Could you please explain this sentence " DAC38J84 operates at a common mode voltage (Vcm) of around 0.25 V or a bit higher." in document entitle "High Bandwidth, High Frequency Transmitter Solution".
In the DAC38J84 datasheet, the compliance output voltage is given as -0.5-0.6 V. Could you please elaborate more about it, is the compliance differential output voltages or the compliance output voltages on each output pin?
If it is the compliance output voltage on each pin, why VCM = 0.25 V?
Samaneh
