Hi Team,
Is there any problem in using the voltage applied to the CH port before the power supply voltage is applied?
Since it is used to monitor the remaining battery level, if you cannot use the above method, you need to consider another method.
The device is powered from a battery through a DCDC converter.
Kenji
