Hello team,
please confirm that after programming the LMP92066 can be used without any uC in the final HW design.
As SDA and SCL will not be used how should they be connected, please?
Thanks and Best Regards,
Hans
Hi Hans,
After the EEPROM is initially programmed, there is no need to further communicate with the device. You could optionally read from the device for status information, but it is not required.
I recommend that the SDA and SCL pins be connected to the digital supply via pull-up resistors.
Paul
