Hi Team,
I have two questions.
・Should errors due to aging be taken into account?
My customer wants to calibrate in the production process and apply it to the product.
・Is sending the “SYNC” command the same as setting the “SYNC/PDWN” pin to “L”?
If only " SYNC "command is used, if it is the same, should the "SYNC / PDWN" pin
be pulled up with a resistor?
By the way, "Power down mode" is not used "
Kenji
