Part Number: ADS1278
Hello everyone,
I use the 8-channel data acquisition board designed by ADS1278. There are always some channel failures in the use of individual boards.
Fault phenomenon :
if all channels are tested normal the day before, the output value of 1-2 channels will change to constant-10v when the machine is turned on the next day, the channel with fault is often the first channel and the second channel, and sometimes have other channels.
My power supply is switch 220 to 12V with DCDC converter, and LDO is used for 5V, 3.3V and 1.8V.
I would like to know what causes this kind of failure
thank you!!!
