In the data sheet for the ADS1259 it says the SYNOUT pin is an output pin but when in power-down mode it is an input pin. I'm not using the SYNOUT output and I don't intended to use the power-down feature. For EMC considerations, would it be advisable to terminate the SYNOUT pin with a 1M resistor to ground? In addition, I'm not intending to use the RST/PWDN pin. Should this pin be pulled high with a 10K resistor? Thank you.
