Other Parts Discussed in Thread: DAC34H84, AFE5809, DAC3484
After reading dozens of disparate (and desperate) requests for support on the TSW1400/DAC34H84 board combination I am still unable to get even the most rudimentary output from the DAC34H84 board. Since I intend to use the DACs at low frequencies I have installed pin compatible low frequency Mini-Circuits transformers on all channels.
I'm assuming the use of the internal clock (DAC JP5 pins 2-3 - any other changes to jumpers required?) to perhaps generate a 1Mhz DAC output square, sine, ramp ... wave output - anything to get a basic output to confirm the board set is working (just in case it matters I have AFE5809 EVM attached to the TSW1400 which IS working fine).
Can you provide me with a step by step example (perhaps with associated files) to make a very rudimentary confirmation that the board set is working (even just one channel)?
It seems unclear where some of the DAC34H84 config file examples reside (as opposed to DAC3484 examples).
I'm never quite sure when the DAC3484 is referenced what pertains and what does NOT pertain to the DAC34H84.
As far as the explanation of the DAC3484/DAC34H84 GUI it seems I am unable to find a complete reference that explains the various settings in a single document.
