Other Parts Discussed in Thread: ADCPRO
I was looking for the recommended specs for the wall adapter of ADS8568EVM-PDK, however, I'm unable to find it. Can you please share it?
Thank you
Thank you
Hello Elisha,
For the AC wall adapter, recommend using the same one originally used with the MMB0 boards or an external bench supply. The power supply is plugged into connector J20 on the MMB1 motherboard.
• Must output 6V-7VDC.
• Must be sleeve-negative, tip-positive.
• Should have a current rating of at least 2A.
You can find more details in the ADCPro Hardware and Software Installation Manual.
http://www.ti.com/lit/ug/slau372a/slau372a.pdf
Also, the link to download the schematics for the MMB1 board can be found here.
https://e2e.ti.com/support/data-converters/f/73/t/466738
Keith N.
Precision ADC Applications
