share the test result on the EVM with me.
     I apologize for rushing you, but I would like to reply to my customer
     about this question by the end of the week.
    Tsuyoshi Tokumoto
    Tsuyoshi-san,
    I will upload my findings tomorrow.
    Uttam
    Hi Uttam-san,
      I appreciate your understanding and cooperation.
      I look forward to your findings.
    Tsuyoshi Tokumoto
    Hi Tsuyoshi-san,
    I tested it on the EVM. It works. In a 24-bit SPI frame, the DAC8811 takes the last 16 bits.
    Uttam
    Hi Uttam-san,
      Thank you for the good news!
       I shared your answer with my customer.
       I appreciate your cooperation
    Tsuyoshi Tokumoto
